- Aftermarket ECU
- RS pistons: which size
- best upgrade for ITR...
- red line'n problem..help!
- Re-Build B18c Type R help?
- ls vtect start up problems
- how much should i shaved of a d16y8 vtec head
- Harbor Freight and engine rebuilding toolz. Is it a good idea???
- main bearing clearances help!!
- Info on arias pistons
- 95 B16a DelSol B Pipe
- My first honda of texas..
- Max net valve lift for b16 head?
- Car "lags" when warm, new swap CEL 14 HELP
- Drag Cartel Testing...
- What will be a good exhaust setup for a b20v, 13-14CR on e85.?
- SAFE MODE HELP! LSVTEC
- LSV Build
- Kiddracing header
- What cc injectors for 12.7-13.0:1 compression?
- Big Valves Question
- Timing Belt
- Why are all the skunk2 reps / people banned?
- fluidampr race pulley info
- crower "econo" billet rods vs steel billet rods
- After Break in, change the beerings?
- KPRO and Haltech Comparison - Totally Stock K20Z1
- B18C1- Lookin for a little Pep
- h2b help!!!!!!
- Few ? about h2b swap from ls
- Oil in intake mainfold and intake ports
- Type S cams... Worth it in a h22?
- Tegiwa Imports 4-2-1 Header Initial Impressions
- B20 FUEL PRESSURE PROBLEM
- 96-98 ek iacv question need help please !!!
- QUICKEST H22 ALL MOTOR BUILT WITH H-SERIES TRANNY?
- stock ls turbo
- K20 chain problem
- Itr itb cams
- nippon p73 pistons
- gsr gearset in h22
- K-series tuning on new AEM Gen2 EMS...amazing results!
- skunk2 pro 2's or tuner 2's on b18c1??
- fully built b20/vtec questions.
- b18c1 hp possibilities
- cam timing h22 blox B
- Victor X on H22???
- JUN3s OR Pro1s?
- A 13 Second D15???
- Pics and video of my N/A LS
- B16a setup problem.(Street setup)
- TWM ITB injector retaining clips
- em1 setup
- Torque Dip in Upper RPMs
- HELP intake manifold question
- ZC Engine - Bisi Header - Pump Gas Dyno Tune
- quick question
- Re Drilling Oil Pressure Sensor, How to remove shavings?
- Codes on my swap
- b16a1 with b18c5 head
- How cool is this stainless air filter?? Would it flow??
- Dyno tune with or without catback?
- oil burning problem..is it worth camming?
- Cracked pro series cam gears
- Which are the best NGK spark plugs for a B18A1 with a B16 VTEC head?
- b16 or b20vtec
- EG6 Master's STOCK F20B DYNO - The journey begins
- Most affective candidates for NA build.
- Whats this?????????????????
- NSCRA All Motor Finals (10/17/10)
- how to tell if i have b16 a2 cams?
- k20z3 destroked to 1.5L 200mph setup
- H2b no first start help
- 99'B20b what ecu should i run? obd1 conversion
- Evo h2b kit axles help
- rs machine pistons
- 99'B20B timing degree?
- High comp z6
- Please Take Back Your Village Idiot...
- 190-200whp B18c1 Capable?
- NEED HELP W/ MY B18C1 BUILD 14:1 COMPRESSION
- oil breather cap?
- vtec and IAB questions???
- LS-VTEC or JDM b18c???
- Good Website or brands for a D16z6 engine rebuild kit
- need help with 88 hatch
- b18c1 dyno'd - low #'s
- questions on itb vtec killer setup
- N/A Accord Type-R H22A7
- RATINGS:NEW URG Cam Gears B16 B18 DOHC VTEC Integra Type-R TODA
- back cutting skunk2 pro series valves
- H22: Mahle Rings on OEM Pistons?
- any body using buddy club spec 4 cam?
- Can you use obd1 ecu with a obd0 harness?
- What do i have?
- my new h22 intake manifold.
- meth injection on a na built gsr?
- 3.5L CFM
- some Qs about my H setup
- Oil Leaking from unusual perp
- sggestions?! please
- Exhaust Cam VS Intake Cam
- rotating assembly ft-lbs
- 3" cold air intake
- b18c build
- gsr cams vs sir2 cams????
- What Intake do you run with the Performer X Manifold?
- Eagle rods better than gsr?
- Can a gsr fuel rail be modified to take AN fittings
- >>Official ALL-MOTOR 1/4 Time Thread<<
- E85 Tuning/Fuel Delivery Questions.
- All Motor LS power increase??
- BBK intake manifold
- Water Methanol System for All motor Set-ups. ????
- help asap 1.7 gsr vs 1.8 gsr trans
- Spoon B-Pipe + Spoon Street
- skunk2 IM installation ?
- 92' accord LX w/ F22B1 stock, cant find performance parts
- Fall Nats-All-Motor SFWD Videos
- LS/VTEC build running rough
- PLEASE HELP CIVIC SI
- valve adjustment for b18c1 help!!!
- help wanted on building a vtec
- PLEASE HELP! TIMING BELT KEPT JUMPING!!
