PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 [180] 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Is there any difference in JDM or us model b20b's
  2. Where should buy my timing belt?
  3. best place to buy k20 swaps
  4. motor build
  5. could a blown head gsaket lead to motor seizing?
  6. TWM Airbox for ITBs... anyone have first hand experience with it???
  7. Stock K20A tuned by Chruch's
  8. Mill PR3 head?
  9. what elese do i need?
  10. How do I pick bearings?
  11. rich running condition
  12. F22b into my Civic
  13. Skunk2 Stage 2 Cams
  14. SRP-Pistons good/bad for Turbo
  15. What Pistons to put into my GSR block with a B16 Head???
  16. Question from Europe
  17. uberdata sucess lsvtec 227whp and 151 ft tq!!!
  18. FITV Question
  19. Opinions on cams and cam gears
  20. latest SMSP d-series header offering arrived today---
  21. 3 angle valve job...worth it?
  22. running 10's on OEM block on gas...
  23. PCV issue
  24. Cost/gains from C/R increase in B18B w/403s
  25. H22 ITB people
  26. ANYONE USING ITB IN B16 HEAD???
  27. B18 VTEC CAMS and Valve Train
  28. Header questions
  29. SOHC upgrading
  30. Race cams
  31. Wanting to install Pistions??? Need some H-T advice though....
  32. 2.15 liter GSR motor talldeck, port polished ITR head = which intake manifold?
  33. What do you guys think of my bottom end plans
  34. Intake manifold HP difference JDM B16 VS ITR
  35. ls vtec
  36. Manifold?
  37. Max bore on del sol TB.....
  38. Signs of Bad Valve Guides?
  39. compression of pr3's in a b18c1
  40. Will any USDM swap material fit on a JDM engine?
  41. Memoryfab Carbon Fiber Intake = J's Racing Intake?
  42. B16A or B18B?
  43. jumpy idle
  44. Running ITB"S
  45. surging
  46. ITB Motors...........check in
  47. Apex V-AFC2 Wires: What are each for?
  48. High compression d15b2
  49. First post test
  50. Headers
  51. us itr piston compression ?
  52. LS whp? post your numbers people!
  53. LS PR4 rod interchangeablility???
  54. anybody here done a all motor f20c?
  55. What kind of Cams do I have...?????????????
  56. who makes good allmotor b18 cams?
  57. B20z into 92 Si questions and tech related questions
  58. ls vtec compression
  59. NEW! J's racing intake
  60. Crower valve springs and retainers, what kind of seats?
  61. Comp Test on Frankenstein Set up
  62. 85mm, 12:1, which cams for power between 5k and 9k.
  63. ls/vtec head milled .040...cam gear adjustments???
  64. motor bogs under any throttle??
  65. model 2 engine match
  66. Just another B16a dyno w/bolt ons...
  67. high flow cats
  68. Engine Start Up....
  69. how to tighten sohc timing belt
  70. Which Civic Is The Best?
  71. Where's a good start for my h22?
  72. do they make aftermarket roller rockers for B-series?
  73. all motor build. tech43 1.9l b16.
  74. Did you see a nice improvement with your itr cams??
  75. Went tuning today...Got some cam timing questions, ect.
  76. F20B specs?
  77. engine question
  78. is my car goona run right with s2s1
  79. n/a building
  80. Wideband O2
  81. 2 blocks back from ERL Performance
  82. would this throw my rotating assembly out of balance?
  83. GSR CRANK -versus- Type R CRANK both balanced and micropolished?!?
  84. skunk2 stage 2 cams make power to high?
  85. b18c vs h22 typs s
  86. AEBS or BLOX
  87. BLOX intake mani dyno result, mild GSR
  88. VTEC ENGAGEMENT PROBLEM...PLEASE HELP!!!
  89. Cam Choice...
  90. Throwing codes in 89 Rex with 01 GSR
  91. ls/vtec with nitrous how safe?
  92. b20vtec Fuel Injectors
  93. Is ANR header a little too much????
  94. Need Advice
  95. Big HP D Series Header
  96. 99 gsr getting ready for the b20 setup!
  97. IACV itb problem.
  98. need input: What size headgasket to help on set-up. (ls/vtec)
  99. do i need a bigger fuel pump???
  100. b16 twm ITB's
  101. skunk2 vs ctr
  102. ctr s2s1 cams with nitrous
  103. D16a6 mild build questions
  104. Dynamic Autosport header install and questions...........
  105. stock sleeves /my setup
  106. jdm or not jdm
  107. need help tuning
  108. LS VALVETRAIN PARTS?
  109. GSR or SiR head
  110. Installed Crower stage 3 this weekend...
  111. Which head?
  112. Advanced Timing= no VTEC???? need help
  113. Crower Econo vs Eagle
  114. Header (keeping AC / PS )
  115. Need help motor reving up and down
  116. going belt crazy!!!!
  117. FREE IPODS!!!!
  118. Piston Ring Installation Question
  119. How IS THis Possible
  120. help tuning b16a!
  121. Hesitation under load / temporary loss of power. MAP or dist?
  122. what to do???
  123. Stock Honda Rods
  124. SEARCHED: hondata tuner near South Sarolina. NOT BALANCED. SGT moved. P1doenst offer hondata
  125. What spark plugs to run???
  126. what is the optimal fuel pressure for tuning?
  127. ecu problems ?
