- RMF headers? How much$$$$$
- ARIAS PISTONS w/ STOCK RODS, WILL IT WORK?
- cams
- skunk2 IM fitment issue, IT'S STUCK
- itb air filters.????????
- ls/vtec nitrous set up questions
- ITR JDM headers vs. DC Sports vs. RMF ?????
- wtb skunk cams pro2's located in Toronto...
- My b20vtec dyno...hows it look?
- Is this head Fixable?
- help asap 94 gsr wtf is wrong
- modifying b18c1
- 450cc injectors in obd0 11.5:1 comp b16
- What material is stock B20 crank made of?
- looking into buying rmf headers need help"
- any companies make rods for b18a crank in b16?
- GSR vs B20
- Would I be crazy to order a header from RMF now?
- k20 all motor questions
- Skunk2 stage 1 ?
- *****difference between b16 obd0 and obd1 intake manifold*****
- Blox Type A's or CTR's for my mild b18c1 build? want to be able to pass smog here in Cali
- Any B17A build ups and ET out there???
- My Timing is OFF! HELP
- D.A 9 wire harness please help
- any dyno shops in utah?
- Spring Question
- Anyone using Acura RDX injectors? 410cc - $37ea
- DYNO - Velocity Stack vs. Cheap Filter
- omni power laves.....diffrence in high compression and standard?
- 92 Integra GS with Honda B16A motor advice wanted
- Headlight INTAKE SICK!!!!!!!!!!
- ITR vs Blox vs AEBS vs Skunk2 intake manifold
- D series head castings?
- b20b VS b16a TB
- 07 Si header
- best motor for base. opinions please.
- Which cams for daily drive
- obx cams
- O2 Sensor question
- Oil coming out breather
- Best CARB legal 95 gsr header?
- B20/GSR w/ skunk2 pro1 anyone??????
- Timing and emissions help.
- does any of you guys use buddy club 4, 5 or 6 cams?
- Dyno day
- Post Your Race Header (Whatever It Is)
- RUNNING REALLY RICH...... PLEASE GURU'S HELP ME OUT
- decided to go all motor..help
- meth injection and 13:1 compression?
- MY POOR MAN'S TYPE R LET ME KNOW WAT NUMBER U THINK I COULD GET WITH MY SET UP
- K20Z3 cams V. K20R cams.
- need more power any suggestions?
- replacement TPS for TWM ITB's
- Head oil supply in CRVTEC / LSVTEC
- Pro 2s in a B18c5 with PCT pistons?
- Wuts the Best Catch Can??...
- Motor back together, pulls strong as hell Comp test numbers good??
- trust washers
- b18c1 engine ?
- My latest build crx all motor! pics!
- My Civic, Your Comments.
- I decided to go all motor where to start?
- Skunk2 Camshafts problem!!! help
- what color are type R valve spring
- skunk2 pro 2's..............again
- Motor going to the machine shop monday, last minute questions?
- carbon synchros??
- valves????
- Twm itb power loss
- All MOTOR Or BOOST
- GSR mild build up
- how can i tell who made my intake manifold?
- Gearing Question (ATS + 4.7 Final Gear too close for 230-270whp setup) ???
- What kind of spark plugs to purchase for my motor?
- Ls/vtec
- DCRH makes my car run lean??? HELP!!
- Crower3 H22 dyno yesterday
- Got 175whp on the dyno again today. But this time MUSTANG dyno
- running on 3 cylinders
- How can I maximize performance with twm itb's
- poor mans type r
- gas ported pistons for daily driving?
- help: D15B2 block with d16z6 head
- Degree specs for sks1
- Help: clearance issue w/ mugen head gasket
- cable trans question....searched up and down
- Questions that will help the newest newbie ever to step into the scene.
- Will this e bay intake make any power ?
- .need some motor advice...
- How much horsepower and torque should I expect?
- QUICK ?
- Bent Valve, Adjustment, or ? CEL 72 + 74, Misfire. HELP?
- exhaust question
- Oil squirting through top of valve cover
- b16 head on a b18a block
- My new RMF header..***Pictures****
- PCV & IAT lines?
- Camp 1320 H22 Header
- building b20/vtec
- off topic but need help fast. who can do a search on engine vins?
- b18c, my first build
- how much vacuum are you guys getting with skunk2 pro2's
- cam question
- Itg Filters
- wanting to build my first engine
- spark plugs
- dyno question
- Spy shots of a newer K20 sleeve on the market.
- B16A2: Build-Up
- Nice 92mm crank B-series Dynochart - from Endyn small bore setup
- Dyno results
- tryin to make horsepower on a budget (everyones goal)
- CRANK PULLEY FLEW OFF WHILE DRIVING
- possible to use ITR bearing with ls rods?
- Building all motor head
- For Sale 2005 Type-S motor with everthing? $3500
- Thinking of going Ls/V-attack
- problem i noticed this morning....
- JDM B18C w/ CTR Pistons??
- Estimated power and do I have the rigth cams.
- THE REAL WORLD... which is faster?
- 10,000RPM
- can it be done?
- ctr vs itr cams?
- H22 All motor options..?
