PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 [153] 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. HELP please
  2. How not to shift!
  3. skunk2 pro intake or jg ?? for 2.0 race motor
  4. cam comparo
  5. Hondata S300. Now has ITB support?
  6. Loud ass valvetrain with Skunk2 Pro 1's, need imput
  7. ls crank into gsr bottom end question?
  8. Engine block
  9. h22 swap or my B16?
  10. ANOTHER Overheating prob.....very weird....but please read! STUMPED!!!
  11. B16B ROD LENGTH! *SEARCHED*
  12. Installing NPR ring into b18c, which side should face up? HELP!
  13. I Need Help NOW...ls-v related.
  14. Question on b20vtec dyno
  15. Oil Pressure spike??
  16. ANYONE HAVE A AEM V2 for sale?
  17. Whats a really good header for H22 motor and where to get??????
  18. if you only had a certain amount of money which would you get: jdm itr tranny or header?
  19. Need opinions, B or K series
  20. Using an Impact Gun for removing the Crank Pulley
  21. whp to break into 12s
  22. B20Z VTEC. Need to know about valve reliefs: Necessary or Not?
  23. Electric water pump on a daily driver????
  24. What would be my displacement if...... Searched..
  25. what octane to use
  26. Will I get good traction with BFG Drag Radials?
  27. My Ls/Vtec
  28. .Need help calculatng compression
  29. Cam Choice
  30. crane
  31. Get in the 13's with an NA B18B LS in a 92 CIVIC CX?
  32. knife edging crank
  33. All CTR internals fit B16a????
  34. RMF header arrived today! BLinG pLOw
  35. engine swap
  36. over bore on b18c1
  37. PoorMan's Type R ?
  38. Skunk2 Stage 2 Intake Cam Busted!! What Now? Warranty?
  39. dyno tuning quick quick questions?
  40. Throttle cable for DIY ITBS
  41. just want to clear something up. (high comp pistons)
  42. my allmotor setup?
  43. project 2.0l poormans itr opinions on cams needed
  44. Please HELP!
  45. Venting the valve cover
  46. b18 stroker kit
  47. exhaust question...
  48. is there a different between JDM 1993 H22A VS the 1997 JDM H22A?
  49. cam choice (searched please help!)
  50. CAN I PUT AND LS CRAKSHAFT ON A B18C1 BLOCK?
  51. Is this a good combination???
  52. Traction problem on eg w/H22na
  53. Can't lower 1/4 mile time using Skunk2 stage II
  54. missing at idle!?!?!?
  55. Fuel Pressure Adjustment....Is this normal....Is this safe....Is this ok, HELP
  56. BLOX RACING PRODUCTS ?
  57. OBX RACING PRODUCTS!!!!
  58. Compression Ratio
  59. B20B JDM
  60. car wont idle up after engine build..... Stumped
  61. b20/vtec piston myth!!!!!!
  62. Question on my setup???
  63. need wideband
  64. any SKUNK2 PRO1 cam dynos?
  65. LS/VTEC oil line questions
  66. LS Tranny w/ All Motor
  67. jdm itr pistons... not a compression question!
  68. just dynoed my built gsr
  69. Hondata S300 vs Neptune and why
  70. Valve adjustment? HELP! PLZ
  71. b20 piston Question??
  72. unwise to bore a gsr block to 2.0L
  73. whats the best place to buy piping?
  74. where in so cal to get crank rods/pistons polished? how much?
  75. Is it bad that the head was previously pulled?
  76. y8 head on my y5 (mini me) help please
  77. f20b over b16
  78. INTERTUNETV: Presenting "Omni's 91oct 1595cc 200whp B16a" IN STOCK!
  79. CODE 8 TDC?
  80. my new setup what compression will i be running around??
  81. Wanna trade cams??? Just feeling it out.
  82. JDM ITR 4-1 vs. DC Sport 4-1 (Ceramic coated)
  83. Injectors
  84. New to the All Motor game.
  85. B-Series Tranny which one??
  86. B18C5 Build
  87. Ls/vtec rebuild.....Questions about pistons
  88. b18c1 build..tuning that important?
  89. Looking for information on machine shops!
  90. dyno tuning help
  91. can i use civic type r pistons with eagle rods???
  92. oh what to do.. ?
  93. Need help with a bogging problem, Video inside!
  94. sleeving and piston questions
  95. how long till mad vtack?
  96. What max RPM can I expect from CTR cams
  97. cranck balancing for ls vtec
  98. Dyno Chart - B17, heads and cams
  99. Looking for Diffut's Inc. contact info
  100. B18C1 dyno today... not too impressed
  101. ACL Bearings
  102. Buddy club Spec 3+ valve lash
  103. Intake Manifold? Why No collector?
  104. Which Cams for my B16
  105. ***ls vtec or gsr??? HELP ME***
  106. NOS question
  107. Quick Teaser of my Build
  108. B16 Water Pump??
  109. who runs a p72 head on a b16 block
  110. ITR CAM vs CTR CAM Which is better for ls vtec build?
  111. extremely low compression test numbers. how to fix?
  112. advice for itb's
  113. Max bore for LS block.
  114. How do I ID Skunk 2 Stage 2 cam?
  115. no water in radiator!!!!
  116. what will ctr pistons make my compression?
  117. valve springs to s2s2 cam
  118. Reccomendation for crank work
  119. Help a brother out. ITB related
  120. OS P30 ring gap
  121. D-Series Build
  122. tuning how much will it help?
