- For 4 Sale
- gsr build
- help! exhaust cam wont move
- which pistons should I go with?
- High reving motor, high compression c5, 20w cyn oil possible?
- Cam Caps????
- pcv set up help please.
- Which engine in my hatch EK?
- ls vtec rev limit
- b16 head gsr block
- b18c5 with ctr pistons
- h22 ring install
- Angle boring, effective in Hondas?
- need help with timing belt???
- B16 or GSR HEAD AND WHY?
- parts prob
- hondata ??
- ARP rod bolts for b20vtec build?
- cam on stock block?
- What type of Pistons?? ITR or EK9???
- 10 Ways To Free Horsepower
- Need some help trying to find headers..
- ITR Intake Manifold VS Skunk2 Intake Manifold
- My All Motor Build. Do I have everything I need?
- Ls vtec question?
- How much HP can you get out of a stock B18C1 N/A
- Xsi B16 all motor build for a 91 gs....
- My jdm b18c build
- gsr trade
- Turbo, Headers, Blow-off Valve, Exhaust
- gsr 2.0 vs ls-vtec
- high power b series owners.....
- Eagle Rods & Crankshaft, Thoughts?
- RS Machines itr pistons and hastings rings
- My Blown Motor Pt. II . rod removal . For those who plan to do their first rebuild. Please read.
- Searched- Stock comp gsr-enough comp for Blox 3's?
- need help on my b20 vtec conversion
- obd2 ls-vtec
- LS/Vtec Build? Opinions and advise please and thank you
- Video Camera inside and cylinder. Link Inside
- gsr build
- jun 3 cams
- for the experienced plz
- homemade itb for sale.....
- Carb'd B-Series.... in a corr super buggy!!!
- acura integra LS B18B
- b20 w/ itb's
- D16 eagle rods knotching??
- crower retainers, pro2 cams need a good match...
- s2 & buddy club cams.. questions..
- all motor gsr
- prepare to built a b20vtec in winter
- Looking for JDM GSR 82mm
- Just took my lsvtec to the machine shop
- catch can
- Portflow inner valve springs
- Some serious help with over heating, please i am desperate for help!!
- would RC310 injectors help me??
- How can I cut ignition if my oil pressure goes to zero?
- What Else to Add HP?
- install cams GSR
- throttle sticking problems.. help please.
- What motor to drop in my Integra LS?
- REAL QUICK tranny question, please confirm
- ADVICE!!!! WHICH ONES FOR D16Y8 NA???
- Are these REAL Skunk2 Stage 2 cams?
- ls/vtec suggestions
- 5Zigen Header for Integra GSR
- Assess H22 Damage? Loose T-Belt
- Performer x on a 2.0L anyone using one
- GSR/B18C1/C4 cams vs P30 B16A2 cams?
- bc4 vs. skunk2 pro1
- head porting in socali
- valve seal replacement on built head!!
- pistons
- b20vtec or b18c1?
- cams for b17 build.
- Took apart my GSR trans got a quick question
- Cylinder head vacuum test sufficient?
- b18c short block to replace b16a
- motor build..
- b18b crank in a b16a
- smokein lack of vtec
- Intake Manifold
- 500 a good price????
- engine builder take a look, bearing damage on fresh engine
- this is my first b20vtec!!!!!!!!
- My Blown Motor . In your opinion what do you think happened? [56k chill]
- skunk2 pro1 cams
- untouched USDM GSR bottom block. IS it possible?
- Best way to get that last few whp?
- cams cams cams
- Reusing Blox retainers
- B16 for D16+$500 bucks?
- Smoking blue on Decel only?
- Is a Poor Man type r reliabe then a ls vtec
- gsr tune?
- Comp Cams 57200's
- does rsx k20 pistons and apr rod bolt fit a h22a both 87mm 11:5
- need advise
- hollow cams??
- Cleaning motor
- over 200?
- NEED ADVICE: Glass Bead woes...
- Rebuilding engine for 225+whp. help on what to buy...
- ok got a question for you guys
- can any1 help me identify this piston
- Best way to reduce B18C5 Stroke
- static compression ratio
- NA... Catch Can
- Can i check for oil leakage past the rings this way? (kinda long...But I REALLY need help here, plea
- san diego tuner 4 built ls vtec..
- b16a
- Engine shop offering me free headwork, I don't know what to ask for... HELP!
- b16a block and head
- Need help asap about what to do until my car is tuned
- effects of reducer on velocity stack?
- BIG head, little block.
- B16b or B18c(GSR)
- b18b camshaft specs HELP
- Critique my 1st round of mods - 94GSR
- b16 vs b20(non-vtec)
- I think its time to go K!!!
- bored block
- Broken head studs?
- cel code 1 on civic hatch b18c5
- Help me with wiring "pic"
- high flow cat vs test tube
- Ls Teg vs. Si with plenty of bolt-ons? y did my teg win
- street imports header
- BEST OEM non-VTEC Cams?