  128. still loving b16a stock block 185 whp 115 ft-lbs
  129. Crower Stage 3 404 Cams for B18a/b Questions?
  130. My possible winter projects: K20-R swap *or* built B-series, thoughts?
  131. HOW MUCH HP WITH THIS SET UP????
  132. Skunk 2, stage 2 cams.
  133. installed Crower Stage 3 today...seems rather noisy, what the deal?
  134. crank case breather for b20 vtec????
  135. General Cam tuning
  136. Short ram or cold air for stock ex
  137. Motor Oil Question
  138. new aquired f22...what to do?
  139. vafc help
  140. Good ITB question
  141. FEELS header anyone have ANY info on it ???
  142. LS/VTEC. b16 head/b18b. What arp headstuds do i need?
  143. what does dyno and timing do???
  144. Rev Limit? (12:5 B20/Vtec, stock sleeves)
  145. topline stroker kit....anyone know anything about it???
  146. ls/vtec pricing problem
  147. B18c ARP main bolt install?
  148. Decisions Decisions
  149. Need Help!!! Block Related with plugs on a B18A
  150. new motor in civic HB (quater mile times)
  151. new here, some b series questions
  152. What is a good brand/model of degree wheels that will work with the engine still in the car?
  153. Q?? high compression motors using oil
  154. How much would you pay for a 98 hatch w/ gsr swap or 98 hatch w/ stock motor
  155. LMA's?
  156. b20vtec idle is 1100-1600
  157. Head work
  158. K Series ITB
  159. hondata
  160. is it a must to use a fuel pressure regulator when using a ctr pistons in a b16a2
  161. B20vtec C/R on 93 octane
  162. How can I tell a Real set of Skunk2 Cams?
  163. Broken Axle or not?
  164. Got Torque? F23 Block, H23 Non-VTEC head Hybrid
  165. Need some help from tuners
  166. regulator question!!!h22a4!
  167. b18a rods pistons into b16a
  168. More LSVTEC questions...
  169. Header wrap on intake?
  170. Aftermarket cam users: experience valve float?
  171. MUGEN HEAD GASKET+HEAD MILLING WORTH $???
  172. Question on Rockets M20 cams?
  173. Pics of destroyed ITR head, Forrest gump does a cam install....
  174. New and need Honda engine advice!
  175. 2 long blink....2 short blinks...OBD0
  176. B17 w/CTR pistons, what should I do next?
  177. How good are Crower Stage 3 404 Cams for B18a/b?
  178. b20 arp rod bolt size
  179. need a tip to beat a rsx type s please help.
  180. H22a?
  181. Pirate's New H23/F23 Hybrid DYNO RESULTS
  182. JDM ITR Pistons, Head Mill, Cam Gears & JUN III's.......hmm...what do you think?
  183. Longevity vs. a slap together project
  184. 2.0 bvtec intake manifold ?? which one is the best ???
  185. building my B16a2
  186. spun bearing or LMAS?
  187. ctr cams help
  188. b20vtec questions
  189. Should I go with a swap or lsvtec
  190. N/A Nonvtecs, I need your help!
  191. how much compression can the K20s hold
  192. Whats wrong with my spark plug?
  193. Would you make a High Compression B series for Daily driving?
  194. other ITB brands
  195. ctr piston +buddy club 3plus + omini springs + b16a2 how to tune it????
  196. New engine?
  197. my goal with b20z vtec!!!
  198. SKUNK 2 valvetrain???YAY or NAY???
  199. LS RODS RELIABILITY
  200. Any one run EXOSPEED b series cams?
  201. ohms Resistance
  202. most aggresvie sohc vtec motor cam
  203. what makes intake sound?
  204. How much could i get for this motor?
  205. installing ARP rod bolts
  206. PCT's and their #'s
  207. looking for a respectable custom header builder: for a nissan..
  208. b20z intake manifold vs stock LS... any better?
  209. an-r header
  210. b20vtec ECU ?'s
  211. b20 type r
  212. b16a vs. b18b????
  213. what comp for my cams?
  214. ? for all the sohc experts............
  215. lsvtec C/R 11.8!! with b16 pistons?
  216. ls/vtec problem!
  217. B18C1
  218. Cams
  219. Which head gasket to use, to bump up compression?
  220. b20vtec VS. B18c5
  221. PR3 cams in P72 Head
  222. is b20 vtec really worth the trouble????
  223. What cams for b20vtec
  224. ONE NUB QUESTION??,...
  225. Valve Springs
  226. Longevity od YOUR LS/VTEC
  227. all motor b16 v.s. all motor ls/vtec (race motor)
  228. piston coatings questions
  229. Question on CTR pistons with b16a2 *already searched*
  230. Sleeve or Bore
  231. my bc3+ cams finally arrived.. need some advice on tuning please..
  232. Finally got the car back up and running! An introduction to H-T.
  233. anyone here run open header or an exhaust cut out?
  234. BREAKING IN MY FB LS/VTEC?
  235. skunk2 valve springs ?
  236. OS type r pistons???
  237. ECU and Tuning advice on setup
  238. h22 crower stage 3 cam question
  239. Help D16 build up
  240. ITB EXPERTS HELP OUT!!! tok her out for a drive!!
  241. is it my p28?or my wirings?
  242. idle on GS-R??
  243. :::PLW wideband 02:::
  244. safer bet 403 or 404 crowers
  245. Tuned or not ????
  246. 3" exhaust...too big for n/a?
  247. need some more specs....
  248. Powdercoat obsessed !!
  249. Complete Engine Gasket Kit ... Need some guidance....
  250. Intake manifold Throttle Body setup
