PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 [223] 224 225 226 227 228 229 230 231 232
  1. Big vs overall c/r
  2. my crowers just snaped!!arghhh
  3. B16 dyno...wow...i'm suprised
  4. All-Motor favorite Air Intake?
  5. EF-1 or PORTFLOW?
  6. k all motor gurus..... what is the point of no return when you cant drive your car
  7. building All Motor b21a1
  8. toda stroker kit
  9. Getting my 91 civic running a lil quicker?
  10. who in here actually has EF-1 cams and results?
  11. increase redline
  12. head gasket layers???????????????
  13. Freezing an engine
  14. Just got back from the dyno
  15. vtec does not turn on?
  16. CRVT *stock* bottom end JUN III TUNED dyno!!! doubters beware!!!!
  17. Idea for a oil cooler using stock radiator
  18. jun h22a dyno in 94 lude
  19. difference between h22andh22a1
  20. Peak Hp with just bolt-ons on B16?
  21. Spark Plugs from people making 195+
  22. Anyone have a 13-sec or faster ALL MOTOR DA?
  23. exhaust question 2.5 vs 2.25
  24. question for ya
  25. oil pressure drop after inst. oil cooler!
  26. ctr piston= valve problem?
  27. what happens when you do this
  28. Resleeving YOUR block. Who have YOU used before?
  29. Need help ASAP...
  30. Gude Cams
  31. Are 13s possible with this setup
  32. Question for you built engine guys about extra noise from engine please read and post your thoughts
  33. Cromoly worth it?
  34. 2.0 DC2 Dyno results
  35. b16a w/ctr pistons and r head and trans.......??
  36. Post your EG w/ JDMH22 time slips, and all modifications here
  37. cant decide what set up to go for ls/vtec cr/vtec or stay b16
  38. Building a header, what size piping for runners?
  39. Some Pics of the D Series 4-1 Header
  40. 2nd gen teg wit b18c5
  41. All Motor Video 12.20 @ 110 mph Ls/Vtec
  42. Skunk stage 3's + GSR block+ls Crank+85mm bore
  43. what oil filter?
  44. can i use an old wiring harness for jdm engine
  45. having trouble with jdm exaust system
  46. D17 tuning problem
  47. b16 with itr or ctr cams
  48. H series TB on a B series manafold
  49. stock b20vtec fuel pressure??
  50. Cams.
  51. Source for chipped P28s in NJ-NY area ...
  52. How can you tell the difference between ITR and JDM ITR pistons?
  53. Intake Manifold
  54. k20 questions.
  55. JDM ITR block handle 9500 R's Daily?
  56. how much gain from 11:5 to 12:1 compression
  57. Spark Plug Gap
  58. Head P/P 4 street?
  59. L/S Vtec or B18C???
  60. b16 all motor buildup, how fast can it be
  61. LS/Vtec dyno numbers, 1320 times.
  62. new cam pics
  63. How to distinguish between Stock GSR Cams and Type R Cams....how do you tell?
  64. H23a1 engine trouble
  65. What does the race harmonic dampner do?
  66. Does anyone run the Ericks Racing Header?
  67. possible valve train problem
  68. 11.5 compression and stage 2 crower cam on h22a
  69. Will a B&M fpr mounted on a non vtec stock fpr work fine on a vtec motor?
  70. autometer A/F and the butt dyno!
  71. how much do you think this setup will make?
  72. Stock jdm b16 rods with ctr pistons?
  73. Why a B16 head on a B18 Block?
  74. Head gasket for 2l B18c bore..
  75. Choosing parts for LSvtec or CRvtec
  76. How can you tell if its a P72 or P28????
  77. Flow bench yes or no?
  78. B20b or z
  79. Letting car sit while Headwork is being done
  80. Wanting to go 12s, most of my parts are here that Im hoping will get me there
  81. Motor swap question?
  82. Yet ANOTHER intake mani. thread
  83. how to improve upon the VTEC effect?
  84. Stock clutch
  85. do i need injectors
  86. What valve springs to use for all motor ls/vtec
  87. 210 WHP with just bolt-ons?
  88. Clutch assembly...lightweight???
  89. best tranny for all motor lsvtec gsr or b16
  90. What WHP do you think with this setup...?
  91. Anyone using a p73 on a 2.0L?
  92. Power and durability for a 90 teg?
  93. What will my car run?
  94. cable b16 tranny
  95. part number for piston
  96. S2 stage2 in H22 w/ stock compression (10.0:1)
  97. acl bearings or oem honda bearings
  98. sounds like a good price?
  99. headers and intake manifolds
  100. has anyone bought this header?
  101. Anyone know exact Compression of B16a with CTR pistons?
  102. anybody have an dynos of b16/b18c with ITB?
  103. B16 Head on B18 Block
  104. Quick Q about skunk2 and crower compatability
  105. how much power or abuse can.....
  106. ls/vtec help!!
  107. Any good place to install my sk2 intake manifold? in OC/LA area?
  108. what exactly is a BORE
  109. good machine shops in san diego
  110. Question for 1 2 NV
  111. bisimoto header?? any experiences
  112. need hints for building up a B16A2
  113. long rod setup
  114. VAFC II tuning
  115. how much h.p. should my 94 ls have
  116. considering replacing bottom end with b20 in a 98 ls
  117. i need some suggestion...for my eg all motor
  118. well i got my block.
