- how can you tell what crank?
- LS swap??
- How to break in JUN camshafts for H22?
- hondata and p28 HELP!!
- All-Motor Guys take a look
- b16 IM stud size
- build my block
- QUICK SPARK PLUG QUESTION...
- SRZ RACING Official Header Test Thread
- Crankcase evacuation. Will this work?
- how can u tell if u spun a bearing
- Crower nonvtec 403's with factory retainers?
- H22 Decisions
- are these skunk2 stage2's?
- Darton style sleeves in B20B block with cracked sleeves
- how much can a ported f22 head flow?
- itr/ b16 head vs gsr head with b18c1/ b18c/ b18c5 bottom end?
- ls/vtec setup...where to get headgasket?
- J's racing header
- ITB vacuum log ???
- is flex pipe gonna be bad??
- Popular Cam Pulley Weights
- anyone had experience of ITR block with B16 head?
- B20vtec DA dyno'd - 246/176
- b18 or b20 ls vtec or b20vtec i have all the parts which one to choose
- skunk cams question help skunk2
- lsvtec questions??
- Build for a Sedan.
- how much horsepowerrrrr ????? ***********
- compression in new motor?
- chipping pm6 ecu
- built motor
- B20 OR B18b cant decide
- Ls Ecu?
- smog for ls/vtec
- vtec wont engage
- ls vtec idle
- VACUM LOW on DIY ITB B16A
- GSR Tranny not going into gear?
- Unorthodox Pulleys, CTR pulley, are they really bad?
- S2s3 valvetrain question
- Crower 63403-2 with omnipower valvesprings?
- GSR all motor rebuild need advice
- head gasket question....which to use on 81.5mm bore?
- what ecu for you high comp ls/vtec guys
- Valve Lock Question...
- Intake, header, hi-flow cat, exhaust...what's next???
- je gsr pistons b20 block
- to h22 owners...
- header with clearance and moderatley priced 200-300
- What should i use for tuning?
- Well I am putting in some goodies; cb7 (90 accord) with minor mods.
- B16a2 Pistons in a B18c1 with a 20thou head skim
- Around 240-245 with compression tester!press the gas pedal all the way
- what kind of wheels and slicks should i get to fit over my itr 11" brakes
- HEADER HELP
- what should be written on my Type S pistons??
- How much power did you gain by dyno tuning...?
- Head Gasket Question
- 1997 CBR900RR Individual throttle bodies......
- My CRVtec setup.. some questions
- crower stage 2 cams
- gude head package
- Summer Project Choices? Need Help
- Cylinder Head Hose
- jdm gsr stock or not?
- B18C1 - Oil squirting everywhere?
- ITR springs...Which is which
- air/fuel question?
- Need an opinion on why my motor sounds like its running on 3 cylinders
- Dyno # of my Skunk2 Pro1 cams Using Neptune
- b20 crank in ls?
- Help me calculate my compression ratio
- Buddy Club 3+ and new valvetrain......Car Dead
- b16+ CTR pistons+ LS crank = what rods?
- H22 skunk2 stage 2/3 cam ???
- My Setup
- Best header for B16B
- Attention Velocity stack owners: Got boost?
- An-R header ?
- Best D series swap combination short block and head?
- p30 pistons in gsr, what rods do i have to use?
- Skunk2 Pro1 Valve Lash!?!?
- d16y7 piston rings in d15b2??
- Has Anyone used ACL rod bearings in ls/b20 rods?
- Spring Seat Pressure to high?
- question in screw changing
- B16a
- air/fuel ratio ??
- zc sohc block with pm7 pistons and a y8 head, ????????
- Custom K-series Western Wristpin: 0.090" wall
- Custom K-series JE pistons: ultralight 90mm
- Cost of Tuning by a profession tuner (on dyno and street/track)
- New Setup
- CAI Size..
- new motor built.. first startup.... what to do???
- wideband sensor and hondata??
- M22 cams in stock b16?
- about to undergo a vortech install
- k20 in a dc2 (hard?)
- Piston to Valve Clearances... How do these numbers sound?
- Just another "hey, here's a pic of my new motor" thread
- Shim for LS oil pump
- i need a basemap for my hondata...
- A day at HOOKUPS...
- Neptune yay or nay?
- Buddy club stage 4 users.........Are you running a Stock or Aftermarket Timing Belt?
- hondata or venom chip?
- i have 3 different head gaskets. which one?
- Apexi PowerFC Documentation
- Portflow Titanium retainers look a little funny... Power Enterprise Timing Belt looks good (20k+ mi
- Compression Numbers Okay? Built B20vtec w/ 12.5-1 compression ratio
- High compression 12.5:1 lsvtec streetable???
- bored out z6
- Decided on exhaust
- What do you think about this valvetrain? Need help
- questions on a 200+whp daily driver setup??
- how does a stroker kit work?
- Recommendations on where to go next?
- How to get a 14 flat
- CTR Crank Pulley Thought...
