PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 [121] 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. what does it mean to blueprint the block?
  2. stock-looking fuel pressure regulator
  3. quick question
  4. rocket h24 cams , anyone runnign them yet ?
  5. Type R Vs Type S??? Which is better??
  6. ISKY VALVE SPRINGS or STILL TODA ??
  7. b20 vtec catch can
  8. pistons reusable????
  9. rod clearence
  10. REMOVINGS SLEEVEs
  11. most hp on n/a k series
  12. For the B20Vtec builders
  13. Deck/Block Height B16a
  14. Kseries
  15. degreeing bc3+ in ls/vtec
  16. Changed some mods, still need a RE-TUNE???
  17. which is better??
  18. b20vtec compression
  19. Recommened intake
  20. whats cams to get for my gsr?
  21. Using Skunk 2 stg. 1 cams or CTR intake cam on a bone stock B18C1.........wat can I expect from it??
  22. I know how much you hate these but.......help!
  23. f18 minime? searched!
  24. BLOX Manifold Now FLAT SPOT
  25. why are honda v-tecs so good?
  26. Tuning Questiong... Timing Related.
  27. pacific raceways video's(black elesvtec in action)
  28. toluene or not
  29. b16 block threw a rod need opinion
  30. where to buy rings?
  31. Its amazing how irritating one additional letter can do
  32. B16A2 w/ PCT pistons: To flycut valve relief or not?
  33. ?valvesprings not what you think
  34. Very dissappointing intial dyno nos from jun 3
  35. All motor fuel upgrades?
  36. which would be a better ecu too use when using hondata s300
  37. steel head gasket for d16a6
  38. Is this a bad rod bearing?
  39. looking for bay area tuners
  40. Built Turbo Motor w/o Turbo....going to hit the dyno for the hell of it.
  41. cams in a gsr
  42. B16b Built
  43. B20VTEC Cam selection and Valve Clearance.
  44. 100 oct pump gas K24... how much comp?
  45. b16a pistons
  46. head bolts
  47. rage vs. ANR header?
  48. STOCK LS rods for 230 whp B20-VTEC: Are they strong enough?
  49. Wanna build a All Motor Monster.Please Help
  50. anyone run itb's on crome?
  51. ITB's....
  52. Which spark plug gap setting?
  53. header questions....
  54. hasport stiffness
  55. DSM injectors in a 2000 civic Si
  56. thinner headgasket ( 2 layer)
  57. skunk 2 intake manifold
  58. BC4's and CTR's in lsvtec....help.
  59. Building a B20 motor
  60. peak cams????
  61. some questions on 2L engine...
  62. Is this safE?
  63. piston to vavle clearance with ctr cams
  64. Few basic questions
  65. Crome tuners...
  66. real rmf headers
  67. Dyno Tuning - B17 heads and cams
  68. CTR pistons , rods...
  69. Buddy Club IV - retainers?
  70. 98+ JDM ITR 4.7 FD tranny VS USDM ITR 4.4 FD tranny
  71. low numbers compression test!!!
  72. What tranny for my future plans? help me decide
  73. h22 intake mani
  74. what are the practical limits of a b18c1
  75. quick spring retainer install question. for all you mad mechanics
  76. Question about my stock valve train VS crower stuff
  77. Looking for more HP on my Motor
  78. Balancer shaft belt hp gain?
  79. b18b intake manifold
  80. "All motor" question.
  81. 2liter LS/VTEC
  82. WITCH WATER PUMP FOR A B20/VTEC??? 22T OR 19T
  83. best motor build? want a 10-12 sec car..
  84. skunk pro 1s..does this sound rite?
  85. what kind of gain is expected, if i change CTR piston in USDM ITR B18C5?
  86. vtec crossover hel please!!
  87. Just did a compression test
  88. trying to contact kenji
  89. Those of you guys with RM cams. How do you like it? yay? neh?
  90. please i need help
  91. Endyn style catchcan, where to find?
  92. B18B vs B18A
  93. Compression #1 125 PSI, #2 190, #3 125, #4 150
  94. where the heck does this wire go?
  95. H22 Probs now i need New cams and would like some suggestions
  96. Need help/opinions with B18C1 build
  97. Do you guys think this is a good set up ?
  98. Headlight intake setups.....
  99. Where is the ITR PCT P30 piston thread
  100. Skunk2 PRO-2 dyno anybody???
  101. B18C MISFIRE
  102. 1999 Honda Civic SI B18C5 ITR Engine CTR Pistons & BC4 Cams
  103. LS/VTEC Vtec engages 2 times but then stops
  104. Race tranny
  105. best d16 build
  106. searched: V2V clearance
  107. B17 with P30's
  108. Codes P0171/P0170 Sys Too Rich(Bank1)
  109. What kind of gains can we expect from a header change -
  110. my pro1 dyno
  111. valve/piston clearence question
  112. ***update my buit update***
  113. need a b20 vtec tuner in Orange county , CA
  114. is this a jerry built?
  115. Wondering what parts i need to replace when doing a build on a gsr?
  116. Pistons for a B16a2 block w/GSR head?
  117. ls/vtec .. help! thanks
  118. f23 cam?
  119. what piston is this?!?!?!? help ASAP!!
  120. Power Rev All Motor EF (P2R) Pics & Setup... B Series
  121. gsr ?
  122. What should be my next step?
  123. Which causes detonation more, dynamic or static compression?
  124. H22 build. Question with NA tuning theory & where to do research.
  125. ignition timing with crome?
