PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 [218] 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. 350hp skunk2 Rsx?
  2. problem with ls engine build; valve leak?
  3. anyone have a 4.92 final drive
  4. Technical Terms - Dynamic/static CR - Cranking pressure
  5. is this setup worth it ?
  6. ls/vtec, high comp b18c idle?
  7. Ctr Cams or Skunk2 Stage 1's? which one?
  8. 13.3 @ 104... 12's on street tires?
  9. off topic: got an offer for a sponsor (my first one)
  10. Hondata Intake Manifold Gasket???
  11. bearings needed for full bottom end rebuild???
  12. pistons\rods for all motor+ N20
  13. GSR head in b16a2
  14. (((ALL MOTOR)))
  15. crower cams vs. skunk springs problems???
  16. how much whp would i need to hit mid to low 12's
  17. ctr compression in jdm gsr
  18. b16a1 and b16a2
  19. Spoon 1.8 Kit
  20. Crower Stage II H22 Cams Questions
  21. valves hitting each other???
  22. Lsvtec Oil Squirters?
  23. B18c1 with JDM ITR pistons
  24. head???
  25. Need part N° for CTR pistons & rings 81mm
  26. building up b17a....
  27. HOW CAN I GO FASTER?? HELP!!!
  28. so...FD opinions
  29. best place for arp rod bolts/head studs???
  30. Milling the head or new pistons
  31. EF1 Valvetrain VS. IB Spec Valvetrain
  32. zex camshafts
  33. why do some all motor guys not run an alternator, what are the gains.
  34. clutch for higher power street/strip applications
  35. Clearance Problems??
  36. pistons coated???
  37. Jerky, stagnate acceleration...
  38. d16z6 intake mani vs y8 intake mani?
  39. HOW FAST??
  40. best cams for stock compression
  41. what do u guys think these are my plans Na Gsr
  42. best h22 cams?
  43. Anyone making 200whp with ITR/CTR cams?
  44. dseries message board?
  45. What do you think it will run?
  46. Dyno Test Imagine Engineering Header
  47. Who Has the Fastes ALLMOTOR CAR?
  48. Honda Valvetrain - 101 (i need to take this course!)
  49. upgrade my stock JDM ITR throttle body?
  50. got my ef1 springs today..!
  51. ITR swapped EG with Individual Throttle Bodies and Electromotive Tec3.....Questions
  52. B18C1 or B18a/b or B20b/z? 240+Whp
  53. Loss of oil?
  54. Intake manifold porting...what goes into this process?
  55. Need some opinions....
  56. which intake manifold for my setup?
  57. Are these dyno numbers right?.?.?
  58. clutch?how would know if i need fullface or pucks
  59. Going to get cams
  60. fastest h22 times?
  61. Mugen computer!!
  62. cuttin out guts of dual stage intake manfiold
  63. what times u guys run?
  64. RFD
  65. Street tuning vs dyno? Hondata S100.
  66. My dyno sheet and questions
  67. to shot peen r not
  68. Any interest in D series street build up?
  69. just curious...
  70. partnumbers
  71. How Much doe's a GSR short block cost$$$$
  72. Valve Springs..
  73. My new build!!
  74. NEW GSR build "searchin for 190s"
  75. Post picks of your streetable race car!
  76. intake mani
  77. I need a replacement gasket for a STR 70mm T/B
  78. skunk 2 IM vs. ITR, which one?
  79. motor mount question
  80. NEED GUIDANCE ON BUILDING A B16. insight greatly appreciated
  81. Need to change out piston rings, need help please?
  82. Weight difference between eg ..to ek!!?? 50lbs??
  83. 85mm in b16a2
  84. with 12:1 compression would
  85. a few questions before I install my skunk 2 manifold..
  86. fastest b20 non vtec times!
  87. b20 info
  88. redrilling intake manifold for GSR
  89. windage tray/oil pickup interchangeable?
  90. Repost CTR Head question from TECH Forum. Pls read ------>
  91. b16 clutch Q?searched n non relate to mine
  92. whats the height of a gsr and b16a head
  93. REV Valvetrain
  94. new set upgood or bad?
  95. Sorry for dumb question....Will JG race pipe fit on other brand headers!
  96. how can you identify jun 3 cams??
  97. Who holds the record for highest hp 1.8 ltr?
  98. which oil pump for ls/vtec??
  99. b16 IAC vacume line on 91 Teg?
  100. Lsvtec Wat Ecu?
  101. Post pictures of your ALL MOTOR race car
  102. Stroke kits
  103. header or exhaust
  104. skunk2 stage 2 head work, now no vtec?
  105. ITR springs + retainers into LS/B20 head?
  106. Jg edelbrock B pipe does it hang low?? at a slant??
  107. where do i go from here....
  108. What should my set up im thinking about make?
  109. apexi power FC
  110. making a header
  111. 14.1 & higher compression piston. where can i get them?
  112. will any B-series oil pan work on my B18c1?
  113. i want to build-up my B18c1, any input?
  114. STOCK ITR or JG Edlebrock intake manifold
  115. 85mm sleeved AEBS B18C1 with B16A head
  116. Road racing engine CR question
  117. b20 vtec compression?
  118. Urgent ECU Tuning problem for hi-comp R motor
  119. Lightened Flywheel or NOT
  120. LS/VTEC Compression Question
  121. tranny question again but a bit different..b16 tranny expert ??
  122. All motor LS, intake mani and head help needed!
  123. ef1 m24 cams?
