PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. *97 Civic Overheating*
  2. JDM B16A: Will GSR parts fit?
  3. H2b problem help
  4. Suggestion on rebuilt motor
  5. 93 Hatch B20b Swap
  6. Mechanical throttle ?
  7. 2.0L Road Race Engine on the engine dyno
  8. Skunk B series Ultra 2 cams
  9. Gsr head on Type r Block anybody?
  10. Non VtAk high compression weird build
  11. Anyone ever heard of Custom Kings?
  12. The New Header test thread
  13. Throttle body swap
  14. b20b header no fit
  15. Help with Ecu jumper
  16. 99 civic Lx
  17. B18C rebuild
  18. b20v quest to 250whp
  19. H22a4 with pde hf1 head
  20. B series head gasket
  21. 4P H22 - 2.55L from Honda's original big block 4 cylinder
  22. b16 valve clearances
  23. Cam choice stroked gsr
  24. Detonation from pump gas?
  25. 10 Second 2.0L B-Series Build?!
  26. Building a motor with optimal Rod Stroke ratio-
  27. B16A2 All Motor Build or Swap??
  28. PRE any good.
  29. PRE any good.
  30. built b16a2 vs Subaru WRX?
  31. Help me Select Parts from my Inventory
  32. 96 accord
  33. B16a CTR intake cam question.
  34. EF B20Z stock bottom end header and OEM IM option
  35. high compression d16y7 Mini Me
  36. gsr/b16 set up help any advice?!
  37. B20Z Non Vtec High Comp
  38. B20z1 b16a2 head
  39. 63mm Exhaust for Em1?
  40. Tested a bunch of stuff on a 13:1 87x99. Manifold vs ITB, K600's vs. Ultra2's,
  41. Header wrap still considered a bad time?
  42. Opinions on my build and swapping parts for power
  43. H22 and Skunk2 wear (again)
  44. D15B2 need some opinions!
  45. B-Series headers
  46. 86x92 B-Series
  47. Accel internal super coil on a b series
  48. Poor Man's Type R build.
  49. B18b N/A build "help needed"
  50. b20z, not the usual questions..
  51. clutch and flywheel combo for mild gsr build
  52. 13.6:1 K24 intake manifold question
  53. Motor swap
  54. B16B 84.5mm build
  55. what should I replace/check with the valve cover off?
  56. Intake manifold question...
  57. H23 vtec h2b swap
  58. HELP with my engine build B18C6
  59. Had car dyno'd for the first time! I have the charts and some Q's.
  60. JDM B18C Valve Lash - Not USDM Not Type R
  61. Ecu compatibility with Jdm type R
  62. My 96 spec ITR swapped CRX
  63. Eating oil/stalling
  64. adjustable test pipe flange bigger than header flange
  65. obd1 gsr bolt and tune
  66. H22 Stroker Guy's 99-103mm please chime in :)
  67. old b18c5 rebuild for itb's
  68. LS Build Dyno
  69. B20 suggestions
  70. B18b1
  71. B20 low compression all cylinders AFTER engine overhaul
  72. advice on a h22 swap in a accord all NA
  73. H2b not putting out
  74. 91 integra swap
  75. h22a4 rebuild
  76. Need some old guys.....SMSP fitment
  77. B20 rough idle
  78. Cams cams cams...
  79. LSV with GTR crank/rods CTR pistons
  80. needs advice please! possible swaps for 88 civic wagon
  81. 01 integra gsr only runs with scanner tool plugged in
  82. H22 EG and H2B build
  83. Bolt-on F23A1 baseline
  84. 2.1L B series - 4 Piston Racing, ASP, Skunk2
  85. 13:1 b20b non v which intake ultra or victor x
  86. Pr4 rod journal
  87. N/A B16A SIR I
  88. Vtec won't engage
  89. 1320 Ramhorn header. Who has dyno results?
  90. type s pistons with type s or stage 2 cams?
  91. need help with identification
  92. 2L GSR build, couple questions
  93. ryanplayjoint's B20/VTEC Build Thread
  94. plz help! ckp code on 95 b18c1
  95. S2 H22 upgrade help
  96. B20V all motor daily
  97. B18c High comp (12:1) running issues - NEED HELP
  98. Built b16a head stock block outputs?
  99. jdm h22 type s piston rings a and b?
  100. Intake Diameter
  101. 85mm E85 all motor destroked CSS b20v 1st build opinions & advice needed *pics*
  102. Oil pump leak - replace seal+o-ring or entire pump?
  103. D16Y7 Engine into 1998 EX Issues
  104. 96' ITR refresh and upgrade questions
  105. Performer X intake tube with icebox
  106. H22 crower stage 2 crower cams
  107. db1 integra with b20/b16 swap (what header to use?) and test pipe
  108. 200+hp All motor GSR (help)
  109. Cooling fan wiring
  110. Oem Lca's
  111. Pro 2's or tuner 3's????
  112. What sensor is this
  113. Poor mans type r b16 stock valves with skunk 2 valve springs and skunk2 tuner stage 1
  114. B20b phk/p8r combo
  115. What brand throttle body are you guys using?
  116. High end 4-2-1 header for b series
  117. P30piston ring gap
  118. Intake questions
  119. Thought I would share my JDM GSR Dyno Results !
  120. valve guide with toda spec c cams
  121. everything you'll probably ever want to know about oil
  122. fuel management
  123. b20 vtec advice wanted
  124. Free flow Frankenstein 2.5" or 3.5"?
  125. oil filter/oil
  126. obd2 integra automatic whats need to tune.
