- basic stock rebuild
- Valvetrain recommendations
- jdm b16a cams in a gsr?
- Problems with yanking
- PVC INTAKE!? =0
- Changing up my motor setup need advice
- anyone have experiance with this header?
- B17A1 w/ P30 rods & pistons?
- spoon vs. oem headgasket
- GSR block w/ RS machine TYPE r piston QUESTION?
- profab tri y headers
- B16A build: eagle crank hitting oil squirters
- b18b1 questions
- wat would be better.???
- rear main seal leak problem!!!!
- ls/vtec fittings
- How much is a clean B16 Head worth?
- 65mm throttle body help!
- Inspecting block deck height
- anyone done a 2.1L n/a ls motor?:
- jdm b20b w p8r head intake mani question
- D15z6 with D16z6 head
- hELP .. head gasket issue
- skunk2 pro1 cams b18c R
- pro 1 cams b18c R
- Profab knock-off VS. Hytech knock-off headers
- velocity stack question
- b16 n/a build
- P30 or P72 Head
- All Motor Question... Skunk 2 vs JG EldeBrock Victor X
- b20b all motor build
- code19 on ecu...
- Rocker arm problem...help
- integra type r build
- quick question!!
- ls/vtec problem
- LsVtec (gsr head) with CTR pistons
- Torque Wrench Calibration
- stock b20vtec what psi on B&M FuelPressureRegulator/ FuelPressureGage
- DC 4-2-1 vs Megan 4-1 for my B17A Which to use?
- Crower maxi-light rods
- Golden Eagle VTEC fitting VS Russell Fitting
- Build MY motor...What would YOU do? - Give your .05 Cents...FcUk .02
- LSVTEC vs CRVTEC Question. For cost is it worth the extra coin. Feedback from guys who have switched
- ITR Having ignition issues
- Is this gonna be a p2v issue???
- How Does Everyone Feel About Crane Cams?
- base map for b20vtec??
- Teach Me Please!
- Ls Vtec n/a advice
- Can anybody confirm please. Cam question
- injector size?
- Valvetrain Question
- D-17 build
- Building up a B18B engine.. what to do?
- LS/Vtec Build suggestions?
- increasing my engine performance
- Which dizzy do i use for a Svtec motor?
- E85 what's needed??
- Crower cams any good ?
- JDM ITR block question
- Wats cams do i really have.... ?
- LS/VTEC using stock breather box setup = too much pressure???
- Post up you ALL MOTOR JE Piston builds!!!!
- What else can a 1992 - 1995 Civic IACV Bolt Up To And Work Perfectly?
- good header for ls/v? hytech replica
- WHICH IS MITSUBISHI ENGINE WITH THE 77 MM PISTON???????
- Frustrated about built type R putting 182 down have questions.
- h2d ef flatback
- 81-81.5mm vs 82-85mm's pistons
- ECU question
- Abnormal rocker pad and cam lobe wear on euroR H22 with JUN III
- buddy club spec 4 vs skunk2 stage 3
- Help!! b16a block w/ p30's on gsr head bad combo???
- lowes plumbing insulater tape
- PRO 3"S OR BC 3?
- NEED D16 ITB HELP
- b20 non vtec ???
- IAC on an lsv question
- B18 Cam Specs - lift/duration data required please
- Need Some Idea's of what could be Wrong???
- OEM rings on CP pistons?
- another b16a question?
- Still having cam questions
- High dome pistons???... Advantages & Disadvantages... For engine builder gurus
- H22 Cams... Pro1's or Blox Bs?
- SMOG HELP
- B16 head problems
- GSR with some bolt ons.. Dyno numbers inside
- pro and cons regarding omni power complete valve train
- PLEASE SOMEONE THAT KNOWS ABOUT HONDAS HELP ME
- info on cams, valves, and springs. ON NEW BUILT MOTOR
- sigle cam power non v tec kinda need help
- building a b18c i need some advice????!!!!!!!!1
- 91 octane vs 100 octane
- Hytech Custom Header Problem!!
- h-beam rods with stock CTR pistons
- 97 ITR cams with GSR Dual Valve Springs on both IN & EX - SAFE? yes or no?
- blox valve springs
- Hesitation ONLY in Vtec
- putting a y8 head on a z6 block
- H23 Rebuild Plan
- OEM pistong ring gap spec the same for standard and oversize?
- H22A SMSP vs. Hytech Header???
- Rockers
- Poorman R Build! Have a few questions!
- Build/blueprint sheet
- fel pro 9274 head gasket thickness question, OEM also, how much do they crush?
- Need help racecar motor? crv?
- b18c4 variable length manifold 'problem' (stock motor)
- need help with adjustable cam sprockets on ls v-tech
- REV Limit, NA build jdm b18c type-R
- LS/Vtec N/A looking for some advice.
- ek20 or b20block with gsr head
- piston to wall with rs machines pistons?
- B16 head/GSR block ?'s
- F22A6 noob build.
- My cars idle is messed up bad
- My h2b setup
- Setting Timing
- type r lag problem
- motor work
- All Motor K20A Tuned By Humble Performance - Just the start....
