PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 [131] 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Q about freeze plug needed when removing PCV black box on a B16
  2. 1/4 mile times ~220whp
  3. ls/vtec = emissions compiant??
  4. Best Cams set up?
  5. urgent cam won't rotate?yikes after head swap!!!
  6. DIY ITB's
  7. experiences with SCAT rods?
  8. Head Gasket ?
  9. Just bought Blox type B cams, Supertech valve springs/retainers and JGE cam gears
  10. B16B deck height??
  11. Best cams for midrange power in B16
  12. Thanks to Hmotorsonline.com!
  13. Boring out Throttle Body
  14. k-series rcrew Intake manifold expander the bang for the bucks or not
  15. ITR DISTIBUTOR
  16. h22 ek vtec problems HELP ME!!
  17. Question
  18. What do you guys think about this head?
  19. Dyno Results: Before and After Turbohoses Velocity Stack. Hella Midrange!!!!!!!
  20. Upside down ITB's
  21. tapping noise from my b16 head
  22. Juss received VTEC cams...should I use these on a stock B20 motor?
  23. Valve guide ? better with or without ?
  24. crower stage 2 cams with itr springs and retainers?
  25. my new Ek w/K20
  26. Horsepower Vs. Torque
  27. oem pistons
  28. 2.5 collector gasket where to get?
  29. any dyno #'s for......
  30. R rods vs. GSR rods
  31. itg itb filters
  32. tech43 piston kit
  33. Dizzy Question/ Crank Position Sensor
  34. Used cams.....
  35. trial memeber??
  36. 92 Civic Megan Drift Spec Cat Back
  37. PCV question??
  38. High milage H22a4: what should I replace?
  39. OT: Lets have alittle fun...
  40. piston pin removal HOW?
  41. integra type r head on stock 99 si motor
  42. Valve Seal Driver Tool
  43. ls or b18c, c1 block better for ls/vtec?
  44. PM7/P29 Pistons in D15 help PLEASE!!
  45. Prototype Racing V-stack, heads up for my NA brethren.
  46. d16z6 head
  47. dynoed.
  48. looking to test spark tri y header but.....
  49. quick itr muffler sound question
  50. intake manifold for b18c1
  51. Compression Test Help..
  52. Cat Size Question
  53. When putting a different cam in your head do you have to replace anything??
  54. Do YOU run a n1 ctr pulley and have YOU ever had any problem or not
  55. Redstone Motors H1 Engine Dyno Results
  56. Is it worth it to get hondata if you have very minor mods?
  57. dsm440s in twm itbs
  58. ANY honda obd 1 distributor fit a b16a??
  59. h22a1 udsm vs. h22a jdm
  60. Any effect if header touching oil pan....
  61. emissions ?
  62. Stock Catalytic with Race Fuel?
  63. p30 pistons help b16 head numbers??
  64. Skunk2 Pro 3s?
  65. 1ST Official 2006 E'Town Event this past Saturday - 2 strong All Motor Cars in the fast class
  66. BA16A OBD 0 CONVERTING TO 0BD1??
  67. 1.8 all motor
  68. Got bored, did some research, OEM Stroker B16A w/B17 crank
  69. post b16 block w/ b17 crank, rods owners
  70. Dyno Difference? J's Racing vs. Prototype/Turbohoses Velocity Stack
  71. Appropriate Throttle Body Size?
  72. Header dilemma, Hytech Production header vs. Spoon B18C 4-2-1
  73. Crane stage 2 VTEC cams Feedback anyone used them?
  74. LS/VTEC build need some inputs!!
  75. Has anyone purchased anything from ANR008?
  76. will the damage affect the engine
  77. The 06 civic 1.8L
  78. i need help for my b16
  79. p28 ECU
  80. ____which rods and such should i use on my bottomend?_____
  81. 85mm bore good or bad idea
  82. is this setup stock?
  83. !!!!Anyone heard of JGE racing engine products!!!!!
  84. RSR GT2
  85. whos running the m24x cams from rocket...
  86. My K24K/K20A build
  87. What is the best header for my setup?
  88. 91 dx all motor with stock engine hp range???????PLZ HELP!!!
  89. Civic Build up, Opinions please!
  90. Got $3000 to spend on motor/tune...what can I do?
  91. axles
  92. CRX turbo project
  93. Titanium Retainer
  94. I need help with my setup!! (Y8 block/Z6 head)
  95. compression ratio change or not
  96. what rods, crankshaft, and pistons should i get for my d15?
  97. staying all motor
  98. Problems with the new TWM setup, and how to solve them
  99. Chipped P06 problems..
  100. best valvetrain for skunk2 pro 1
  101. h22 itbs
  102. Would an OEM ITR LSD diff fit my LS hydro trans?
  103. i just got a car and dont know anything about honda engines so i need some help
  104. Help with oil pumps!
  105. all motor help!!!
  106. OBX ???
  107. HELP!!
  108. A few questions regarding the d15b2
  109. B16A2 head on B18C. I need some guidance on building this.
  110. H22A All motor Build
  111. A couple videos of my LS/vtec 1986 Accord hatch
  112. Flowbench Data K20a2 head
  113. bang for the buck 200 whp all-motor
  114. intercrew?...h2b?
  115. Timing belt change on High comp engines
  116. what is my ls vtec compression?
  117. intake manifold??
  118. What does it mean ported head?
  119. Exhaust Flow Rate/Intake Flow Rate Ratio
  120. skunk2 throttle body. what cable bracket?
  121. NEW K20R BUILD
  122. Got headers? We do....
  123. injector ???
  124. ecu for f20b? (link)
  125. inline4 vtec conversion kit
  126. my new b series build up...
