PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 [171] 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. K series specs
  2. Need imediate help please on H22 Block!!
  3. all motor ls/vtec in 00 coupe
  4. Yup Another CTR LS/Vtec Question
  5. Which header is this ??? (Pic included)
  6. individual throttle bodies
  7. Skunk2 GSR IM?
  8. 230WHP+ guys. What throttle body/Intake manifold combo are you using.
  9. skunk2 stage 2
  10. eagle rods...what size of socket to use for rod bolt??
  11. new build *toys* came in today
  12. B20/VTEC or ITR?
  13. ACL race Vs ACL STD-pics!
  14. dohc header question?
  15. GSR stock Head Gasket thickness?
  16. All motor junkies...I have a vid. All motor LS VTEC accel Vid
  17. Is right my set up for the goal?
  18. Is This Head Fixable?
  19. B20/Vtec reliability questions..
  20. b16b type r pistons in a b16a2 engine
  21. High compression required for aggressive cams?
  22. cam gears
  23. Crank case breathing questions
  24. 2.5 or 3in exhaust.....
  25. Are jdm itr injectors the same as all other b-series injectors(240cc)???????
  26. ITR LMA's and Rocker Arms
  27. All Motor Golden Eagle Block?
  28. Boosted D16 Or Stock LS?
  29. M24E or M24X
  30. H22 scored cylinder?
  31. deckplate/ talldeck motor + using regular header... how to get it to fit (clear oil pan)? :o
  32. gsxr 1000
  33. my dyno graph
  34. OBX valves
  35. Scraper and pan baffle for Honda A20 now available
  36. off your Purchase! at CARTOYS.com
  37. off Fortis Grill Guards! at AutoAnything - ends 2/15
  38. at AutoAnything - ends 2/15
  39. clearnence issue need some good ass help
  40. what is the best ECU for all motor????
  41. dyno of my b16- 178whp, 120ft/lbs
  42. buddy club stage 3's??
  43. Thinking LS/vtec
  44. Crower stage 3 cams....
  45. b16 w/ type r internals?
  46. Cat length?
  47. Cams.....
  48. GSXR 1000 ITB's again. This time a step further.
  49. throttle body help!.
  50. Crower stage 2 vs. 3 on mild/low compression d-series?
  51. oil pump install
  52. crower stage 2 street/race cams
  53. gsr w-type r
  54. Any good motor builders in so cal?
  55. install time/cost
  56. Looking for a ZDYNE tuner. Northeast!
  57. what would new rods do refering to more power?
  58. HeaderTech Header
  59. This is a question for my ALL MOTOR guys!!!!!
  60. Uberdata of an N/A setup?
  61. b16a swap into 91hf crx stuttering at wot???
  62. My first engine build. H1 motor. (fingers crossed)
  63. bottom end suggestions
  64. 180-200ish NA ls/b20?
  65. homemade itb's?
  66. Crower Cam Specs
  67. b20 vtec
  68. itr/gsr crank?
  69. itr/gsr crank??
  70. p30 pistons into gsr
  71. DIY ITB question... I want the FACTS. not here say.
  72. High compresion fuel pressure question?
  73. CBR 954 ITB ON A D16 93 SI dial-up beware just stay away
  74. d series smsp header?
  75. how hard would it be to get 880cc to work on a all motor set up?
  76. Question about intake and exhaust camshafts
  77. what manifold for ITBs on a GSR head
  78. TRANNY GURUS help i wanted to mix gears and had ???S
  79. '96 Spec JDM ITR w/ TWM ITBs Video
  80. Looking for Video of all motor LS/Vtec in milw,WI
  81. allmotor lsvtec?
  82. DC Sport vs. JDM ITR
  83. Dyno'd my GS-R w/Toda A's
  84. Stock fuel injectors and fuel pump with 94 GSR All motor?
  85. Type r connecting rod and GSR??
  86. pr3 pistons??
  87. N/A d16
  88. what do you think what is the maximum power what a b18 type-r engine can make?
  89. what are the biggest, saturated, obd2 clipped injectors?
  90. Are USDM ITR pistons good enough for skunk stage2s?
  91. which TBs for ITBs
  92. need idea ,i just going to get a complete set of F20C S2K (engine , tranny , wiring sets)
  93. how important is a girdle?
  94. what should i do....ls or zc swap for 89 civic si???
  95. what you guys think about a Skunk2 IM for LS motor
  96. flycutting pistons
  97. Good header for 2 liter b16??
  98. just a pix of mugen k20a @ tas 2005
  99. Question concerning valves
  100. How much will stock LS B18B rods take with ARP Rod bolts?
  101. vafc vs vafc2 wiring
  102. Buddy Club Spec III+ Dyno
  103. post your single-cam all motor setup!
  104. stroker kits are they worth it and where do i get it
  105. What Do you think I would run with this setup
  106. question about the spoon stroker kit for b16b
  107. Spoon P28 ECU
  108. what can i expect to run with this setup?
  109. M21 vs. BC 3+
  110. just dynoed b16
  111. A question about manuals
  112. need some help with recent build-up
  113. Serious motor builders look inside!!! cylinder wall scratches.
  114. I need somebody to make a set of ITBs for me (Will pay $200 + Will provide the parts)
  115. LS/VTEC question
  116. Msd 2 step question
  117. Ran my car at the track (k20a2 in Ek)
  118. D16z6 Ecu question
  119. All Motor peeps, Does your catch can return line to Intake manifold......
  120. suggestions about all motor setup?
  121. Anyone using EF-1 Valvesprings and retainers?!@!
  122. ITR (length) rods with LS block/crank
  123. b16 rod bolt queston??
