- B20 question
- ?????Head milled .020 (twenty thousandths).....which pistons are safe to use?????
- b16b questions
- LOOKING FOR GOOD B20/VTEC TUNERS IN SO.CAL
- ctr pistons
- T1R exhaust anyone?
- Need Help With H23 JG Cams
- crvtec/lsvtec coolant hose routing
- b20 vtec overheating part 2
- HELP:emissions inspector almost blew my car!!!
- B20 vtec builders
- 300+whp H22?? All Motor
- spray on lsvtec good or bad???
- LS/VTEC with gsr headgasket?
- The Perfect Engine???
- since i get asked this all the time-
- Those of you with BC3+ cams ?
- *sigh*..... my AN-R has broken again....
- Good Tuner Around Indiana?
- looking for good quality all motor sound clips
- should i buy Hondata s200 with boost olption for all motor
- question for a friend?
- can this set up make power?????????
- 256HP 178TQ some vids and pics indside
- Individual Coil Packs...Hondata
- Popped another Driver Mount
- how much compression can a stock OBD1 p72 handle
- how much can i mill my head on my crvtec
- what specs should my vafc be for all motor??
- Milling
- Big cams in a b16
- B18B in CRX SI any all motor ideas to make car faster?
- Here it is, B18a/b, B20b/z Aftermarket cam list and specs!
- Newbie just got 1999 SI
- Newbie to ITB's...Need some help
- Nasty crankcase pressure!
- Tuning Concept
- What is needed to get a good all motor setup...............
- 200whp easy?
- can smoeone burn me an uberdata chip?
- Those of you who have built an LS/VTEC..I need some facts
- d series 1/4 mile times
- semi-ot: what brake pads do you street guys use?
- which cam BC4s or M24S
- My H22 base Dyno
- b18b compression question?
- Vacuum pump?
- my eg vs a ford lighting 13.6 pass with bolt ons
- i got some ?? about ls and ctr shit
- boring engine for OEM oversized pistons....do I need a bigger Head gasket?
- calling everying that has a z10 block girdle. are the dowel really nessary???
- rpm service throttle bodies
- what motor mount inserts, jdm b16 into eg
- who has skunk2 stage 1 tuned vs. BC 3+ tuned dyno charts?
- h22a4 goal to make 200whp with current mods
- messed up bearings due to.....?
- JDM ITR in a EG
- lsvtec burning oil during vtec
- how large are the Honda CBR 1100 throttle bodies??
- A sports ITB'S...anyone have these or know about them?
- 2000 Si B16A2 Head on 97 ITR B18C5 Block?
- difference between b18a and b18b cams
- 11:1 CR Versus 6lbs of Boost
- ls gsr internals
- skunk2 vs wicked cams..
- D15B2 w 102 HP
- What cams are the most aggressive with the closest to stock idle?
- Good and cheap intake manifold porting?
- ls/vtec ?
- ls water pump and ctr water pump are they the same
- JUN Cams Questions
- CTR of Skunk 2
- Vtec sound is wierd
- swapping z6 head to a y8 head on a y8 block.and raising compresion
- AN-R Header Dyno's....
- Fullybuilt LS/vtec what are some numbers to expect?
- 13:1 H23
- DOHC VTEC Heads on a V8
- venom cam gear settings
- F23 dohc vtec help
- Engine swap for '98 Tl inline 5c.
- Swapping out ITR pistons for CTR pistons on new ITR short block?
- Worth porting a Wicked IM?
- 2.0L b18c5 or b18c1
- High Compression on stock ecu maps
- Highest *B series* dyno on *91* octane gas???
- h22 skunk2 IM in eg
- numbers for un-built lsvtec
- Whats the difference between VTEC and VTEC-E solenoids?
- what for my block?
- sohc skunk2 intake manifold info-
- 2.5 exhaust flange?
- What header your using? Comments?
- Tuning buddyclub 4s with VAFC
- n e 1 have this prob?
- AEBS Typhoon Vs Skunk 2 IM
- CTR PISTONS RINGS AND GSR RINGS
- Which AN-R header to go with?
- ECU question.....!
- Anr header or jerry built header?
- Where should i get my car tuned? N.Cali
- B20b rod bolt size?!?!?
- DC2 radiator in EK
- Is it worth going Buddy Club spec 4's over spec 3 pluses if I'm revving to 8600 rpm?
- I need a Poll, Endyn, Alaniz or Portflow??
- Header Coating and temp. Question
- valve spring specs
- Oversized vavles
- NEED SOME ADVISE LS/VTEC OR GSR
- Requesting Type-R B18cR n/a Build Advice
- Dyin problems only on highway
- can i run jun IIIs with my comp
- STR cam gears and fuel rail??
- Crower 2 cams, need valvetrain
- Does Gutting worth it?
- cam gears for gsr
- ive posted a few pics here and there..
- MSD/Crane coil and cap for NA???
- Mustang dyno: 12.0 hp @ 50 mph
- SNEAK PEAK AT MY NEW BUILD<<<<<<<<<------
- skunk2 dseries products. looking for feedback
- Pulling with a B18c or B20
- AN-r Equal length Header
- for b20vtec guy!
