PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 [174] 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Are there any quick N/A coupes out there?
  2. h23 dohc vtec owners
  3. help wit my lsvtec
  4. lsvtec all motor?
  5. V-AFC hard to tune or no???
  6. maximum compression pistons for skunk2 stage 3 cams
  7. i need good cams to put me over 200hp all motor.
  8. b16 - Itr head work and parts Questions
  9. walbro 255lph fuel pump
  10. opinion on my motor build-up parts... and some suggestions
  11. how high can i rev b20 vtec
  12. Pros & Cons (if any) on forged pistons/rods???
  13. HELP!: Are these OMNIPOWER springs & retainers?
  14. suggestions for b18 set up????
  15. which springs for these cams ( cam spec inside )
  16. B17....square motor??
  17. ITB MAP sensor issue (on stock ECU)
  18. Wat does all motor mean? plz explain thanks
  19. 1986 Honda civic hb?????????????
  20. problem with the timing belt keeping tension!
  21. hardest cam's to tune?
  22. help on all motor b18b install
  23. Got a J's style intake...
  24. LS crankshaft
  25. k20 head dropped a valve...pics
  26. Comptech or greddy header ?
  27. LS..piston question
  28. Valve "dish" Volume?
  29. Picking H-Series cams.
  30. jun, good or bad?
  31. Decisions, decisions. Need some assistance.
  32. Skunk2 All motor Monster Specs
  33. Thanks God for my 215 hp sohc non vtec allmotor dyno !!
  34. Question for all you header pros...
  35. my soon to be setup!!smsp header that much of a differnce?
  36. will buddy club 3+ work well with stock gsr compression?
  37. Bearing clearances with Dart block.
  38. 450's too much?
  39. What head parts should i get?
  40. Alaniz or Portflow??
  41. Best cam for stock valvetrain??
  42. GSR with B16 tranny?
  43. help on bottom end assembly(h22)
  44. skunk2 stage 1?
  45. J's Racing Carbon Fiber Intake
  46. shops that work on the d16y8 for all motor and turbo power on the street.
  47. best exhaust to use with AN-R header
  48. lookin to build ls/vtec but want list of good parts
  49. 81.75mm ctr pistons...if this safe????
  50. B Series Fuel Rail fit H22?
  51. Mild NA LS/Vtec Build
  52. Any Info on ls/vtec setup
  53. B16 ITB`s
  54. CTR or ITR cams for my setup... Plus a manifold question
  55. Good H22 Header in Civic with AC
  56. Fuel Rail for TWM itb's ?
  57. dsm 450s in a zc
  58. which exhaust?
  59. Buddy club spec III+ with milling head ?
  60. Need to know how this set will run!!!!!
  61. 13.6 B16 with bolt ons
  62. B18A revving
  63. B18b vtec head with vtec not hooked up?
  64. Which BC cams should I choose?
  65. Best mods
  66. b20 vtec Probs!! Any help me out?
  67. AEBS GSR intake manfold.....it better be worth the wait.
  68. no vtec after overhaul on my ITR
  69. Which springs with Toda D cams?
  70. how can u tell?
  71. looking for a tuner! uberdata in SOCAL around SANTA ANA!
  72. Anyone with J's Racing Intake?
  73. S2K TB on a B-series manifold??
  74. Replacement cam gear bolt Qs
  75. help me change my mind,,,,,boost<<<
  76. valvetrain upgrade?
  77. good a/f for mild all motor
  78. engine ground kits
  79. Intake manifold for 2.1Liter setup
  80. speedo sensor WTF???
  81. real clearance ? about header
  82. question about timing on hondata s100
  83. Intake Manifold Porting
  84. What engine is better to make alot of horsepower out of ?
  85. best place to buy JUN cams for h22a?
  86. where to get official honda shop manual??
  87. Aem V2 vs. PasswordJdm's j's racing knock off
  88. ALL MOTOR H22 race dragmotor! pros? cons?
  89. B18c5 all motor build up?
  90. k20a header
  91. SingCam screamin Vtec Video (inside)
  92. deckplate and rod length?
  93. tunning
  94. DA Mounts QS
  95. GS-R Block
  96. Help on Torque Spec for Stretch Head Bolts
  97. best tranny for All Motor
  98. BLOX CAMS..yay or nay
  99. warp crankshaft
  100. GUESS THE HP...yet again
  101. F20B Question!!!!
  102. TODA BELT ON B20 VTEC?
  103. Well i susspose i should get a suggestion on cams.
  104. California smog on all motor
  105. just got obx stage 2 cams
  106. Low Compression Buddy Clubs?
  107. all motor og ramanan t.
  108. turnaround time for head work?
  109. Help me maximize this build(C1/B16)
  110. adjusting the cam gears, confusion.
  111. High Flow Cat Testing Round 2
  112. What transmission?!?
  113. blox stage 2 cam's thumbs up or thumbs down
  114. Crank pulley balancing?
  115. street racers online
  116. Pistons selective fit?????
  117. need a quick help
  118. Evaluate this setup...too much compression for street?
  119. gsr question
  120. Hi everyone, have you seen this MPM Dashlogger?
  121. H22A baseline dyno, tell me what you think!
  122. Just would like to double check that these are ITR cams
  123. Skunk2 ecu idle trouble
  124. GURU'S elaborate on my crank balance sheet.
  125. Can a B16A make 240hp.?
  126. LS allmotor setup?
  127. CARBURATOR OR FUEL INJECTION????
  128. check this out .....!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  129. what would make my vtec stop working?
