- Guess at whp???
- K
- Buddy Club or Omni Power Drivetrain components?
- k20a2 i/h/e k-pro vs built b18c
- bisimoto street or Toda header?
- Sputtering??????????help please
- my b20 is overheating!!!! pleez help
- Cam timing question
- N/A D16Z6 ??????
- should i advance my timing on the d16z6
- NON-VTEC cams into PR3 head, WTF?? (Rusty Shackleferd's build)
- B20 experts...need some advice
- Which gaskets do I need???? Putting pistons in my b16...
- turbonater
- Red Line Fuel Injector Cleaner
- intake manifold and throttle body question!!!!
- Examine this dyno chart please!!! chart is breaking up
- ctr pistons in b16a worth the money??(already did tons of searches)
- Are 310 injectors too small for this 2.0L, ported head, 12.5+ compression??
- B20 Track Motor
- will my stock 95 gsr injectors support 200whp?
- ls vtec or b20
- Rod bolts and bearings
- help me build my block...b18b block and ls crank!!! planning on ls vtec
- H22 Civic ECU Reseting Problems
- 200WHP Dyno- Stock Block GSR
- which IM and TB to use?
- My All Motor Dyno (a little angry)
- JDM copy header test---
- $1200 to put into a b16.
- NEED HELP---> *CODE 45*
- rebuilt..... how do i know?
- H22 Type-S camshafts specs
- Potential of a K24?
- 4.3L vtec 6 cyl
- do i really need to get rods shot peened?
- b20 crank or gsr crank on my b20vtec???
- Is the RSX Type S Toda Engine kit anygood?
- BC spec 4 -VS- BC spec 3+
- H22 ITB Favor....
- H22a zero balance??????
- ***GSR tranny???? HELP PLEASE ****
- Problem at 7K RPM's
- engine plans
- best vtec
- Need help making a decision
- Are BC4's to much for 11.5 compression???
- question about my all motor set up
- Do you think its worth the time and money to work with a D16Y7 engine?
- a/f ratio from tailpipe vs a/f ratio before the cat.
- RM H22 vs. JUN H22 Cams
- argh, b16 timing belt troubles
- Useful Camshaft info for everybody
- ******* calling all header building experts!!!
- Elevation
- need help
- My car keeps dying/studdering!!!
- how much should a shop charge to put together an lsvtec
- ITR IM on GSR Head..did seach..needs to be cleared up(fixed title)
- A lsvtec question
- QUESTION ON MY SET UP????
- Which cam makes more power Ctr or Skunk2 stage 1
- Ignition Recomendations...?
- worth it to sell an-r??
- NA JDM B20B CRX...what cams??
- "PINING VTEC", any info???
- to total seal or no tatal seal
- what i need for a reliable 250whp out of my b18c1
- which ecu is better?
- high compression pistons???
- toda d's
- itb question
- 12:1 CR build questions
- looking to buy b20 block or swap asap help!!!!!
- Do i need to upgrade my stock Rods?
- itr head on b20 block.
- Injector balancing/cleaning?
- Seattle area all motor street cars>>odd request.
- Low Oil Light on???
- ctr cams or bc spec 3 + on b16a2 engine????
- SI Head on GSR block, did a search need clearing up
- Need engine rebuilder in San Diego area
- new h22 dyno
- LS block-b16 internals...
- jdm p30 pistons, need help.
- motorcycle itb sizes
- Teaser Pics; Homemade ITB's. Gixxer 1000's to meet B18C-R SOON !!
- Mayo under oil cap...!
- Air Filters for ITB's ?
- B21A1 Cylinder Honing
- the sense of rising panic- 13:1 on a stock b20 bottom end.
- CTR Cam Power Gains
- m24 cams
- Who's got Dyno #'s for the BLOX/WICKED Tuner Type-B/Stage-2 Cams??? Happy or Not Let's Hear It
- SMSP prototype header install
- tranny s1 ? lsd? syncros?
- why does my car run too rich?
- what cam to choose?
- I need to get my block resleeved. where?
- h22 clearance?
- Power gains from Mugen N1 ECU for B16b
- Who to go to for custom ECU work??
- does f20b have balance shafts???
- AN-R H22a header -- Typical gains????
- ls/vtec question
- TODA ?'s
- rc 310s big enough for m24 2.0l 13.1 cr ???
- NGK spark plugs and msd ignition
- what are are the best bolt ons and cam for a d16z6 build
- header test with vid
- anyone heard of Safety Head gaskets?
- B16b and spoon stroker
- H22a in a del sol....were to begin?
- crane cam stage 3
- Type S pistons
- rocket m24x specs (h22)
- which arp head stud to get with obd-1 b16 head with obd-2 b18b1 (ls vtec)?
- *PICS* which arp head studs is this
- ctr pistons and thicker head gasket..
- Turbokit for a 97 honda accord
- Couple questions about the K24a1?
