PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 [84] 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. need help with buying crank and rod bearings for k24
  2. Raising Compression from 10.2:1 to 11.0:1
  3. Venwood needs some guidance on creating a "Road Race" D16A6
  4. Cometic Head gasket thickness?
  5. question about jg engine dynamics head
  6. Low dyno numbers (Need opinions)
  7. TWM ITB install need help!
  8. Walbro 255
  9. nice flaming backfire!!
  10. GUDE head work??
  11. best cams for stock B18c1? also what headers?
  12. 10 second First Geb B16A possible ???
  13. b20vtec piston/valve clearence
  14. Blox tuner series B , on b16 PROBLEMS!
  15. engine building shop northeast?
  16. New motor for CRX...input needed
  17. best cams on a JDM ITR motor
  18. Choosing the right Honda bearings
  19. which supertech valvetrain for blox b's and skunk stage 3's
  20. gsr high comp. pistons?
  21. k24 blocks...
  22. cams in a gsr help me
  23. throwing code 68 which I can not find on any check engine code list
  24. Header with 3in collector?
  25. Bang for my buck
  26. Switching from obd1 to obd2?
  27. DH racing
  28. Name that ticking noise!
  29. Top Fuel Stage 2 Cam Specs *searched*
  30. NA LS...
  31. OBD2-OBD1 injector harness mod
  32. Tuned at BISIMOTO - BlueprintMfg Stage 3 Cams vs. Blox B Tuner Series Cams
  33. Rocket cams ecu chip
  34. Piston compression 91 octane
  35. run with open header??
  36. Are these Skunk 2 stage 2 cams because they broke. Help!
  37. I need valve adjustment tips
  38. H22 HONDA DRY SLEEVES HP Q's
  39. Is 11.5 compression good for jun 3s
  40. how much am i going to pay...
  41. ITR Replica Header for 150$. Opinions Needed.
  42. Stock block b16a.......What pistons P30 or Pr3????
  43. CTR pistons B16a2?
  44. ls-v fuel and ignition
  45. What cams are these?
  46. Are Rocket M24X too large for stock c/r JDM B16???
  47. Tools needed for replacing crank and balancer oils seals?
  48. CTR pistons with flat dish valves :: too high compression for daily driver?
  49. what went wrong....lol
  50. Spark Plug Orientation?
  51. ceramic and ss headers..
  52. h22 itb Question..
  53. Skunk2 Pro2 Question ?
  54. 2000 civic si please help
  55. HELP!!! need someone to tune my car/tel. no. good vouches...good price
  56. Custom Cams Duration or Lift
  57. pr3 cams
  58. Flattened rod cap?
  59. Buddy Club Spec IV's Overlap
  60. Toda cam question
  61. throwing code 58 or 67
  62. Toda Valve Springs Life Time with Skunk2 Pro Series stg 2
  63. Throttle Bodies
  64. injectors
  65. Can anybody tell me about KMS?
  66. Biggest Cams i can run with oversized valves ITR
  67. h22a4 spun bearing
  68. lsv build
  69. can't decide on throttle body for the gsr
  70. Just got my H23A to start....
  71. AN-R HELP!!!!
  72. Whats a good Oem Bottom end combination for 12.1 in a LS/Vtec???
  73. Place to find good liquid filled gauges for my twm fuel rail?
  74. blox cams
  75. I need advice???
  76. b18a1 question
  77. ls vtec tranny
  78. COMETIC GASKET QUESTION
  79. Burning oil...Strage noise,B16
  80. GSR stroker???
  81. Flared Pipe for 2.5" Collector
  82. test pipe + no muffler vs actual exhaust system...
  83. CAMS
  84. Thumbs up for Bisimoto
  85. my real c/r???
  86. PLZ NEED INFO ON BLOX STAGE 2 CAMS
  87. What cams are good for my K series setup...
  88. Valve Springs Retainers D-series
  89. h22 guys...gotta question
  90. cams will not turn on new built motor????
  91. What Cam do you think is best for my setup
  92. NEED HELP
  93. 11.3:1 - 11.6:1 safe on 91 octane
  94. CTR or ITR cams on B16A3???
  95. Injector + Fuel rail help F22C.
  96. hood shim
  97. Oil orifice o-ring?
  98. Viscosity Factors of differing oil Weights
  99. GSR head on a semi built b16a block?? Do it or go full gsr??
  100. what the hells wrong with my friends timing belt?
  101. NEW HERE,,ITR HELP
  102. Toda Spec A2 pin/key.
  103. Skunk2 Stage 2 cams installed and......
  104. b20vtec LS vtec all motor times
  105. buddy club 4's or rm m25's?
  106. NEED HELP with injectors PLEASE LOOK!!!!
  107. Best IM for GSR?
  108. what kind of engie/tranny
  109. f23 crank question.
  110. what power can i expect from my b16?!?
  111. car wont start on 1st try
  112. All I need are cams to complete my LSVTEC build - need guidance!
  113. 301 cam on a D15B7
  114. Oil for B18C4 Turbo Engine?
  115. Designing an intake system like a header?
  116. Teach me about valves.
  117. Profab Tri-Y header fitment
  118. My 2.0L build - Suggestion on TB
  119. Crx D16y7 problems
  120. i have a couple questions about my setup. CTR pistons in LS block
  121. Locking rockers together???
  122. 88 honda crx si i need some assistance
  123. what jdm motor do i have?
