- d16z6 swap
- Header help
- Just some cool, different Honda headers to check out
- How to degree your cams slideshow...
- b16 or lsvtec
- what block should i get?
- 200whp b16 and pass smog possible?
- Possible to break the 200 whp barrier with ITR cams and 11:1 pistons?
- bad head noise
- Need some help Brainstorming up a motor.
- best rebuild kit for 00 civic si
- PTW clearances p29's
- Porting/Boring Throttle bodie
- Opinions on my H2B swap ..power wise...??
- reusing old rods
- Cooling
- rod/stroke ratio
- Is 3" exhaust too big for stock b series motors?
- ur good ol' o.e. build
- D15A3 rebuild w/ pics
- 12.5:1 and 91 octane?
- which header is this?
- tools needed for head rebuild
- High compression D15, or d16 building for power and efficiency?
- angle valve job
- semi built b16 block and gsr head
- ITB or ported intake, which one for my setup
- which path to chose? mild build or swap
- Do omni test pipes usally leak?
- Engine wont start *HELP*
- header option you chose
- no vtec, no codes, about to give up
- B18b rebuilt, I have some questions
- Question for you head porters??
- Ring End Gap Issue...
- B20Vtec Dyno Results
- Anyone gone from SC'd to N/A?
- Best engine build book for honda b16 engine?
- newbie b series flywheel question
- 2.5 -> 2.25 exh. good or bad?
- Need help to find out what socket I need to take off arp head studs/golden eagle
- which cam better suit a hi-revv'r
- cylinder head
- Timing belt slack *weird*
- road race - v stack or sealed box
- how good are blox products?
- Copper coat on barely used GSR head gasket?
- *************vtec problrm*************
- Crvtec plug gap
- Looking for a dyno result
- Ram air
- what numbers do you think i will be getting on this setup?
- H22 head F23 block aftermarket piston choice?
- *Official* K-series NA Numbers
- what camshaft should i use in my civic
- crower cams
- Hytech Replica Header + AC Compressor Fitment Issue
- d series header
- GSR Build-up
- Skunk2 Tuner Series valvesprings?????
- Brian Crower Cams
- maybe you all motor guys will know?
- headgasket help/deciding
- Opinions on blox stage 3 cams (tuner series)
- 92 cx hatch d15b8 ign timing question
- header installation tips?
- My build in the making
- mild build questions...
- What WHP do you think my Poormans Type-R will push??
- chipped valve on b18c1 p72 head
- GSR head/B16 pistons: 26deg vs. 27deg valve angle clearance?
- Built G23Vtec, Cam Q?
- GSR rebuild q's
- PR3 head
- arp head studs
- shit 4-1 header on b16
- ******* B series with h22 injectors *********
- timing belt questions?
- b16 na build questions
- valve lash adjustment and power ?
- headgasket question
- valve guides?
- tryin to build 200whp na lsv..
- quick question about degreeing cams
- Do you guys think I'll hit 200 whp w/ this setup? itr inside =)
- Performance Headers
- K20A2 @ dyno-results 236hp & 163tq!!!!!
- milled head
- Skunk2 pro1 eat rockers and eat themselfes
- Finally figured out what i'm going to do. Hopefully a good idea.
- Help W/b20Vtec
- G23 vtec Build (courtesy of import tuner)
- GSR build help...
- Cams for B20 ITR 84.5mm
- Help with b20
- head rebuild? for 160K?
- INJECTOR SIZE for All motor Build
- gsr cams in a B16?
- building ls/v scored some cheap crower rods need torque spec????
- H22A pre-96 vs. 97+
- rods or pistons
- New guy HELP?? now what after ITR
- B16 question on std cylinder bore
- harness
- Has anyone use a RS (RMF copied) drag style step header?
- GSR block,LS crank/rods,JDM ITR pistons
- ls vtec w/ ctr pistons
- Car will not stay started and dies
- Oil pressure guage question
- Best header? B16b
- Solid-fab/import_trung header test, with dyno graphs!!!!!!
- All motor lsv questions
- How to make sure you got the motor you paid for? 2.6 K
- how much power in ported head?
- N/A B16 Build
- Question for the all-motor gods
- B18c build questions
- new type lma's soak in oil ?
- Bisimoto Header
- what to expect
- B18A1/B18B1 valves interchangeable?
- 200 whp gsr
- theres assholes in dc2 forum
- newbie question??STOCK JDM ITR??
- IMW Presents: B-Series Header Test // KiddRacing on STOCK BLOCK GSR
- when port matching...
- built all motor dyno problem? weird powerband, what is wrong?