  127. Ask me no questions and I'll tell you no lies...
  128. marking on cams?????
  129. m22s in a gsr???
  130. jdm gsr cam or itr cam?
  131. Jeremy Lookofsky 9.79@143.51 video
  132. I came across a 86mm sleeved b18c block. Now what crank to get?
  133. Milled head...cam angles?
  134. ITB's and built motors: question about air filtration?
  135. B17 crank/rods + CTR pistons in B16A?
  136. NEW SET UP!!
  137. piston Rist pin question, only if you know for sure, no guesses plz.
  138. Aftermarket Radiators????
  139. 20 grand all motor 95 gsr..... on craiglist ..... I call BS
  140. Integra 96 LS NON VTEC B18B 14.4 @ 96.8mph
  141. Rebuilding H22A4 block -- Questions
  142. 150 whp on a D-series?
  143. Good header for a B18c motor??
  144. skunk2 intake mani... CHIPPED P28 or VAFC?
  145. question?
  146. LS VTEC BUILD ADVICE HELP
  147. Valve cover venting on a d-series?
  148. all motor newb here
  149. D16Z6 future power?
  150. Oil clearance question/bearings
  151. for my n/a brothas'
  152. Anyone ever heard of Devcon??
  153. Doin a B16a2 build all motor need helpp!!!
  154. Am i dreaming yes or no
  155. tuner in nw florida?
  156. skunk2 stage1 camshaft for GSR.. stock manifold or single runner???
  157. Port and polish
  158. best exaust set up for my car???
  159. unortho crank pulley
  160. Head gasket and coolant flow
  161. can i swap 99 gsr parts into my b18a1?? from the block?
  162. header coatings
  163. Crower ti retainers loud?
  164. p61 ecu ???
  165. ssautocrap ITR cams?
  166. Compression test results on LSVTEC
  167. Built 94 LS compression? And no it didn't blow up, yet.
  168. wich cams for my 1.8l beast?
  169. Spoon sports header???
  170. 1992 Accord 'hangs up' between shifts
  171. Which budget Header for LS/Vtec? <$400
  172. what are all the parts i need to make itb's?what are the best throttle bodies to use?
  173. ls vtec plans for cerifaction
  174. Mild LS/VTEC Build Begins Now...
  175. B16 Rebirth: New Build, New Parts, New Questions
  176. b18c vs.b18c5
  177. how much HP should an all motor get
  178. b20 motor???
  179. the new 06 civic
  180. valve springs to be used?
  181. how high are you revving on stock LS rods?
  182. How many ways are there to "hype" dyno results?
  183. 98 coupe build
  184. BEST CAMS AND VALVE TRAIN FOR LSVTEC
  185. OEM GSR HEADBOLT LENGTH?
  186. b16 or b18?
  187. JDM B18C1, sensors leaking oil? Please help!
  188. yet another itb question
  189. gasket sealer on GE Ls/Vtec kit
  190. any INFO on competition clutch kits
  191. What would you do?
  192. which header for mild b18c1????
  193. valvespring wear
  194. My setup i need some advice here!
  195. Definative method for removing stripped headbolts
  196. few problems with freshly started ls/vtec
  197. B16 question
  198. started motor today not sure it sounds right
  199. ITR Muffler Exhaust dilemma
  200. b18c1 build up, what should i use??
  201. wcan i do this to my engine?
  202. Which motor oil to use for next change?
  203. valvetrain upgrade on b16a - Omni Power?
  204. Phearable.net's Latest Electronic Fuel Injection Intro Guide (Good Read).
  205. what size throttle body?
  206. ITR dyno low numbers?
  207. what kind of chipped ecu ????????????
  208. flywheel question
  209. injector cap
  210. Blox HSL cam or Blox type B
  211. stage 3 NA cams for DOHC
  212. guide on how to instal a b16b into an ek
  213. New Toys (600rr ITBs)
  214. vavle springs... to install or not to install
  215. itr lsd in a b16
  216. Jdogg tuning in the Northeast end of March!
  217. Skunk 2 stg2 VS Skunk2 Pro 1
  218. D-series pistons
  219. Advantages of b16 head on gsr bottom end
  220. gsr head gasket
  221. stoked b series hp
  222. JDM B16 w/ B17 crank?
  223. Another GSR Rebuild Question....
  224. While i'm at it....piston swap?
  225. Finished Ls/Vtec about to start anything I should look for?
  226. Whats the best way to store a head for while?
  227. Is Toda header direct bolt in when replacing JDM ITR 4-1? n/m
  228. Ls/vtec coolant hose routing?
  229. Just did a compression test. Do these numbers sound right?
  230. Noob questions Header&Test Pipe
  231. home made ITB's to make power?
  232. I need some headwork and some advice.
  233. Type R chip?
  234. Dyno my stock CRX B16A Dyno at Rage then purchase a Rage header look at the results
  235. Which header RMF, Hytech, SMSP, etc. CLEARS the Type R Inspection cover Brace?
  236. How to do a compression test if the motor is not in the car?
  237. PISTON-TO-VALVE CLEARANCES
  238. Toda Spec C2 Cams?
  239. Ideal Compression Using Rocket M22x's
  240. JDM Integra-R P73 Piston Set (OS) for 91 teg?
  241. head milling question
  242. which pistons?
  243. mini me setup on crx
  244. ek b18c help
  245. Need custom ITB input...
  246. Wut Rod Bearings?
  247. what headgasket
  248. HEADERS vs GROUND CLEARANCE
  249. h22 skunk 2 Intake manifold on 93cx hatchy
  250. Anyone have F22A1 flow numbers?