  126. a question for b20b/b20z
  127. Head studs..!!! NEED help
  128. b20z and b20b
  129. Calico CT-1 bearing coating; does it work, and does anyone use it?
  130. Mild GSR, BPI flow stack with filter on, back to back dyno
  131. Dynoed : 100% Stock Shortblock ITR + skunk pro 2 = 261 hp (230whp)
  132. need help
  133. Spoon N1
  134. Overheating
  135. new dyno results
  136. ITR exhaust on em1?
  137. Just got tuned...
  138. ITR tb too big for b16?
  139. CTR or ITR
  140. STR intake manifold. Is any 1 using in n/a B?
  141. 5zgen header
  142. No Vtec
  143. Lost Motion?
  144. p30's work w/ GSR rods??
  145. ITB Story: d16z9 172Hp@Crank
  146. after dyno tuning.. how much ore whp am i expecting to get?
  147. Cams and turners
  148. please point me towards the right direction..
  149. couple lsvtec questions.
  150. K20
  151. skunk2pro1
  152. can anyone explain how Endyn stuff works so well?
  153. Best tranny for me!
  154. bc4 vs m22x?
  155. My Dyno VIDEOS, 2.0L 249whp 171wtp, NOT FINISHED TUNING!!!
  156. Question itb lovers
  157. d15 build
  158. best aftermarket cams on stock valvetrain
  159. Skunk 2 Pro 1 cams ??????????????
  160. question about b-series rods and b20vtec
  161. Prothane motor mount inserts
  162. Clutch/Flywheel Question...Need Help!
  163. what tool do you guys use to take the main cap bolts off?
  164. ctr pistons w/ gsr rods?
  165. All motor mid range punch for B18cR. Suggestions ?
  166. learning how to dyno tune
  167. problem with dx to d16 swap wiring
  168. CAI humming noise
  169. How much is my head milled?!?
  170. crower cams sugestions for B18c
  171. itr intake vavler springs over gsr intake springs?
  172. Aftermarket Intake for F22B1 - VTEC
  173. my civic 87 ls/vtec all motor
  174. Explanation of VTC
  175. I'm completly stumped..
  176. Qestion TODA Spec B cams vtec crossover point
  177. Ls/vtec bogging
  178. 2.25" vs. 2.5" on a 97 accord LX
  179. d16a6 block, z6 head, d16a1 pistons and rods - Clearance?
  180. First gen b16a
  181. b16a pistons in my b18b (yup, i have searched!!!)
  182. cams for 1st gen b16
  183. PIcked up a stock LS Block that says PR4 .8??
  184. Frank Motor Build
  185. JDM B16A
  186. ls/vtec all motor.
  187. b16a with itr cams
  188. 93 ls b18a1 obd1 injectors w/ 95 gsr wiring. do you need a resistor box?
  189. my engine build - advice etc.
  190. mint gsr 50mm twm itbs 1150$ toda d's 1000$
  191. gsr vs prelude
  192. question= what offset piston rings
  193. quick question
  194. vtec clicks in?
  195. Part 3 - ranta18's H22 All-Motor Build
  196. No VTEC engagement
  197. CTR intake cam on stock B18C1...is it possible to use?????
  198. Need expert opinion
  199. Quest for ??? Magazine's Dyno of the J's/Password Intake...
  200. ls/vtec obd1..what factory ecu and injectors?
  201. HELP!! Car won't start after having pumped FULL TANK!!
  202. valve to piston clearance ( CTR piston + M22xx)
  203. best headers for a b18c5 in a EK hatch
  204. single layer hg and sk2s2 cams...will i touch
  205. Cam install ?.. head not on block
  206. modify header
  207. noob question about motor???
  208. Crower Stage 1's Low Idle - Car Stalls
  209. unusually low idle vacuum readings with pro1 cams
  210. Bolt on turn down exhaust for a Civic with a b series
  211. fuel pressure regulator question.
  212. Idling Buddy Club Spec IV?
  213. Anyone ever hear of these cams?
  214. Is the ES Tuning Muffler any good??? Does anyone have one or know how it sounds?
  215. Buddy Club spec 4 cam verification? Just want to be sure...
  216. HOW WELL DO B20B OIL PUMPS WORK WITH VTEC???
  217. ...reving skunk2 pro1 cams...
  218. Valve Guides
  219. itr swaped hatch isnt fast?????????
  220. Skunk2 Pro 1's or Skunk 2 Stage 2's???
  221. ls/vtec or gsr motor
  222. b-16-into 92 integra /turns on. but turns off. ????????????????
  223. ALL motor Type R in a del sol Vs tuned SRT4
  224. 11.5 c/r w/87 gas possible?
  225. Couple questions in regaurds to my build
  226. need help
  227. Need new valves
  228. Skunk2 pro2 cams won't idle! any suggestions?
  229. Which spark plugs?
  230. Tune the stock ecu or buy a chipped ecu from ebay? please help
  231. Anyone heard of JG Sleeves?
  232. which is a better program to run
  233. what header will you reccommend?
  234. B16a cams
  235. what fuel rail/ regulator for n/a motor?
  236. Will I hit 200whp+??
  237. any dynos with an exahust DUMP? how well would this work?
  238. 15x6.5 or 15x7
  239. quick: which VTEC cams are these????
  240. build non-b20
  241. best nonvtec intake manifold?
  242. ctr pistons in a b18a?
  243. 94 hatch b16 cv axles??????
  244. B16A1 FOR SALE 1200 O.BO
  245. All Motor RSX-S with $6000 Budget or Stock Block RSX-S on 10Lbs of Boost Daily Driven?
  246. Another Honda-Tech Meet????
  247. Weight reduction for Pro/Am All Motor Question...
  248. Toothless timing belt!
  249. ? 0-60 compare with gsr, si and ex
  250. Cams for B16a
