- Do I really need new springs for this......?
- which valvesprings will be best...
- Suck me!
- Moroso Breather/Catch Can to Exhaust Like this?
- Good Hondata tuner in western WA Tacoma area
- Which Flywheel for 12:1 c/1 200+ whp gsr??? Exedy or ACT prolite?
- Gude Bullfrog?
- dart block? corella h beam rods?
- any numbers on the buddy club spec 4 head package?
- 13:1 compression......pump gas??
- should I re-tune a/f ratio in this case?
- Do I need anything else
- Resources for EDUCATION on cams: selection, profiles, degreeing, etc.
- quick question about stroke in b18c
- Rehone or .25 over???
- GSR rod bearings on LS rods?
- F23a Block with h22 head?
- wat size injectors should fit my setup???....370cc or 440cc RC Injectors..
- Question regarding RC Injectors......
- JDM B20B with P8R head and 404's: how much to mill?
- Ls/Vtec Pistons and Rods question
- 163whp 122tq all motor b20vtec stock internals
- 2.0 SETUP HELP
- Deshrouded combustion chamber??
- BEST PRICES
- H22 Block with B-series Transmission
- Looking into building my B16 to 2 liters (want to do it right)
- head milling
- Serious header questions.
- b18c1
- Broke a sensor which one is this? (pics inside)
- INJECTOR CLICKING
- Custom H22A crx 4-2-1 hybrid NA header how to...
- LS/Vtec bottom end?
- Assembling an Engine
- just bought sum cams and camshafts do i need to upgrade valvetrain???
- building vs. buying a motor
- cam timing for s2p1????
- Does a Carsound Hi-Flow Cat Dampen Sound AND kill power?
- Velocity Stack Flow Analysis
- Intake manifolds - Design, Aluminum VS CF.. powerwise...
- 01 civic lx cam lobes
- finally posting my numbers and set up
- what size exhuast piping?
- Good speed shop in Delaware area?
- JG Cams Dyno test....
- skunk 2 retainers
- please assist...what are the k20's dimensions (yes i searched)
- compression !!!!
- Need help deciding on short block~!!
- $1000 budget
- b17 GSR camshaft Question
- need some answers on 1.6vtec 1.8 vtec
- Damaged b18c1 Block, mount tore off. Have ??
- what is a good program for my p30???
- Dyno shops in the NW??
- Camshaft Recomendations
- My b18c1 rebuild update! Blox/jdm itr/rocket m22x/buddy club/comptech + more!
- need help picking cam
- GSR Shortblock vs. ITR Shortblock
- quik question
- ITR intake cam / GSR exhaust cam
- will accord 5spd. fit prelude both 89's
- GE LS/VTEC Conv Kit or Cometic Gasket
- B20 Dyno, Mustangdyno feedback please
- Are nippon racing pistons any good?
- B series crank snout diameter?
- Size of injectors for DC5 type R....
- how tell if its a b18c5 haed
- GSR Build
- Dyno- whats it do?
- ls/vtec running ls pistons
- skunk 2 made in taiwan
- ctr or itr pistons
- gsr block w/ b16 head & tranns...good set up?
- whats mods for a completely stock b18b swapped in a civic?
- is this throttle body too big for my car? 73mm tapered to 69mm plate?
- CRV VTEC
- gsr block finally done! tell me what u guys think
- stock gsr to 200whp
- Stroker Crank
- blowing the alt fuse 3 times day...
- what IM for set up?
- type r throttle body
- cam choice jdm b18c
- whats the difference between the 1st gen b16 valves, springs, and retainers compared to the type Rs
- Dead Battery In My Prelude.....WHY?
- low CR (<<12) in b16 - toda B's or C's?
- B20 dyno + pics of ride
- help stock pistons wont work with eagle rods(wrist pins just slide in)
- h22 cams
- K series Rocker Arms in B Series head
- Oil pan and oil suction pipe for Dart B20+ block....
- d-series all motor(d16z6)....need info/advice
- underground racing cams???
- act 6 puck clutch kit or exedy stage 2 clutch kit
- Spoon Internals?
- what can i get for 1500?????
- B20 Vtec head
- All Motor B20
- buildup of a b16
- lsvtec dowel pins
- what size slick??
- Phantom Grip rockers on a daily Driver?
- USDM B18c5 or USDM K20a2, what would you go with??? details inside.
- home made ITB sale price?
- ITR Cam Shafts in b16 Head???
- CAM SEALS HELP!!!
- Budget build (ITR motor)
- How much is too much!
- ls crank in gsr block?
- Sound like a cracked sleeve? Need advice
- sparkplug wires
- springs/retainers
- search buy didnt find anything
- Texas Tuners....
- Need Help LS/Vtec
- LS vtec
- Need help ASAP, Headgasket question.
- whats stock headgasket thickness???? bseries
- P28 ECU Codes
- need itr/gsr/b16 oil pump and water pump
- k20 in 04 civic coupe
- How much can I mill with Skunk2 Stage2's?
