PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 [130] 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. spark plug and wire question
  2. Question about the blue-colored coating on P72 conrod bearings
  3. Should I take it easy until i get retunned?
  4. Running without tps bad?
  5. Throwing Codes 7 and 41 obd 1 LS help
  6. Gsr into 91 si
  7. Blox intake mani. install on B18B HELP!!!!!!!!!!!!
  8. rmf
  9. Verification of Coding for honda's
  10. Issues with Delta cam regrinds anybody with current or past experiences please chime in
  11. Need help How do you put a jdm crx del sol cluster in a u.s del sol??????????????
  12. CTR pistons on a ITR w/BC IVs??
  13. M24X, does my motor have enough balls?
  14. diff between OBD-1 GSR oil pump and OBD-2 ITR oil pump?
  15. 14.2sec @ 98.50mph / Integra Non-Vtec B18B All Motor / Track Times 1/4mile
  16. gsr rods on ls crank???
  17. Custom Exhaust Question
  18. How far can you Rev your Eagle Rods???
  19. 48mm itb on h22?
  20. WHAT TO EXPECT?
  21. CHECK ENGINE LIGHT?
  22. LS skunk2 intake mani on B16 head?
  23. Buddy club V con worth it???
  24. How do i check engine codes on obd1
  25. crome tuner in nw florida?
  26. D16A6 Assembly Problem, Need Some Help
  27. AEBS intake manifold for gsr
  28. Ls Vtec help
  29. how to install cams,springs,cam gears,valve seals,head on or off
  30. ? about b20 with itr or other tranny
  31. need help quick! tranny casing question
  32. Type R motor B18C5 with CTR pistons, Can I use OEM head gaskets?
  33. IS this close to being a b16b????? pls feed back on my set up
  34. is this close to a b16b
  35. does anyone have a copy of all motor rules book????
  36. 3rd gear burn out
  37. to those with velocity stacks - how clean (welds & lining up) in the inside
  38. Intake manifold for D16?
  39. Which catch can are you guys using?
  40. P30 for LS/VTEC with VAFC???
  41. d16v1 engine modifiactions
  42. SSR Engineering/ DTR Honda CL7 Header
  43. do i need cam gears with an ls/vtec?
  44. clutch problem
  45. how do i get maximum midrange with my sk2 mani? (searched)
  46. Custom ATI Damper build
  47. engine sat for 5 months...checklist before starting it back up
  48. My first motor build, too bad it didnt last long :-(
  49. Nearing completion about to get my motor tuned, need help deciding on CAMS
  50. Running Nitrous, Cam selection Question.
  51. 1mm oversized intake valves???
  52. Building GSR
  53. LSD transmission question
  54. First build ever, GSR Dyno
  55. good all motor headers, and their fitment around the engine brace/flywheel cover
  56. Crower Stage 3 intake Cam Gsr Exhaust does it work?
  57. eagle rods confused on torque specs
  58. Full-Race Honda B-Series Intake Manifolds
  59. balance LS crank and rods for LS/VTEC?
  60. can Nippon B16 pistons be used with Eagle Rods?
  61. B18c6 with ITB's and Toda Spec D's...what CR?
  62. question about skunk2 IM
  63. eb16 how much whp should i be expecting?
  64. Need help with fitting for ge sandwhich
  65. jun cams good?
  66. Password Magnetic Drain Plugs
  67. pro2 or S2S2
  68. Geez. RSX with ITB's
  69. Need help on a big decision fellas
  70. can i use parts from my b17 to build an LS/VTEC?
  71. Seattle Area Crome Tuners?
  72. Did a compression test!
  73. b16b stroker which crankshaft to use
  74. Duration vs. Lift
  75. b18c question...
  76. NEW VTEC CAMS?
  77. fixable or not? Help!!
  78. F/S: 1997 Acura Integra GSR Cams
  79. b18c HELP NEEDED
  80. fs wiseco pistons
  81. jdm 4-1 headers or dc sport 4-2-1
  82. o2 simulator???
