- ARP HEAD STUDS ON A D16
- Modifying Stock Pulley
- d15b/y8 vtec mystery
- Blow by on motor - how long will it last?
- Mini Me???
- Flywheel for dc5
- Crower stage cams
- Porting LS head
- Ditched the turbo.....Going N/A *semi-built ls/vtec*
- porting b18c
- First post! Looking for some opinions!
- Skunk2 Ultra series "Street" manifold Pics
- ►► March - April ►► All Motor Classifieds
- Manifold pressure and all motor
- Skunk2 Ultra vs BMC race
- EK sedan with GSR Headgasket MAJOR leak
- LMA's for B Series Vtec - S.o.S.
- built B20VTEC what you guys think
- ls vtec stock piston
- aftermarket throttle body that can use a oem throttle valve?
- 85x89 runing rich or burning oil!?
- what is the name of this
- itr or skunk 2 valves
- B18C Cylinder head build
- Arp installation (LSVTEC) Help
- 1988 Honda civic dx b16b swap
- rs machine pr3 pistons need balancing?
- Lsv Smells like gasoline when driving
- GSR ALL MOTOR QUESTION
- S2 Pro or Tuner series ?
- Can I run Skunk2 Tuner 2 with basemap or.....
- lsvtec conversion??????
- D16z6 fouling plugs help please
- H22a1 block and pistons..f22 crank rods.. crank is BINDING..help?
- E85 na compression ratio question
- Would a ZEX nitrous control unit be worth buying?
- LSV Swap Q's
- Honda bearings
- My GSR Build Need Suggestions
- B20 vtec help questions
- B20b vtec
- B18C5 IAC Codes and troubles
- how much does it take for detonation to damage motor
- Jdm Gsr rebuild
- ls/vtec build - crank question
- 2.2L Timing Belt Video
- B16A? What Year?
- Camshaftless engine.
- One of those Exhaust Questions
- B18a1 noise
- b20v
- D16 for B20?
- What cams should I run?
- Time for a new intake need some input.
- DIY $5 Secondary B-Series Timing Belt Tensioner/Cam Belt Tensioner
- supetech pistons
- Looking for reviews on Cylinder heads international
- Running 3" Stack. Upgrade suggestion?
- methanol injection on all motor lsvtec
- all motor b18c5 build help
- Info about Installing PCT Pistons in B16a2 block
- K20 custom intake fitted now running like shit, vid inside, help please?
- gsr repeated map sensor failure
- 1995 eg with jdm gsr engine
- Skunk2 70mm Throttle body "overkill" for current setup ?
- Good or bad hone job?
- A6/y8? B7/y8? B6/y8? or just y8?
- b20z 200 hp build help
- d16z6 timing tensioner problems
- B16A build/ poor man type r
- Damn Toda Cams >?
- Engine Swap
- IAT sensor missing for aem induction system
- How to build a reliable B16?
- ring gaps too big out of the box
- Motor won't fire
- Source for Internal Parts J35A3- Rebuilding BF225 Outboard
- ARP head stud's install question
- B20 vtec or B20 turbo or both???
- PCB F20B CC Volume
- More help with b20 engine
- Can Any1 in Maryland or surrounding area degree my cams!!!!!
- Needs some advice ?
- D16Z6 All Motor
- B series build off
- B18C ITR Build
- 1981 CB750c oil on jugs 2nd stud #1 cyl spins outside
- Block Guard?
- milling the head
- ls/vtec injectors - looking for suggestions
- are these toda cams?
- a6/y8 mini me build. a6 intake vs y8 intake?
- opinions
- B18C1 Poor Mans Build
- edelbrocks 4730 B series camshafts, anyone running them?
- Burning Oil poor mans ITR +
- has anyone talked to DonF? Heard bad news....
- help with strange misfire please!!!!!
- F20B Osaka Power Check
- Motor swap ?
- D series endurance racing help... all motor
- OEM Sleeve thickness & material
- looking to go b20vtec on my auto 99 crv need help
- Tried My Hand At Porting...
- GSR Skunk2 intake manifold throttle body gasket
- whats a good price for a B18b1 block
- Cam selection help
- B20 exhaust sound changes and power differences
- D17Y6 Coolant Leak
- quick lsvtec piston question
- high compression b20 vtec
- 95 accord f22b1 to jdm f23a swap
- for anyone that wants to put a b18a tb on a d16a6 manifold...
- K & N Cold Air, Throttle Body Spacer
- Exhaust Mods 2009 Accord Coupe V-6
- DIY IACV in ITB's
- guys help me! i just traded my truck for this integra
- Are there legit HKS cam gears??
- Is anyone running a PLM bigtube header(tri y)
- 1990 CRX
- Myths about 00-01 H23a PDE heads
- ARP connecting rod bolts
- swap a b16 for a b20??
- Would i be 'over camming"(S2 tuner 2's) with this setup ?
