- S2 tuner stage 2 or stage 3?
- Odd smoke/moisture issue, rebuild head or longblock.
- How much RPM with buddyclub spec 6
- oil orifice???
- Crower Stage 2 Cams
- What exhaust system shuld i run on my h2b cr-x ?
- b20 bearing selection help from a noob
- Bisimoto style headers.... $350
- Can I use this B20 block
- What's wrong with my H22?
- NA F23-H22 Hybrid w/ stock bottom end/built top end
- Mods not yeilding the correct results...
- ITB throttle problem
- B18C1 175whp & 125wtq Goal?
- Tuning out hesitation
- To the folks running RDX 410cc injectors. What fuel PSI do you run?
- Camshaft Dilemma:Skunk2 Pro1 or Pro2?
- Valves - Aftermarket Ex + OEM In
- My B16A2 Rebuild All Motor Monster
- ||||| NEW MEMBERS PLEASE READ THIS |||||
- Poor mans type R build questions...
- skunk2 pro valve springs installed heighth
- JDM ITR Dyno
- skunk2 cam gear ?
- D series question
- in need of a motor
- h22 Valvetrain Help
- Most power using a catalytic converter
- B20v Build Suggestions
- what year is my motor
- Plastigauge Black?
- stock block b20vtec cam upgrade question
- H22 Swap Cooling Problem!
- B18c... or is it?
- mini me question
- I plastic gauged my bearings and......
- Ls-Vtec Oil Pressure Problems..((Help))
- H23 Swap Into CD5
- Really Poor Man's Type R?
- B20VTEC
- intake manifold swap
- Poor Man's Type-R Crank Pressure
- crover stage 2 or ITR cams??
- need aftermarket valve spring retainers??
- my car wont start ??????
- head gasket info
- b16a2 all motor
- Built B20vtec HELP !
- JDM H22 TypeS info
- what b16a intake manifold?
- my 91 hatch si wont start
- Which manifold?
- Break in on pump gas or E85?
- Help spark plug reading
- need help with cams
- Who does engine work? Midwest area
- engine code HELP!!
- B18CR Replacing rod bolts (OEM)- Resize rods?
- I have an Exhaust question
- which amsoil to use?
- Anatomy of a Merge Collector
- Need help with LS swap!!!!!
- best exhaust for all motor?
- Help me with what b16
- ls crank gsr block, any fitment issues?
- ARP bolts 208-6001 for b18c
- b20 vtec help
- i need help with my gas guzzling civic si
- The Shodan & Project "SHE"?
- good compression ratio for street
- b18b em1
- Bearings...... i'm so confused...
- S2Pro1s, MAJOR ticking/clacking coming from the head- Details inside.
- how do u wire vtec to a jumper harness??
- b20v injectors?
- F22A1 upgrade or H23 swap?
- it's time... my gsr nitrous build
- will ctr pistons fit ls rods
- H22a parts
- Acl bearing question
- Dizzy problem
- H2B drag noobie. Help would be nice.
- B series camshaft identification
- B16 simple build suggestions
- Throttle Body Question
- 02 honda civic 90,000 miles
- SCAT rods, need balance?
- A lil help......Question about lowering compression w/thicker head gasket???
- 97 Civic EX D16Y8 HELP keeps dying randomly.
- Can't decide help!!!!
- f20 or h22
- thinking about switching from a bseries to a kseries
- E85 B20/vtec sputter above 5k rpm??
- fabricated itb's
- bad idle issue with lsv
- Cost to benefit: oversize valves?
- Can I use OEM retainers with Skunk2 Tuner Stage 2 cams?
- 12.8.1 CR what fuel ratio to use?
- How to check coil bind?
- b20 vtec/ARP head studs??
- need help on ls/vtec
- New H2B header
- injector size
- Can I Borrow an 81.5mm Ring Compressor?
- mild DD build questions guru's chime in plz!
- 83.5 mm arias pistons?????
- DYNO VID: 206.50whp All Motor D16a6
- ROCKET MOTORSPORTS M24<<<^_^>>>SKUNK2 PRO2
- Looking at a set of Web Cams, whats your thought?
- Blacktrax: In house or sent out?
- type R cuts out in vtec. help!
- engine swap or turbo?
- 94 civic engine swap?
- Identifying Skunk2 Pro2's
- longer intake studs
- track results from basic ls build
- Help H22 Cam seals keep leaking
- 94 accord h22 swap, 6500 rev limiter, help!
- b20vtec pistons????
- Pro 2 vs Pro 1
- Is plastigage adequate?
- H22 with itbs won't run idle or run right. Butterflies gaps?
- which catalytic converter to get
- B20/B18vtec ITR broke 4-cyl! Why?