  83. JDM ITR header... true or not?
  84. OBD-0 Tuning
  85. Need a reputable tuner in SoCal for a NA ITR w/ BC spec IV
  86. Polls on header's
  87. Skunk2 Throttle Body (need help from experience plz :)
  88. Thiner head gasket = cam gears +/- or same?
  89. Intake or ITB?
  90. oil pump sensor
  91. weak vtec
  92. DSM injectors --honda
  93. B20B or B20Z
  94. Turbo ITR Problems, No VTEC powa!
  95. Help i need insight on project...
  96. obd1 change over help
  97. any criticism flames is appreciated... aid my build i am new.
  98. 89 integra timing belt help
  99. Is skunk2 IM really that bad ?????????????????
  100. GS-R intake + Type R exhaust cam?
  101. Oil pump
  102. should i have went with bigger cams?
  103. f20b conn. rod part # ???
  104. H22 Build Going to Dyno on Wednesday!
  105. WATS THE MOST WHP YOU SEEN WITH TODA C'S?!?!?
  106. cam specs for gsr please
  107. ah shoot... i need some help
  108. What should i expect at Dyno day!!!
  109. Rpm Service Throttle body install
  110. what should i expect???
  111. injector flow rate question (diy itb setup)
  112. buddy club spec 2
  113. What Cams for Head with Oversized Valves?
  114. has anyone buy from extreme jdm
  115. Whats the difference between a rebuilt engine and a port and polished engine?
  116. Post your D series N/A build.
  117. I just got some BLOX type A camshafts, is there anything eles i need/should get?
  118. Burning Oil
  119. K series questions?
  120. Mugen Intake owners.
  121. Can someone school me on pistons, compression, and combustion chamber
  122. Head mill
  123. obd2??
  124. LS/VTEC bottom end
  125. need help
  126. damn no more thicker cometic head gaskets
  127. Adj. Cam Gears Cause Cel Code 9
  128. lightweight flywheel 1 piece VS. flywheel 2 pieces
  129. Oh wow..B16 swap with LS tranny..UHHHH!!
  130. How many of you guys use Toluene?
  131. duration and lift for b16a2 cams and gear ratios for y1 gearbox/tranny
  132. Whats better for LS/Vtec?
  133. s200, s300
  134. Skunk2 K20A Pro Series Cams
  135. Cheap alternative to expensive throttle bodies.
  136. What Things Can I Do To A Stock Block GSR Motor?
  137. Package Deal: Buddy Club Spec IV's or Skunk2 Stage 2's???
  138. where is the write up on d series itb's
  139. motor builders need your help
  140. what rods to use for LS/VTEC?
  141. Skunk2 pro1's much more power than the stage 2's?
  142. skunk2 stage1 camshaft (searched)
  143. Running a 2.25" pipe with 2" muffler, bad idea?
  144. Do I Port Match My NEW Rage Tri-Y Header?
  145. Final drive teeths
  146. What header for a DD/occasional race car w/ b16?
  147. B20 Vtec Questions Mild Build Need Sugestions
  148. ENDYN Breather Kit Issues!! Help
  149. best valve train combo
  150. Best place to have you intake manifold ported and reworked????
  151. tuning cam gears????
  152. B16b pistons in b16a. ECU?Compression???
  153. A couple B18c/BC stage 3 questions
  154. iac ???
  155. Anyone have the dyno of different Throttle Bodies?
  156. automatic to 5spd or just go ahead and get an engine?
  157. Which header is better?
  158. B20 vtec dyno
  159. i want methanol...
  160. Looking for experienced machine shop in hemet or riverside area
  161. Need help with Throttle body!!!
  162. TRI-Y Header gains?
  163. my ALL-MOTOR daily driver
  164. Help looking for B16 throttle body
  165. cam help for h22 , got some questions
  166. m24x with stock B16 valve....Gen2 spring...will this work?
  167. dyno'd today...dissapointed...
  168. Another BlowBy Question on B20V
  169. ITR headers
  170. Do I HAVE to rebore the cylinders for stock bore pistons? How much is it?
  171. $ Jun 3 would run for? anyone? Cali ppl?