  119. i need mucho advice from the supposed experts at honda tech (h22)
  120. read for hours now i only have one question on b20/vtec
  121. p30 pistons vs. jdm type r's
  122. Rebuilding head on D16Z6 SOHC...
  123. B16 bored 20 to 30 over...
  124. Ls TB size vs b20 TB?
  125. the "definitive" rod thread
  126. How can I find a good tune shop in Orange County Ca.
  127. anyone solve that idle dropping prob. when clutch is in??
  128. Injector question
  129. Need advice for raising comrpession on B18C
  130. more potential: h22 or b18c5
  131. Skunk2 Stage 1's now what?
  132. Hondata tuning question
  133. HP estimates? h22 with a bunch of stuff
  134. whats possible with a h22 type s
  135. h22 type s Question
  136. Need a j's racing intake asap
  137. Fuel pressure gauges?
  138. Main bearing problem
  139. Wut kind of tranny is a Ysk1???????????
  140. building bottom end *options*
  141. Temperature coating pistons and head.. (pros and cons)
  142. Mugen headgasket?
  143. CTR Pistons in b16 w/ mugen head gasket.. will it hit?
  144. B16a + P28 + NOS ???
  145. Blown off breather chamber?
  146. Watch out for DPR Racing, Stole $9,000 from me. Thiefs.
  147. What next for my all motor setup.....hondata?
  148. cams
  149. SI pics
  150. Most likely a stupid ? so let me hear it...
  151. ctr cams-how to tell the difference
  152. b20 all motor?
  153. just got some jun IIIs
  154. acl honda bearings
  155. I might be getting a bubble...
  156. tap tap tap tap tap sound when shutting car off?
  157. DTR 4-1 side exit header
  158. gaining 90 whp?
  159. Dyno?
  160. Big bore vs high compression
  161. Need help on motor build
  162. EGT probe...what cylinder and how far from head??
  163. need custom exhaust piping
  164. MIL Status Getting On My Nerves...
  165. car wont idle right until about 7-10 seconds of being on!!!
  166. engine builders in canada...?
  167. had my car dyno tuned
  168. Stock B20 bottom end and Jun3's.
  169. BEST ALL MOTOR BUILDER/WEB SITE?
  170. First time at track with new setup
  171. Motor oil.....:(
  172. LSVtec Turbo or non-turbo?
  173. LSVtec? to turbo or not to turbo?
  174. what does everybody think abou the JG Edelbrock Header w/IB 2.5 mod?
  175. aftermarket axles
  176. Motor almost done!
  177. AN-R header installed! Pics inside!!!
  178. looking for aeromotive fuel regulator
  179. New best time/mph
  180. Good idea or not ???
  181. oil catch can???
  182. Extrude honing...What's your experience with it?
  183. For yall to check out
  184. 50 shot w/ skunk 2 stage 2??
  185. Clutchmasters or Exedy?
  186. Alright people which one do you guys perfer?
  187. Help
  188. Best valve springs & retainers for sk2 stg2's?
  189. JDM Length Cat?
  190. ats 4.92 in a gsr tranny
  191. all motor buildup piston question
  192. lsvtec r/s ratio worse than ls?
  193. What about this?
  194. advice for pistons in a gsr
  195. old school vtec power b21a1
  196. Cosworth Pistons
  197. b18b with ctr internals
  198. building ls/vtec ....how much power is this good for?
  199. b16 vs. b18c1 in performance & potential
  200. which cams for this setup. fat powerband!
  201. 9000rpm on B20VTEC
  202. What compression will ITR pistons yield in b16?
  203. Please help me with my cam setup choice.
  204. PLEASE HELP !!! Recommended TB size for this built motor .....
  205. ef-1?
  206. Skunk2 stage I or II
  207. True DOHC ZC Headers
  208. Is it ok to drive Untuned Cams?
  209. My New toy that Im going to dyno for everyone and a vid clip too
  210. TB and Intake Question?
  211. 200 whp
  212. B16a and B18c1 Cam Specs
  213. ITR 1-4 gears into a GSR tranny ? ? ? *tranny experts LQQK pls*
  214. Help me out!!! My all motor ls/vtec engine is malfunctioning!
  215. who makes (ITB'S) for SOHC??
  216. pump gas ... compression ...
  217. LS/VTEC question
  218. Exmag looks restrictive what do you think?
  219. into a Ek, h22 or B20vtec
  220. kamikaze header over dc header???
  221. Lost my D series engine building pages, lend a hand...
  222. 1992 : d16z6 turbo- or - 18c5
  223. horsepower winner
  224. All motor, upgraded internals, VAFC does the job ?
  225. will a cams (skunk2) lobes wear down if i dont get valve adjustment?
  226. Ef-1 cams? what can they do for me?
  227. Itr valve springs, and cams?
  228. Should I blueprint my injectors?
  229. *** Respectable : 160whp and 135torque on a STOCK B20vtec?
  230. 68mm STR T/B too big?
  231. Need N/A Advice
  232. Wheel horsepower
  233. Biggest OEM injector
  234. which dc sports header is good for a b20z..
  235. ? ? ITR ROD Q u e s t i o n s ? ?
  236. What is a good all motor street set up?
  237. average price on engine build
  238. B20/VTEC guys...
  239. HELP TUNNING!?!@? help me smart ass's!@
  240. h22 piston/rod combination
  241. Can you run Jun3's on a stock B20 bottom end?
  242. h22 compression
  243. Ok ok.... stage 3's, or trade for stage 2's???
  244. Need some help with my RPM 68MM TB (done search)
  245. B18c-R or B18c???
  246. skunk2 d series intake manifold???
  247. B20 block on B18C
  248. most whp on stock compression(b18c1)
  249. 98 dx hatch with 98 ex intake manifold??
  250. Which IAC to buy?????
