PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 [165] 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. mini me on d16a6 use y8 or z6
  2. Who has the best price on Scat Cranks???
  3. How to identify if the head is built...
  4. b18b piston question
  5. CLEARANE ISSUE?
  6. looking for a streetable cam that wont wear out my valve train so fast
  7. exaust scavaging vaccume pumps and crank case pressure
  8. B20z pistons
  9. Dave Hickman and a 215 whp SOHC sheet hahaha
  10. Had the b16a for almost 2 yrs. time to go faster, need suggestions
  11. New Engine Buildup, Edelblock Victor X or not?
  12. arp for ZC all motor
  13. another Engine Management Thread :)
  14. oversized or not?
  15. Old crowers to new crowers?
  16. Need help fast! Headwork soon!
  17. Driving untuned..
  18. DIY ITB: Injector sizes!
  19. DC Sports header
  20. Best Bang for the BUck set up for B-series ALL motor
  21. valvetrain upgrade! What else?
  22. b18b all motor injector size
  23. how much should i expect to pay for an lsvtec?
  24. What cam should i use?
  25. LS VTEC: Best clutch?
  26. Bent Valves.......?
  27. CBR 600 F4I throttle body good for itb's for a d series????
  28. Who does ecu chipping in Texas?
  29. SOHC Crane cam users LOOK
  30. problem with AFR
  31. cams specs? post cam specs here
  32. Will a bad brake booster cause a fast idle problem on my 87 civic?
  33. What is this plastic piece
  34. vafc
  35. stock jdm type r video
  36. Opinions on CTR pistons w/ pump gas
  37. JG Camshafts????
  38. ATS gears
  39. How high can i go compression on 94 octane?
  40. dc header troubles
  41. Balancing Shafts
  42. Ls Block need help
  43. Custom exhaust for a ZC
  44. Fastline perfromace oil baffles, any good??
  45. questions on drysump and what valves?
  46. H22 Hi Flo cat?
  47. High Idle: Skunk2 IM and JG Throttle Body w/ no FICV
  48. will i be undercamming wit this setup fully tuned
  49. san diego hondata
  50. i just installed it ... now what ?
  51. GSR or CRVtec???
  52. Thermal losses/testing...what is ideal water temp?
  53. ctr pistons n gsr rods in b16a
  54. Speed govener sucks
  55. .5 mm Oversized valves, with skunk 2 stage 2 clearance?
  56. Serious Question for those with high comp ratios
  57. cams?
  58. 8mm Arp rod bolts in a LS
  59. spark racing pistons vs. topline
  60. AEBS GSR intake manifold released? am i missing something?
  61. 2nd and 3rd grind FIXED With Inserts.
  62. B20 swap requirments.. what else do i need??
  63. Wrist pin removal without damaging the piston?
  64. ls vtec questuon opinions on pistons (also estiomated power output
  65. \\\ 205whp - 1.8L - 91oct - lsvtec -dynochart inside! ///
  66. Budget Header Comparison
  67. timeing???????
  68. 217whp w/ 143tq ITR piston no port 91oct. 1.8L
  69. Decided to try my hand at some headwork. What do you think?
  70. Calling ALL header Manufacturers
  71. where does this plug go
  72. backpressure...need help
  73. backpressure...after every shift?!?!?!?!?
  74. h22 swap into CRX
  75. can these be fixed?
  76. problem with toda header
  77. B16 head's
  78. in-line fuel pressure gauge readings?
  79. Question about a used Automatic Japanese Transmission for a 99 Integra LS.
  80. Whats minimal upgrades for Toda Killer cam?
  81. need wiring diagram for vafc..version 1
  82. Sneak Peak: Half of a 2.0L project complete...
  83. electrical problem... experienced help needed
  84. Throttle body
  85. Which intake manifold?
  86. 9000RPM DESTRUCTION!!!
  87. im confused , please help figure this out .
  88. H22A1 N/A Brand NEW. White Smoke?
  89. Surging Idle - Help please!
  90. IM GETTING DYNOED TOMORROW
  91. Anyone wanna buy a spare '95 GS-R short block? (Make offer)
  92. b16 head on type r block
  93. ITR tranny gains
  94. best upgrades for a B18C5?
  95. high idle after skunk IM install
  96. Will CTR piston fit in my b20/vtec?
  97. A question for all the H22 owners out there
  98. starting my lsvtec build (what do you think?)
  99. Battle at 10,000 (I won?)
  100. Traction bar question
  101. skunk 2 stage 3 cams with usdm p30 pistons
  102. stock gsr rods at 9k
  103. New project...need help
  104. Swap shop in SAN DIEGO?
  105. Build Up help
  106. should i get one ?
  107. Poll for those that have destoyed an oil pump...
  108. Dynamic compression
  109. All motor lsvtec compression question??
  110. danm Hondata help!
  111. which is an intake or exhaust cam??? help
  112. Ferrea Valves Question...
  113. Break in period--CTR pistons.
  114. Best Gsr hearder for the money
  115. What oem pistons for my build?
  116. Stock rods - might broke at 9k rpm?
  117. Looking for advice on b16/b18
  118. **MUGEN HEADER for BSERIES
  119. Compression tested WTF?
  120. block girdle (search is down)
  121. Bearing Size or kit For B20's
  122. !LL W!LL's B16 Dyno Results! Stock bore/stroke! OEM Honda! 200+whp?
  123. gsr cams into a jdm b16a
  124. what is the perfect spark plug and wire setup for...??????
