PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 [81] 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. ported head dynos?
  2. Help with some torque specs
  3. b18 bore
  4. I need to replace my chipped OEM crank pulley on my DD
  5. crazy reving on start up?
  6. Could you guys lend me some Allmotor market insight?
  7. Heres my build, all opinions welcome!
  8. P30 bearings for an LS Vtec?
  9. LSVTEC problem!!!
  10. lsvtec idling?
  11. sputtering, possibly pinging, need some help/advice
  12. my idol keeps going up and down...
  13. driving my new rebuilt poormans type r
  14. BC Spec3 Cams 1/4 Results!!!
  15. new on here and trying to buy part
  16. Eagle Crank $349???
  17. what cams would be good for me
  18. acceleration noise
  19. Best Setup for my EK
  20. kseries build
  21. Just did a compression test
  22. which thickness head gasket? please help...
  23. what size throttle body to use?
  24. ne1 know where i can dig up some ctr vs itr cam numbers
  25. going ls/vtec..need help..
  26. Cam decision
  27. POOR MANS TYPE R timing belt
  28. b20/Vtec Horsepower
  29. TQ specs
  30. LF: Info on TODA ITB's
  31. finished installing cams now car wont idle.
  32. ITB's And VTEC sol seal
  33. Causes for dropped valves?
  34. b18c1 sleeve question...
  35. Special Thx to Combustion Contraption!!
  36. Removal Of The Head
  37. How much do ITR/CTR cams usaully cost for both intake and exhaust?
  38. B16 Block
  39. Forgot to oil cylinder walls prior to installing pistons with rings, what should I do?
  40. 81X89 just turned it on AGAIN!
  41. Help: ITR Intake Manifold/TB on B16a
  42. Fuel pouring into cylenders
  43. All Motor Ferrea Piston Ring Set for 84mm Bore
  44. what compression for crower stg 2 cams
  45. Dumb question: Installing used ctr cams?
  46. P1-COMP??
  47. gsr header on type r?
  48. gsr block 86mm bore
  49. help me find a shop to port and polish my head in Minnesota
  50. no vtec????
  51. Removing top layer on a Cometic MLS head gasket
  52. ls vtec
  53. Need advice on Performer X manifold + 68mm throttle body
  54. b16A or b20b?
  55. Is using Toda cam gears with oem timing belt smart?
  56. new head gasket question
  57. Poor man's Type R + LS crank?
  58. Bearing clearances and plastigauge results?
  59. building my bottom...
  60. LSVTEC Times for EG hatches?
  61. Where or How to get a 1 layer headgasket
  62. Need Advice on TB & 3" Intake
  63. poor mans type r
  64. Cometic Head gasket ?
  65. standalone question!!! need as much input as possible!!!!!
  66. im wanting to build my b16 in my crx... and i need some pointers..
  67. type r cams + stock springs and retainers?
  68. b16 pistons in LS
  69. Which camshaft for B16 11.5cr
  70. Water/Meth injection and Piston coating ??
  71. are nology silver spark plugs any good compare to denso iridium?
  72. Hytech vs Rage vs Ebay Tri Y header
  73. Opinions?? GSR Pr3 Dyno
  74. performer x on built c5
  75. B-VTEC head flow testing. For entertainment purposes only. Portflow approved.
  76. Rod bearing destroyed. Where did all the pieces go?
  77. For those who are using a blox IM and 70mm TB
  78. Good place to buy a jdm h22 for an h2b build!
  79. what rod length for 95mm stroke with stock deck height?
  80. Itbs on the fritz help......help? LOL
  81. Keeping the air intake tube cool - header wrap or powder coat?
  82. Budget rebuild on an OBD0 LS?
  83. any way to go faster?
  84. GSR engine with CTR Piston Dyno!!!!
  85. gsr head question
  86. b18c5 smoking on high rpm!!
  87. Blox cams for H series
  88. Question about where to buy catch can fittings
  89. New SOHC D Build
  90. B16 head build advice: comments appreciated
  91. Whats the bore??
  92. Which flywheel for a 86x89 build, 8lbs or 12.5lbs??
  93. b20b stock sleeves are 48mm or 48.5mm
  94. camshaft bolt problem!!!!!
  95. semi built h22 in an integra breaking 13's
  96. Swapping tranny out this weekend input??
  97. throwing solid cel (no code) with p28 in an lsvtec
  98. B16 Valve adjustment question
  99. Prelude 3" exhaust on 4th gen
  100. anyone have ITBs on their DDs?
  101. LS main & connecting rod bearing specs.
  102. jdm h22a type-s or not?
  103. I hate the search function- What blox cams?
  104. ls vtec p28 w/ s2 chip...
