PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 [214] 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Stock Toyota 4AG ITB's on a B-series motor
  2. torqe specs on arp head studs b18c1
  3. Any easy ways to squeeze the most out of a stock H22 in a civic?
  4. LMA position
  5. 02 Veloz civic - what type of motor
  6. what timing belt is best? oem, toda, power enterprise, or somthing else?
  7. Are all D16 cranks the same? Mine snapped
  8. command flow installed...what fuel pressure?
  9. correcting r/s ratio in a ls/vtec
  10. b20 power????
  11. How to silence ITB's
  12. built motors
  13. Here is a pic of my Race ITR on the Formula one track of Magny-Cours France
  14. d16 vs b16?
  15. CRVtec crankcase pressure prob
  16. Just baselined my car 98 gsr 164hp/120tq with toda b's??????
  17. Another Engine Poll! (which is better to build for street/drag)! PLEASE HELP!
  18. Happy New Year from Hybrid Racing
  19. best cams
  20. 86mm?
  21. B20 non-VTEC
  22. happy new year!
  23. i know yall get this alot but i cant wait
  24. Your experience with forged pistons/rings concerning clearances and oil burning?
  25. Dumping the turbo project what motor should I get???
  26. got 500 bucks to spend for a h22 header...which one?
  27. got a little question?
  28. Today i Started the PORTED GSR IM Proyect
  29. which piston rings 3 part question
  30. tranny question
  31. need help with setup *lsvtec*
  32. Difference between B16a and B18c Pistons?
  33. * WARNING * anyone buying CTR/ITR cams anywhere else but the dealer
  34. do i realy need a apexi vafc
  35. Crower 404 cams clearance with stock pistons
  36. EF1 m24E,m25, and m25E compression
  37. any thoughts on the endyn crankcase breather?
  38. Custom Air filters
  39. what octane gas does everyone use in a stock b20vtec?
  40. 200whp with this set up?
  41. how much hp from this set-up?
  42. Which exhaust would make the most power for me?
  43. Weight of popular rods?
  44. hookups import -tek ???
  45. JDM H22 bottom block?
  46. B16 GsR head
  47. Lookin for OBD2-OBD1 conversion harness!!!!!!
  48. how to identify skunk2 stage 1 cams?
  49. Can my block handel my auto power? =o
  50. For my DIY'ers....a good website to get your header and exhaust pieces.
  51. Apexi JDM Header anyone tested??
  52. best for b20/vtec - type r pistons and rods, or b20b pistons and rods??
  53. 95mm crank??
  54. which oem exhaust camshaft will make more H.P.
  55. how to tell the differance between intake and exhaust (retainers)
  56. need help on jdm b16 dropped in a ek (harness info) please!!!
  57. drag launch suspensions???
  58. Should I buy skunk two stage two cams for my 95 gsr
  59. Can anyone identify this exhaust cam? GSR? CTR/ITR? ...
  60. Tanabe woooo hoooo
  61. JG Manifold on a B16A2, some install questions
  62. Port Flow kit ?
  63. Stroked B16 - will it work?
  64. HyTech Exhaust awarded U.S. Patent
  65. Do these compression numbers seem oddly low?
  66. hp formula and lsd install difficulty?
  67. r/s ratio calculation
  68. Best Intake System For N/A Poor Mans ITR.
  69. PCT/CTR piston and compression ratio
  70. NEED H22
  71. Who has/has had a spool or welded diff on a daily driven car?
  72. Gonna give K a miss....I think....
  73. all motor gurus what you think about this....
  74. i got an rc injector question
  75. eWhat size piston in my ls vtec
  76. accordinglydone.com any good...?
  77. CTR PISTONS AND CAMS IN A B18c (JDM) GSR?
  78. formula.???
  79. how to identify skunk2 valvesprings and retainers?
  80. B16 setups
  81. is it a good idea if i do a pipe from the collector to a glasspack to the muffler w/no cat or test p
  82. B20 vtec times
  83. motor mounts
  84. h22
  85. found some old pics of my blown b16a
  86. Do I need an aftermarket fuel rail for 370cc injectors ?
  87. Toda spec b cams
  88. allmotorlsvtec motor break in...