  125. pics of JG sheet metal intake mani?
  126. Dyno results of a tuned Ls/Vtec OEM parts build.
  127. info on IB spec vavle springs and IB spec retainers?
  128. KOS header help?!?
  129. Tb size
  130. Another B18A question.
  131. Feedback for Track Speed Racing.
  132. Exhaust Piping Size?? (alread searched!)
  133. spark plugs.. lean ??
  134. Any cam markings on skunk2 stage3's?
  135. Yet another possible choice for hi flow cats
  136. aem uego for obd1 o2 sensor.
  137. ITB's will this work
  138. jg cam gears off??
  139. Anyone advice
  140. Whats a code 5 for a b16a vtec?
  141. Mild ls/vtec ef video<<<<<<<<<<<<<<<<<<
  142. Valve seals
  143. B16B + Toda B's
  144. welding combustion chambers
  145. BBK IM???
  146. b16 with d16 exhaust
  147. DPR FI Touring Camshafts
  148. recomended cam gears for a B18C
  149. M22/x/xx Cams in Stock SIR2?
  150. CTR
  151. who all here are running ctr pistons in there b18c1 block?
  152. ANY TUNING SHOP IN NYC
  153. Clutch Suggestions.
  154. cam girdle
  155. Civic Street Legal from Puerto Rico
  156. [FAQ] ECU codes. wiring. and more inside
  157. BC spec 4 vs M22????
  158. what do i do?
  159. Help identifying cams.. PLEASE!
  160. what kind of cams ildes good and make good pwr?
  161. GSR AEBS intake manifold - any info
  162. SOHC TURBO or H22
  163. lightened stock flywheel???
  164. projected DYNO numbers 1.8 B18C
  165. will portflow inner valve springs be compatible with bc3+ cams?
  166. RLZ Engineering's 2004 Season Comp 4 Motor dyno inside
  167. need help with with what wires go where....
  168. Hp Gains on the Non vtec B18
  169. sohc vtec f22b1 motor build
  170. ebay ITR header
  171. just dynoed my new motor
  172. Compression test: Is it possible to have "0" in a cylinder???
  173. cam question?
  174. stock block b16a2, suggested cams?
  175. Throttle body to big??
  176. Which gasket for RPM Services Throttle Body?
  177. ctr cams in b18c
  178. p30 question
  179. Crower Stage 2's how much power..
  180. NEED HELP i need a wiring diagram for a VAFC II ASAP its going in a 98 civic
  181. Buddy Club B-Series VTEC Motor Spec V Plus Camshaft
  182. Red Civic Standard -- pics of my allmotor setup 2005
  183. Are OBD1 and OBD2 distributors internal's the same? help!!??
  184. Port matching manifold
  185. Why would these bolts break? (cam holders)
  186. who has an oil temperature gauge and why
  187. Where can i get a b16 head for a cheap price
  188. Check this out. Examples of how not to install an oil pan.
  189. ITR setups
  190. pr3's in b18c1
  191. Crank Balancing...
  192. Oil Cooling
  193. getting itr cams (b16) what power do they make from 8200-8500 rpm
  194. NEED YOUR HELP GUY'S ON MY NEXT SETUP ASAP!!!!!!!
  195. my build up
  196. How do you calculate compression ratios?
  197. Accidentally fueled up with 87 octane, and now!
  198. FOR ANYONE WHO HAS USED THE OBD CONVERSION HARNESS
  199. Any tunning shop in MA. area
  200. engine choice
  201. b16a vs. b18c1
  202. Header question
  203. Where should i get my swap from????????????????
  204. itr header question
  205. Euro Intake Manifold....
  206. Step by step: How to install a crank scraper (with pics)
  207. Exhaust size question !!! Which muffler to use.
  208. compression ratio on stock ls block w/ gsr head
  209. 4.9 final drive ?
  210. used itr cams? ASAP!!!!!
  211. CMI HIN?
  212. Emission Question??
  213. Crower 403's??
  214. obx intake manifold
  215. valvetrain...b20vtec
  216. B18A block with GSR rotating assembly?
  217. intake and exhaust...whats next???
  218. I had my engine rebuilt and would like a few opinions as to what direction I should take my engine..
  219. You Cock Smokers
  220. anyone know where too get flex pipe for a good price???
  221. B17-not enough comp. for skunk s2?
  222. HELP!! Firing Sequence messed up.. im under the clock here..
  223. 01 Prelude H22 tuning
  224. aftermarket Bike ITB's?
  225. 92 accord
  226. Which cams should i get?
  227. (Catalytic) do you loose power if you hollow it out?
  228. I want to make more power......... Here's how I plan to do it!
  229. Fuel Pressure on RSX-s?
  230. K20 Into A 1995 Accord
  231. To those with AN-R Header...
  232. b-series headers
  233. dyno results
  234. Endyn Breather Kit and Valve Cover Vent Question???
  235. Change final drive or tranny swap
  236. denso iridium or not???
  237. First time dyno...opinions.
  238. Will my motor be okay?
  239. DTR B Series Race Header
  240. Stroked B16
  241. 4-6thou worn, 0.25mm rebore??
  242. 12's with 181whp?
  243. all motor gsr
  244. VAFC throttle points?
  245. Engine problems! some one HELP!!!!!!
  246. welded diff. to make LSD
  247. CTR cams and compression........
  248. p72 chip
  249. Skunk2 Pro Series
  250. crank!!!!!!