- B20/ Vtec vs GSR swap in EK hatch
- which model vehicle header do i have?
- Injector questions
- Input on H22 parts.
- bore B20 vtec to 85mm+??
- Skunk2 Stage2 Cams???
- TWM ITBs
- ::::: Lotus in the aftermarket ? :::: Need your feedback !!!!
- High octane gas
- vtec controller
- Coolant line diagram
- toda B install specs needed
- a few technical h22 internal ??'s
- Lighter crank Pulley?
- need opinion on stock daily driver what flywheel
- Where to purchase ctr pistons?
- CTR/ITR crankpulley
- compression numbers .... really low ?????yet cons. whats the deal
- what throttle body will fit a 93 civic sohc si???
- max compression ratio on b16a2 std sleaves?+ other stuff
- motor sputtering at wot at temperature
- Help?
- Magnaflow Muffler Size?
- DH-Racing build
- ls/vtec noises...
- Heads up for those using ITBs w/ stock ECUs
- HEADERS: stainless or coated
- 96 itr question
- Import builders????
- bc3+ idle problems!
- Detonation at low RPM
- 190lph fuel pump. Too much for NA GSR?
- ** fastest all motor in the US**
- Compression Verification Please
- itr pistons or JE ???
- where to buy these headers?
- Installing Progressive Valve springs
- Best cams in a b16
- catch can question
- edelbrock race header?
- skunk2 Pro1+ on stock jdm b16a sir2?
- OEM 2 Layer Headgasket
- help with all motor build
- Can anybody tell if this is a ctr intake cam?
- What is the duration of Toda A cams?
- All motor tuning
- megan racing test pipe...2.5"?
- A True all motor setup?
- longer resonator?
- 2001 Civic Engine Swap
- please help
- b18c1 spark plugs(yes i searched)
- ALL MOTOR WORLD RECORD BROKEN TODAY
- Cutting Crankshaft (Removing counterwheights)
- upgraded valve train sks2
- stroke
- High comp. piston & rod choice?
- Crower vs SS1 vs CTR on stock block B16??
- Bent Valve, Time for Upgrades
- stock 05 d17
- d17 head swap
- how to find out if a valve is bent? (valve out of motor)
- Water/Methanol Injection for N/A applications
- Low temperature Thermostat & Thermoswitch - your views !
- Rocket m22's vs. Buddy Club 3's
- TWN ITB's on an H22a
- gsr or b16 head
- B16 head no cam caps ?
- Running Too Rich, Engine Code 5! HELP!
- Metal shavings...
- quick compression question
- (sighs) n00bish question
- 400cc injectors
- Heater bypass
- compression test, Oil consumption, my options? (thanks) jspec b16a 2nd gen
- Building a 13 second whip
- ls block, gsr head, what timing belt?
- Facts on CTR crank pulley.
- skunk2 cams with a chipped ecu????
- gsr and b16 oil pump gears?
- jays racing intake knockoff
- anyone use the megan cat/testpipe?
- gsr motor question.......
- 85mm 12:1 compression + ITB's, what size injectors?
- k20a2 dimensions and clearances?
- Red Civic Standard -- dyno tuned 2005
- throttle body
- Apexi Power FC Tuners in Socal??
- D series high comp mini me.. will it work or will it just go boom??!?
- Skunk pro manifold
- Profab header Works Good!!!!!!!
- my "problem". all motor b16a
- where can i get a block
- I NEED HELP!!! CAN YOU MIX MATCH VALVE TRAIN?
- If that possible??
- How much power can a built k20 make and still be reliable for a DD?
- 2.0L gsr vs 2.0L ls
- IS ANYONE RUNING AN ERICK'S RACING THROTTLE BODY ON A B18C1?
- NON-VTEC
- if i dont bore my TB, will that hurt me?
- There is no way I should beat this guy....
- NEED HELP, spark plugs hitting pistons
- HKS F-con pro!!!
- crower 403 or exospeed ls909
- LS Rods?
- OBD! DOHC ZC
- ctr pistons in gsr ? and rm m22?
- Does it fit?
- JG/Edlebrock Intake Manifold - Which Throttle Cable and Bracket!?!?
- INJECTORS
- what should i expect from port and polished TB ?
- Custom K-series CP piston: 90mm
- stock gsr head vs. 3 angle port & polished b16 head
- OBX cams
- Camshaft pics (RM M22 vs. S2 Pro 1 vs. sir1)
- GSR hatch Need New Spark Pluges and Wires Any Suggestions ? PLEASE
- crx project
- crank shaft pulley came loose now engine is making weird noise
- I NEEED torque specs for LS/V AsAp!!!!
- Ecu trouble!
- How to tell Skunk2 Cams?
- J's intake on B16a? Yay or nay?
- Urgent..please help
- If you could, would you buy...
- d16y8 mini me surging issue
- Delta 272 cam
- Anyone running JUN 3 cams is a b16b?
- What cams are these?
- EK K20
