PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 [201] 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. should I ?
  2. header hardware
  3. help with itb length on b16
  4. how important is air intake temp sensor?????????
  5. (an-r v.s ericks racing)
  6. Toda Timing belt really needed???
  7. T1R header link
  8. Can i get this any cheaper !
  9. Fujitsubo
  10. rsx type-r motor
  11. BBK throttle body and TYPE R manifold
  12. Torque Specifications for ARP headstuds in ls/vtec
  13. ls swap in a 99' hatch
  14. Got my DTR header today..
  15. Q 4 B20 allmotor set-up
  16. Need help with D16Z6
  17. im stuck at a crossroads, i need help with choosing my new motor (kinda long)
  18. distributor for ls/vtec
  19. header fitment into crx???
  20. Jun 3 Rev capabilities? Limit?
  21. What header is this?
  22. My JDM ITR 4-1 hits my LS oilpan
  23. CTR cams or JUN type 2 ??
  24. What is a good throttlebody size?
  25. Need Chassis Help!
  26. H22 Intake manifold?
  27. Q on ITR rear muffler
  28. B18C-R
  29. Noticable gains from skunk2stage2 cams?
  30. cams
  31. DIY: GSRX 750/1000 Homemade ITBS
  32. Dart Talldeck (link)
  33. Fuel Injectors and Fuel rail question
  34. Diagnostics Please - Allmotor problem...
  35. Baby R "poor mans type R"
  36. CTR pistons in b16
  37. sti in jectors
  38. Mugen Head Gasket
  39. Oil In PCV and valve cover lines
  40. need input on tuning, EEPROM programming any good?
  41. JDM? USDM? How can you tell the difference??
  42. Toda B's
  43. Good site for parts...??? HELP!!!!
  44. MSD 7AL on JDM H22... HELP!!!!
  45. All motor B20 Vtec
  46. Lightening stock flywheel good/bad??
  47. Dyno Numbers??
  48. What AEM EMS to run???? Anyone?
  49. How hard H series in Ek hatch...???
  50. Hows this list for my b16A2 N/A set up?? This is more of the top end setup.
  51. Questions on current setup??
  52. ecu needed ??
  53. Mugen Twin Loop for my setup ?
  54. b16 just dont cut it any more
  55. all motor setup
  56. Type S????
  57. Help I need fiberglass doors
  58. My 1st 1/4 Time with new motor..CRVtec
  59. Milled head and timing belt
  60. VAFC2 - where to tap it?
  61. claying motor head gasket question ????
  62. All motor B20z ??
  63. I've found myself in a maze - this import tuning stuff is killin me
  64. no more vtec on my b16??
  65. Advise
  66. Jun 3 cams?
  67. im going all motor in my gsr who should pnp my head
  68. DC Header wrap-
  69. Best header THAT RETAINS A/C?
  70. Compression based on camshafts
  71. clutch for my application?
  72. 929 ITBs, DSM injcetors wont fit!
  73. HYBRIDS JP!!!!
  74. ls/vtec power drop off????
  75. Question about the Skunk2 valves.
  76. act pressure plate?
  77. How do i know if my AC compressor is bad (DC2)?
  78. Big Difference between ctr/pct and jdm itr pistons in a b18c1
  79. Spark Racing Engine Builders?
  80. power i should make with this setup??
  81. Ideal Compression?
  82. Finally my JUN parts arrive =)
  83. optimum 00"civic swap
  84. AEBS Torque Specs?
  85. anyone here use nippon pistons or rings???
  86. aem or iceman whats the best
  87. hey whats better hedertech or smsp headers
  88. B18C1 timing
  89. need info on crvtec's
  90. Rust on cams.
  91. Another retainer thread....
  92. Header Tech (Link)
  93. Prelude V-tec
  94. HELP ! i need technical guide for FORESIGHT 250cc
  95. Ls/vtec opinion
  96. what kinda valves??
  97. b20 with b16b head?
  98. non vtec b20 header hang low????
  99. With $1000, what could I add to my B16A?
  100. Opinion of an action clutch??
  101. VTEC question?
  102. HELP!! PR3 Head, Crower Stage 3 cams - no valve lash
  103. B18A head on B20B block... will it work? any hp/tq gains?
  104. Cool Can
  105. cleaning piston tops???
  106. My new and first project – 88’ All Motor D16 Rex!
  107. JDM ITR final drive in a 93 JDM YSI?
  108. Cams in GSR with pct piston?
  109. accord flywheel
  110. Does anyone know the rod length of the F22C/2004 S2000 motor?
  111. videos with the ending .mp2
  112. need help
  113. 1.8??2.0
  114. si vs. gsr tranny
  115. Toda Cams, Stroking, and the beauty of DC5
  116. Check the ITBs
  117. b20a5 + b18c1 head + ? = vtec?
  118. JDM ITR Pistons and Rods in a GSR engine = Weekend Job w/out Pulling the Engine?
  119. dyg2001's 2.0L Dyno Chart
  120. how fast is 220whp in 1/4 mile?..
  121. bearing sizes for ls/vtec??
  122. gsr question
  123. disabling gsr secondary valves
  124. A/F ratio Running Rich
  125. Is it possible?
  126. aebs tyhpoon intake manifold
  127. [CAM ID possibly GSR]
  128. video:b20/vtec 223 whp
  129. ls/vtec or poormans type R
  130. Oil Pressure Sending Unit ?
  131. anyone use dpr rods???