  89. BISIMOTO
  90. Discussion of cams for an otherwise stock JDM ITR.
  91. JDM P30 Pistons, part number requests (Standard and Oversized)
  92. 98 B16 in a 96 coupe, P30 pistons, portflow head and CTR cams - Will it pass smog?
  93. crane stage 3 cams
  94. CTR intrnals on a B16a2 block
  95. icebox intake vs. stock intake loudness
  96. porting and polishing
  97. I did something stupid any consecuences
  98. anything else needed before its built
  99. TODA camgears questions?
  100. LIST YOUR LS/VTEC SETUPS!
  101. comp tested...
  102. JDM GSR pistons????????
  103. my future setup goals
  104. apexi header anyone?
  105. what will happen?
  106. LS/VTEC Revving ablilities..
  107. 98 spec JDM swap with some goodies, 200whp possible?
  108. What kind of header is this?
  109. Looking for a carbon fiber spark plug cover to complete my allmotor..
  110. How is this?
  111. New motor for turbo??
  112. ls/vtec help
  113. B18C1 Head Q's.. Dowel Pin Placement + headgasket... urgent help!!
  114. all these mods on my motor, will it put out 200whp or not even close
  115. is there a difference between ls/vtec oil lines that are out there on the market
  116. A/F Ratio
  117. header collector size thread
  118. Anyone using uberdata for their tuning?
  119. B18c With CTR Pistons and Toda Cams with OEM HG, Clearance Issues?
  120. It's a SETUP.....
  121. Switch from Syntetic to mineral
  122. electric water pump
  123. When warming up your car on a cold day, do you....
  124. is this good for 200whp?
  125. Stroker kits
  126. B20 BUILD QUESTIONS
  127. H22 people what size throttles
  128. How long have you had your LS/VTEC?
  129. Honda Bearing color to thickness chart for everyone who loves using OEM bearings PT#2
  130. Stock LS block
  131. Project B18c5 Killa
  132. TIPS on CAMS!
  133. is it cheaper to buy aftermarket rods or get my b20 rods shotpeened and balance?
  134. B Series DOHC VTEC JDM Cylinder Head on ebay????
  135. My B20 nonvtec build
  136. Camshaft dyno thread!
  137. Valve Adjustment Specs
  138. fuel pressure drops off before starting up engine
  139. which head studs for ls/vtec??
  140. Good Machine Shop in Central Cali?
  141. Someone on H-T, have this christmas present for me? (Spring Test)
  142. Check out these two pyr street cars from thier website, just want some infor
  143. Rod / Stroke Ratio ?????
  144. MY ITR
  145. **** further recommendations needed****
  146. What do you think I'll run and what #'s I'll hit
  147. B16A with CTR pistons??
  148. looking to sponsor head work
  149. ot: Looking for a couple cars to sponsor (EVS)
  150. REQUESTING RECOMMENDATIONS to help build a b16
  151. Rebuilding my B18C. Have some questions. All Motor.
  152. Pros and cons of dropping in forged pistons...
  153. Does anyone have a trashed B16a Head? I need one valve
  154. ls/vtec....what injectors....?
  155. B16a pistons in LS.....
  156. WHATS THE BEST AND CHEAPEST B16 ALL MOTOR SETUP!!!!!!!!!!!!!!!!!!!!!!
  157. Why would exhaust valve hit piston outside of valve relief?
  158. What block?
  159. b20 vtec Q's
  160. spark plug gap
  161. How about an LS N/A monster.....
  162. what setup for me???
  163. b16a2
  164. CC of type s piston dome?
  165. low compression in cyl #1 on a b20/vtec...
  166. Question on Degreeing JUN III's
  167. what kind of power would a gsr with b16a2 pistons make?
  168. aftermarket fuel rail for B20vtec
  169. 4.7 fd into 5th gear b16tranny at 1/4
  170. Engine Builder in SC, NC, GA Area
  171. *help* timing on a 1.5, 88 civic
  172. lma's going bad? cross post to FI forum
  173. b20 redline....
