PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 [88] 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. torque number
  2. b20 questions
  3. ARP rod bolt question
  4. how to, or where to get cams measured?
  5. help vtec built gsr
  6. REAL QUICK: is this intake CA street legal (yes an intake question)
  7. 95m eagle crank, Rod, 85.5.. Spark Racing pistons, Supertech Valvetrain WHAT CAMS ?
  8. ITB QUESTION
  9. r these piston still good?
  10. look who stole my cams....
  11. question on b16 head
  12. how much power
  13. What the heck?
  14. Spun a bearing, how much to repair?
  15. wich combo to go with?
  16. Nyce1s.com.... NOPI MIR Day 1 & Day 2 Drag Race Videos Round by Round
  17. what will work with PRO-SERIES
  18. I have a friend who will not listen.... Please HELP!!!
  19. rod bolts
  20. built h22 what is the highest can you rev it?
  21. ARP rod bolts the same for B-Series Rods?
  22. replaced headgasket, wont rev past 3200 while in nuetral
  23. NEED help finding a good shop to do all motor build in SOCAL!!!
  24. OBX cams pros and cons
  25. newbee to hondas and need some advice
  26. 96 JDM H22a -- Open or Closed Deck?
  27. Places to get bin files?
  28. crower stage 3 cam for d16z6 ?!??!?!?!?!?!
  29. Question / Debute Pro2s and ebaich springs or however you spell it(stock block?)
  30. HELP ON FINDING THESE PARTS!!!!!!
  31. JDM D15B with Skunk 2 IM or D15B stock IM?
  32. dmaestro has been a member for 1283 days.
  33. EK9 Mugen Intake..
  34. k20a head
  35. SOme easy installs to bring the "power" to my b16
  36. wideband for a nonvtec application?
  37. At what rpm will my vtec engage in my b16
  38. what do you think of my setup?
  39. is a d15b a direct replacement to my d16y7
  40. Need Help ASAP...
  41. Project B20-R is coming together
  42. DYNO results from churchs: LSV EM1
  43. filed a compression ring too much....engine builder input wanted
  44. Shaved head+ RS 85mm ITR's
  45. What pistons will get me to 13:1 ???
  46. What clutch to use??
  47. h22a eg questions?
  48. gsr header..ef hatch
  49. bolt stretch guage
  50. PR3 PISTONS IN LS MOTOR
  51. Rocker arm ratio discussion (high ratio vs low ratio)
  52. Car cranks, WONT START? Fuel pump? Bad Injectors?
  53. Header question for LX
  54. anr header???
  55. B18b Cams? stock valve train..
  56. Stock injectors w/walbro 255lph... OK?
  57. how can i check if a set of cams i have are prelude type s
  58. Skunk 2 Cams/Valve Train, what bottom end work is needed
  59. tranny ?
  60. question bout b16 cam gears (maybe wrong section)
  61. Cam Gear Off one tooth?
  62. quick piston guestion
  63. B20B VTEC what kind of number??
  64. Tuning
  65. basemap for my all motor
  66. LOOK WHAT I GOT.....1.9L ls/vtec..crower stage 3 cams...need advice what to do....
  67. opinions needed H-T - CROME or HONDATA ???
  68. scoring on cylinder walls
  69. Dyno graphs of B16A CRX with Skunk 2 exhaust
  70. LMA retaining clips
  71. Vtec or not?
  72. 600 horsepower all motor your opinion
  73. GSR MOTOR OIL EATER!
  74. JSR: Jdm Shit Racing header?
  75. bored gsr or b20
  76. ls-v with gsr cams?
  77. My LS/VTEC plan/build.
  78. Ls motor with 402's
  79. nicked piston wall :(
  80. compression ratio question
  81. OBD II Swap into OBD I car Direct Drop in?
  82. Forged pistons and rods?
  83. Knocking noise from dizzy side of valve cover
  84. Bore out or just high comp 81mm?
  85. Distributor Wiring Issue! Need Help!
  86. p28 or p61
  87. engine prelude for accord swap somebody can help me
  88. Help - got my BRAND NEW Build High Comp. GSR running But.
  89. is this gizzmo good?? launch control system...
  90. can a headgsket not seat?
  91. B20Z PHK piston Part #'s needed
  92. Acceptable Engine Out of balance ?
  93. Ls-Vtec build
  94. Please Help with b20b basemap..
  95. cam install and now tapping noise?
  96. Pics of ITB filters
  97. external oil feed line on a b18c?
  98. end of this b18b
  99. Difference between Us or Jdm Vtec solenoid??
  100. Gsr Block..Which head?
  101. Loud claking noise in h22a motor.
  102. Spark plugs for high CR B16
  103. main and rod bearings
  104. Blueprint Manufactoring cams...anyone Dyno them
  105. gsr head with bc3 + ??
  106. 440's too big?
  107. Power Goals???
  108. LS/VTEC fuel problems
  109. Which cat for this setup?
  110. Offset boring rods?
  111. Can i use sandpaper to hone my block?
  112. Y P30 pistons over PCT?
  113. HYTECH PRODUCTION HEADER
  114. arp gsr headstuds be ok for b20 vtec
  115. build an ls/vtec on an eg
  116. b series motor
  117. SKunk 2 Stage 2s Question
  118. Brian Crower Stage 2 vs. 403 vs. 404 which one for streetable non-vtec?
  119. LS Vtec ....... help INTAKE MANIFOLD PROBLEM :(
  120. B20Z vtec Questions! ??
  121. is this a good set up
  122. deff ls/v-tec
  123. 1997 honda civic dx power steering
  124. B20/vtec plug gaps.
  125. how do you tune itb
  126. b20 in ek
  127. LS VTEC + BLock Girdle
  128. Pics request of Ported/polish D16Y8 head!!!!
  129. ls block compession ratio
  130. compression test on my b16
  131. Need help with tuning
  132. Stroked B16
  133. straight pipe
  134. Buddy club Spec IV cam datasheet needed!
  135. Exhaust Setup
  136. Skunk 2 Manifold Question
  137. all motor h22's in intergra's.
