PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 [192] 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. an-r header
  2. I posted this in the RSX forum but 320whp n/a
  3. Looking for ITB videos..of B-series motors..
  4. MAP SENSOR Q (56k holy shit)
  5. Inline fuel pump
  6. good header for my setup
  7. So whats the gain in a 2-layer over a 3-layer headgasket?
  8. Hi flo cat question?????
  9. h22 question
  10. b18c intake manifold fit LS head?
  11. Why all motor ?
  12. If vtec doesnt engauge because...
  13. STR fuel rail help??
  14. will i need a new headgasket if.....
  15. h22 camshafts... opinion
  16. is Js racing really that good??
  17. ITR pistons, rods, crank in a GSR???
  18. Ring gap Question
  19. All motor help
  20. INTERESTING FIND: B16 IM VS. ITR IM on B20VTEC..
  21. all motor 220 230hp ,
  22. ls-v-tec or b20 frank! block girdle?
  23. B16a stroke VS CTR
  24. Warped block
  25. Power gains of gsr head?
  26. Chipped ecu vs reprogrammed by skunk ecu
  27. gsr flywheel in a hydro b16 tranny?
  28. 11:1 pistons = what size injectors?
  29. Rods....I or H beam?
  30. Spark Plugs for an 11:1 ls motor.
  31. difference in a SI head and GSR head
  32. Biggest bore on stock B18c5 sleeves?
  33. b16b ihe tuned hondata 154.2
  34. Choosing the correct main and rod bearing colors from Honda
  35. Correct formula/math for manifold volume to engine displacement?
  36. b18 question??
  37. Top Speed 4-1 header
  38. how much for bore, hone, and piston install
  39. LS Vetec vs. Turbo
  40. CRVTEC fuel and hondata question.....
  41. Valve adjusting
  42. anybody ever heard of Peak Performance Headers??
  43. Code 41 issue w/ Hondata
  44. where do i send my valves?
  45. gaping rings?
  46. HELP ASAP: Thinner Cometic HG worth it?
  47. Need ideas 4 building JDM 1.5 VECH
  48. Pics of the build...
  49. Possible motor purchase a eg b16 w/mods **caution motor noob**
  50. AEM V2
  51. need help on a set up
  52. All motor help
  53. which motor/ sedan
  54. Intake Manifold Design thoughts...
  55. H-22 intake manifold for h-22 civic hybrids
  56. Those With b20vtec do u feel vtec crossover?
  57. opinion on motor route
  58. Fuel Injector upgrade?
  59. Vaccumm Pressure stayin at -757mg/
  60. After I rebuild, I want to drop in a Ford Motor
  61. Which tranny is good for All Motor setup??
  62. b16 build any help out there
  63. Need my TB Ported out
  64. Help with question on setting cam gears????
  65. reliable mechanic
  66. Im sick of the NOISE!
  67. Fuel Talk
  68. NA engine B16A2 CR 14:1 use of watter injectors !?
  69. What rods to run with B18c 95mm stroke crankshaft?
  70. B16a1 head with big cams on 1.8l???
  71. dc sport cat back killing me?
  72. Installing pistons with block in the car?
  73. ATTN: All motor LS owners! PLZ READ!!!
  74. B18a Spun Bearing ? ? ?
  75. Problems of running a B18A in a 99 teg?
  76. Is it bad to pull out?
  77. CRANE VS. MSD IGNITION
  78. will buddyclub spec III+ cams work with stock b16 springs and retainers???
  79. Engine Building Tip! Look here.
  80. gas ported high compression pistons..?
  81. help with mild all-motor setup (cam choice)
  82. DIY crank/rod/main bearings?
  83. Warm-up time on forged pistons in daily driver?
  84. ***oem or aftermarket distributor???***
  85. integra motor in crx
  86. question about torqueing the headstuds on build ls/vtec
  87. Anyone ever drive an all-motor car at 9.1CR??
  88. torque plate needed for boring a b series sleeved block????? HELP
  89. dyno tuning... is it worth it? read pls.
  90. skunk 2 stage 2 cams in a stock gsr
  91. What caused my motor to do this to my spark plug
  92. Aebs, Skunk2, or Itr Manifolds Which is better Help !!!!!!!!
  93. Crower 403's or 404's ?
  94. which thermostat for b16a(SiR I)
  95. What timing belt for a tall-deck Dart block?
  96. What kind of spark plugs do you use?
  97. Poll. Crush Bent vs. Mandrel Bent piping
  98. Somone explain to me how final drives work?
  99. Torque specs and sequesnce
  100. Weapon R Race Header pictures
  101. new parts=big difference
  102. B18c All motor setup?
  103. Bearings?
  104. are your s2s3 cams to much for your engine???
  105. Some questions about Hondata's basemap.
  106. Compression ratio on pump gas please help
  107. IT'S ALIVE!!!!
  108. question about CBR 954 DIY ITBs tps
  109. Ketone's Dyno
  110. Is all motor worth it? (few other questions too!)
  111. how much are syncros?
  112. Daily Driver set-up!
  113. anyone use the REVHARD intake manifold yet???
  114. Grinding in 3rd Gear.......
  115. Full throttle Modified Nordskog
  116. Hondata tuning
  117. GUDE head package???
  118. type r pistons in LS block?
  119. Anyone using JUN type IV's? I need your input.
  120. how good are the Buddy Club Camshafts?