  174. 10-94 header dyno
  175. dc jdm 2.5 header+2.5 testpipe+2.25 b-pipe= OK?
  176. 12:1 compression
  177. how many distributors have you killed?
  178. skunk2 stage 3's
  179. str tb ....sticky and stiff throttle???
  180. Whats better? Semi built b18c1 or Poor Man's Type R(b18cblock/b16a head)
  181. looking for a swap
  182. ITR cams in GSR head... Valve adjustment specs...?
  183. opinion on manifold
  184. 11:5 compress in a GSR
  185. endyn rollerwaves for h22 compression... WTF?
  186. My B20 VTEC build up
  187. HELP... Looking for Rods for LS/VTEC
  188. Having Problems with Local Machine Shop
  189. attn:ls non vtec owners tranny question
  190. I Have No Idea Whats Goin On
  191. exhaust and A/F RATIO??
  192. b18b w/ stroker kits?
  193. anybody running jdm ITR or CTR wrist pins on eagle rods?
  194. Why is it recomended to use the same brand cam gear, as cam?
  195. Did a Search - Need Contact Info for Erick's Racing/STR/etc. Throttle Body PLEASE.
  196. Aeromotive AEI-11101 Fuel Pump
  197. need opinions on this setup and have some questions
  198. b20z non vtec or b16
  199. What have I got?
  200. itr throttel body install
  201. Recommendation for fuel pump?
  202. CTR vs. Skunk 1's and then some ...
  203. Opinions on this header
  204. Cam recommendations for 12.0:1 compression
  205. Suggestions: affordable header / legalities
  206. VTEC oem bearings VS LS oem bearings
  207. Where to start?
  208. all motor cars in ventura county/santa babara county
  209. Best place to get rebuild parts for my d16z6
  210. B18C increased displacement & hight reving
  211. 88-9 integra pistons in my d16z6?
  212. junk K motors?
  213. running a pr3 on a stock b18c , question about manifolds
  214. Ls/Vtec rev-ability..
  215. crower 95mm crank
  216. VTEC Cut Out
  217. Ls/Vtec
  218. ?? about compression
  219. If you have a +220 WHP engine , please let me know your setup. Here is mine.
  220. Looking for an used ENDYNE AIR carbon IM
  221. GSR or ITR crankshaft ?
  222. Mugel or Moroso oilpan for road racing
  223. Tell me if my plans are sound...(concerning near dead b18c1)
  224. Duration and Lift on cams ... What does it all mean???
  225. h22a dyno 220 hp to the wheels
  226. Which alternator belt w/ CTR n1 crankpulley
  227. What Intake Manifold? (H22)
  228. Rev Limit: B18C1 w/ ITR cams/valvetrain, PR3
  229. what custom crank for gsr block?
  230. B20A1/3/5 and B21A1 Block and general info needed
  231. ANYONE HAVE A LS-VTEC WITH CTR PISTONS (12.2 +/- TO 1)
  232. 4-1 to b16a1
  233. b16 or b18c???which motor is better to built up.????
  234. Lost my All Motor to Lun in Socal....
  235. air fuel ratio guage question
  236. what sleeves to use...hmm
  237. 190whp lsvtec stock TB adding 68MM what gains
  238. IM/TB combo what would you recommend?
  239. Ericks Racing throttle body idle adjustment screw doesn't do anything?
  240. Having Problem fitting GE Dowel Pins
  241. Anyone here run crower 403's on the street?? vs. say the 402's for street.
  242. 96-97 itr header?
  243. Building N/A Motor
  244. B16A1 cams vs B16A3
  245. flywheel question
  246. I put in a ITR cam today...and I'm sad. (CTR)
  247. TWM vs. TODA vs. Hayward Performance ( ITB's)
  248. Fuel pressure regulator (adjustable)??
  249. What Side of Valvespring is UP??
  250. Anyone have some exhaust comparison dynos?