- gasket thickness question
- Motec Tuner in Phoenix, or close?
- need my car to go faster what should i do?
- GSR SWAP TUNING QUESTIONS
- 94 civic D16 -> B18 head swap?
- 91 Octane Pump Gas B-Series Dyno
- Built GSR Head onto Built B16a Block.. Worth it?
- Will B18c1 block internal fit in B17a1 block?
- intake manifold and throttle body for 2.1 gsr
- opinions on my setup needed
- tuners in california
- LS/vtec header??
- SPRING SEAT PROBLEM
- Any extrude honing guinea pigs?
- f20b sump vs h22
- What intake manifold do i get? b18a1
- what company's do manifold porting?
- VTEC Quesiton
- ARP head studs on an ls vtec??
- Which ECU? p72 or p73
- All motor Nissan setup and numbers
- Bestofjdm.com
- Valve guides?
- Mr. EG's LS/VTEC Build
- Flycutting, how to do it right?
- knocking in h22a
- which one is better the b17a or the b18c1?
- what do u think about the whole b20 vtec build?
- Help me analyze this dyno graph...
- B18c1 Rebuild kit
- Help diagnose my low power: B18C
- what oil pressure should I be making??
- Advice with budget and options
- 2.5" piping, i need a header
- S2Pro1 into B18CR
- really need help... built ls vtec will not hit vtec no matter what
- B20vtec head gasket help
- Randy Owens H series Intake Manifold Testing
- please help d15zc vtec!!????
- LS-vtec with no Vtec!
- Exhaust Adapter
- P29 pistons with stock z6 internals
- Track results !!! Bseries All motor 4piston Head
- Basic build, any suggestions?
- Where to get piping? im trying to make a header.
- Extreme Cylinder head Mods ...
- Exhaust piping Kit
- Need help with throttle body size in my set up
- need advice, think piston rings are bad! H23A1
- is it worth it to port head on a 1.8l 81.5x89?
- Car stalls under heavy breaking
- New Custom Cams from AllM0t0r
- Questions/Suggestions for the last few items for my build
- No vtec oil pressure at front test port
- valve springs with head on?
- f22parts.com
- built gsr
- HEY MANs all-motor b20vtec
- head gasket thickness
- smashed my header, bought new one and a wideband today
- hytech header vs toda header
- Rebuilding a B18B1
- what NGK plug part number should i use
- B18C or B20vtec???
- B18c all motor build
- ctr pistons in gsr????
- What sensor is this? and oil from breather?
- Fresh built b18 ls wont start up...
- crankcase breather kit for a ls vtec
- exhaust help! 2.5" to 3"
- Buddy club spec 3+ questions.
- SMSP B Series header on an EF
- P30 vs P73 Intake Mani On semi built LSV
- checked cel code and ..........
- h2b build advice
- My 2201cc lsv build
- New Cam lineup
- b20 for road racing??
- what cams are the best 4 no tune? DD
- b16 block with gsr head
- Sleeving cost?
- Have a few questions I need answered
- Built b18 ls motor which injectors.
- H22 build for +250 WHP advice
- Build Question Gsr
- is this build worth it?
- help...trying to figure out my D series engine info
- All Motor Bseries - Dyno Results - Ported Head Comparison
- Jdm B18 c Block on B16 Tranny Have done research ! General Questions
- f20b block h22 head?
- Poor man Type R , Problem please helpp
- ITB Installation...
- B20 future build.
- Machine shop in San Jose bay area
- built motor shuts off closed throttle
- Throttle stop screw help throtle Body!!!
- what timing belt would i use for an ls vtec?
- 13020-P73-J00 pistons in gsr???
- car not starting due too ECU !!??
- No heat after cooling system flush
- daily driving on 13cr
- 4-2-1 vs. 4-1 on b17
- GSR Build...Any suggestions??
- Retune for header change??
- Weird TPS voltage issue
- Tiger Japanese Engines
- 12.2 compression with 55 shot nitrous?
- Who sleeved this block.
- 1.8L gsr build
- northern georgia..shops?
- B16a all motor-- opinions?
- No O2 sensor running s200
- fluctuating idle, strange throttle response
- Clearances and effect on HP?
- best to use for type r cams
- Blown Head Gasket?
- injector size ?
- CHIPPED P28 HELP?!
- How to determine if a motor is good?
- [B]Low Temp T-stats[/B]
- aftermarket jdm itr pistons?
- b20 vtec... advise?
- BC 2's vs Toda Spec B..
- What is the stock b16a 81mm Piston Ring Gap measurement? Please Help!Please Help!
- Freshly built B18C5 LOW LOW idle problem
- sleaving among other .....