- Built GSR VS. Stock K20A2 explanation inside!
- weapon r race header...?
- LOL, 6puck disc & extreme Pressure plate work with 95mm stroker motor??
- B20Vtec - Stock bottom B20z
- need help with valve spring comparison please!
- Stuff i learned during a b18c build
- Little Help With My B16 Build!!!!
- Retarded Intake cam effect on AFR
- All motor
- Cam KINGS and GODS
- b16 retainers/ buddy club dual valve springs
- Rebuilding ITR
- Timing Belt Question
- Quiet 2.5" SS muffler What you guys recommend?
- Urgant Help plaes. Supertech valve springs
- What are the very minimum things I would need to tune an LS VTEC?
- B18C5 bottom end internals in Jdm B16A??
- fuel and idle problem, could use the help
- BC3+ vs. BC4's vs S2s2 vs s2p2
- predetonation???
- mini me swap wiring
- Going b20vtech Carillo lightweight rods worth the money?
- type r cams?
- kinda dissapointed with my new set-up...
- Throttle Body Suggestions for mild B17a build
- F22Z2 head swap?
- 88 prelude head bolt issue
- question about b20 orthia
- Are Megan headers any good?
- 94 civic swap
- Building a B16a Head. Info needed.
- BDL help, please read...
- Took my head off today to shave...look what I found
- Valve job for B series stock port std valve head
- LS VTEC vs B20 VTEC
- throttle bodie synchronizing
- what oil pickup to use?
- gsr idle problem
- question about buddy club 3 camshafts
- problems w/ type r head on a gsr block?
- opinions on my ls/vtec setup please
- saw somewhere posted about a buddy club head package for 771 can anyone find this for me
- Exhaust with stock headers
- Does Restore work?
- k20vs k24 EK
- supertech dual valve spring color>?? help!
- what kind of power should i make
- B18A1 Exhaust Port Questions
- can anyone tell me what cams i have?
- Need Advice On Build
- NEED HELP ON SOHC BUILDING
- what kind of header should i use?
- why the fascination with ITR/CTR cast pistons in builds?
- m21 cams vs. skunk 2 stage 2 for high comp motor
- b18a1 bearing tolerances
- H22 Ported Head, H22A porting.
- tell what you think of this head if anything will be holding me back.
- gs-r all motor setup
- 12:1 compression p73 pistons
- endyn breather on a crvtec
- Low oil pressure, NOW i am completely lost !!!! HELP
- 1000 dollars to build head
- BPi contact info?
- FAQ- Which Head Flows Better B16 OR GSR
- B16B..... Assistance please
- all motor sohc questinon
- your b16a horror stories --> i wana hear them
- My Type R setup need yor opinions
- integra type r power problem
- H22a Head Porting results
- tri Y header question...
- skunk2 pro series intake manifold
- Need to get my manifold CUt and ported. Who can do this for me look within.
- NEW HONDA-TECH section ( ENGINE BUILDING) Please VOTE!
- Show us your all motor LS setups
- best k24 crank?
- 2000 JDM Type Rx Build
- F23 HEAD FLOW TESTED
- Is the Blox intake manifold for LS's an improvement?
- ls vtec with hsl cams question!!
- LS/VTEC Cylinder Head Question
- b18a1 rebuild or buy b18c1?
- Cam Gear Adjustment for Stock GSR B18c with ITR Cams
- 200+whp 1.6L
- Engine Rebuild.
- What were your torque specs on your rods after using the rod stretch tool?
- Most accurate way of torquing main bolts/studs
- What to buy when rebuilding a b18c1?
- Any experience with the fox racing h22 h2b header?
- what tools do you have/use for assembly?
- new tb new problems help!
- Anyone have the actual phone number of nissport.com?
- toda vtec killers
- Nyce1s.com - Honda Day @ Atco September 27th 2008 Official Commercial Release!!
- do (bore x stroke) = cutting the block
- did i bend my valves?
- DC2 JDM Honda Integra Type R (you tube on board)
- b18c1 stock should i put a b16a head?
- b16 head planeing
- 82mm GSR build through school.
- ctr pistons
- Noob needs help with ls rebuild
- What piston do i have???
- itr pistons or ls crank and rods w/ pr3 pistons
- question about connecting rods
- Skunk 2 or Supertech for a valvetrain
- H22A NGK spark plugs (ZFR6F - 11 or BKR7E - 11)???
- d16z6 fuel injectors
- compression reading
- Skunk2 pro1 cam timing settings
- D17A2 upgrade cam gear?
- WHATS BETTER? D16Y7/Y8 OR STRAIGHT D16Y8
- New Hytech Header Style Question
- how to keep LS/VTEC from starving oil?
- Hytech header problem
- how do I shift my powerband?
- Anyone ever get there head worked on by m2race
- Bore on An ls
- Injector preferences
- transmission won't go into gear at High RPM's, after installing the Tilton Twin Disc
- pmr question
- reusing used forged pistons. what should I pay close attention to?
- hytech header question
- yoo few head questions.
- flow chart question??
- POSSIBLE F23 Frankenstein? H23 or F22b head?