  124. JG elebrock 2 pice header or DC 4to1 2.5 Header
  125. SPOON or TODA CAM Sprockets
  126. need information
  127. how to make engine like new again??
  128. an-r/prospeed
  129. need help car is making a wierd popping noise
  130. Ne one need motor work??
  131. Cooling Question...Mugen Thermostat...etc...??
  132. deck plate
  133. What HP gain when putting CTR pistons in a B18C6 (Euro ITR)
  134. Southeast Hondata Tuners??
  135. ls/vtec help
  136. block girdle
  137. WTB: Royal Purple...
  138. Ls set up.
  139. 12.5:1 je pistons and oversized valves
  140. What grade gas is best to use in 2003 DX Civic Manual Tran.?
  141. tilton clutch??
  142. New Updated Setup for my Hatch
  143. Are GSR rod bolts the same as the ITR rod bolts?
  144. is this a new gsr intake manifold?
  145. arp main bolts
  146. Headwork on B20VTEC
  147. 2.5" Mandrel Bent Exhuast
  148. Header installation question
  149. b20 vtec question
  150. AN-r header distributors..hit me up!
  151. how to remove sprocket on the oil pump?
  152. lsd in ls trannny
  153. GOT JUN STG2 CAMS FOR MY 00SI....what else do i need?
  154. LSVTEC wiring harness
  155. need to know what bearings i need?
  156. big horsepower EW4!!! HELP
  157. Need help with SRS Light
  158. need help with this setup! opinions
  159. Wanna make at least 250 whp all motorstyle
  160. What is the difference int-ext ITR valve springs
  161. Needs some tips for b20a5
  162. AllMotorSOHC.com is back up.
  163. arp head studs necessary??
  164. ls vtec
  165. b16 with all bolt ons and ctr cams what to do or add next?
  166. b20 block help
  167. Probability of an H22 crank and rods in a K20... a few questions for K and H gurus...
  168. breaking in new motor
  169. ported gsr intake manifold
  170. transfer internals from one block to another...
  171. whats the difference between high cat flow and test pipe ?
  172. Alaniz, DPR, Portflow Head Work
  173. what kind of pistons for b20b gsr for all motor
  174. transmission question
  175. anyone have any picks of the AEBS intake mani installed?
  176. Choosing gearing by powerband
  177. IVE SEARCHED
  178. post B18B setups and whp
  179. oil squirters
  180. winter build up
  181. what next for b16a1 w/ few mods on it
  182. Engine builders in southern wisconsin area????
  183. ATTN: ecu guru's...I need your opinion
  184. gsr ecu with skunk2 intake manifold
  185. Throttle body sizing for my B16 setup?
  186. Milling cylinder heads and cam timing??
  187. B20 head ques.
  188. my car runs fine for 10minz.. then runs lean!!
  189. Reuse Stock Rods? Limit to number of times?
  190. what pistons should i use on my set up?
  191. you need porting and polishing
  192. at what point do you have to start upgrading the bottom end?
  193. EnGiNe BuIlDeRs PlEaSe HeLp!!!
  194. V5 Motors
  195. d16z6 IM vs d15b7 IM ??
  196. What valvetrain for this setup??
  197. Where did this car go???(Canadians may know best)
  198. what to expect from a d16z6 in eg hatch, with a stock block and built up head?
  199. PROBLEM!!!
  200. NA Tuning - the right way?
  201. best header for around $600???
  202. Knife Edged Type R crank??
  203. GSR Vtec solenoid Vs. Type-R Vtec solenoid
  204. What intake manifold for sk2s2?
  205. B16 compression buildup
  206. Weird Problem with LS/VTEC setup
  207. anyone....um....shootin' flames ?
  208. starter motor
  209. b20 rod bolts
  210. Exhaust question
  211. Are JDM ITR 4-1 headers really 2.5"???
  212. cost of shot peening???
  213. All Motor B16b 12sec Build Up Process recommendations
  214. timing mark on b16???
  215. knifedgeing ? where can i get it done?
  216. ctr im on to gsr head
  217. Is this setup good enough for 12's
  218. going N/A now
  219. b18c engine build
  220. oil cath question
  221. Suggestions on my setup
  222. Questions about Possible Setup for my b18c1
  223. head gasket Q (kinda searched)
  224. Piston ring life.
  225. crower rod bolts reusable?
  226. forged internals in ls/vtec
  227. Big Props To AEBS Intake Manifold Finally Made 200whp!!
  228. b16 bore to b18 eguals best of both worlds?? read
  229. toda cam gears...work well with skunk2 st 2?
  230. stupid question...
  231. ctr pistons with skunk2 stage2 cams???
  232. code 14,intake air control..??
  233. new skunk stage 1's are in, not impressed yet....?
  234. Importbuilders 2.5" collector Edelbrock header mod - Anyone have part no's, directions or pics....
  235. What do you think of the F20B
  236. Got quoted for port n polish...whatcha think?
  237. Need a baseline to get a motor running Fuel pressure and timing
  238. i am in need of some h22 building experience
  239. which clutch is best for my need?
  240. Can someone tell me the # to TrackMasters ?!?! or the WWW???
  241. H22a buildup questions
  242. help out RLZ
  243. Bay area Guys Check this out
  244. Quick question
  245. built b16 vs. mild lsvtec
  246. ls/vtec setup. why ls rods???
  247. Any negatives to high comp./ dished piston?
  248. LS/VTEC stuff
  249. Quick question: Skunk2 and toda
  250. 2.0L header on a 1.8L
