- Cams for N/A b18a w/ pct pistons
- Sparks out of the Exhaust?
- TUNING ? FOR YOU LS/VTEC GUYS....
- OEM B SERIES HEADGASKET SIZE?
- K20 Power
- hey guys i need some help asap???
- cam questions
- head port mapping ?
- Time to hit the dyno
- Tune before break in? on my fully built b16?
- Buddy Club IV / Skunk2 stage 2 - who copied whom?
- DonF where are you ?
- questions about k20a2 valvetrain
- 86 accord with carb
- B20 bolt ons
- Need Help about cams for b20 vtec
- 200 Hp with stock B16 cams!!!...???
- Bosch LSU-4.2 wideband life span?
- HELP Can My block still get an Align Bore?
- Using 1 layer from OEM 3 layer replacement Head Gasket
- H2B or All motor B18c
- Fuel cuttoff at 3500rpm and no power at all before hitting that!!!
- problems with tps sensor fitting
- sohc builds
- S200 vs. S300
- anyone familiar?
- Domestic gearheads chime in! SBC Build help!
- All Motor Head Build Up... Advice?
- Buddy Club Spec II over the Tanabe Hyper?
- B18C worth $$$ over B16 in EG?
- Looking to build a J30A for an airplane
- toda valvetrain on b18c5??
- Crome K-series???
- RM Valvetrain what cams?
- HELP compression TOO MUCH????
- difference between ITR and Skunk 2 Intake Manifold
- Can you tell me what year my b16 cylinder head blcok was manufactured from these pics?
- crower 405 non vtec sound clip or video?
- Whoes the best head porter in the U.S.A??
- Max Rpm with b20 Frank
- jdm gsr build
- Newb, With A Mechanic Question Or Two...
- why not to use stock valves agressive cams...
- Type -r throttle body
- ls/vtec build knock sensor needed or not?
- 95 civicv/ b16a fully built..surging idle problems
- f22b1 injectors
- built b16a head on stock b16a bottom end...
- ESP's 4-2-1 H22A Header
- breaking in motor
- question stock block b20vtec
- what header should i use on my d16
- dart block
- b20/LS eagle RODS difference Q
- wtb itb's for b16
- b20v Bearings require??
- H22 cam delema
- hondata s200 tuning question?
- ACL race rod main and thrust bearings or OEM
- Element problem..HELP anyone
- Skunk2 cam or zex 59300 for d16z6
- B18 powered EK, what test pipe to use?
- h22 sputtering at 3k...need help!!!!! already searched
- anyone have any experience with blox type c and blox type hsl
- Low compression piston NA set-up?
- Quic question about revving with CTR cams
- Blown motor...rebuild or buy new??
- Finishing up b18c1 rebuild, what option should i take for tuning?
- Midwest Motorsports Intake Mani
- Power/longevity RE: P-H clearance
- Piston acceleration and flow.
- Connecting rod Q!!!
- determining cr help
- Where to buy side exit header|b series ??
- ls/vtec
- Anyone have a set of skunk2 stage 2 cams that would MIC the lobe sizes?
- to itb??? or not to itb....thats the question
- Clutch Disk Issues? BB6 Prelude
- How far should i drive to get tunned?
- Help to pick up cam-shafts for TWM ITBs with my specs...
- post your poor mans type r build, and comments here
- ITB's??
- hey im trying to put GSR pistons on to ls rods. will the LS wrist pins work for the application
- b16 intake manifold on a single cam
- LSV/b20v Conversion kit
- difference in power from 2.25 to 2.5 piping? [searched]
- Typical Settings on a fuel pressure regulator!!
- GSR / ITR Bearing QuĦestion
- Hondata S300 MSD Pro Billet Distributor : Question
- Headgasket one layer question
- P30 vs P72??? does anyone really know?
- All motor b20 vtec
- JG edelbrock header w/ b-piping...info on header/b-piping??
- My JDM ITR lost Power and its my fault
- Purchase pistons or bore the block first?
- more power
- how to: V2V and P2V
- Quick flywheel question (searched)
- lsvtec Q - anyone running crower stage 2's with stock bottom end?
- 00 b16a Question Help please ASAP
- B18C1 built up question
- Valvetrain Question
- b16 or GSR tranny on a obd1 GSR motor?
- Edelbrock Performer X For B-Series
- Needs b16 head, check out parts for trade
- JE or Wiseco???
- ~~buildin b20v Q!!!!!
- LS vtec Question
- engine problem
- GSR tranny problem. Got no responses in other forums.
- Which B series header should I buy? Help, input needed!!!
- b20vtec rod selection
- H23vtec R/S ratio
- JDM B16A w/ TODA Spec-A cams and bolt-on parts (Dyno inside)
- ls/vtec dowel pin locations (SEARCHED)
- mulitple injector sizes?????
- TWM users
- ARP Headstud Question!!
- should i wait for cams to tune?
- what should i replace b18c head, block? v seals piston rings?
- seat brackets?
