PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 [73] 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. i think i blew up my motor
  2. Supertech Springs and Ti Retainers Yay or nay?
  3. how big can you go with a b20?
  4. .catch can or breather kit
  5. what transmission came on OBDI 1.5L vtec
  6. Initial start up problems! clacking sound and engine wont rev up!
  7. need more power
  8. Al vs Ti vs SS retainers?
  9. need some all motor transmission advice...
  10. 3rd Gen Odyssey was 255hp for 05, but 244 from 06 on...
  11. Throttle Body size
  12. Type r piston in gsr
  13. Ku engineering Intake mani
  14. Connecting rod numbers
  15. valve spring color ?
  16. Buddly Club IV Cams Defective?
  17. anyone using Obx high flow cat?
  18. distributor question
  19. Valves? Ferrea vs Omni?
  20. Official **K Series** Camshaft Thread
  21. Official **B Series** Camshaft Thread
  22. Official **H series** Camshaft Thread
  23. Official **D Series** Camshaft Thread
  24. 0.040 or 0.030 Head Gasket with Domed Pistons!
  25. best place to buy oem distributor
  26. b18c5 with CP 11:5.1 Pistons.... suggestions on cams
  27. Skunk2 pro1's, pro2's or Tuner Stage 2???
  28. is this block trash?
  29. Upgrade Radiator?
  30. Help with H2B setup
  31. help on identifying cams
  32. Ls V build...
  33. Hayabusa Throttle Body on a SOHC has anyone done it
  34. b16 piston clearence question
  35. cam opinions b16
  36. h22 piston rings? HELP!!!
  37. Rocket Motorsports m23 cams in lsv?
  38. help picking the right cams
  39. b20/vtec problems
  40. LOOKING TO MAKE RIGHT CHOICES FOR MY H22 BULID
  41. B18c6 over bore question
  42. gsr block ls crank which bearings????
  43. LSvtec cam question???
  44. msd distributor 8488 worth it?
  45. rod and piston ?
  46. Port&Polish = Lower CR??
  47. boring problem
  48. Catch can question
  49. Greddy Timing Belt
  50. AC Condensor
  51. how to check if a crankshaft is good.
  52. Please, few questions about Tanabe Hyper piping...
  53. k series
  54. skunk 2 cam gear owners
  55. Are Tuner springs and Retainers good for Pro Cams?
  56. quick question about my tachometer
  57. Recommend a header for my DOHC Sir2 DD
  58. NEED HELP ASAP PLEASE
  59. what cams should i run?
  60. Want to Extrude Hone my Performer X - Any Recomendations?
  61. port and polish questions
  62. Block Guard
  63. knock sensor?
  64. BPI Flowstack users chime in.... couple of questions.
  65. itr valve springs/retainers
  66. 2.0l attempt advise....lol
  67. Tune it?
  68. BluePrint K20 ALL MOTOR build
  69. Best catback
  70. honda civic bolt ons
  71. fuel filter fitting...metric to AN adapter
  72. P72 Ecu with Blox Intake Manifold.....will it work?
  73. Degreee specs for BUDDY CLUB STAGE 4's please... i already searched
  74. RC310 Injector Installation
  75. Changed my oil viscosity - pressure is up substantially
  76. b16 build
  77. Best VS/retainer combo for IPS k2's?
  78. Big tube tri y or regular?????
  79. skunk2 tb FAILURE destroyed my engine what can i do........
  80. biggest cams for my setup?
  81. tranny problem
  82. ctr cams in gsr and more
  83. pro1 extend driving question
  84. JDM ITR 4-1 Header on 1st gen B16A problem.. (touching oil pan) safe?
  85. Compression test results. Input appreciated!
  86. 240whp/160tq B18C?
  87. arp head studs
  88. B series or k series
  89. motor is jacked up...
  90. B16 OBDO- B18 TEG LS INJECTOR AND FUEL PRESS REGULATOR COMPATABLE?
  91. question about lsvtec head...
  92. JDM ITR with I/H/E makes 201whp
  93. 11.1 compression
  94. built ls vtec vs stock ls turbo
  95. next step?
  96. Do these flow numbers look good?
  97. JDM headers vs USDM headers
  98. which d15b?
  99. Ask For Next Project B18C Engine : Exhaust system,Intake manifold,Throttle body,etc
  100. Ask For Next Project. Exhaust system,Intake manifold,Throttle body,etc
  101. Need Help on Buddys all Motor setup
  102. .car won't stay running!!!! NEED HELP
  103. cams
  104. Cylinder Head Reassembly [B18 LS] : HELP!
  105. Hytech replica header dyno test
  106. blox type A cams in stock lsvtec?
  107. ITR Throttle Body
  108. Lovefab H-Series Header
  109. Head Milled/Skimmed
  110. anyone have a Stock LS dyno pic ???
  111. compression help and vin help
  112. Being Bullyed but the Turbo guys!!!!
  113. JDM 98 Spec B18C-R N/A build... help!
  114. ***Throw it on, or sell it?***
  115. all motor question? please help!
  116. Dynod the GSR setup. Results inside..
  117. need help in calculating compression
  118. Motorheads! Take a look at this site!?!?
  119. h2b oil problem
  120. Exhaust
  121. motor smoking? N/A help
  122. rod bearing ?