  121. Compression b16a2. What the...####
  122. Will vtec switch in with cable speedo instead of vss electronic speedo?
  123. No Head Gasket?!?!?!
  124. What is the BEST intake manifold.... period??
  125. B18B all motor Build, Help or comments.
  126. Wat's next best after all eternal bolts on
  127. Scooter
  128. what axles are you rocking for the track/street?
  129. rev limit on b16b
  130. Intake for 00Si
  131. What parts?
  132. why do forced induction driers feel good when they beat a n/a driver?
  133. Crower cams
  134. do 98 gsr engines have 2 vtec engagements?
  135. safe redline for a b20 vtec
  136. what do you think?
  137. Comment on this set up
  138. Need some direction.
  139. B17 rods w/b16 crank?
  140. port work. combustion work.
  141. ctr motor swap with rough idling
  142. Crower 403s, really bad idle, shaking, and codes 71 and 73 (misfires)
  143. the resleeving process
  144. if you ever wanted a DC Race Header...now is your chance!
  145. Big bore throttle bodies...
  146. H23 Vtec w/ type s pistons = what compression ratio?
  147. DYNO TUNING....
  148. Can u use obd1 injectors with obd0 ecu
  149. How To Manage High Compression, Big Revving D16A6?
  150. b20vtec Build. NEED HELP Immediately
  151. has anyone every got there hondata tuned here?
  152. Can anyone help me with cams and guesstimate whp
  153. Crank pulley bolt
  154. b18b block limitations
  155. My port and polish.. any tips
  156. Time to wish me luck...
  157. Odd problem with car.....
  158. not sure if my rods are shot.....
  159. newbie on auto repair
  160. anyone know if a ITR Oil Pump Fits a 1st gen b16??
  161. Who is the best all motor tuner?
  162. b20 vtec whats up?
  163. JG edelbrock IM
  164. need some motor/tuning help. high compression...
  165. Best overall Quality, Worksmanship, and Performance gain on a headers is????
  166. skunk 2 stage 1 cams
  167. possible bent valve? help me find out
  168. When motor builds go bad :(
  169. ANY All Motor Tuners in FL?
  170. Timing for B16a2 with slightly higher compresssion???
  171. Crappy shift linkage = missing 4th gear?
  172. Tuning necessary for just I/H/E and 11.8 CR?
  173. Cam gear wobble...
  174. JDM ITR TRANS how to tell differences
  175. LS Vtec??
  176. light weight crankshaft
  177. older skunk2 stage 2 cams
  178. Results of my dyno session today...
  179. fuel pressure regulators
  180. What do you think of this setup???
  181. My Motor Build. Think I May Be Fuxored! Built D16a6
  182. Buddy Club Spec 3+ cams vs JUN Stage3
  183. stock b16b runs 8.4 on slicks
  184. Engine builders answer this short question please.
  185. What size exhaust piping you guys running???
  186. how do you recognize TODA VALVE TRAIN??
  187. custom chips for GSR ??
  188. AXLE WONT COME OUT OF TRANNY..... ANY SUGGESTIONS?
  189. old setup vs new setup
  190. Which catback for DC JDM 4-1
  191. cam quality
  192. D Series Thoughts
  193. rod bolt tqing method
  194. ITB b18cR
  195. Debating using this ITR crank...hmmm
  196. B20z harness in EG?
  197. max compression on itr stock
  198. LS/VTECvs.F20B
  199. help me out
  200. how high stock gsr rods can handle????
  201. b16 highest compression possible?!?
  202. D16 mini-me with gsxr 600 ITBs
  203. does anyone know wieght of a b20/vtec
  204. JDM B16a sir 1
  205. YET another LS/VTEC build....pics inside(if they work no 56k)
  206. ls/vtec camshafts??
  207. Ls/vtec GSR head with USDM ITR pistons and 2 layer headgasket. My compression???
  208. could your motor burn oil even if compression numbers are accurate?
  209. Intake Mani and TB for RS
  210. need help tuning VAFCII for the track
  211. CFM of ITB's?
  212. injectors
  213. throttle body tps/map sensor
  214. Honda engine specs website
  215. swap shhtuff
  216. Question about TODA ITB.....
  217. Anyone build Non-Vtecs?
  218. Quick question--Vafc showing +0.00 pressure for cm2/kg- Toda cams
  219. What happened here?ROCKET?
  220. Does anyone make a strong steel retainer?
  221. storing a engine...
  222. buying used cams ??
  223. what size alen wrench for a b&m fuel pressure regulator?
  224. Which ECU with b20/vtec setup?
  225. Will the lsvtec run ok on stock p28???
  226. GS-R build question.
  227. help with my NA setup please.
  228. 4-1 vs 4-2-1 how big of a differance?
  229. Kinda set back...itr pistons in b16 block???HELP
  230. about converting to obd1 and hondata.
  231. Air fuel ratio for a NA B18C1
  232. consequences of maxed out injectors??
  233. which d-series engine is better.
  234. ITB's in my ITR what are your thoughts
  235. question about connecting rods and pistons
  236. Ditching my turbo Good idea?
  237. Anyone Own Endyn Rollerwaves? (i need one cc'ed)
  238. H22A H22 208WHP Dyno
  239. Oil around block
  240. Serious Idle Problem
  241. dohc valve cover on d series
  242. B18C/B20B hybrid swap
  243. golden eagle lsvtec conversion kit leaking
  244. Power enterprises belt, where to buy?
  245. Knock sensor help??????
  246. whats better k20 or b20?
  247. b20 build
  248. differnce between b, d, k, and h series engines
  249. Motor Horsepower
  250. How much HP can I expect with this setup?
