PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 [78] 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. b20 vtec help
  2. rebuilding question ????
  3. best headers for a crx chasis
  4. 101mm stroke with 1.75 rs h22 possible
  5. honda bearing specs?
  6. Vtec oil squirters in LSVTEC
  7. best hytech replica or profab???
  8. 50% Leak down, poor dyno results-- What do you think?
  9. Going from a brown main bearing to green bearing, how much clearance will I gain?
  10. need advice, opinions and thoughts on my, in the process build.
  11. Quick Question About Rings
  12. Experts on exhaust system please. Just a little help
  13. limits of a stock sleeved b20vtec
  14. new k series engines
  15. 92mm B series crankshafts
  16. b17 intake manifold on p72 head?
  17. Any guess to what the motor is going to make on the dyno?
  18. Could This Be 2.0 ITR Engine? [No, Not Just Another B20B VTEC Build]
  19. best intake?
  20. all motor lsvtec bearings/valves?
  21. max lift and coil bind on rocket gen1
  22. JUN 4 cams, anyone test them??
  23. Main Girdles?
  24. No Turbo, No Nos, need upgrade.
  25. benefits of a vented catchcan on a stock engine - please reccomend setup
  26. which cat for a 00 civic si?
  27. can I use arp rod bolts gsr 9mm stock gsr rods??
  28. carb'd ?
  29. toda spec d ?
  30. Yes or No to Mfactory close 3+4+5 gearset + 4.7 FD
  31. What are the Odds and How do I tell...
  32. Best choice of cams? b-series
  33. Removing bracket bolts on 86 crx exhaust manifold
  34. Reusing Head Gaskets
  35. recommended crank/head for b18c1 block?
  36. any suggestions on where to get head work done in phx az
  37. ENGINE STALLS 1000 RPM CONSTANTLY / NEED HELP!
  38. how to get pm permission?
  39. What compression for a daily driver??
  40. all motor?
  41. Carrillo Pro-H VS SCAT 4340 H-beam + Scat Crank?
  42. gasket differences
  43. All-Motor Hatch Slicks
  44. jdmshit.com JSR 4-1 Header
  45. Any1 Use Engine Block Warmers?
  46. having fuel injector problems
  47. B16 final drive and gearing questions (searched)
  48. What Cams are these?
  49. LS VTEC sluggish acceleration
  50. destroking a NON VTEC B20
  51. b20vtec help and opinions
  52. WTB: NEW, B-series starter
  53. machinists: alternative to rebushing rods?
  54. D15B VTEC on 90 HB Si
  55. 205 WHP LS GRAPH INSIDE Pump gas 93 OCT.
  56. Side exit header advantages
  57. stock b18c5 and a stroked b18c5 power difference?
  58. retainer to valve guide clearance specs
  59. What do you guys think of my daily driver setup?
  60. Is my exhaust too small?
  61. need help with overhaul
  62. Anyone used PULSTAR SPARK PLUGS????
  63. high flow cat
  64. piston to deck measuring
  65. b16 pistons on LS/b20 rods in a b18c1 block w/ B16 head
  66. Need help in choosing cams!
  67. ITR valves vs GSR valves
  68. ls/vtec w/ ctr head whitch head bolts?
  69. Critque my b20 vtec build
  70. something tapping hard noise
  71. need help on LS/Vtec cam selection
  72. Washing block after hone
  73. b20 vtec help
  74. What should i set my vtec @ 2 step
  75. HELP-- JE vs SRP shotpeen rods or not????
  76. ls vtec build
  77. Hondata Intake manifold gasket???
  78. Just curious
  79. Mugen Head Gasket
  80. Questions on a proposed build of mine.
  81. need help getting the car ready for the track?
  82. All Motor Type R
  83. alright, so im having a little trouble finding some K stuff....
  84. Official F20/22 NA Motor Thread
  85. N/A guys, which do you do/like most, 1320 or auto-xx?
  86. 00 civic all-motor?
  87. which valve springs?
  88. 2.5 or 3 inch collector for this setup up?
  89. Golden Eagle LS VTEC kit
  90. Skunk2 Intake Manifold and Throttle Body Question...
  91. LS VTEC PROBLEM
  92. stock jdmd15b header questions?
  93. walbro 255lph fuel pump?
  94. Beware of Pocketrockets Racing!!!
  95. Kingmotorsports B20-vtec intake manifold and header test pump gas!!
  96. about to buy type s cams
  97. Can I get honest opinions on my catch can choice?
  98. Look at what we picked up from King Motorsports yesterday!
  99. exhaust
  100. ICEMAN INTAKE FOR HEADLIGHT???
  101. post em up! crazy headers for all motor applications
  102. RPRacing 2008 NOPI/NHRA Motor Build
  103. What head is in this integra?
  104. best valvetrain for 00 itr/ctr cams (Supertech,S2, etc)
  105. Started my build and main bearing clearances show .002 on plasitigauge....
  106. new to HT, but not so new to hondas...
  107. Shunk2 cams
  108. Throttle body question please help > B-D series
  109. what throttle body is this?
  110. ls/vetc set-up
  111. HELP!!! B20VTEC....
  112. Top Fuel Power Catback Exhaust?
  113. Question about coolant loss
  114. Well my build starts soon, have a few questions......
  115. how high compression I can go to be reliable?????
  116. ok i did do a search... about different injectors
  117. Help me figure out this code
  118. oversized valve question D-Series
  119. Baseline Results
  120. Need help fast!
  121. wideband o2 sensor replacement
  122. will profab header clear my ek hb??
  123. 94 hatch gsr build/setup oem/itr/toda/ctr. opinions?answers?recomended work?hp/trq/comp?
