- Who makes the most reliable AFTERMARKET cams?
- what is the best brand for lsd?
- anyone hear of kms-engineering?
- spoon vs skunk2 stage1
- wuts the best place to get.......
- Edelbrock Intake Manifold
- H22 injector size?
- what is engine building
- ZC Performance questions.... ZC pros help me out!
- Toda Vtec killers or EF1 cams???
- Open Deck or Closed Deck Cylinder Block for NA / All Motor , which one is best ?
- port matching IM to head?
- is LSD really worth it for a street/strip daily driver?
- engine bad!! is cylinder head OK??
- more agressive cam w/stock valvetrain
- JUN III's will they wear down my B18C head
- Anyone know how a B17A should run?
- ls vtec head bolts torque specs?
- need help w/ b16a
- all motor ls vs. all motor VTEC
- Does any one got any good vids of all motor street racing?
- ideas?
- Differences between 95GSR head and 1st gen b16 heads??
- piston help please!
- b16a1 question....
- Motor almost broke in quick question before I get it tuned
- fighting for 13's
- milled head
- Dyno tune
- 11.5cr with a 80 direct port shot on 92 octane..?
- whats wrong?
- k20 and k24
- crower stage 2 cams
- Engine Build Constructive Critisism
- My B16 Dyno Numbers
- what is the highest compression ratio that can be run on 93 octan?
- I've seen the light - What it takes to make real NA power
- type s head
- why does all-motor seem faster than forced induction?
- b18c5 block and Gsr head?
- help tuning for itb's....
- B20 Vtec
- Discussion: Dyno A/F vs. Street A/F
- I'm boring out my Ls/VTEC to at least 85mm.
- vtec solenoid
- D16 budget set up
- ITB's for non-vtec??
- What rpm's do b16 cams make power til? Cam questions $
- Where can I get new 75mm (STD) ZC Pistons?
- Zex cams?
- Need ECU Program
- Port/Polishing Intake manifold?
- milling the head - calculations
- D16Z6 Intake manifold on D16Y7
- 230Whp GS-R
- b20z in a crx?
- Thin headgasket plus Skunk2 stage 2 cams question
- any all motor guys in here using the m and h 23 inch slick
- 500 miles on new engine... What oil should I use?
- Best intake manifold??
- vtec wire ????
- V-AFC Gains
- dynoed b20vtec ek...s2s1 cams not cutting it!
- Camshafts
- which A/C bracket for B18C into EK?
- need some advice
- endyn breather kit
- how do I cut b20 valve reliefs???
- semi all motor help needed
- Cam gears on STOCK motor
- Started fabing our new header today
- All Motor : Race fuel and Spark plugs for my engine Recomendations please
- Rev Limit of GSR Valvetrain
- what should i set my setting at until i get my dynoed tuned?
- itb's installation help
- CRX with a B18
- Need help with torque specs.
- H22 Build up
- machine shops in washington?
- Don't get excited yet, but the AEBS intake is installed.
- Which cable transmission is the best to use?
- B20 VTEC leaking oil
- Changed pistons what hp gains should I expect and what compression
- Any downside to mixing/matching cams?
- Turbo KA??
- HONDA/ACURA HORSEPOWER
- B16 head for ls/vtec ported & polished.. take a look
- Calling all Honda tech experts!!!
- V-AFC tuning lag?
- I need video/audio clips of any engine with ITB's
- My All motor GSR, shooting for around 185-205whp (13 sec. 1/4)
- greedy exhaust
- CTR pistons + B18C1 + SK2 Stage 2 cams valve clearance?
- better trap speeds?
- What injectors/fuel pump for a b18c5 with jun 3's
- which distributor with LS/VTEC
- having problems with crower cams
- all motor ls
- anybody need any oem bearings?
- Whats the highest c/r to run safely everyday on pump gas? (93 octane)
- Engine started to knock
- can you hear an NSX vtec crossover?
- CRYOGENIC INTAKE SYSTEM ???
- new aebs intake manifold...any news?
- question on honda f4i cbr itb's
- Fuel Injectors, I need some help...
- Best Big Bore Trottle Body
- New to the NA game and need some help.....
- an-r vs. jdm dc 4-1
- DTR Powered JDM B18C5 wins Sonoma Dyno contest..
- motor build
- ls/vtec rod issues
- what do you think
- tuner for hondata
- ? are integra B18C1 motors internally or externally balanced?
- b16 head vs. b18 head
- Research of my LS/VTEC is done!
- compression
- toda spec b or c's
- Which head is better for b20?
- LS/Vtec owners, what kind of gas mileage do you get?
- B17 and USDM P73 pistons...what C/R should this yield?
- AN-R Question
- whats better longer 5th or different final drive - are they compatible(cable & hydro)?
- how to increase 1.6 to 1.8
- which b16 tranny for all motor
- GSR block better with B18c head or B16 head?