- Official All Motor B20/Vtec Thread
- Cam Spec's Skunk2 and Others Degree
- DC5 Type R muffler on a Civic EK model...
- Seeking bottom end b18c5 build wisdom/advice
- mugen exhaust?
- Oil Leaking from Speed Sensor??
- Skunk 2 Pro 2 + LS Vtec
- B18c1 200whp goal...
- Cam timing vs Crank timing
- obd1 h22 tb on a gsr
- New fuel cell fab pics
- A few cam questions
- ITR/CTR CAMS QUESTION...
- help with SKUNK2 STAGE 2 CAMS
- Header - Help!!!
- SMSP b20vtec 1Piece Header came in Today!
- Buddy Club Spec IV on K-series???
- B18a1 what can i do with it?
- random question
- Dumb LSV question
- crower 403 cams or brian crower stage 2s?
- ls vtec around $1500
- valve spring compatiblity
- Force induction
- question regarding to crower stage2 63402A-2 cams
- Update on bogging problem
- So build it!!!! But Long
- High comp longterm reliability
- Help with Toda spec b cams!
- arp Head bolts or head studs
- what arp rod bolts for b20 frank?
- Bought a head
- can you use p30 [b16a] 81mm pistons in a b20 block ?[84mm]
- Can someone help me find a thread from this forum? Red EK coupe that people thought was FI
- High Flow Oil Pump
- would this be reliable
- tune chrome on the fly
- ls/vtec...best clutch for my application?
- skunk2 stage 2 or stage 3, cams?????
- Which ARP head studs should I use?
- where to set cam gears while claying...
- HELP!!!!B16 TRANS W/ LSD & 4.7 ????????
- B16B RPM Limits
- how much for a d15b
- HEADER QUESTION
- what is the best rebuild kit will give me the most gain for my LS?
- ITR exaust cam
- ls all motor
- Exhaust "blow out"?
- Moded sparkplugs
- I did a search for poorman's got nothing...
- P30s in LSV with Skunk 2 Pro 2 cams Valve Clearance
- LS BLOCK FOR A LSV!! Help!
- Am I ok to rev to 9000?
- ls longblock
- Do i need to sleeve
- OEM headgasket thickness b16/b17
- Compression ratio for Blox type A's?
- My simple B18 Build....Tell me what ya guys think?
- connecting rods
- B20 sleeve question
- M22x's and overbore valves, yay or nay
- H23 block with a built head
- s200vss300
- h22a4 ???
- H22a4 block/f20bhead???
- all motor USDM H22 dynos
- Moroso Crankcase evaluation setup - questions?
- trouble on installing header
- Whats the Best way to Build my OBD0 ECU?
- sending head out...any good shops in cali?
- ls/v or gsr
- h22a rebuilt burning oil HELP!!
- B16 all motor dyno/drag video
- Oxidation on block
- Best setup to run on a DA. PLEASE VOTE!
- N/A catch cans, why do some have breathers?
- springs require for sk2 pro 1 cams?
- !experienced help needed! technical question
- question about my b16a
- poor man typr
- Some more LS/VTEC questions. HELP ME OUT!!
- valvetrain
- possible cylinder head warpage?
- custom header
- Need help removing head
- Need advice on this setup?
- Need help
- pro series skunk 2 vs blox intake manifold?
- Crower vs JUN Cams H22
- yet another boring ls vtec build
- supertech valves
- Buddy Club Stage 6 Cams (BC6)
- Swapping cams / relationship to base ignition timing
- JDM B18c Fuel Pressure
- Type R Valve Springs Important Question
- ALL MOTOR D16a6/D16z6head BUDGET BUILD
- lsvtec whp
- VTEC HEAD ON MY D15B1?
- ITR IM on B16a, What kind of gains?
- blox
- B18C R 98' Spec N/A Build UP
- Octane boost = Loss of power ??
- plastigage results------ SOME INFO WOULD BE GREAT-----
- my first ls/vtec. (82mm ls/vtec questions)
- Head Gasket Going Bad = GSR All Motor Head Rebuild
- INTAKE! ! Suggestion
- 2.4L 800HP 20000 RPM F1 Engine Warmup Video
- compression
- Pistons: side loading and stroke- skirt size vs. weight?
- Can headwork (when done correctly) make you lose power?
- 4 cyl NA engine, parts (part1) in action (part2)
- K series intake questions
- ls/vtec all motor
- PDE-E01 ECU how to reflash
- Cam Design Question
- 215 whp set up, what exhaust to get that closest to stock sound?
- B18c Dart block/ huge motor for sale!!!
- compression calculator
- Starting My B18C 2.0Liter Build
- ALL MOTOR b16a WHAT KIND OF SETUP :[
- B16 Questions and Concerns
- Forged I-beam rods and rs machine oem b16 pistons good combo for ls/vtec?
- b16a w/ partial ITR Internals !!
- bearings
- bore b16 to 1.8
- Quick Question | All Motor JUN
- Individual throttle body set-up
- 91 accord. trouble starting