  124. 9.33cc dome + 12.8 lift, clearence issues??
  125. Jun stage 3 cams.....
  126. PICS UP (b18b Head) SS valves, slight port????
  127. cams?
  128. Broken Skunk2 Valve springs?
  129. Motor build up(balancing question)
  130. Anyone used or know of people who used spark racing forged rods?
  131. Mild h22 build need input.
  132. itb question
  133. Wicked stage 2 cams????
  134. ls/vtec compression???
  135. USDM vs. JDM GSR Compression
  136. D series and B series Fuel rail?
  137. Dyno Testing by SRZ Racing! All motor info coming soon!
  138. What kind of intake should i get for my 96 LS integra ???
  139. For those that have had experience: tips on tuning Toda Spec A's
  140. Buddy Club Spec3+ valve lash???
  141. motor parts for sale b d and h series
  142. a good porting company for k series
  143. Need REAL advice on LS/Vtec Build! searched
  144. WHat rods/crankshaft are these??
  145. Use of toluen+gas
  146. flushing tranny question
  147. b18c5+built gsr head:good or bad:
  148. Head Experts Help. Milling Question.
  149. First Gen b16 in a CRX
  150. H22 Injectors
  151. d15b...to buy or not to buy
  152. anyone on here running a mugen head gasket
  153. B-series engine build suggestions???
  154. Best B18C setup on budget?
  155. Look what the JDM Fairy left at my doorstep today!!
  156. Question before my cams go in (h22)
  157. ITR or CTR pistons going into b18b
  158. 2000 $ to spend
  159. Mixing Cams
  160. Finished LS/vtec...CEL/fuel pressure
  161. fuel problem
  162. What is average compression in each cylinder for my this setup?
  163. 250+whp H22 ultimate clutch set ups
  164. 96 civic type r motor or gsr
  165. B16 valvetrain
  166. How many Hp anD TorQue I shOuld ExEpect ...
  167. Port and Polish quick question!
  168. ls/vtec ?
  169. nippon racing pistons??
  170. Next Step??
  171. My ls/vtec project
  172. Injector placement ? for D series ITB set up
  173. Headgasket thickness
  174. Ls/Vtec tuning problem.....
  175. What think about this setup??
  176. b-20 vtec makin power
  177. No Oil Pressure...tried everything! JDM H22A!
  178. fuel ?s on lsvtec
  179. Crower valve train
  180. B18c1 smoking after hitting vtec?
  181. GSR MOTOR SUCKING AIR!
  182. skunk2 valve springs....can you install them upside down????
  183. skunk2 stage 3's with ctr's
  184. Are B20 and LS blocks Identical (besides the bore)
  185. installing pistons, what else should i be replacing?
  186. The ALL-MOTOR Clutch Thread
  187. Crower Stage 1s h22
  188. is my leakdown bad?
  189. Extrude Honing Intake Manifold
  190. low dyno #'s
  191. Port and Polishing kits
  192. DIY H22 954rr ITB progress
  193. H22A1 NA Setup question?
  194. D16A6 and the knock
  195. Have You Thrown a Rod in a B Series Engine?
  196. Type R header on b16
  197. aiming to get 170whp.. what header?
  198. !!!Header Decision, Need Help!!!
  199. Recommendation for Moderate B18C5 Build?
  200. stroked and bored b16 numbers?
  201. need soem help on a intake ???
  202. B20B + PR3 head (B16a) timing belt
  203. Where can i get a kit for my swap?
  204. d15b vtec build..
  205. How do I seal the oil seperator hole on a B18a block?
  206. Do u need Extra fuel when u p&p ur head on a LS??
  207. ls vtec with b16 rods and pistons
  208. header pic request
  209. diy itb's
  210. all motor gsr
  211. b20z block on b16a2 head?
  212. ls/vtec tuning what are my options
  213. Trouble with Skunk2 IM on an LS?
  214. Fuel Tuning Type R SMSP I/H/E Question
  215. Rods
  216. looking for hondata tuners in TX
  217. I want more torque in '99 EX sedan to get off line fully loaded!
  218. Best CR for Buddy Club Spec 3+?
  219. anyone see the jdmshit SS header?
  220. R/s ratio question
  221. the build so far, anything else i should add
  222. ITR Inner Springs vs. Complete Valvetrain
  223. Chipped ECU with ITBS?
  224. what throttle body to go with??? im stumped
  225. idle problem!!!
  226. Buddy Club Racing Spec Computer Software?
  227. MY TURN WHAT NUMBERS SHOULD I GET
  228. OBD0 and ITB's help..
  229. Where did you get you b18c5 swap
  230. crank pulley question?
  231. Dyno comparision: Rocket Motorsports M22 vs Skunk2 Pro 1's
  232. all motor
  233. Vision Header VS JDM DC Header
  234. About to cut my IM for ITB's, have ??
  235. Head Gasket ?
  236. 92mm Crank off-the-shelf street motor buildup ...
  237. KEEP IT NA OR BOOST ???
  238. Best cams for setup
  239. Q on Omniman's 200whp NA B16A2 Build...
  240. OHIO: good dyno tuners??
  241. Highest rev on my car =)
  242. 91mm bore H22
  243. Anyone using Rocket M22s on PCTs???
  244. All B series Main bearing the same?
  245. ??????head swap??????
  246. buddyclub 3+ peaking at 7331 rpm
  247. skunk 2 cams
  248. Cleaning solvent?
  249. whats a good setting for lsvtec
  250. Anyone one on here have a frank motor(ls vtec, b20 vtec)?