  130. ls allmotor
  131. Factory Piston Rings?
  132. B-series mechanic needed in N. Central Florida.....
  133. Signs that I might have bent valves?
  134. Feedback on 82mm bore
  135. how come no one makes 84mm cast pistons?
  136. Boosting K20A compression ratio
  137. Poor man's type r...
  138. b20vtec build.
  139. MSD rpm switch to actuvate vtec question
  140. Need some choices on Cams!
  141. Rare b20 P8R head question...
  142. Need Help.
  143. another header thread...
  144. sohc heeellp!
  145. Are Motor Swaps common?
  146. Gains from itr cams in a b16
  147. Question for tranny?
  148. wideban o2 sensor
  149. Innovate LM-1 vs. Plx m300
  150. Cams for b18c1
  151. Exhaust Question
  152. which intake and header should i buy?
  153. *dyno* 1st gen b16 Vs GSR cams *thanks mainstream!*
  154. Who has the most HP stock bore? B18c
  155. If peak power is @ 7600, why rev to 8200? Opinions/Facts wanted!!!!
  156. what to do with b18c
  157. rod/piston combo?
  158. Valve and Seat Concentricity
  159. when do skunk2 stage 2 cams stop making power?
  160. itb itbs injector location.
  161. HONDA Bearing color chart help!
  162. 89mm crank in B16
  163. compression calc change cspeed.com
  164. Cam Installation Instructions
  165. were do I start with my prelude
  166. Ls-vtec intake manifold questions
  167. 2001 Honda Fuel Rail for a 3.0 V-6 Coupe
  168. clutch lines on k20
  169. 3 yr old tried and proven valvetrain
  170. how is your ctr's in your b17.....
  171. B20B4 block, B20Z pistons, B18C1 crank, rods, girdle, and head
  172. WTF!!!!!!! whats the buddy club website?
  173. DA mounts for K series?
  174. Best HG to increase CR on a B series?
  175. increased compression
  176. Intake Manifold
  177. upgrade exhaust system
  178. Diff between head and a block
  179. F22 motor, D Series Trans, where can I get an adapter?
  180. All Motor LS
  181. fluid damper pulleys, where and how much?
  182. Rocket Motorsports M22 cams...where to buy?
  183. h22a DTR street header...
  184. VAFCII tuning question
  185. Check out ma setup
  186. help!with all motor h22
  187. Will i benefit from a SKUNK2 IM in my LS
  188. B16A - ITR internals...
  189. P28 ecu chips.........
  190. got 2 b16s dose the cyl walls look ok? come see(pics)
  191. In the works of a new build
  192. HELP!!!!!? Engine wont start....
  193. Fuel Pressure Gauge leaking.................help!
  194. Piston Ring alignment?
  195. OBD2a- Obd1
  196. Battle: H22 swap vs. B18C-R
  197. Build it or leave it?
  198. my new motor
  199. Milling PR3 Head?
  200. OFFICIAL knife edged CRANKSHAFT thread
  201. Si Valves (the company not the car)
  202. bad TPS?
  203. how much space?
  204. Fending off corrosion while waiting.
  205. looking to upgrade the header?
  206. K20R vs K20a2 vs Turbo GSR
  207. eg hatch with gsr cat problem
  208. injectot clips
  209. air to fuel ratio
  210. p30's or ctr's in a gsr? what kind of compression will i expect from each?
  211. What Size Tb and Intake mani for B20vtec
  212. Two dented runners. Help
  213. strange things in b16a dyno
  214. Identifying cams
  215. building a b16
  216. Got a chance at a b18c swap, is this a good set up?
  217. Tranny trade???
  218. Safe cam timing separation on Jun 3s
  219. LS-Vtec Build
  220. Went to Hawaii for vacation and look what I found waiting for me when I got back!
  221. K20 Swap
  222. F23 Head Swap??
  223. Passing Smog with high compression help
  224. B20B stock piston with GSR head , how big is the CR ??
  225. stock idle is at 700-800?!
  226. b16a2 budget build
  227. Head stripped, Intake Manifold side HELP
  228. attention tuners need aem ems tuned next month twms 13.1 cr 85mm gsr
  229. max in/ex valve size for b18c1 head?
  230. valvetrain question...
  231. B16A1 Build..
  232. what about Comp cams
  233. Advantages of breather filter over pcv?
  234. Alternative exhaust scavenging theory
  235. Looking for some to tune my all motor in Dallas area
  236. Freind Has a 97 Teg, what to do next for 14's?
  237. any interest in a Titanium Nitride coating group buy?
  238. Crower 404's
  239. Are all B series TB the same fitment?
  240. Installing ITB's onto my EG soon. How do you hook up vacum for brake booster
  241. extrude hone porting a stock IM
  242. help a bro out vtec crower cams
  243. Dyno Runs
  244. Exhaust set-up
  245. ARC Chamber for a DC2
  246. ITR headgasket verses piston choices.
  247. Ported GSR TB/IM is comparable to what set up?
  248. A few buildup questions....
  249. piston sizes what do they mean?
  250. 95 Civic Ex or 95 Integra LS?