- help - idle & throttle response issues with 70mm TB
- Video EG H22 stock on street tires 13.6@161km/h
- do you think this is a good setup...
- Pistons...?
- BC specIV vs. Scunk2 stage 2 for B20/GSR?
- The block is built , thanks Redzone Performance!!
- Injectors?
- Symptoms of a defective ECU?
- skunk 2 satge 1 or stage 2 cams???
- 82mm CTR pistons questions
- Valve Choice
- harmonic damper pulley recommendation?
- Dyno prices
- engine temp?????
- New Block...Motor Wont Crank...HELP
- h22a problems
- belt tensioner
- Increasing thermodynamic effiency through piston work
- confirm these are Skunk2 Stage 2 camshafts please
- IPS-K2: 8620 vs. Ductile Iron
- B20 vtec help PLZ
- figuring out what to do to vheaply update my ls motor...
- Racers, post your last ditch, extra HP secrets
- what pistions and cams should i use in my LS vtec
- just another ? about lsvtec
- ls/vtec or Poor Man Type R
- LS VTEC how reliable can be????
- Some Headwork questions i have..
- please help!!! itb install
- i want to build my b18b
- do skunk2 stage 2 cams idle stock?
- Toda Header
- Bigger Throttle Body?
- Would a stock LS/VTEC blow quick?
- Pr3 pistons-b18a block burns oil
- K20A2 CTR build - Suggestions wanted
- B18c1 Idles fine then dies out PLEASE HELP!!
- B17a1 Crank...?
- B18C-R my best et.....what do you think?
- M22 degree?
- adjusting valves after installing cams...
- Fully Built B18C1-How Much HP?-Is This A Good Setup?-What do you think about this Motor Build?
- 5 main gridle
- compression ratio
- Inconel Valves
- Need your opinion on his REAR Intake manifold *SEARCHED* :)
- how to identify skunk2 stage1 cams, NEED HELP!
- Piston/valve clearance, searched, not a noob question (bad anyway)
- ls/vtec setup question
- air-fuel ratio question...
- hyd b16 lsd on a cable ls??
- anyone use this LSD
- F/S 85mm JE Pistons with rings 12,2:1 Comp for B18c blocks
- Ferrea Roller Cams
- Started up my new engine...
- taking the proper measurements. properly.
- Crower recommends turbo cam on NA sohc???
- do i go cams or intakemanifold
- estimted power with this setup?
- What injectors do I need? PLEASE HELP!!!
- Camshaft guide for Oversize valves
- Skunk 2 Throttle Body
- What diameter of Washer used for a Prelude LMA Swap in a B series?
- CTR PISTONS IN B18C1?
- for your viewing pleasure
- itr pistons ls/vtec
- S4C B16 TRANNY ?
- ARP Flywheel Bolts for k series....
- K20R Dyno results
- OBD2A to OBD1 usdm? Ecu Conversion harness?
- (members must read!!)too many non tech threads in the ALL MOTOR forum
- wtb flywheel
- GSR with mods Hondata s200 -p30 map??
- B20vtec w/ Skunk2 Stage1, EST. WHP?!?!?
- Problems/Questions building my engine
- Peak Performance Stage 2 cams. Anybody make power with these cams ??? PLEASE HELP!
- cams for a stock LS
- using a s100 to run individual throttle bodies
- ___question about valve springs___
- OT, but need input for supra motor.
- how do i know what i got pr3 or p30s pistons
- Want to do a swap, any tips if anyone has a clue on the 1981 hatch model!
- seattle shops
- B20 Vtec............
- Can you help me with the compression thanks!
- spoon b16
- I'm curious: What's the most that anyone has bored a B16a with stock sleeves?
- OBD2-OBD1 conversion harness
- Super light Factory Honda pistons
- Rmf k20 header???
- B18C5 or K24 setup.....CHECK THIS OUT
- OBD0 vs. OBD1 B16 distributor?
- How Many miles?? forged pistons
- Upgraded FUel Rail Necessary?
- k20a header dtr
- Fundamental Question - Timing vs. A/F Ratio
- ? On buying ACL bearings for my LSVTEC build
- lsv rod bolts question??
- manley/ferrea valve springs, retainers and valves vs skunk2 ones
- k20Z valvetrain need ideas
- Help...OEM honda piston rings have to much of a gap.
- gB18C1 mild buid, cams and timing settings advice needed.
- compression ratios question, please help
- test pipe or high flow cat???
- N/A D16z6 Motor Build Help Please
- Enough Mods To Need a Tune?
- Wear Caps??
- what motor setup for a 12 ish street tire crx?
- planning a build....what do you think?
- blox cams
- stage 1 camshafts
- Rebuilt motor went bad....
- PR3's vs Forged (11.5:1) Pros and Cons for my setup?
- Would this N/A Setup be worth it? Opinions needed
- Compression question
- ITB's or ITR transmission?
- engine making a funny sound in VTEC
- B18a B18b Rods and crank the same ???
- achol/water injection setup
- Mild buld for my b18c5 skunk2 pro1?
- most horsepower ever made on naturally aspirated LS motor (fully built) ???
- am i getting rip
- retuned my b16a, 257whp
