PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Need piston ring end gap clarity for NA build
  2. B20 - Crack on block
  3. Forged Piston on OEM Ls Rods?
  4. Difference between Ferrea B series rockers??
  5. Not just another LSV post !!
  6. b16a (sir2 version) swap help
  7. engine builders help me out
  8. Need Advice: High Comp B Series idle issue
  9. burning oil after bottoming out
  10. LS VTEC BAD AFR Need Help plssss
  11. A little advice on build please
  12. b18c-R headworks
  13. 2001 CRV - B20B/B16A swapped - Header question
  14. RPM wont go past 3k
  15. Boost with no tune
  16. LS-V(b20v) Build Opinions
  17. BEST MOTOR FOR ALL AROUND...
  18. How do you "store" your engine once it's removed ?
  19. Which Motor Mounts Do I Use?
  20. A mysterious Japanese marking on a USDM B16A head. Is it "Tadashii"?
  21. "GLSR" Build Advice/Opinions/Insight etc.
  22. Tools for port matching
  23. skunk2 tuner stage 3 help
  24. Bad fuel pump or spark plugs? Car wont start. HELP!
  25. Hidden Tech?
  26. Car Problems
  27. Buddyclub IV Upgrade
  28. Is gap same for NGK PFR6G-11 and NGK PFR7G-11 Spark plugs 4 USDM B18c & JDM B18c ITR?
  29. Engine build opinion
  30. d series camshaft help
  31. cams for b18c choice
  32. C27A into Series Landrover
  33. h2b header options
  34. Looking for info on upcoming b16a2 build
  35. Cam Identification
  36. odd smoke issue.
  37. h22 road racing build questions
  38. GSR build. need some advice
  39. First B16 build need advice
  40. Where is this oil coming from in my head
  41. i can not find oversized RRC pistons. please help
  42. d16y8 internals for turbo
  43. H23A blue top + RLZ head dyno (Turbogixxer Tuning)
  44. Build questions, injectors, Hondata s200/p28, B17-High CR
  45. Constant air in coolant...
  46. Car keeps cutting off. Please help me...
  47. Fresh B20V or keep old GSR ?
  48. in need of an 81.25mm piston ring compressor - sleeve style like ARP
  49. Poormans Build
  50. is this normal cylinder wall wear with Supertech pistons?
  51. Pros and cons about rev limit set at 9000-9500
  52. Crower 403 valve lash help
  53. HELP! Removed spark plug and oil drained into engine
  54. B16 not running right! HELP slugish
  55. My stock D16z6 Won't rev past 6,000! HELP!
  56. valve spring recommendation
  57. b16 intake side ticking
  58. Idle Issuses
  59. RENEGADE E85 / NEED ADVICE FOR USERS
  60. LS/VTEC Build (Tech Questions)
  61. what to do with an 96 ls?
  62. b18b N/A
  63. NPR rings 21-GNH08450
  64. Out of the Box Header Design
  65. Wiring Issue
  66. suggestions on my b20vtec build
  67. ectune vs crome
  68. exhaust cone for street exhaust set up?