  123. How do these plugs look
  124. year of motor
  125. Ripped Timing Belt, What Can I Expect?
  126. Need suggetions on a B20 Build
  127. Lsvtec Idle... Please Help
  128. NA h22 dyno
  129. I need help guys on Ctr Piston or Itr Piston with ctr cams head
  130. Clearences
  131. Piston #1 or #2 or #3 or #4...??
  132. Just degreed my cams. Need some input please
  133. B18C GSR into EF HELP!!!!!
  134. Need help identifying if I got skunk2 stage 2's, not sure how to compare to specs is see here @ HT
  135. Took my new ls/vtec project to Cecil County
  136. K series crank pulley bolt
  137. I NEED A LS HEAD TO BE BUILT
  138. noob needs B16A2 Help
  139. My ls vtec set-up?
  140. When car is @ op. temp. it runs like crap! WTF!!!!!!!
  141. Just some questions on a setup
  142. help with port and polish
  143. valvetrain setup and cams
  144. B20VTEC Dyno: Brian Crower, Victor X, Tri-Y, etc... (VIDEO & GRAPH)
  145. CRV's engine block bolts have pulled out threads - need options to repair!
  146. all motor questions? help.
  147. need help ls rods on type r pistons in gsr block??
  148. hey need help with my setup
  149. ctr piston in jdm b16
  150. Reuse thermal gasket?
  151. jdmshit.com B series header
  152. Spun bearing NEED HELP please !!!
  153. Complete Parts List To Convert From DPFI to MPFI
  154. itr cams on ebay yay or nay
  155. p30 .25 pistons what rings??
  156. toda spec a cams
  157. Use my ls block for ls/vtec or use the ls crank for my gsr??
  158. What happened to Danny and Six Sigma/DTR??
  159. ARP torque specs?
  160. Type R Oil Pump leak....
  161. King Bearings
  162. b20 headgasket on b16 block
  163. MY B20 BUILD
  164. dyno on DC jdm header
  165. Clutch Removal for '87 civic si
  166. Block Guard Removal
  167. VA-machine shop
  168. I have a fuel problem???
  169. B16 Header Choice; Help Me Decide
  170. CTR motor- CTR ecu vs USDM SI ecu
  171. Distirbutor cap and rotor button?
  172. DC Sport Headers for Integra RS
  173. Help: Rocket M24X Cams
  174. what do i need to convert to OBD1
  175. Loss of power after tune up wtf!!
  176. HELp this guy offer to help fix my ITR for me
  177. Black Smoke
  178. CTR Cams
  179. ls/vtec question
  180. 3rd times a charm! (poor mans type r build)
  181. Size of H22 Exhaust Valve throat
  182. new crank for all motor?
  183. how would this setup do?
  184. In search of a local Shop..?
  185. B18 Type R Darton sleeved
  186. Assembly high compression milled motor
  187. Innovative Race compared to Street Engine Mounts
  188. I got a questin about a b18c1 and b18c5
  189. B16 build?
  190. skunk2 pro cams stage 1 ?
  191. Questions
  192. skunk2 pro series intake manifold for b16 head 170 shipped like new
  193. all motor gsr
  194. k24 or stroker kit????
  195. Crank is hard to turn, don't know why???
  196. VTEC Problems HELP!!!
  197. ls-vtec build
  198. 68mm T/B good for my setup?
  199. are these good cams or not ? need opinions on these cams
  200. Thoughts on Buddy Club Spec 3+ head package for B18C1?
  201. obd 0 to obd 1 vtech head swap
  202. stuck with finding the right motor
  203. B18C W/ Type R pistons. To tune or not to tune?
  204. CRV auto tranny shifting VERY rough and smells like a clutch burning...
  205. Ls Vtec help
  206. Bearings?
  207. B20vtec help! car runs like crap.
  208. can i use an aermotive a1000?
  209. ACL main and rod bearing clearance??
  210. LS VTEC IM: Victor X or Modded ITR?
  211. 13:5.1?? too much??
  212. LS Crank in GSR Block???
  213. Minnesota- Need a good machine shop that deals w/ Honda's
  214. fuel economy of stage 2 setup?
  215. Fully built GSR motor 218whp, 161tq. Will this make a reliable DD?
  216. B20 IM/TB header question for all you NA guys
  217. All motor Build Help
  218. HELP!!! B17 N/A Build
  219. Info on Rocketmotor sports cams....?
  220. Skunk2 H22 IM Question...
  221. Please help Car wont start
  222. need help on a built up for a built b16 head on a gsr block
  223. rockets m22 camshaft degreeing?
  224. *** B18C1 GSR W/ ITR or CTR Piston ****
  225. GSR rebuild with itr pistions jdm or us with jdm ecu
  226. 10,000 rpm
  227. bottom end rebuild questions
  228. CTR pistons
  229. Anyone with this setup? and recommendation..
  230. My car idles low after I run it through third
  231. B16B spoon stroker kit... opinions!
  232. b20 stroker ... need new sleeves?
  233. Another question for the pros:
  234. 88 crx swap
  235. itr intake cam/gsr exhaust cam combo
  236. max bore for rs machine sleeves?
  237. which spoon 2 pc header is this?
  238. reshape journal or get new crankshaft??
  239. b16 w/ ctr pistons
  240. *help!!!!* SCAT 92mm stroker crank
  241. hey does anyone know were I can buy this clamp/bracket please...
  242. Why do so many K swapped owners choose to go ITBs?
  243. ls vtec build help
  244. Help Identifying B16 Head
  245. t1r Response Header and Test pipe on DC2
  246. How to lock rocker arms for cam degreeing?
  247. Best cams for setup??
  248. HELP cams...
  249. b16 del sol all motor
  250. ARP head studs need help.