  124. pocket rocket racing
  125. Building my bottom end......Quick question
  126. easy D?
  127. Machining OEM pistons to fit forged rods?
  128. Thoughts on single layer HG
  129. Fitting D16A1 in EG6.
  130. B18c5 (LSD) vs. H22a (LSD)
  131. Question : N/A Build
  132. ls vtec
  133. HELP- CLAYING THE MOTOR
  134. Stock GSR intake manifold or ?????
  135. Gsr final drive ?
  136. What are rc370 good for, whp
  137. Are Skunk2 Valve Springs and Ti Retainers enough for Skunk2 stage 2 (non pro) cams?
  138. I want To Build my own motor where to start?
  139. Anyone test the Rocket Motorsports M25E camshaft yet?
  140. help building a jdm b16a
  141. how will twm itb's be with this setup?
  142. ls/vtec? stock block/ built head or stock block stage 2 p&p? please help...
  143. my first set-up for my eg :)
  144. Supertech
  145. Cam gear question
  146. has anyone made 300 WHP out of an H
  147. are 310cc injectors enough for my setup????
  148. ls/vtec in 94 integra ls, will it pass smog?
  149. Crower stage 3 cam questions
  150. TQ spec eagel h beam rods.....
  151. LS/VTEC
  152. buying modified pistons
  153. evaluation help
  154. Identifying Real or Fake Skunk 2 Pro 1 Cams?
  155. B16A S1 transmission?
  156. f20b question
  157. LS/VTEC piston/rod/rod bolt/ring combo for 12-12.5:1 compression
  158. d16a6 camshaft
  159. new to all motor.!
  160. Buddy Club Spec IV valve/piston clearance? b16
  161. Head Clearance
  162. Fuel injectors for built B16A
  163. all motor 8 valve
  164. B20 intake manifold
  165. B18 LS engine + GSR cams
  166. LS/vtec; 12:1 compression; stock cams. Tuning question?
  167. GSR VS Type R rods
  168. Search n00b
  169. Buddyclub spec 6 cam Vs Buddyclub spec 5 cam
  170. RM M21 result
  171. rebuilding motor??
  172. help with h22 type sh harness
  173. rsx muffler vs. 06 civic si muffler
  174. all motor build dilemma
  175. really need help
  176. what's decent clutch for street and drag?
  177. anybody got a link...
  178. 200whp ls/vtec?
  179. GSR after tune question?
  180. looking for a good dyno place
  181. itb
  182. Clutch for All Motor Build
  183. Engine Build Tools and Gadget thread.
  184. noob build question!! help grealty appreciated!!
  185. What cams are you running? ITR
  186. h22a4 build
  187. please post before and after k series itbs graphs
  188. f20b stroker
  189. b20 overbore okay or no?
  190. Good cams for my type R ?????
  191. Are ITB's worth it on a stock JDM B18C1?
  192. all motor b16 setup help
  193. Blox throttle body problem
  194. AEM Fuel Pressure regulator help
  195. crazy idea... muffler = intake?
  196. my Toda Spec b exhaust cam broke..need a new one!
  197. King Bearings?
  198. Buddy Club Spec 3 Cams -- Any problems?
  199. Piston rings gap measurement ???
  200. semi ls vtec build
  201. F20c Piston- dome volume
  202. JDM automatic SIR B18C motor
  203. Guys with password jdm / j's racing whale penis intakes:
  204. obd0 ls/vtec question? and i did search.... knock sensor
  205. b18a w/ p30 pistons
  206. B20 vtec idiling weird
  207. transmission issues at high RPMs?
  208. Vtec will not engage
  209. Please help me! (searched already)
  210. bearings?
  211. H22 Type S cams
  212. gasket makers.
  213. all motor set up suggestions/opinions OPEN
  214. allmotor and smog legal???
  215. Comp Cam??
  216. need help recreating the ALL MOTOR TOPIC index
  217. ? About aftermarket valves
  218. higher cylinder head temps with hondata gasket?
  219. b18b head with b20z head and other mods,will this work?? and yes i searched
  220. b20b-pistons
  221. Port and Polish in VA/MD ?
  222. can you mismatch cams?
  223. Bore or not to Bore ?????
  224. first time at the track
  225. probably a very noobish question
  226. Achieving 200 whp??
  227. Octane rating between UK and US
  228. OBD1 / OBD2 dash harness question
  229. ?'s on stock b18c
  230. will hayward itb's clear a k20 dc2?
  231. VTEC Has me at a Still
  232. B20 VTEC Injectors?
  233. Pr3 pistons & Rods in gsR ?
  234. B18C1 B16A head, all motor 11.1 compression Issues....
  235. a few simple questions...
  236. Prelude- advice on which mods to perform first to last
  237. help plz
  238. main cap bearing readings help....
  239. differences in b16 heads?
  240. K24A1 block and K20A2 head. Got some questions.
  241. new build, oil pressure woes
  242. 96 jdm itr swap info help
  243. high idle&running rich
  244. HELP!!! full msd ignition no spark..
  245. highest compresion for 91 octane..?
  246. Clayed motor issues
  247. Probe rods
  248. B16 All Motor?
  249. Motor build Help
  250. kteller T-bodys?