  127. Vibrant 2539 header bracket for B20Z
  128. B16A2 @ITBs. Rough idle and smokes as hell
  129. TODA Spec C: fake or real? need help please!
  130. Will this piston work
  131. Six Sigma Racing
  132. B20V build having hard time holding idle
  133. Vtec wiring
  134. Bearing talk for high CR motor.
  135. b18 85.5mm 13:25:1highcomp build!
  136. B18C oil pump port
  137. ENDYN D16 NON-VTEC 1.7L Stroker underdog...Why NOT
  138. 1/8 mile FD 4.9??
  139. K20/k24 or GSR
  140. advance timming question.
  141. All motor: B18c6 or B20 frankenstein?
  142. has anyone ordered custom na bseries cams?
  143. itr intake valves and flat face exhaust valves?
  144. Injector/pump help!!
  145. What size injectors?
  146. b18c performer x
  147. Looking to clean up the engine bay, what can go?
  148. B18C Barracks Build
  149. Building a B20z2 Motor, Suggestions?
  150. Pcv valve trouble
  151. B18C5 12.2-5:1 CPR Arias ,CP ,JE ,Or Wiseco pistons?
  152. All motor build 84x87.2
  153. Lsv spark plug question
  154. another sohc nonvtec build to look down on
  155. GSR vs. Type R Engine Build
  156. P73 piston safety vs Nippon?
  157. Valve cover vacuum line relocation.
  158. lsv headgasket?
  159. High Comp B20 Build "The Drag Rat"
  160. Building B20V for autoX car, couple Q's.
  161. b16b build
  162. oil light
  163. B18c5. Oil line and can from b20v
  164. GLSR Build
  165. All Motor SOHC D16z6 150whp 14.4 Daily Driven
  166. Vaccum hose problems
  167. b20b 185whp non v
  168. JDM B18C Titanium Retainer failure question..
  169. p28 ecu, usdm oil pump, on jdm 98 tir motor!
  170. JDM B18C white smoke on WOT
  171. Cam identification help
  172. usdm b18c vetch solenoid work on jdm b18c itr?
  173. Oil seeping between head and block
  174. D16 all motor
  175. What do I need for a head swap 96?
  176. 1996 Honda Accord v6 engine making loud rattling noise help!nnn
  177. B20z2 Ring Gap Question
  178. B16 stroker
  179. 96 swap
  180. D16Y8 with goodies off a tooth?
  181. Need some help 94 civic B18/B16 head
  182. Opinion's
  183. B18c cams in b16a2 cams not lining up with TDC
  184. B16a2 with B18 cams
  185. Sleeved B20 - 86.5mm head gasket failure
  186. My Endless B20V build
  187. 2000 Honda Civic
  188. Injector size for E85
  189. Flashing engine light
  190. Ever seen this before? Carnage inside!
  191. Looking for Bisimoto f23vtec 2.3nitrous centerline specs?
  192. JDM D15b overheating?
  193. Honda gasket?
  194. Skunk2 Pro2/3
  195. d14a4 idle problem
  196. camshaft battle. ctr vs s2t2
  197. NA b16 or gsr
  198. BC stroker kit 'long rod' vs 'normal'?
  199. Post your stock block vtec B series all motor builds.
  200. B series cam id
  201. h22 dizzy
  202. B17 rod?
  203. Help me ID my Buddy Club spec3 cams
  204. 1982 Prelude Accelerator Pump Leak
  205. Build ls vtec 82x89
  206. how many hours should i expect out of a premium rebuilt Z6?
  207. JDM D15b running rich
  208. obd1 b18b1 loud intake noise at high rpms
  209. PLM Header Fitment
  210. 85mm B20v with CSS
  211. Fuel choices
  212. 00 civic gsr build
  213. Engine stutters after new intake installation
  214. Bisi Cam Gear
  215. My 82x89 GS-R
  216. Decisions of an engine to get/build
  217. b20v build in EK shell
  218. Cams??
  219. D16Y8 Coolant Problems
  220. How get more power b20vtec
  221. Catalytic converter cell count VS flow & power gains?
  222. Engine management question
  223. B16 OEM rebuild kit?
  224. header question for hopefully more power.. need knowledgeable advice/dyno
  225. Ctr rep
  226. best motor combination.
  227. B20vtec..84.5mm..pro 3's
  228. Best throtle body size to...
  229. ITB Throttle Position Sensor Issues
  230. Dynamic cranking pressures
  231. 88x99 k24 build thread. 4piston, Myers, K-tuned goodies and more!
  232. b series dyno comparison?
  233. Timing Help ? 1991 prelude 2.1
  234. OEM-like QUIET exhaust with catalytic converters on high HP build
  235. Piston question
  236. b16a trouble starting
  237. J30A1 upgrade
  238. P72 vs P72-1
  239. Eg b20z
  240. BC Stg 2 NA cams into ITR
  241. Ground locations on lsvtec (b16a2 head/b18a1 block)
  242. Simple 300whp recipe. K24/20 with all shelf parts. Also Dc4 vs Ultra 2 graph
  243. Oil leak help
  244. Throttle Body Opinions; What Brand Are You Using?
  245. J25A Valves (98-03 Inspire/Saber)
  246. Ej1_Civic's all motor 86.5x98 2.3 Litre Progress Build
  247. DOHC ZC HELP!!!
  248. Hondata S300 B16 duty cycle problem, HELP!
  249. My turbo to all-motor b20-vtec build thread...
  250. 1988 Civic d15b2 Surging Idle Help