  69. j32a1 head swap into d16y7 head
  70. Re-ringing pistons w/ ARP rod bolts, remove crank with rods? Resize rods?
  71. f20b with pro1 cams
  72. best place to get cam reground b series
  73. help need info on crv block to gsr head
  74. To port or not to port cylinder head - daily and weekend road race car
  75. f20b cam question
  76. brian crower stage 2 camshaft N/A
  77. best cams for a dd setup
  78. Kaizenspeed Manual tensioner
  79. Spark plug options high compression
  80. Help!
  81. Blox Type C Vtec Engagment
  82. what cams hard for me too tell
  83. b18b1 swap non vtec ecu car stalls
  84. D16z6 all motor! Springs and retainers helpp!!!
  85. bottem end....wha to look out for
  86. stock b18 ls motor with nitrous
  87. Buddy Club stage5 cams
  88. Crower 402 vtec cams
  89. D15B7 good?/
  90. NEED SOME HELP
  91. euro r intake mani or skunk2 on f20b
  92. 95 civic swap not sputters with p75 ecu
  93. Skunk2 Pro Series Stage 2 Cams
  94. S300 p28 ecu set up
  95. Brand new C5 block, fully built head, are Tuner 3s too much?
  96. cam choices for nonvtec (I know, another one)
  97. P73 ecu with obd1 harness
  98. intake pipe shape effect on power
  99. B18C1 with tuner 2 cams, worth installing/getting tuned ?
  100. N/A B20 non-vtec ITB K-Jetronic, yay or nay?
  101. Come-back LSV Build (DDTECH, SKUNK2 or MikeySpec feel free to hop in)
  102. TWM ITB B series I need your help
  103. AP1 F20C Engine Untuned, Tuned, Tuned+V-stack dyno graphs
  104. NEED FRANKENSTEIN ENGINE HELP..!!!!!!!!!
  105. stock b20vtec cams
  106. Need insight on B17 rebuild!
  107. king Main&Rod Bearings?
  108. Periodic flooding - twin carb D15B4
  109. What is the tolerance for differences in piston weight??
  110. 1995 dc2 gsr all motor aiming for 12's
  111. D Series with B series TB
  112. ITR Valve Stem Question
  113. what would you do for the money?
  114. My H22 tune. Comments and suggestions needed.
  115. d16y7 all motor build
  116. 96 integra/1.8 Japan motor/ strange noise
  117. Looking to Identify Valve retainers!
  118. Help! weird valve sound!
  119. car cuts off sometimes NEED HELP!
  120. pistons???
  121. ITB issues
  122. Steel vs titanium retainers, info needed
  123. civic stalls with a p75 ecu
  124. just sharing my new personnal record all motor
  125. itr valve questions
  126. smoke while decelerating valve guides or valve seals?
  127. Help identify cam
  128. D16 Motor Ticking HELP
  129. Which Clevite Bearings for B20 rebuild?
  130. what kinds of damage can be fixed?
  131. Toda Replica Header vs PLM Big Tube Hytech
  132. First time mini me swap
  133. Drag/road coarse b18c1 build advice
  134. eagle or oem gsr rods with forged pistons?
  135. Question about my VT
  136. Stock gsr rebuild: How tight is too tight P2W?
  137. best cams for b20vtec?
  138. ruff idle
  139. All motor na h22 afr problem?
  140. Intake studs.
  141. Flat valves & Thinner HG's a waste ?
  142. gasoline on spark plugs
  143. NA all motor F20B build
  144. buying a honda Question b18a to b18c
  145. b16a, need help ASAP
  146. Can I use a B20 crankshaft in a B18c block.
  147. need help picking exhaust system ?
  148. distributor/timing issue
  149. LS VTEC EK won't start - need help
  150. y8 head on y7 block question
  151. Why b16?
  152. F1 Cylinder Head tech
  153. what should i tell to the machine shop
  154. fully built ls.....smoking
  155. thicker headgasket options
  156. installing new arps/headgasket install leak???
  157. Running Rich, Idle Issues?
  158. Need help with header.
  159. To much vaccum
  160. All motor a little dissapointed
  161. header question?? comptech usa
  162. Porting for Duh-mestic V8's, Just for Mr. Rocket
  163. h23a1 cam journal tolerances, head toast?
  164. Mini me questions
  165. VTec wiring question
  166. Ideal afr for stock b18b1
  167. Crank but no Start b16a
  168. valve cover gasket sealing on built engines
  169. Breather box help prevent oil consumption?
  170. Gonna try this all motor thing one more time...
  171. H23A BLue Top Dyno Cam Thread
  172. All motor h22 build
  173. Help! Back to get reamed out again but I need the help..
  174. b16 replaceing LMA have few questions
  175. Header advice
  176. B18c1 with type r pistons no tune or tune
  177. whats needed to run ITB's
  178. how much whp do you think would this put?