  138. installing water lines, HELP ME!
  139. pct (b16b ctr) pistons into stock b16a2 block, do i need to modify rods?
  140. Wierd Cutting out/stuttering problem With new head
  141. JDM gsr, which head to use?
  142. tunning tips?
  143. 70mm ThrottleBody on CTR??
  144. need help on type r head
  145. b17 build, questions asked
  146. blox b cams with stock h22 header?
  147. h22 autotensioner fix???
  148. looking for and H22 block
  149. car shuts off right after it starts
  150. valve rocker arm
  151. Carbon buildup in the throttle body?
  152. XS POWER CAMS PROS N CONS
  153. O2 Sensor wire too short after RMF
  154. CRV A/C causing engine to miss?
  155. Quick Question About IAT Sensor..
  156. My build My head, what do you think.
  157. LS/VTEC help needed
  158. radiator fans
  159. Water in engine damage?
  160. Is my timing off, or is this acceptable?
  161. Different cranks
  162. LSD
  163. Tuning a D16Z6, which options?
  164. S2 Pro 2's or Toda Spec C
  165. main and rod bearing questions......
  166. Anyone use or have thoughts on the AEBS intake manifold?
  167. B20/Vtec
  168. All motor Non-vtec build. Should I stick with LS 1.8L or go with B20 2.0L
  169. ITR distributor question
  170. reliable autox b18c1 build questions
  171. stock b16a headgasket size
  172. Skunk2 Stage 2 in GSR/tuning?
  173. Slipped Timing belt on new ls/vtec!!!!
  174. Tuning.
  175. B20Vtec Compression Test Results, GOOD or BAD?!?!
  176. LSV APPRX. FUEL PRESSURE
  177. Help...please...SOMEBODYYY...Valve relief question
  178. Fuel pressure regular on stock rail with gauge, possible?
  179. Most Power from Stock Head Port and 1.8L?
  180. Ls Swap to 98 HB Dx question
  181. please help me!!!!
  182. IB stage 2 sleeves - bad install??? opinions needed
  183. b16a question
  184. Callin B17 Tech's piston height ?
  185. Oil catch can install help, please, i've searched!
  186. Skunk2 IM question (GSR)
  187. lsd???
  188. Head milled, timing advance?
  189. d15z1
  190. h22 main and rod bearing clearances
  191. aem fuel pressure adjustment
  192. 8:5:1 Pistons.. Question.
  193. Can i run 11.5:1 on a stock JDM P73? Need answers quick!
  194. Just swapped in my B20 VTEC in my ek hatch but idles at 3k....need some HELP!!!
  195. B20B/LS Head swap... Possible? Beneficial?
  196. PP head
  197. h22a4 oil squirters removal
  198. h2d swap
  199. b20/Vtec Help
  200. problem timing ls/vtec i need the time timing gun number
  201. what is the difference between a b16a2 head and itr head with regard to rocker arms?
  202. good performence parts
  203. b16 bc3 cam gear setting?????
  204. Cam spec. @1mm lift
  205. piston and rod setup
  206. How to get in touch with Rocket motorspots
  207. Oil Leak help
  208. My compression
  209. Vibrant Performance Timing Belt Tensioner
  210. What springs and retainers w/ Crower 404's?
  211. Is my exhaust too small?
  212. Thoughts on M1 Full syn discussion in the ITR fourm/my350z.com fourm
  213. degreeing my Pro 1's
  214. Noob question!
  215. how much horsepower?
  216. B18B1 NA Build or Swap? please help.
  217. GSR help
  218. pistons for b20vtec
  219. Help me identify this part
  220. PR3 Pistons: OEM vs Nippon vs RS Machines vs Hastings
  221. would you guys buy a crate motor for a honda?
  222. Pistons for ls/vtec
  223. head noise?
  224. Spark plug gapping for NGK BKR7E-11...
  225. Spark plug reading
  226. King Motorsports Intake Manifold studs? PUHLEASE
  227. LS Non-vtec Build
  228. 240 ttws good or average?
  229. ls/vtec gasket fitment question
  230. just tuned wat oil set up to use next..???
  231. Quick question. What will CR be with PR3 pistons in Non-vtec B18A1
  232. gaskets
  233. eg guage cluster
  234. Did I get the wrong crank???
  235. 95 GSR is a ported head and cams worth it ?
  236. Buddy Club headgasket?
  237. base map
  238. CODE # 9 PLEASE HELP
  239. Cam Gear Clarification
  240. Quick queston
  241. clerance probs with moroso oilpan H22
  242. My '93 accord is overheating - why?
  243. Unnoticed topic: how to rtune ignition?
  244. golden eagle intake manifold
  245. Tuner gears with pro series cams?
  246. k-series crank pulley on h-series?
  247. 300hp H22...?
  248. blox/ BPi velocity stacks?
  249. what happened to zealautoworks compression calculator
  250. Fuel pressure up..alot on itbs??