- Stock 1.6CTR cams in a 2.2L Block
- Tsudo exhaust for EF hatch
- window woes
- Hybrid Exhaust...
- Dropped Valve,Head Fu?ked....please help!
- anyone have ITBs on northeast coast??
- TODA Injection Kit
- Hondata s100 VS crome
- Running way too Rich ???
- b16a2 help
- total rebuild?
- Can you put a 5.0L motor into a 92-95 eg?
- So now that its all been said and done what cams..
- What are the upper displacement specs for a B16, B18 and B20 block?
- Timing belt for Dart B20+ block...
- just got dynoed today, a little upset...
- DIY Porting Tips - Final Cleaning
- hairline crack on block by oil squirters? has anyone seen this before?
- ITR Header on my B-series Swap?
- The NEW "Steve Taylor where are you" thread
- RM valvetrain install
- post all ur ls/vtec specs
- Do OBD0 and OBD1 map sensors read different voltage?
- b18c1 with skunk 2 IM question with ECU
- Help Identify this B20B with P8R
- b20vtec ITB's or Skunk2 Pro-Series Mani?!?!?
- 85mm high compression pistons
- ITR/GSR rods in LSVTEC, with CTR pistons?
- need help with motor and spark plugs. pistons closing gap on spark plugs
- darton flanged sleeves
- ecu problem
- 85mm b16a2
- all motor question
- Piston choice on a Poor Man's Type R???
- Ls/Vtec High Comp Build up
- what would be my best bet??
- headgasket thickness
- H22a head work
- Question about Tuning motor
- skunk 2 camshaft pro serie 1 where...??
- civic radiator slowly leaking on gsr engine, engine does not have bleed bolt
- help dialing in cam
- ? B20 Vtec build ?
- will this be safe?
- Metal to the pedal..white smoke?!
- regular oil vs. synthetic
- Question: Toda High Power Single Plate Clutch or ANY single plate clutch
- AN-R header for NA H22??>>>>>>>
- NEED advice building b16a head on a gsr block.
- Best bang for the Buck??????
- another sleeved block
- Anyone using Crower 62404-2 Non-VTEC camshafts
- Pics of the new Toda ITB's installed on Ill Will's EG6
- alittle insight on a new brand up and coming.. OBX..
- my an-r header cracked :(
- Oil Pump Instructions
- V-AFC Controller Hard wire hook up ?
- ITR HELP
- LS/vtec question.......head gasket and block and head prep????
- DIY intake mainfoild??????
- help need ctr piston rings and locks
- ls vtec build
- Are these cams okay for my build?
- Help choosing rods
- Think i just blew my tranny...
- Anybody got complete engine (B16/B18) swap up for sale for a Del Sol?
- Greddy Injectors - 720cc
- ITR cams in ls???
- Cams help!!
- Dyno Results.....Built B16 Help!!!
- b series code book help???
- ITR intake cam only...?
- Land and sea dynos
- WUT TO DO NEXT? TO MANY CHOICES..
- quick question p28 knocksensor
- CTR piston question
- What exhaust set ups are you EG b18c1 folks using?
- power output of the ITR
- lookin for a LS block sleeved 84.5 or 85 bore
- need help kina confused?
- High Compression and Gas Mileage
- question about vtec engagement
- My GSR build up
- B18 series questions need help
- Getting started on my gsr, please give me some input.
- Adding a few parts to my GSR...Few Questions
- what pistons are best for LSVTEC
- CDR'S OR IDR'S???
- question about ITR cam
- Anyone have a decent AEM base map for the following? PLEASE!!!
- b20 83 mm pistons
- gsr w/lsd or b16 w/lsd
- guage
- D15B2?
- Sleeved Block
- Rebuilding Engine.....Few Questions
- Mystery Power Loss
- Temp. guage problem Help!!!
- WANT ALL MOTOR POWER: I T B 'S or standard plenum manifold!!!
- Idle Air Control Wiring in H22 EK civic
- how can i de-restrict my 1985 honda sh50 city express? anyone?
- OBX Intake manifold for b series? is it any good (SEARCHED)
- Help me decide: M22x or M22xx Cams
- which cams are better
- which headhasket?
- Question Mugen vs Spoon (b18c5)
- engine management for new setup
- h22a with jun3's...any dyno's?
- Mild build b16 200+hp how reliable is this as a dailydriven car?
- yo anyone here know eugene?????
- Compression experts: how much to mill b16?
- BC3+ cams
- WTF: are these skunk2 cams?
- all motor gsr 13:1 comp on pump gas ?possible?
- need ny builders!!!!
- looking for more horsepower, not just another add on
- b20vtec parts list
- buddy club spec v
- Cam timing for all motor build
- 237whp dyno chart posted 92 octane, Full exhaust, AC, custom sheet intake manifold
- why do you need to connect an oil line when building an lsvtec?
- what would my compression be???
- ALLMOTOR B18b Build
- most aggressive cams with stock b18c
- 0 deck