- Buddy Club V cams help...
- Where can i get a good jdm d16z6
- Engine Lights - Got some interesting codes. (x3)
- gettin ready to build a ls/v-tec for my crx
- itr vs ctr redline
- Daily Drive All Motor 200HP Decisions?? Buy JDM ITR Motor or Build my Motor
- what size injectors for built gsr w/ ITB's????
- reving to 9k
- Magnetic Drain Plugs, are they all the same?
- Mixing oils mobil 1 & VR1
- ITR/CTR cams in a stock gsr
- **what kind of cams are these??** please help!
- tesing pics (sorry)
- Can you use a stock OEM B20 head gasket in a 84mm sleeved GSR block?
- my c5 set up.
- LS/vtec tune
- 98 accord
- NEED TUNING ASAP
- Integra Collector, Inlet/Outlet, Questions on Fitting (DC2 1994 RS) Items.
- why does 13.3 make more than 12.5 in a mild pump gas all motor car??
- Dyno result from my B16a2 hatch help please!!:(
- Ghetto Intake
- can't install valve seals...wtf
- searching for ways to improve my setup
- Tranny, transmission problem or throttle bearing?
- H22 LMA's vs ITR LMA's
- need advice on what to do to my b18c1 block
- AutoX all motor setup...need suggestion
- obd0 vs obd2 b16 oem exhaust manifold differences
- Questions for Camshaft expert esp. blox
- poor mans type R or the real type R ??
- forged rods and oem pistons
- cams cams cams! which ones?
- Intimidated on first assembly/build.. Need your help Honda Tech
- Removing Pistons...
- Need Advice on a New build..... swaping the gsr block for a b20
- I have a B16A2 already, what else would I need for a B20/VTEC?
- Gsr block?
- ***2.0L LsVtec~~~~ powered by BISIMOTO***
- Nippon Pr3 Pistons for LS Vtec
- i finished building my motor...
- Y7 to Y8 mini me
- Compression options/available pistons for a stock sleeved B20vtec?
- planning to build ls vtec need help
- TWM 50mm ITB's on stock 98 spec JDM ITR motor w/ race header
- d16z6 vs d16a6
- tranny problem or clutch plate?
- B18B Swap Info
- Did I go overboard with my clutch selection
- b20 tranny internals in a y1 tranny ?!?!?!
- pistons?????????
- intake manifold worth it if im looking for midrange?
- Northern California Dyno Tuning for Hondata
- Why you don't make power in the high RPM with small cams, very simple.
- Motor Just Died On Me!!! Need Help!!!
- People who had experience with this...
- dyno proof.... tapered tb > no taper
- VTEC controller or hondata?
- CYP cel after advancing Exhaust Cam 1 degree
- b20/vtec build
- Gtuned ebay header???
- Any Insight on my bumpy torque curve?
- CROWER CAMS & BUDDY CLUB CAMS OPINIONS
- Safe Rev Limit, LS vtec, a/m valvetrain, ARP's?
- exospeed or web cams?
- D16a6 build last few Q's
- all motor tuner
- which one is a better daily driver cam, the pro 1 or the pro 2?
- b20 or LS Vtec.
- B20 vtec engine wont run right
- ls-vtec VS b20-vtec as daily driver > best ?
- LS Motor build
- BC feed back
- All motor build: GSR Crank or LS Crank?
- Y8 head on a Z6 block
- Replacing rings and their chain reaction.
- Harmonic dampers
- New to all motor section, have question about build and blox b cams
- What are size difference of b16a headers between 88-91, 92-95, 96-99 and type-r?
- Help me choose a cam, please!
- b series motor build
- Any buy one of these hytech replicas
- little help.b18c
- F20 Cams
- I want to improve my B16A setup... looking to go from 164 to 180 whp. Suggestions?
- VTEC engage
- what engine will be the best for all-motor?
- any experience with Redline 4 probe sensor egt gauge ?
- For this cheap?
- B16a stroker
- h22a chipped ecu
- Victor X vs Performer X (Anyone have a dyno comparison?)
- oil squiters?
- Is anyone useing a 95mm stroker kit on there daily driver?
- ls/vtec that made decent numbers untuned
- Airflow/HP specs?
- Question about fuel injectors
- would anyone happen to know about ls/v hogh compression pistons
- GSR Motor Build Recommendations & Advice Needed
- Question help: JG Edelbrock Pro-Flo Header for GSR
- Who else makes a true 2.5 Inch exhaust other then KTeller???
- where can I get h22a4 piston
- Valve train
- Mild build on GSR
- block boring
- this set up..
- type r bottom b16a
- Which of these 2 flywheels for all motor
- Built B20vtec DYNO!!
- How to install a head gasket.
- H2B --- K KILLER????????
- ITB's size?
- all motor build what setup to do??
- Head gasket choice
- inspecting bearings
- all motor h22
- D16y8 Swap question
- pro 1 cam wear problems
- Rage big tube or small tube?