  179. H22 Swap out issues....
  180. b18a1 injector swap
  181. Degree cams with no spec sheet
  182. B18c type r help bard
  183. help finding 84mm b20vtec pistons
  184. best b16a2 rebuilding kit?
  185. HELP>please..notched D16z6 block/small dimple/cracked????
  186. b18c1 all motor build
  187. What size exhaust diameter 2.5 or 3inch??
  188. power band falling too quick
  189. up grade Fuel delivery system???
  190. My 2.0L B18C1 Dyno charts and 1/4 times
  191. 3k on build need t-belt advice
  192. Any reccomended NON-straight-through mufflers besides Flowmaster?
  193. B20b vtec head gasket leaking
  194. Valve springs for itr cams
  195. swap or Boost my 1999 civic si
  196. K20 - JE pistons on stock rods - how stupid?
  197. skunk2 ultra street
  198. d16z6 vitara Ring End gaps. Specs driven Na then turbo????
  199. need advice on how to get my b20b to work in my eg
  200. ~200+whp LSVtec Build From Start to Finish
  201. Why is ATI race damper [b-series] so underdriven?
  202. Oem Replacement Rocker Arms
  203. ITR valve springs question
  204. Seeking general advice to tune up a 2013 Civic. [ALL WELCOME]
  205. B18c Cam specs?
  206. b18 build / poor man type r
  207. supertech vs pro cast wpc treated
  208. Idle problem HELP.
  209. d16z6 rockerarm assembly top thread hole stripped????? instlled wrong length bolt.
  210. Strong d16a6 non vtec on nitrous YouTube vid
  211. Rocket M24xx
  212. B20V Early VTEC/Rev limit
  213. B16A Cylinder 1 Misfire
  214. What cams and gears are these?
  215. All Motor b18c EG
  216. d16z6 putting back rockerarm assembly cam caps silicone????
  217. B20B old or new
  218. Bend spark plugs...?
  219. Is this my engine "missing"?
  220. JDM b16a obd1 won't start???
  221. b18a with pr3 pistons?
  222. DDTech H22 Prototype Camshaft Dyno Testing
  223. P.R.E. Stock sleeve B20VTEC Dyno
  224. Dc2r stock exhaust one em1 performance?
  225. Itbs!!!!!
  226. 1988 JDM b16a rebuild CtR pistons/Skunk2 Tuner2/81.50/82mm?
  227. CAM GEAR ADJUSTMENT HELP!
  228. Opinion on welding a block
  229. B18b1 block P8R head compression specification.
  230. Advice on Valve Selection for JDM B18cR
  231. Valve noise - valve tap or paranoia?
  232. Is this a Record ?? :)
  233. Crane cams failure, anyone else?
  234. Intake manifold air flow too much?!?
  235. d16z6 Help Different rocker-arm/camshaft assemblies/bolts in a different head????
  236. Sticking aftermarket throttle bodies
  237. N/A GSR Ls crank, autox DD time trials
  238. do I need RDX injectors and a Walbro190 with this setup?
  239. need help on what engine
  240. GSR crank damaged, what are my options?
  241. High Coolant Temp+lost Coolant
  242. When a bad rod bearing = a good deal!
  243. will stock ecu run this setup temporarily without permanent problems?
  244. Throttle Cable setup on a 90MM Accufab TB
  245. b20 vtec build need to do research
  246. B20vtec when driving car won't go over 3grand
  247. EXPERIENCED PEOPLE WHO HAVE BEEN AROUND THE BLOCK. HEAD NOISE. WORN GUIDES? HELP!
  248. GSR crank in my B18a1 Help..
  249. Ls/v swap
  250. Good Comp, Good Leakdown, Bad HG?