- What should a COMPLETE short block have?
- Dream Setup......Whats yours?????
- JUN 3s with 11.5 pistons
- b20 stock reving capabilites??
- Look what [B]Brown[/B] did for me! :p
- 92 Si stock and cai dyno w/graphs
- Test pipe that will fit on to a jdm header in a EG civic
- ok, new injectors, yes or no?
- Deck Plate or Stock deck???????
- Where In MD can I get a motor sleeved
- What rpm's can a stock b16 bottom end handle?
- non -oem bearings for d16z6
- When Calculating Compression...
- B17 to Type r
- H22A Tech Q - JDM vs. USDM Rod Bearings Differences?
- LS-VTEC Cams
- This is what I had to do on my lunch break...........
- LS/vtec internal choice
- honda prelude si 4ws b21a1 moding
- Crane Stage II LS cams in a non-VTEC B20?
- Anybody with B20 block + C5 head?
- MOTUL oil
- B16B Pistons in B18b
- stroker kits... crower vs golden eagle
- ??Manley valvetrain??
- 2 headgaskets???????
- Another COMTECH header question... but for a B16!!
- Camshaft break in
- honda crate motors
- ITR rods???
- Leaking tranny?! Help !!!
- Is there the slightest difference?
- Info on Best wires and plugs with MSD 6A and Blaster 2
- Whos running the mosted bored out D16 ??????
- Looking for a good intake manifold for low end -mid range power for a b20z.
- H22 swap
- all motor questions...
- b16a head on b18c5 block
- GSR crank/LS block
- need a piston rod combo for a sleeved 2.0 gsr block 84mm
- pistons with raised wrist pins
- fuel pump re-wire
- what cams???
- B16block/LS crank how?
- i have to cylinder heads which one?
- F20c With K20 tranny???? Is this possible????
- Bosch Injectors
- Civic Type R questions
- Will a d16z6 block mount up to a d16y8 transmission?
- ls/vtec Q??
- all motor japan
- hasport mounts?
- 200 whp
- cam help
- he ran 11.5good clutches.......
- Two of the best tools ever made!
- piping diameter match-ups?
- What To Do?. Machine Shops Cant Press Pistons
- 92 non vtec ex intake and throttle body on 92 vx vtec
- Opinion Poll: Bottom end
- OT- "All motor not cutting it?" ad
- MSD Soft Touch Rev Control - part# 8728 - need help installing in LS/Vtec
- WHAT WOULD BE THE BEST INTAKE MANIFOLD FOR ALLMOTOR
- skunk stage2's in b20vtec
- need help with fuel
- thin head gasket..
- next mod for my set up?
- Some crappy pics from NHRA sport compacts in sonoma!
- Tanabe Hyper Medalion
- some pics of the all motor
- The new Dart build. (56k wont cut it)
- Exhaust
- what CR to use for stage2 cams?
- jun short complete engine
- b16 civic tuning book
- B16a2 Setup
- What ECU burn to run
- resizing for arp rod bolts???
- NEW INTAKE MANIFOLD ON MARKET.....AEBS
- My ITR blew up what next?
- jun type 3 cams questions?
- Skunk2 Camshafts I, II, or III
- Hardcore all motor b18c1's hitting what kinda hp/tq ranges?
- Engine builders in Las Vegas
- any good all motor tuners in Tx?????
- D16Y7 Looking for 30-40 whp NA
- looking for a clutch for my setup
- LS/VTEC head gasket, what's the best?
- Probe Rods
- whats my estimated hp and torque.
- Why do I keep spinning rod bearings.....
- lsvtec buildup
- newbie question! re:cam gears
- taking out my A/C
- Flatshift Function
- B18C5 all motor
- 2.0liter all motor packages
- all motor's most wanted?! :)
- Bisimoto Header Dyno
- when replacing synros, do you have to change out gear set as well?
- making power..
- Can we rev past 8400rpm with skunk2 stage 1's?
- K series
- Are there any indicators of authenticity for Skunk Cams?
- Will p30 b16 Pistons hit my LS valves???? Helppppp
- All Motor Basics on a D16Z6
- What Cams Rock The B-seires & Why??
- what fuel pump?
- clearance difference btw JDM itr 4-1 and JDM DC 4-1
- 1.8 to 2.0
- thinking about going to all motor ls/vtec
- Confused Aussie....upping CR on B16A2
- d16 head on d17 block?
- broken timming belt on 87 civic
- Don't Deal with this guy in Fresno!
- B16B specs
- Ideas on why I am running lean right at 7k
- Wiseco ring spacing or honda ring spacing???? QUICK
- How many whp should I expect by the AN-R???
- Converting a LS block to 85mm Bore...
- got some 405 LS non vtec crower cams not sure if i can run them or not, help me
- injector sizing for h22 build up
- 290cc prelude injectors on ls/vtec too much?