  123. Basic power to weight questions....lies?
  124. Some Special Tricks for going fast without boost!
  125. breaking up at low rpm's
  126. Flywheel & Pressure Plate Question
  127. LS/B20 VTEC question
  128. Need a custom chip for B20b Crvtec!who can do a best program for me.
  129. LS VTEC SET UP
  130. what would my compression be / what is the best air / fuel ratio
  131. Dead alternator
  132. b20 vtec questions
  133. Question about the B16B engine.
  134. obx manifold problem
  135. Dyno'ed my ls today....
  136. cams in ls vtec
  137. which generation b16 head is the best?
  138. Post up ur 85x89 dyno charts!!
  139. question about compression?
  140. Skunk Stage 2 cams
  141. a question
  142. Is anyone running pully kits these days?
  143. LSVTEC, ITR header, and oil pan problem
  144. H22 Civic Swap
  145. Will a stock Vtec beat a stock vr6?
  146. All I can say is ,You gotta see this
  147. Can you visually tell which are stock and which are aftermarket?
  148. Opinions on Crane Stage 2 cams
  149. Rod Question
  150. distinguishing between heads
  151. HELP! GSR BEARING ISSUE
  152. question.....
  153. b16a sir2 w/lsd...greddy header...2 1/4" catback...j's racing intake....1/4 mile time?
  154. Honda standings in All Motor
  155. Cams are in, headwork done, and now.. Im starving for fuel!
  156. LS crank + GSR block = hitting oil squirts
  157. Golden Eagle LS/VTEC conversion kit.........whos got it??
  158. B16A1 clutchquestion
  159. would you do this for a b18c
  160. LS/Vtec New to Honda Build Up
  161. obd0 to obd2b converstion, any problems?
  162. which header "LOOKS" best?
  163. civic swap map/idle probs
  164. ls over h22?? HUH!
  165. Built B20 vtec
  166. I shaved down the underside of my rocker arms - with a dremel! (56k death)
  167. Hate to do this, but I need quick engine building help (real broad, n00b-style help)
  168. b16a TB vs b18b TB
  169. freak z6
  170. Best power range and safe revving
  171. need some help with my b20A JDM.
  172. B16a pistons/ls block??
  173. what are my choices for a OBD2
  174. Some new goodies for the c5....
  175. JG CAMS Anyone?
  176. just got my body kit from RMF
  177. a good shop in pa,nj,ny
  178. Twm ITB's worth the jump??
  179. piston question
  180. i am a math retard - where is the database/ page with rod and stroke's listed for honda's.....?
  181. camshafts
  182. mid range power loss skunk2 stage 2....
  183. which header for skunk 2 stage 2?
  184. H22a HEad.. need advice on Head Package...
  185. all motor ls questions
  186. Definable Knock Control
  187. .137 Ls rodDs
  188. Built LS
  189. ITR Oil Pump the same as a GSR?
  190. Would these cams be over kill????
  191. Trying "ALL MOTOR" Now
  192. VTEC only pops 1st time???
  193. valve clearence
  194. Spark plug wire battle?
  195. b16 oil pump with LS/Vtec??
  196. will this work??? po8 auto ecu chipped so now it can be use on a 5 speed tranny?
  197. Hondata S200 and S300
  198. B16 in a eg which ecu to use thats not a p30?
  199. what cams will make the most power to 8.5k on an all motor(dont want to rev high)
  200. bigger throttle body?
  201. GSR crank VS LS crank in GSR block
  202. Intake question, please help
  203. Avg price for piston/rod install?
  204. My vtec isn't workin
  205. engine swap
  206. Piston bearings
  207. LS/VTEC
  208. car running too rich at idle, need help
  209. Should I run a 5, 6, or 7 spark plug with 13:1 compression
  210. jg ported ls head?? shed light.... Link for pics
  211. upgraded valvetrain with stock cams
  212. Calling all B16 guys....
  213. cam sprockets and cam gears
  214. INSIDE LOOK AT SKUNK2 RACING
  215. Which Rocket springs/reatiners to use w/ M22x? Gen1 or Gen2
  216. LS/Vtec which block someone experiened help...
  217. ls/vtec build in my crx, what should i expect? faster than srt-4? same?
  218. change my oem injectors ??
  219. 2.0L...Use JUN 3's instead of BC4's for more clearance with .5 oversized valves??
  220. Bored and Stroked B16 PT.2: tuning and DYNO
  221. any luck with p72 head on a b16?
  222. how to at least 200whp b18c N/a
  223. GSR / LS rod bearing?
  224. To D series lover…. Another D series all motor “230 BHP” graph..
  225. competiton cams
  226. I have a question about stock retainers.
  227. B18C5 2.0L 12.5:1 Build, need suggestion
  228. B18C5 2.0L Build Pistons, Suggestions please
  229. 68mm s2 tb?
  230. D16y8 SOHC all mtr best CAMSHAFT?
  231. Building b20/vtec...few questions
  232. LS ROD ARP ROD BOLTS?????????????
  233. Cam install question B16A with BC IV
  234. B16 crank and rods in B18a Block Need help ASAP!!
  235. Looking to buy Toda Spec B or C Where???
  236. help building a engine will ctr pistons fits on ls rods
  237. B16 build question
  238. type r oil/water pump
  239. endyne/ the old one and a 300whp/ 200ft-lb allmotor h22?
  240. all motor build q's!!!!!!!
  241. zc sohc shorblock??
  242. Skunk2 Pro 2+ VS. Rocket M22xx
  243. Management
  244. Please Help Guys: Tired Motor Needs A Fresh Start!
  245. Head milling/cc'ing question
  246. FS\FT NX WET KIT
  247. B16 Valve angle recommendation
  248. HELP! bogging at 7k ls/vtec
  249. B16a or B18a/b for all motor build?
  250. b16a2 mods