- B16A2 N/A Setup help :)
- b18c5 Teg w/ high idle and no vtec
- Gsr stock rebuild issues
- stock gsr with bc3+ cam injector size question
- plz help with my 97 accord overheating
- b series cam help
- need vacuum diagrams for 2000 D16y8
- After instilling MSD 6AL, Car misfire at 4500RMP and up
- honda accord 2006 heater
- Crank won't turn freely!!!!
- B16A2 High compression Query
- anyone know what header this may be
- Should I build w/ this cylinder head? NEED ADVICE
- B16b
- injector problem ls swap
- would you re-use these rod bolts??
- engine problem b16a2 - please help :-(
- Poor Mans ITR swap into 99 usdm SI
- GSR
- N/A H2B del sol (pictures)
- motor swap questions
- B20b - with a B16a crank
- What type of engine harness for JDM D15b on EK?
- f22b dohc questions HELP PUH PUH PUH PLEEEEASE
- lighter wheels, lighter flyweel, no PS what can i expect?
- GSC Power division NA cams
- A6 pistons in y8?
- Re-Use piston questions
- Parts list
- drilling b16 piston wrist pin oil holes-pro 1 cams
- D16Y7/D16Z6 Mini-Me headbolts
- What should I do to boost my cars HP?
- acl bearings
- High compression pistons and gas.
- fully built lsv
- Comparing int and ex itr valve springs
- which would be more reliable for dd? 82x89 lsvtec or 84-84.5x89 b20vtec.
- hytech replica header for F22A/H23A1 non-vtec
- accord sir-t, f20b detonating
- Overheated engine..URGENT HELP!!
- type r bearings
- reaching hp goal of 140whp
- vtec problem on dyno
- [HELP] H series Sk2 pro series IM vs RBC
- Bseries or h2b
- Kinsler ITB installation
- h2b has wierd noise
- b16a2
- smog removal
- ZC into EG swap inquiries....
- h22 type s real or fake [pictures inside] help
- B20 Crank and Rods in B18C1
- BC3+ to JUN type 3 cams for daily ?
- Ever seen a cam lobe like this????
- trying to decide on a setup f20b f2b or b18c type r
- bearing lube question
- 3" exhaust beneficial on a Usdm B20Z?
- Cam Degree'ing
- d15b head swap help&tips
- b16a1 build
- just got a 4 door eg trying to do a b-series swap i need some opinions
- B18b1 eg hatch upgrade to b18c5
- Will d16y8 injectors work on 98 b18b1?
- Sparkplug for high compression
- setting ignition timing on a sohc zcobd0
- vtec engaging twice
- h22 crower 3 cam questions?
- Is this block sleeved?
- Ls/vtec question
- 2000 civic ex build
- Jdm-r b18c build ej2
- engine swap question
- 1998 Honda EX 2.3L Tranny Problems
- k internals in h series motor?
- is it worth putting in type r cams into b16 without valvetrain upgrade or tuning?
- Basic engine operating temps? (oil temp/pressure, coolant temp)
- need a lot of help
- BC Rods Question BC6019 vs BC6057
- Advice on rebuilding a B or D series for daily abuse?
- 1 WISECO PISTON
- B18B timing belt
- Help!!! Please!!!!
- b16 w/out girdle?
- front main seal changed, now rear leaking..b20
- Brown valve guide seals and blue seals question?
- ANY ONE RUNNING ON 85MM STOCK B20 SLEEVES
- Oil squirters.... squirt squirt
- the EVOL Build Cleaned up.
- Toda springs and ITR retainers question
- S2 TB has not FITV. cause of idle not going down ?
- Engine almost dies on start up....then..
- 92Mmm or 95mm crank for B series ?
- itb injector spray patten?
- H22 100mm stroker. Need advice
- 93 BETTER THAN E-85
- piston to wall with rs machines itr knockoff pistons
- B16a rods
- EM1 Exhaust Noise Help
- Tappet Clearance 0.2mm vs 0.007mm
- Help with camshaft selection
- k20/k24 S2000
- Identify cam help needed
- Pics of your VSRExhaust/KTeller/Mandrel Bent Exhaust Kit
- Want to know good brands for pistons
- vtec wont pop help
- b16 all motor build questions?
- Headed In the Right Direction? 99 EM1 SI
- b20 vtec questions
- Temp/Pressure sensor location ideas and setup. Suggestions welcomed?
- f22a4 good starting point?
- diff in d series heads
- Putting a B16A into a 2000 Civic EX
- Megaphone vs Cutout
- D16 BSFC Charts?
- 2inch straight its good...pics
- Urgent Help - Weird Issue
- b16b, f22a1? help?
- stage 1 cam question
- Textbook vacuum leak... right?
- What is the world is a "b16b7" ???
- Switch from full b18c1to a b20 block with b18c head
- I NEED B16A O2 SENSOR HELP!!!!!
- Strange idle problems
- all motor gsr help. -searched-
- 99 SI EM1 Bolt On's and questions
