- what sleeves for my bored k24
- 220 hp possible
- dyno charts b18c stock block/head almost 200whp
- Where this oil coming from..??
- timing dilema on my d15/d16 mini-me
- Idle Problems, Help!
- How many miles on b20vtec
- 8,500 rpm ok for stock gsr block??
- ITB Vacuum ports? can i run them from the stock injector holes?
- Going from GSR cams to ITR cams worth it ?
- CTR cams,springs,retainer for 600?
- Help> Problems with VTEC cross over at light throttle.
- Should I go back to my stock full pump!
- Dyno Results for RedZone Performance Built B20/Vtec Block
- SOHC race pulley
- what is redline of prelude type s (h22as I think)
- Does anyone have PICS or REVIEWS of the headertech header???
- skunk 2 intake mani.....
- does ITB really make power for all motor?
- JDM 4-2-1 header... HUH?
- I need your help going to the dyno tomorrow
- what kind of valvetrain?
- Suspension Setup?
- SOHC Performance??
- Trip to the dyno....
- People w/ Walbro fuel pumps... did it raise your fuel pressure?
- Some body that speak spanish?
- Help!
- valve spring compressor with head off car?
- Is it worth it to bump compresson up 0.2 ???
- I need feed back needed before i go blow some money on somthing i do not need.
- Ls all motor...would this work?
- JUN Valvesprings
- Full Race LS/Vtec dowel pins?
- strange picture
- Compression test results (is this normal)
- New motor setup...B18c5
- TODA C Spec cams...worth the $$$?
- Skunk2 stage 2 with CTR pistons in B18C1 block with PR3 head???
- The Best intake manifols for all motor car
- weird weird problem... need help
- Difference in power between b20b/vtec and b20z/vtec?
- 200 whp 1/4 times?
- b16 swap w/ctr valetrain?
- 95 EX Head gasket
- BisiMoto D16 Header. Best Bang for the buck?
- What do you think about this setup?...B18C5
- Intake piping?
- help guys!!!!!!!!!!
- what would be the best exhaust size for my b16 crx
- DC Sport w/ a 2 1/2 collector
- What's the Biggest Cam.......
- Eric's Racing and Leslie Durst : Are they Finish in 4th Gear or 5th Gear
- 220+ hp
- brakess....feeling unsafe...emergency plz help
- Skunk2 Stage 2 - upgrade fuel injectors?
- Help!!!!!!!!
- cold air or short ram?
- would like a new motor for si
- ITB's vs regular sytle intake manifold
- MY B-20 VTEC
- ls/vtec torque specs
- worth it to me to upgrade?
- TIMING
- Can lower bearings be used in upper??
- Best cams for stock 10.0-1 gsr compression?
- Importance of valve lash to make power?
- Question for the All-Motor Guys
- 11.5 to 1 compression question
- Type-R head on a B16
- Which one its the BEST IM for the GSR, Wicked, Skunk, AN-r, Stock modified???
- 85mm too much for the street?
- Jenvey ITB's....
- Brauning motorsports. looking for info
- Undecided mod to do next
- ITR crank in a ls block???
- Help Me how to identify a B17a Crank?
- Just dynoed my b16
- ls rods itr pistons
- went to go start d-buildup AND....
- Hytech low air pressure header
- Next step on my CRVTEC N/A Buildup!
- Lsvtec ibspec motor packages?
- looking for all motor vs boost vs boost articles (read the whole thing before telling me to search!!
- Sticky: What all do i need for a mini me
- what compression
- any one know where to get this stuff
- 200+ HP ?
- Uberdata compatible ecu's? Need someone to socket one for me..
- vtec help
- LS/Vtec, Vtec controller good or bad ?
- Making parts work together, 101
- type r 4-1 or DC 4-1 header
- D16y5 over D16z6
- b20b4 strength....?
- putting a civic radiator in a 95 Integra GSR
- Quick LS Build Question
- DC SPORT Header 1997-01 Acura Integra Type R vs. 1996-97 Acura Integra Type R JDM
- So I want a little more compression???
- B20V, how safe are the walls?
- what H series header will allot use of powersteering and ac?
- Fluidampr for b-series
- throttle body question
- what is a chipped ecu?
- i feel losing power for this
- 12 sec all motor SI vid.
- my current all motor #'s
- *PIC* How Much Would You Pay For An Uncoated Bisimoto Header *PIC*
- what fuel pressure setting should i set???
- b20vtec w/ buddy club 3+ dyno
- J's racing intake
- Hondata dyno numbers.
- itr intake manifold on a b18c1?
- jdm cams vs. skunk 2 cams
- Cams for a Stock B16
- For camshaft install....
- ATS first gear and 4.785 or 4.9 FD in 89-91 cable B 16 trans... Is it possible?
- cam gear setting on ls/vtec...did search
- All-Motor Preludes
- Anyone EVER had any problems using CTR pistons on B-Series rods that have to be slightly shaved for
- S2 IM on LS leaking gas...HELP!!!
- Help me with my next mod!
- can i use type r crank in b20 block??
