PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 [51] 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. are crower cams & brian crower cams the same or are they different?
  2. Crower Stage 3 GSR stock compression??
  3. what happens if the b20 vtec was revved too high?
  4. Torque Multiplication - The Most Efficient Way To Make More Power
  5. ctr cam ?
  6. Fully built b16b
  7. skunk2 pro2s too big?
  8. used cp piston
  9. B18 Intake Valves
  10. GETTING IT STRAIGHT - Velocity Map of Intake Port
  11. 14 k rev
  12. b20Vtec questions.
  13. h22 msd coil problems i need some help
  14. Alaniz Head work
  15. poor gas mileage
  16. question about b18cR headers.
  17. Headgasket Question ... Whats the difference?
  18. 1.9 LS/V Questions and such
  19. Help w/ header choice.
  20. Bore TB from GSR or LS??
  21. increasing compression by increasing rod length?
  22. rmf drag header vs race which is better?
  23. cam cap bolt torque specs(searched)
  24. B20 Vtec oil catch can
  25. 43mpg...How *Lean* Can You Go???
  26. spoon cam gears
  27. GSR BLOCK LS CRANK what rods?
  28. claying vtec engines
  29. 2.0 LSVTEC N/A NEED HELP!?!
  30. Do AEBS and ARP use the same head stud nuts?
  31. Please!!! Why am I leaning out after 5k RPM?
  32. Should I go 82mm?
  33. b18c soon to be built head
  34. What do I need
  35. cam question
  36. do i need fuel system upgrade to be safe???
  37. will i be safe?
  38. #3 Cyl Hot/ Wierd Engine Problem
  39. wall finish and piston ring gap
  40. what would cause this?
  41. dohc vtec gasket ....
  42. stock JDM B18CR dyno graph
  43. Which ARP headstuds do I need?
  44. Cruising AFRs?
  45. OEM LS-Vtec Engine Question n Opinions
  46. crower cams
  47. Cam too big??
  48. B18c1 issues...
  49. b20 or ls block..ls/vtec
  50. crane cams question
  51. Oil light problem on 2.0 GSR
  52. b16a arp head studs. fit b18c1
  53. Advice on a new Head Gasket
  54. Tuning/modifying F20B question?
  55. ITB V TB
  56. what numbers could i expect
  57. b16a2 n ctr n16 dyno graph. any has them?
  58. Which cams can i use that dont need upgraded springs?
  59. b20vtec questions
  60. valve lash adjustment help.......................
  61. Dynoed 85.5mmx92mm with new Skunk2 Megapower header
  62. 84mm pistons
  63. **Bone Stock h23a 185whp/155wtq**
  64. Not Another Breather Thread!
  65. problems TWM ITB and B18C5 stud bouncing
  66. Where to buy toda replica header?
  67. H22a Cam Questions?
  68. Vtec Lagggsss
  69. just a quick question
  70. b16 crankshaft question...
  71. couple questions
  72. hope someome could help
  73. what should i adjust my cam gears to?
  74. what octane should i run?
  75. Valve Seal
  76. Compression test results JDM B18C
  77. diagnosing engine miss
  78. Disappointing #'s ??
  79. stroker?
  80. WHAT CAMS FOR MY SET UP?
  81. CTR Pistons in B17. Will I run into valve clearance issues??
  82. P73 ecu on gsr
  83. oversized valves
  84. wat motor setup?
  85. ITR dyno #s inside
  86. help identify this header
  87. B16a build questions
  88. wat cams?
  89. Eagle Rods and RS Machine Pistons
  90. Header Dilemma
  91. PM6 running a Z6....?? Searched
  92. identifying spoon cams
  93. Need help with fuel system
  94. TB size help on my build?
  95. K20/K24 13.7:1 ON STOCK SLEEVES
  96. comptec or jdm itr
  97. Help need opinions...
  98. GETTING IT STRAIGHT: Does more overlapp "bleed off" compression
  99. someone please help and give me advice
  100. did leakdown test resulted 5-10% is that bad???
  101. ALL MOTOR 1.8 BUILD, TODA, ALANIZ, RC, ITR... NEED SOME HELP - PLEASE!
  102. OPEN HEADER or Skunk2 exhaust system for B20-VTEC (9.6:1 CR)
  103. B18A/B Q's: Will OEM Retainers work fine with crower valvesprings??
  104. killer cam
  105. 84mm alternative to RS machines...
  106. ATI superdamper question
  107. gsr head b16b block?
  108. Oil Catch
  109. Buddy Club Spec3+
  110. Need help figuring out compression with 84mm RS itr pistons.
  111. JDM b18c stock block w/BC spec IV's
  112. Hey guys, help me out with this H22..pics included
  113. Newb needs help with B18C1 build
  114. Degreeing B-series Camshafts: Manual VTEC engagement (B16A2)
  115. Any off the shelf 3" CAI for B18C CRX available?
  116. '92 Civic Loudness Engine Sputter Problem? - Stock B16A, HELP!
  117. Skunk2 '06+ Si Solid Mount How-To
  118. d16z6 to b16 helpp
  119. newly built ls/v smoking bad please help
  120. Adjusting Cam Timing
  121. ITB's on a DD?
  122. D15Z1 compression ratio increase?
  123. who makes OE cast aluminum pistons?