  124. how much compresion? searched!
  125. BLOX THROTTLE BODY INSTALLATION QUESTION
  126. B16 Setups??
  127. How High before I have to get race fuel?
  128. Differences in gross lift (calculated) vs lift at valve (actual measured)
  129. FS: GSR Build Question
  130. b18c1 in eg coupe est. quarter miles times
  131. witch one
  132. help with the type
  133. Are after market valves needed?!?
  134. skunk2 stage 2 cams....Tried search please help
  135. Retainer to valve seal clearance???
  136. Anyone with 12.5:1 CP GSR pistons in a B18C5/6
  137. Z6 or Y8. please let me know
  138. new STAGE CLUTCH Question
  139. Need help confirming head parts
  140. building a block
  141. vtec in a dsm
  142. How streetable are TWM ITBS??????
  143. B18B swapping pistons and ecu maps.
  144. just the intake sound or exhaust?
  145. what is the best setup for a D16Y8?
  146. B series Rocker Arm ratios, DIFFERENT?!
  147. Thinkin about building my GSR
  148. rage vs hytech replica
  149. How much Hp would a port and polish give?
  150. Problems with a d15b2
  151. itr swap question
  152. b16 or ITR head?
  153. LS VTEC injectors question????
  154. Mishimoto Carbon Fiber Intake!
  155. ECU QT.
  156. HOW TO PORT A MANIFOLD
  157. brief opinions on header Hp & Looks. Rage ss try y vs weapon r try y race header
  158. d 16 to b 18 b1 help
  159. racing oil pump???
  160. which h22 header?
  161. Quick Question... Quick Answer
  162. Whats the most that the stock fuel system can handle....
  163. GSR IM fit B16 head?
  164. need help and advise on fully built all motor gsr.
  165. SKUNK2 CAMSHAFT????????????????????????/
  166. K20 header ?'s
  167. how can i tell which stock b-series cam is what
  168. Timing issues
  169. how do i make my ls vtec faster
  170. B18c1 + 2.5" cat back with 2.25" twin loop=
  171. B16A SIR MORE POWER OPTIONS??? next..
  172. b20
  173. can a d17 longblock go with d16 tranny???
  174. Civic type R flywheel?
  175. tiny comp cam on stock b18c1 springs?
  176. milled head with valve train still in... how do i clean?
  177. arp main bolts
  178. what engine harness(es)
  179. Which msd system is best for all motor lsvtec?
  180. 84.5x89 dyno vid 241hp/168trq
  181. fuel curve question
  182. skunk stage 3 or web cams
  183. car weight
  184. vtec solenoid busted on the b16. possible to use the sohc vtec solenoid
  185. will s100 let you pull CEL codes
  186. Question skunk2 IM with 65mm TB
  187. GSR Race ACL rod bearings onto LS Eagle rods??
  188. porting tools
  189. Some updated pics of the new setup going on this weekend.
  190. no compression
  191. Has anyone installed oil squirters on a LS block?
  192. 1mm staniless steel valves on a D16a6 head?
  193. please help
  194. RM M22 Package
  195. Timing belt slip/valves bent?
  196. 100 octane in the b18c-R
  197. confirming Skunk2 stage 1cams(not Pro series)
  198. Real Skunk2 Stage 1's???
  199. All-motor IM/TB question!
  200. toda B vs PRO3
  201. cylinder/piston wear with b16 strocker kits ?
  202. Ls Vtec build question
  203. what rod is better
  204. Turbo pistons and rods for 3.5l Honda??
  205. B16 build HELP!
  206. buying used cams,springs, retainers
  207. camshaft design vs rod length
  208. crower 402 question for non-vtec
  209. can I use s2000 pistons in a k24a2
  210. s2s1 problem
  211. d15b7 question
  212. for all the non vtec guys
  213. BC3+ cams with stock gsr intake manifold.
  214. degreeing skunk2 pro1 cams
  215. Spark Plug info
  216. No Power and delayed Throttle Responce - NO CELs
  217. MSD Ignition. YAh or NAH?
  218. Cam is off by one tooth :(
  219. Machining piston valve reliefs?
  220. fresh JDM B20b swap Running but a few problems!
  221. i am looking for a header for a Prelude 2.0 S
  222. NGK BKR6E-11 vs BKR7E-11
  223. Megan JDM 4-1 dyno numbers?
  224. JDM H22 Dyno #'s
  225. crower 404 question
  226. Removing pistions from rods
  227. d16 High compression build cam help
  228. D15B with PM7/P29 pistons questions????
  229. used sea-foam in motor, now it won't start/spark
  230. b16a2 cams vs b16a sir cams
  231. Vtec Not working!!!!!!!!!searched....................
  232. A few questions about Skunk 2 parts.
  233. LS/vtec Troubles!!!!
  234. wats the deal with high and low compression with boosting??
  235. ls/vtec head gasket dilemma
  236. Brief view of Crane Camsshaft for b series Vtec
  237. Engine Builders
  238. Is 18.2 air/fuel ratio ok for cruising?
  239. Cheap? Serect? DIY Ways to gain whp?
  240. Please recomend me some cams and valvetrain for 1s gen b16a
  241. DOHC ZC IDLE ISSSUE???
  242. west coast pro all motor cars for next year
  243. Engine Builders - Can you use gsr bearings in an H22a?
  244. Question about dynoing. Does a tranny make a difference?
  245. Edelbrock B-pipe
  246. ***Higher Comp. Pistons, Help Please!***
  247. Will a P28 work?
  248. More D-scussion... what/why the D16Y7 intake manifold
  249. someone help me....what is a long block and what is a short block??
  250. anybody wanna see some 4g63 ported head pics???