- Deciding on NA setup ... b16 ..
- diy head swap
- Acuga motor help??
- CTR catback with high flow cat. Robbing of power?
- need help with crank
- My 12grand engine build...lsvtec
- why are lsvtecs faster than h22's??
- Wierd code 15 help!
- Stock jdm b16 header + stock cx cat really that bad???
- Bent valves... how
- Knock Sensor code, timing retard????
- B18C1 compresson vs. B18C5 compression...interesting question
- Whats the word on the GX20
- bottom end ballencing w/ itr pistons
- Need help on a all motor d16a6 set up
- need help identifying this LSD
- AAA Will I receive the power in LS?VTEC AAA
- need help modding my single cam vtec
- when dose the bc cams like the vtec?
- road race motor ?
- VIDEO: stock h22 with boltons...11.86 @ 111mph!!!
- CTR Piston ring and pin install question?
- OEM bearings with Aftermarket rods
- Got my SMSP header... damn nice
- KABOOM!!! what here can be saved if any of it
- 90 CRX...motor choices?
- Powersteering Tech Question |B16a|
- how much difference does a 4.78 final make???
- Skunk 2 cams in an H22 (USDM)- should we go Stg 1 or Stg2?
- B16 CAM AND ECU QUESTION!
- bore size question
- mugen head gasket on ls/vtec??? does it work?
- OS bearing in stroked b16
- 9014rpm limit on UBERDATA?
- searching for EF-1 products
- Will b18c1 with ITR pistons be safe using the Stock ECU?
- All Motor y8
- b20 vtec N/A
- CROWER valve springs
- Milling head w/o removing valvetrain?
- need help.. where to buy banjo fitting???
- just back from the Dyno b18c1
- Can I get some advice or any pointers about my setup??
- H22 Block Pictures
- What should I do ?
- Looking for OEM Honda TB sizes...
- WTB ITR CTR B16 Trannies B18C5 LSD
- B20 VTEC.... reliable?
- need suggestions on what rods to use with b20crank
- allmotor help
- H23 Vtec Safely Reving to 8,000rpms
- ITS the EX fuel pump equal to the SI or VTI fuel pump
- Searched: Any East Coast MD/VA/DC CROME and Uberdata Gurus.?
- blown gsr block.....got a good ls block where to start at?
- GReddy Emanage or EFI PMS?
- Prelude injectors good for my set-up?
- A few (dumb) questions:
- ZC Internals
- RECON Crate Motor
- rod bearing clearance to lose???
- what do i need? ctr pistons in b16a
- itr cams on b16???
- skunk 2 IM manifold on stock gsr...
- Need help !!!!!
- pic request: searched and found nothing
- Finding TDC
- Camshafts for b17
- Duration vs Lift! (Cam Question)
- Sleeving B18C5
- what kind of header?
- Exospeed results?...Good and Bad welcome
- NA stickers
- Little Help on DIY ITB TPS
- 12.5 second all motor? Is it possible?
- B16A SWAP BUDDY CLUB STAGE 3'S?
- HELP!?!?
- Ls swapped crx exhaust question.
- aftermarket cam wears out rocker arms?
- STR 70MM THROTTLE BODY
- JUN Not Making H22 Parts Anymore?? (say it ain't so mack! say it ain't so!!)
- really quick questions before i start...
- H22 high compression question!!
- My new gsr to itr setup.
- getting JDM motors legally smog.
- Will this IM make power? (stock B20z w/ powa chamber)
- Best header and cams for torque? (and other parts that create good midrange)
- OBD0 engine management suggestions?????
- What cam/spring/valves/Ret. are you using in your SOHC??
- Ls Vtec or B20vtec?
- where's the cheapest place to buy jdm dc header?
- who's using uberdata
- difference between a b16 and a b18?
- Electrical Problems.... Need Help.
- What are the best injectors for an all motor H22a?
- TODA A or BC 3+
- What is the most Preferred and Durable AfterMarket Piston? All EXPERIENCED Opinions Welcomed!
- best way to go all motor?
- Which Cams Should I Go With?
- CTR Piston Valve relief
- anyone daily driving s2s3?
- noob question about vafc????
- Dunno which head to port and polish? jdm gsr or itr
- What mods would you do to a H22
- b18b1 block
- IS THIS TRUE?
- Best header that still retain AC??
- intake manifold dynos
- type r cames in b16a2
- toda's or jun's ???
- my drag crx(h22)
- d series sms header
- Is it worth to port and polish a b16a head?????
- allmotor 1.6L
- dc headers vs. usdm itr headers////
- My Honda Idels CRAZY
- 1st gen b16 head "valve seals"
- JDM ITR build - ITB potential
- What is H22A stock fuel pressure?
- Hondata and block offs help needed
- using valve lash to make power
- h22a individual throttle bodies
- oil in #1,2,3 need help asap
- Camshaft question
- Need a lil help with my setup and tuning it skunk2 hondata
- Big Bore people. are you running spot faced comb. chambers???
- skunk2
- I think Im going to build a d16z6...