  124. Hand Radiusing Forged Pistons
  125. White stuff on exhaust valves.. b18c1
  126. Shudder in low rpm?
  127. Help w/ tuning platform!!
  128. Engine Identification
  129. Oil baffle hitting GE main studs????????
  130. Cam Selection, Valve clearance, etc. Help needed
  131. all motor gsr help
  132. what plugs to run on 195whp b20vtec
  133. Braile Battery Install
  134. How much should i mill my p75 head?
  135. Minime Cam Questions?
  136. B18C Type R Cam Choice?
  137. car is making wierd ticking noises
  138. Cat back system R&D
  139. 65mm or 68mm tb?
  140. Whale penis vs aem intake
  141. Compresion ?s
  142. strange VTEC engagement
  143. b20b help? suggestions?
  144. wtf!!! oil light on after rebuilding motor...f@ck b series ahaha jk
  145. #1 inj not firing
  146. skunk2 pro stg 2/3 ?s
  147. Ls build suggestions
  148. Frustrating B18C Build
  149. P30 rings
  150. Vtec Killers Streetable?
  151. 200+ whp b18c
  152. JDM ZC DOHC question.
  153. cam suggestions for my b16
  154. New blox header anybody???
  155. Pro2 cams - valve clearance?
  156. The differences & Nuances between the B18B1 & B18C1 bottom end Engine Blocks
  157. Oil burning question
  158. Advice before tune?
  159. B20 vtec all motor 1/4 et
  160. SMSP header for my set up?
  161. daily driver NA ?
  162. LSVTec build ... cam and valve questions
  163. Cam gear ?
  164. 12.5 to 13:1 comp on 85mm b20b??
  165. y8 lma hitting valve cover
  166. timing belt tensioner troubles
  167. Allmotor GSR build, will it pass smog after the build
  168. will 13in rims fit on my 96 EX coupe?
  169. Who can i get in maryland to tune my all motor lsvtec?
  170. fning code
  171. knife edage crank qustion
  172. GSR Camshafts on b16 head!?!?
  173. d16a6 block issue
  174. d series
  175. Best Place to Get Headwork Done
  176. ls-vtec itr pistons
  177. does anyone know the factory valve specs for the h23?
  178. Buddy Club P1 Valve Qs
  179. My Vtec killer Idle
  180. Pretty trick K-series valve spring changer.
  181. Elusive Idle Problem: Searched
  182. code 92 on d16y7 need help..
  183. Glowing Header
  184. Custom Header
  185. Poor Mans Type-R ; NEED HELP!!
  186. can itr block girdle fit b20b2?
  187. Small chip on RS pistons, still ok??
  188. B16/B18c1 Retainers
  189. Can I hit 210 whp with this valve?
  190. Oil Pressure Issues
  191. stage 3 crower cams all motor
  192. Question on a crank
  193. k20z1 in a dc2
  194. victor x manifold question
  195. What happened to "Import Builders"
  196. MSD system.. Is it worth it?
  197. F20b dyno numbers
  198. GSR crank pulley question, please help me out here.....
  199. is it possible to swap an h22 or k series motor into a 2000 neon
  200. WTB......Type R Cams w/ Camshafts
  201. help with b20z swap
  202. 2.0 LS Vtec build Qs
  203. what does it take to run a P8R head on a b18b1
  204. pm6 pistons in y8
  205. oil question.
  206. Nippon Racing Pistons
  207. 68mm Throttle Body w/ 11.5:1 GSR
  208. b series
  209. micro polish crank?
  210. engine balancing.. just pistons
  211. jdm spoon knock off or 96 ITR header?
  212. Which header for my new build? I'm too picky!
  213. Need imput on dyno results B20vtec with bc4's
  214. NEED HELP! what is my problem?
  215. H22A WHP numbers/questions
  216. What cams are this
  217. Valve adjustments
  218. Mini-Me Cam Timing Help!?!
  219. Valve train problem ......HELP!!!
  220. Update on ENDYN/DHPS Cyl. Heads
  221. Throttle Body recommendations.
  222. Confused.......ECU Limp Mode?.....
  223. ls/vtec leaking out oil
  224. Testing hairline crack in block?
  225. ls vtec help!!!
  226. B16 build advice, ideas for a weekend track car(not street driven)
  227. need serious help wit engine harness
  228. Motor has not run for 2 years. Any tips regarding start up?
  229. Oil pan leak on a new rebuilt b17
  230. Help w/ Breather Kit
  231. Need help building from the pros
  232. bolt on help
  233. 14.5 compression ???s
  234. Need Help Identifying Pro1 cams
  235. Poor mans type R
  236. Bad news need suggestions!!!!
  237. SRR cam gears
  238. Cam seal problem
  239. D15Z1 power options
  240. GSR Build
  241. Skunk2 stage 2 or pro1?
  242. HELP please - built motor problems
  243. Crower 404 on a b20z non-vtec
  244. D16y8 vitara piston help
  245. b16a Vs. H22a
  246. Does a 95 Si engine harness work with a B20vtec
  247. need help. best race setup for b18c5?
  248. B17 Mild Build, Parts Recommendations?? Header and Cams
  249. knife edge?
  250. B18A1 - New Rod Bearings