- ctr 4-2-1 vs dc 4-2-1 header
- 219hp 139trq 1.8
- my partial dyno
- next step in building a true jdm civic
- ARP head studs LS
- crvtec not making any power after vtec??
- which engine is better?
- k20a2 crank in a k20a3?
- h23 rods
- First time at the Dyno with the car (baseline no tuning done)
- My first dyno Check it out!
- prelude vs civic???
- B16 head lower compression on b18c block? How much to mill head? HELP!!!
- Best b-series *TOP END POWER* CAMS ?
- ITBs + winter (10-40 degrees F)
- How much Tuning helps on all motor?
- Vtec looses power.
- HP vs. Torque
- how many ls/vtecs with ctr pistons?
- what motor to put in my crx ?
- Finally dynoed my build!! (w/ new Profab header)
- Zdyne ecu in my DA, anyone have any pre programmed setups for obd2 b18b?
- k20 or h22
- what you think of my setup????
- Compression!
- ls rev limit
- ls/vtec PCV system????
- spoon sports venturi plate worth the money or not?
- what is this? under the throttle body? victor x install!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!
- I searched, no luck. Quick question? What size rod bolts on a b16a2 8mm or 9MM?
- AEM EMS Vs Hondata s200
- What else do I need..........?
- crx with ls swap vs. 95 civic coupe with gsr swap
- Low or Part Throttle tuning
- B20VTEC over 200whp
- Intake Manifold/TB combo for ITR...Is 70mm too big???? chicago burbs
- 91 octance or 100
- bypassing VAFC
- what do you guys recommend?? please help
- just got a gsr block wat do i need to complete it?
- cranks the same (journals)?
- what to do for motor swap
- n/a b16 dyno numbers
- Where to buy AN-R Header. Or similar. B Series.
- SNOFLAKE....DYNO TUNEEEEEE
- dyno #s from today
- who here makes ITBS?? either diy or other
- d16z6 cam question??
- A basic guide to uberdata / crome / tuning in general.
- Advice for an Engine swap for my civic
- B20B VTEC build - Parts question
- NEED HELP PLEASE !!!!!!!!!!!!!!!!!!!!!!
- Rocket Motorsport Vs. Toda Vtec Killer Cams
- ebay ctr cams real or not ?
- INFO ABOUT TURBO ON B16A2
- where can I get assembly lube from to install cams
- aem cold air vs aem v2 cold air vw injen cold air. 03 accord
- B16 challenge
- B20z w/ torque chamber?
- Fixing timing belt
- Engine Building Guide
- Are these obd1 prelude injectors? how do I tell
- Difference between jdm S1 tranny and USDM S1 tranny?
- Oil Filters
- Some all motor hatches
- CTR cams need sum info
- anyone just drop in Skunk2 Stage1 cams and didn't tune??? for b18c1
- Ls/vtec buildup parts list
- do i need arp rod bolts
- question about CP pistons
- will these rings fit?
- b16 long block
- Skunk 2 stage II cams
- d16 non vtec build up
- compression issues...
- ARP rod bolt install. Re-size or use heat?
- running s2s1 in my car
- ls ITB
- car wont rev over 6800
- Skunk2 Debacle
- all motor set up on 99gsr questions
- D16Z6 Build up comments please
- Differences between VTi, VTi-R and VTi-S. (Newbie Question)
- TRANNYS
- DC JDM 4-1 header vs. JDM ITR 4-1
- **** your input about titanium retainers ****
- HONDATA OR EMANAGE
- Benefits...?
- Best Header?
- RM vs. skunk2 valve springs & retainers
- LS/Vtec VS H22a
- how much do i torque down my flywheel and clutch?
- Intake Manifold
- Which tranny?
- why doesn't anyone make a flat top high compression (12.5:1+) piston?
- Opinion needed, JG or Skunk2
- Skunk 2 Stage 2
- can i ask a couple noob questions?
- Is it worth it to change my intake manifold?
- Catch can and breather box behind block.
- TODA C Vs. Skunk Stage 2 & 3 cams
- B16A2 Compression Check Results
- an-r header fitment..b16
- "Type R" Oil Pump?
- what lsvtec block girdle on setup????
- Do I need injectors?
- bent valves, changing a few things... need opinions
- f20b so heres my plan
- Any clue what header this is???
- Your opinion on Dh-Racing.
- GSR or LS Rods?
- Question on Rear difusers.
- Remote mounted FITV?
- Headwork for h22...
- Question: What B20b motor mounts to use?!?!?!
- 2g's and a gsr longblock..... what would you do.
- ls block with 0.40 over itr pistons
- buddyclub 4's
- WHy should i CHange my Bearings when rebuilding my motor?!?@!
- Spoon/Mugen Head Gaskets and JDM ITR 11.1:1
- Piston to deck height/Ls block with GSR crank and rods.
- LS/VTEC: GSR, B16, or LS Bearings?
- H22 Cam question!
- piston for b20b?
- calling everying that has a z10 block girdle. are the dowel really nessary???
- street imports itr replica?
- need a header...
- Best cams for my setup??????