- GSR/No Oil... new oil pump
- cheapest place to buy RDX injectors / clips
- K20a2 vs a3
- DC Sports JDM 4-1 SS headers VS Megan Racing 4-1 steel race header
- what bolt on's can i put on my B18A engine for N/A in australia
- B16a2 Block with B16B crank?
- 4.9 Final drive
- polishing the runners in your sk2 pro IM
- E85 tuning issues, lean in 4th gear
- valve lash spec for h22 skunk2 pro2
- LOL.. might be going the itb route again, question about vacuum boxes
- Is there a differnce between spark plug wires for B18C1 vs B18B1 engines?
- i need help pls valve spring question
- Ram Air
- highest c/r in b18c1 with BC stroker kit
- Exhaust Fabrication??
- Cam Gear Adjustment
- what else can i do to make my b16a faster?
- HELP ME :-( :: B18C4 engine with ycp type-r pistons not turning over - piston contact
- Sanjiyan's All-Motor GSR Build
- need help with my gsr
- ek b18c1 build
- All motor gsr, advice
- ENGINE BUILD
- Head question?
- decent motor mounts for a 200whp daily driven civic?
- VTEC Adjustment
- will k24a1 valves work in a k20a2 head?
- Aftermarket airbox options
- 1993 civic hatch
- Life expectancy of your built motor?
- h22 retainer wear, pics inside.
- Spark plug gapping b20vtec
- Spark Plug Detonation & Pre-Ignition I think I have acheived Both
- Need Help
- clearance thoughts
- what is the diffrence Blox HSL tuner and Blox HSL competition CAMS
- b18C screaming monster vid
- Loud exhaust!! making it quiter??
- Ls vs V-tech
- valve springs and retainers
- B16b CTR piston with ITR milled Head?
- My first frankenstein b build.
- F23 Frankenstein Header
- H22 Vtec not engaging
- 88 HF + LS/VTEC = FUBAR!!!!
- Most hp or most parts with out getting it tuned
- Do i need to send my block the the machine shop
- Are my Skunk2 pro 2 cams no good? pics inside.
- Head Gasket - Coolant & Oil Holes
- What cam for mild D16A6 build?
- BLOX CAMS
- Info.: NA spec. B16A2 engine with weird black spots on cilinder walls
- GSR
- Dynos with Tuner Appointements in Las Vegas?
- 89mm B16B ;-)
- Possible to replace primary o2 with a wideband?
- aluminum radiator question
- 2.25" or 2.5" exhaust?
- Budget h2b kit
- F20B Dohc engine noise question
- Cam seals
- ITR Piston To Wall Clearance?
- does anyone know if DH Racing VTEC Eliminator Cams are any good?
- B18C4 build - compression ratio
- b20 oil dipstick
- Compression and valve lash
- car will not start
- Mugen XH4 vs P28 with Crome
- would i need a b16a injectors for my set-up?
- ek gsr idle problems and weird noise
- My All Motor LS Non VTEC build
- B series cams with A on the ends ?
- Nitrous Cam
- Help me!!!
- G23 Build...Need help!!!!
- Upgrade Valves?
- OEM vs Supertech valve guide seals questions..?
- B18b1 Civic bogging and idle problems
- where to get cam degree equipment...
- Breather Box on gsr block delete
- need opinions on all motor cams for gsr
- Itr Valves
- cracked block sealed up good?
- b16a mild build up
- B-series, missing anything?
- Couple of question on my LS/VTEC
- Looking for a basemap for a JDM D15B
- My H2B build!!
- Got some head! Now, what?
- 100 octane in b18b1
- how acurate are xenocron basemaps?
- LS/vtec need to pass emissions
- GSR (B18C1) WITH CTR PISTONS CLEARANCE QUESTIONS
- What spark plugs for GSR with 12.2:1CR
- LS/Vtec build help with PTV/PTD clearance...
- the DIY port job/runner clean up tests charts can i haz??
- B20V, Skunk2 Pro Mani OR JG VictorX?
- 100 Shot direct port
- LS vtec
- p72 ecu: Burnt iat resistor? Idles rough/dies
- Advice on Street B16a.
- itr motor
- Benson Sleeve or AEBS Sleeve
- d15b turbo swap into 2000 civic dx - help needed!
- Timing belts Aftermarket Vs. OEM
- d15b vtec swap help?
- excessive pressure blowing out cam seals
- D15B2 to a D16A1 piston question.
- What should my motor dyno for whp??
- best injectors for my set-up?
- Best intake manifold b18c
- AEM Wideband????
- What the F*#*
- High comp pistons on stock ecu?
- NEED HELP!!!
- is this a good set-up?
- couple of questions or ideas......
- rocker arm shaft bolts torque specs? typo in the manual?
- overheating. help!
- Um...Cam Specs?
- B20/vtec Rod choice.
- Offical announcement of Rocket Motorsports
- Am I detonating or mis-firing?
- F23 block/H22A head... who wants to help me get it together?
- Removing header/ o2sensor