  132. CTR pistons too much for daily driven ls/vtec?
  133. introducing a new ITB to the market!! (australian)
  134. Ignition Heat Issues?
  135. Receiving a set of free ITR cams...is changing pistons a "simple swap"?
  136. CALLING ALL JDM ENGINES!HOW DID YOU WIRE YOUR 4 WIRE O2 TO TAKE AWAY THE CEL
  137. what fuel pump is best for my setup?
  138. Any way to rid of rev limiter without new ecu????
  139. ls vtec qusetion
  140. anybody have step by step instructons on how to change a release bearing?
  141. Noob question about raising compression and A/F ratio
  142. Port and Polish Question
  143. release bearing question....can somebody help me out??!?
  144. pro's and con's of switching b18c head with b16a head
  145. Thoughts on my setup and HP potential..
  146. Dees anybody have a list of Honda TB sizing?
  147. camshaft installation
  148. Which pilot bearing?
  149. Ctr cams in a Gs-r??
  150. all motor race car fiberglass parts question.
  151. Budget Buildup any suggestions?
  152. New Pistons: 4 ring grooves, Rings included: 3 rings..??
  153. 81.5/ 82mm piston around 11.5 - 12:1
  154. B20 rods in a b16!!?
  155. Can a bad o2 sensor affect hp?
  156. AN-R Intake Manifold for GS-R?
  157. k24 vtec
  158. Question about GSR
  159. V-afc tuning
  160. Good Numbers ?? 99 Si b16a2 ... and Predict my numbers... b18b
  161. 92-95 civic size radiator in GSR
  162. Heat wrapping stainless steel headers bad?
  163. b16supertuner - All motor build Pics and Specs..
  164. question about pauter rods
  165. Opinions on my future set-up.
  166. new motor break in?
  167. oversized valves and cam Q
  168. AEBS Intake Manifold for 2000 B16
  169. Diagnose this: Clutch or Tranny Problem?
  170. Red Civic Standard -- pics of my allmotor setup
  171. How do you have the valve cover so you can adjust the cam gears
  172. T1R or Skunk 2 mega power cat back
  173. best place to buy a complete/stock shortblock?
  174. best c/r to run
  175. importance of torque
  176. replacing cams and dyno stats for them
  177. Gs-r EG
  178. Which piston rings to get (all rings the same?)
  179. B20 non v-tec times
  180. What is a good book on engine building
  181. Which engine should I chose next?
  182. got the all motor 2.0 Vtec dynoed
  183. I NEED guidence from this forum please help!
  184. Specs on exospeeds y7 cam ?
  185. reworked skunk manifold
  186. valve adjustment with skunk stage 2
  187. Anyone ever deal with Hytech Exhaust in Irvine, CA???
  188. Installed Air/Fuel Gauge.. getting nothing from white wire..
  189. Head Work
  190. milled head, cam and ignition timing
  191. B20VTEC with GSR tranny should I go with a JDM S1 tranny for quicker times??
  192. AN-R header!
  193. What are the all motor setups running now a days? street... (1/4 mile)
  194. Help with Exhaust Decision
  195. tech 43 ls cranked b16 piston kits
  196. Pics of Norris Prayoonto's New All Motor K series Drag Insight!
  197. ITB info site ?
  198. 95mm crank B series
  199. B16A2 dyno problems - VTEC engagement?
  200. who makes 98MM or 100MM cranks for H22A?
  201. which ITB's are plug and play??
  202. Shot peening or eagle rods?
  203. B18c1 Block Sleeving
  204. Guess HP/poor mans type r
  205. Ferrea Valvetrain
  206. Any D series warriors here?
  207. Gear setting on a SOHC Vtec and compression?
  208. Clutch Question (Searched)
  209. redline abaility of a B20 block?
  210. fresh JDM motor has no compression
  211. Tuning with Cam Gear and CTR cams.
  212. minime(b7+z6) or jdm d15b vtec??
  213. When stretching rod bolts...
  214. 93 pump gas with octane booster...
  215. is a jun header worth it for a all motor, please reply asap
  216. Main Bearing Help Needed
  217. CHECK MY SET Up
  218. Dual carb kit...I got one!Whats it off?
  219. How in the world do i log out of my bro's account and register so i can post in this thread!
  220. Compression on jdm itr block with ctr cams with stock head gasket??
  221. Nar Spec Header?
  222. what type of tuning would be needed with this setup?
  223. to stroke or not to stroke ?
  224. b18 vtec block with b16 head..what head gasket? b16 or b18 or are they both the same?
  225. What's this BLACK thing on the Flywheel??
  226. Skunk2 Stage 2 camshafts on EBAY
  227. Anyonew have Pictures of their All Motor Cars
  228. www.fastestfwdstreetcars.com is updated...........lots of all motor cars.
  229. Are type R valvesprings and retainers strong enough for S2S2's?
  230. Anyone seen a Cold Idle Valve Block Off Plate???? Details Inside. Skunk2 IM Users PLEASE READ!
  231. Sugestion....B18c, Itb....cams, and compression
  232. want more power out of my NA
  233. Stage 3 cams with milled head
  234. Are ITB's Streetable or Race ONLY???
  235. Thin head gaskets
  236. Authenticity of CTR cams...
  237. APEXI POWER FC Tuning........
  238. Milling a H22 Head
  239. dyno from my ITR
  240. Piston to deck height
  241. Should i go with this (not fantasy tuning)
  242. Need help with High Comp. Pistons
  243. Bore my C1??
  244. i have a ?
  245. What to buy next....
  246. b16sirII or B18c(obd1) or h22a
  247. In a high output NA engine (185whp +) which
  248. any experince with dh-racing heads?
  249. LIGHTEN flywheel...newbie!!!
  250. What can I rev to?