  105. GSR B20/Vtec
  106. Transmissions? Whats the best? Whats the best for the price?
  107. Will b18b spark plug wires work on a GSR/ITR/B16 motor?
  108. Skunk2 Pro2 + CTR pistons.....who has experience?
  109. LS Crank in GSR Block question
  110. What ecu?
  111. My b18c5 dyno graph with M22x and simple basemap.
  112. need some answers
  113. i have a bunch of questions
  114. H22 N/A Build - Please help!
  115. Ring End gap for forged pistons
  116. H22 oversized pistons
  117. lsvtec all motor
  118. A thank you to HT AM section
  119. PMTR Dyno Results
  120. GUDE CAMSHAFT?? compared to STOCK
  121. High comp valves and compression
  122. B16,B17 or GSR head on my b18a1??? 89 CRX HF
  123. Cam ?
  124. King Motorsports Intake manifold test!! check it out!!!
  125. honda exhaust
  126. AEM CAI 3"s?
  127. what civic si motor does this come from
  128. Spark plug White tip
  129. Anyone selling a b16a2 head for 99 honda civic si
  130. gsr intake manifold question
  131. need help d16z6
  132. DA injectors
  133. Need help on what is my best bet for good power by using little cash...
  134. Arc air boxes!!!
  135. Need help asap: valve settings with blox b's
  136. fs:new in box p73 (jdm itr) pistons std. size
  137. ARC in a EF??
  138. Rebuilding a b16a2 crankshaft with .50 acl bearings good or bad idea???
  139. engine builders chime in: bearing clearances
  140. Honda Performance shops in / around Charlotte, NC??
  141. stock rpm's
  142. crower stage 3, valve to piston clearance.. need help plz
  143. B18c stroker all motor
  144. Car creeps forward on starting line
  145. b16 stock girdle on ls block??
  146. LS vtec help please !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  147. rage header??
  148. Skunk2 Stage 2 vs Skunk2 Pro 1
  149. Need advice about Chipping Ecu and using Vtec Controller
  150. 3" exhaust
  151. GSR (p72) vs SI (pr3)
  152. I NEED HELP TO FINISH MY LS/VTEC
  153. Diff. between A1 or B1
  154. H22 Build Question
  155. 95mm stroke in a b20 with B16 rods. Need info pls.
  156. Project 220whp... stock head, 100% stock block...
  157. Couple rod questions
  158. highest compression on pump gas
  159. quick motor question
  160. Any place in NEW YORK to get honda's tuned the right way?????
  161. honda outboard engine more nfo
  162. bisi camshaft quest
  163. redline/ premium shift points?
  164. gsr all motor
  165. Port Match Intake Manifold to Throttle Body Q!!!!!!!!1
  166. gasket question
  167. lsvtec suggestions?
  168. Help me on choosing
  169. all motor drag radial et's and 60ft times.
  170. Gray oil HELP
  171. smsp 2 pieces header
  172. suspension
  173. CRX w/b16 MOTOR MOUNT question and opinion on mine!!!!
  174. Toda vs J's racing.
  175. list for the top 100 fastest all motor cars
  176. What to do for an exhaust for a k20 eg?
  177. piston to valve clearance.... lsv
  178. what to do before hitting the dyno?
  179. IAT correction a must
  180. what turbo muffler
  181. need coolant line help!
  182. Possibly the lightest crx ever! 327 LBS!
  183. dc sport headers 4-1 into a gsr block...should i buy b16 or b18
  184. ctr piston on gsr rods
  185. h22 forged pistons
  186. 84mm bore a LS block..??? ??
  187. Any REAL differences between B20B/Z blocks (besides pistons)?
  188. New ITB setups from Kinsler: K, B, D, F and H
  189. headgasket
  190. intake manifold question (b16A)
  191. valve ticking on built motor
  192. 200+whp..... traction?
  193. Which cams for semi built b16 (stock bore & stroke)
  194. Can i clean the inside of the motor without tearing it down?
  195. Blueprint Manufacturing?
  196. Gas porting pistons....
  197. More effective gearing
  198. Vtec Head codes
  199. What everybodies input on building a Ultimate LSVTEC??? w/ $5k
  200. Adding bung for wideband o2'
  201. anyone know what company makes this header?
  202. show me you velocity stacks!
  203. Hytech Header ground clearance...
  204. Need a good all motor tuner in the Mpls/St.P Minnesota area
  205. B20
  206. 250psi on CR Test - Guess the Ratio?
  207. B18 Head, B16 Block, B20 Bottom End?
  208. odd ball....going all motor D
  209. Quickclutch? Anyone heard of this before?
  210. help with h22/h23 build
  211. redline?
  212. who a good tuner for the MD/DC/VA area?
  213. New motor rebuild complete - break-in procedures
  214. blue retainers
  215. ls vtec help...plzz
  216. cam scaring bad?
  217. b20 help
  218. what size hone to use on b18
  219. B20vtec timing
  220. EF8 b16 header, Can you identify it?????????????
  221. frankenstein bottom build????
  222. K24a2 Swap
  223. Header Question
  224. please help me with smog, i barely failed. how do i fix it?
  225. Are these NPR pistons?
  226. D series questions
  227. the best cams for my setup? Ek9 cams fully built head
  228. GS-R build: P30 or P73 pistons?
  229. thanx for the help re-afc neo vs. crome
  230. Dizzy question
  231. clutches
  232. Engine smells burnt - Crap
  233. idle problem
  234. ls/nos ?
  235. cam questions. built ITR
  236. HKS air filter pre oiled ?
  237. Toda A2 Cams info/dyno #'s?
  238. Get this clean
  239. What engine for an EG Hatch??
  240. 12 sec h22 eg sedan
  241. Integra Hytech exhaust working on 96 Civic hatch w/Hytech long tube header?
  242. would like to bore 1.8 to a 2.0.....
  243. b16a help
  244. Does LS and B16 use the same rod bearings?
  245. afc neo vs. chrome
  246. shaving b16 head...
  247. Final Drive help!!
  248. B16 head help..
  249. HEAD LIFT? blown had gasket? dropped sleeve?
  250. Custom 2.5" exhaust but which muffler?