  172. B18C in 92-95 civic wont stay running
  173. H22 dyno...JUN,DTR...P1 Auto
  174. drain plug
  175. loss of torqe someone help
  176. Best HEader for the b16
  177. import builders intake mani
  178. ATI super damper (Searched the archives)
  179. Where can I get a Pro-fab header?
  180. ANR header ok, Compact? Standard?
  181. do i need to sleeve my block?
  182. ***Official All-Motor Stock Sleeve B20VTEC Thread***
  183. WHICH...Toda or Jun
  184. New, cheap kind of tuning for OBD2?
  185. B16 Dyno CTR Pistons & Cams
  186. A CAM SWAP AND VALVE SPRING/RETAINER HOW-TO INTO A B16 OR B18C, B17.... U GET THE JIST?
  187. Bubba tuned 99 ITR motor w/ BC spec IV
  188. What do i need with stg3 vtec camshafts?
  189. 4.7 final drive in a ys1 ls trans, Can it be done?
  190. Lotus Elise video
  191. what fog light can i use on my 1997 stock del sol front bumper. oem or custom
  192. recommend me some pistons
  193. 50% SALE on Omni's 200/B16 DVD for all Omnipower Customers!!
  194. identifying gsr crank?
  195. itb's
  196. ECU preferrence for Hondata S300- P72 or P28?
  197. N/A Noob has a cam question
  198. crank pulley removal
  199. If my motor is an obd2 LS block. and a B16 head. What are my provisions for a oil seperator box?
  200. Skunk 2 Stage 2 Cams valve lash?
  201. Build my B16a1 head or buy a B18c6 head?
  202. scat rods
  203. ALL MOTOR SETUP WITH A 1998 B18c5...complete rebuild QUESTIONS?!?!
  204. Review of Crane 101-0012 non-VTEC cams in B20B
  205. Jenvey ITB on 2002 Civic Coupe K20a2 swap big pics inside
  206. I have many questions on tuning...please help me better understand the idea.
  207. autronic ecu , cdi , cops -B series
  208. intake runner length tunning, have some questions...
  209. Installing a AEBS IM in a B series
  210. someone pour this into a b20 :P
  211. Looking to maybe get a stainless header for my 01. What is the best?
  212. Getto dual valve springs?
  213. Building G22 Hybrid. Need al lthe help I can get! Couple Questions. Already searched.
  214. blox b on stock valvetrain?
  215. 2nd Gen B16a Cams.. what are they worth
  216. CTR pistons in a b16
  217. will the RC 440's do the trick??
  218. Pr3's GSR Head in LS/VTEC what compression?
  219. DOHC ZC Fantasy Build
  220. 2.5" donut gasket
  221. d15b7's limitations
  222. rocker arms
  223. !!Light weight Crank pulley!!! does it work
  224. bi6 build ?
  225. very difficult to get car to idle correctly.....
  226. Post your ITB dyno results before and after
  227. pully kit
  228. What will i gain from the P30 ecu on my B16A???
  229. Help! Needed To build 160-170 whp b16a2! help needed urgently!
  230. Quick Question?????( sorry if posting this in the wrong forum )
  231. estimate whp of built h22?
  232. i need ES OVAL for 99 gsr!!! 2.5 inch plz!!!
  233. is used comptech headers worth 250.00 4-2-1
  234. which header for the $$
  235. looking for machine shop in Hemet riverside CA open Sat
  236. Are there advantages to running oversized pistons?
  237. AEBS or stay with B16a2 manifold
  238. obx cams
  239. Crankshaft question??
  240. !!!Are BLOX Intake Manifolds any good!!!
  241. cams question
  242. fCR-Vtec questions
  243. GSR motor took a crap on me(rings). Need advice on rebuild HELP.
  244. What OBD do i have?
  245. type r cams
  246. Swap Appraisal, Type R
  247. head flow #'s ???
  248. Interesting new Motor setup.....B20 w/ CTR crank and rods
  249. b20 throttle body
  250. Help me figure out this noise in my head...