- Fly Cutting pistons? Good idea?
- New Stuff from Phantom Grip??!!
- Any 84.5mm headgaskets?
- Going from 12.0:1 - 14.0:1
- Budget B18C5 buildup....
- Buddy Club 4's lope so nice
- Gsr cams question
- Any tips on installing cam, balancer etc. oil seals?
- Love Fab Headers B-Series
- most compression on 93 octane
- D16y7
- vtec z6 head or vtev y8 head???????????
- Prelude LMA's in B series motor omniman please help
- surging idle help!
- H22A...idle trouble! HELP plz :(
- H22 Build
- GSR TB & Type R throttle cable
- b16
- PR3-3 Headwork Q's, dillemas.
- 60MM or 62MM throttle body for D16Z6?
- How advanced are you???
- Wisemen check it: MAP sensor code
- AEBS Intake mainfold and hondata gasket
- fuel managment for my all mota gsr
- another header topic....but please read b16 related
- Tuning Miami
- aftermarket throttle bodies all sticky?
- Hondata Intake manifold gasket
- need some help and info about individual throttle bodies
- b16a head with itr head job
- My DIY itbs
- what rods?
- How much hp gain
- is an AEM fuel rail necessary?
- Better to go k20a or k24 for all motor?
- B20 85mm... 14:1 comp need some help on new pistons...
- Is $400 good for a B16a head with everything and 22k on it??
- Gas mileage on cams????????????
- need info on arias/tech43 b16 stroker pistons
- crvtec overheating!!!
- b20vtec constantly overheats..!!!!!!
- Do I need to replace my LMA with cams
- Je 10.5:1 pistons in a d16y8
- Ahhhh, do I go with Skunk 2 Stage 1 or 2?????
- How far can i rev up to?
- JDM h22a Cap and rotor question
- crippled gsr crx
- ecu opinions ????????
- CAMS
- Cam Question
- OT: if you think obx is a bad at copying others products
- Cams mix match??
- RC injectors, plug & play?
- (NETWORK)State to State.Bodywork Motorwork Parts
- GSR with stock IM and CTR cams or BC3+
- Which Exaust is best For N/a Setup
- Stock K20A is getting close to 10 second 1/4 mile in a drag car
- B16 cams
- Need Help Tranny Problem
- Injector Orientation ?? For those w/ homemade ITB's
- cp to high for a daily driven on 93 octane,tuned?
- b16a with ctr piston and ctr cams, what ecu or chip
- what motor?
- B18B1 boring
- ?'s about my z6 build-intake manifold and rings
- Exhaust set-up
- hondata??
- Z6 abd Y8 cylinder head - - -
- vafc settings air fuel ?'s
- sick gsr crx
- Question here
- did a compression test and cylinder #1 has no compression the rest have 220
- Shorter to longer geared trans....bad for track times????
- crower rod bolts vs. arp rod bolts.....
- How many see 13s in your stock bore b16??
- my B20 non-VTEC dyno results.
- Budget B16 Build Up
- im lookin at my clutch...
- New cam in D16Z6
- comp cams stage4 (race only) look!!!!
- what axles are you running
- b18a into 88-91 std questions
- Would switching to the LS cam make any difference on a supercharged B20B?
- b18a1 b18b1 head??
- What is needed to install ITB's?
- Good Company In Sac that does engine work...
- HELP me pick a setup, im torn, B20 nonVTEC, or GSR/ITR hybrid
- Hondata?????
- skunk stage 2 with stock gsr compression
- Help!! Broken lsd or tranny? k02a
- b20 or ls bore question
- Is there a better cam than the buddyclub 4's
- tb with cams and mani
- ITBs tuning
- what numbers should i hit?
- i need your opinion
- need help d16a1
- Wanted: apexi vtec controller instuctions
- AEM Tru-time cam gears
- GSR SWAP IN A EK NEED HELP !!!
- How to degree my cams?
- another what do you think of my setup topic, kinda...
- ordered my twm itb's
- Overheated V-tech block!
- Should I go B20VTEC or just rebuild my B18C1...need advice
- Tranny question..Not shifting when accelerating hard
- What Crane Cam is this
- BLOX imtake mani on B18a/b
- O-rings
- YS1 Cable Trans and Hydro Gears Question
- *******************Skunk2 Stage 1 Cams and Adjustable Camgears **********************
- Did everyone forget that Toda or Jun made cams????
- did a compression check, what do you think?
- ported intake manifold
- D-Series
- Torque
- ARP rod bolts
- B-series Rocker Arm Ratios?
- Engine Tuning - Referencing Thread on Forced Induction board ...
- highest compression oem pistons
- IMPORTANT: Limiter at 6900 UPM but only in fifth gear! Whats wrong?
- CAN A STOCK B18c1 CMP..HIT 200 hp??
- 9.2 CR B18B --> 11.0 CR B20... what else do I need?
- H22 Headers Q's
- Question about an individual throttle body????????