- DIY Compression Ratio Calculation
- hytech header question
- n/a b16a build worth it?
- What is the best combination ls build?
- Usdm b16 jdm b16
- ls-v
- jdm itr pistons valve clearance
- how can I get this compression ratio?
- Spring tolerances
- 1st post! Intake question!!
- Harmonic Dampner needed?
- incorrect valve lash, cause vacume leak?
- swaping my head with cams or no?
- 185whp?
- VTC mechanism on the k24
- very minor piston to valve contact
- New lsv build question
- simple question about degreeing camshaft
- jdm pr3 rocker arms question( need help ????????)
- RS machines pistons in LS
- what are the limits to a healthy N/A B vtec
- where could I buy a good ring gapper?
- Humble Performance K20a Dyno Tune
- camshaft question
- How much modifcation till tunning required?
- narrow header, where do you think it makes most power.
- How do I store my motor?
- Compression ratio tests using CTR pistons
- will i pass emissions with jdm itr pistons
- b18c1 NA build question
- Hotter Sparkplugs in a B16A
- b16 pistons in b18b1?
- breaking in a motor???
- Toda spec A cams
- Brian Crower III
- exhuast gaskets question
- B20/vtec ??
- ls crank and rods in gsr?
- THROTTLE BODY Part???
- B18b1 "what mod's can be done to cause no check light ?"
- is this worth fixing can it be fixed
- NA TYPE-R Build
- where is the ALL MOTOR B20VTEC TIME SLIPS thread at?
- ITR CAMS on ebay????
- k just added ,hytec replica header,new intake,exhaust and no power difference
- Should i go all motor gsr or b20 vtech?
- Best place to buy pistons and rods?
- B16A Torque specs
- need some info on itr cam specs and gsr cam specs
- stock b16a, how much can i bore on stock walls?
- building an all motor poor-man type-r need some input
- Throttle Body
- itr cams in a stock gsr head?
- H22?
- b20b build questions
- CTR muffler EK9 restrictive for built b20vtec?
- velocty stack question please!!!
- open headerS
- What Cams Should I Use 4 My ITR Street/Race Swapped Ek
- ls vtec crx no electrical power
- ITR pistons help questions
- B20 internals Vs gsr ineternals
- i need help
- ls vtec?
- B16 header , fujitsubo /feel's / toda
- b18c4 or b20z build question
- Bottom end build question
- B16A manifold on ITR [Dyno]
- Are there different ways of positioning your piston rings??
- Cyrogenically treated engines!
- i need help with 93 civic GSR hatch
- Bigger injectors, cars dragging? HELP!!!!!
- h22 build with new kid racing header
- Help me which to buy inside micrometer?
- H22 Question
- side exit header megaphone/muffler ?s
- All motor integra type R ?
- HP Guess for Fit 1.5 l engine
- B20Vtec ????
- 550's to big 4 my b20vtec
- HELP. Dizzy keeps blowing seals
- help w/ build b16 with gsr head
- Do I really need a PCV?
- Help, new B20 Build using oil
- HKS Silent Power Exhaust? Jasma?
- how much hp do you think i can expect?
- custom b16a stroker?
- B18C1 Needs a Rebuild. Few questions
- question to those who know valvetrain
- how much hp?
- toda cams pro's/con's
- Buddy Club Racing Spec IV Cams Questons
- Interest for PPG/Bullhead Straightcut Syncroed H22 Gearset
- 70mm throttle body for fully build H22A
- gsr cams
- my na motor thoughts???? lmk
- 99-00 si b20 swap info needed
- How much power is possible with stock b16 cams
- Header clearance issues....
- SPOON VENTULI PLATE is it another turbonator?
- Alternator Help
- What exhaust w/ long tube header?
- I have a problem with my b20
- any tips or advice on porting intake manifold?
- camp1320 a done deal?
- H22 or F23 with H22 head?
- specific info on merge collectors and new header design.
- if i switch exhausts will i lose power....
- need some quick help identifying aftermarket cams
- Glyptal Paint?
- Blox test pipe/ megan header
- Piston still good???
- The h22 Build ... DUN DUN DUN
- Stock B20vtec Dyno graph
- lsvtec with b16a crank, head and ctr rods and pistons
- Upgrading my valvetrain...q about keepers!!???
- Anyone try these headers?
- No spark, whats the problem please help!
- A few questions(First time Honda Rebuilder D16Y8)
- skunk2pro2's with blueprint raceing (import builders) valvetrain
- vibrant 4-1 header
- gsr gridle+ main caps on b16a and 94 ls block
- N/A build... which parts?
