- check this dyno out (Hytech replica header)
- 1986-1987 Legend Pistons into a B20B/Z block?
- oil pump
- b16 hell cam issue
- dead cylinders
- g23 piston and engine setup help
- 00b18b's LS/VTEC build: Checking my bearing colors
- b16a1 idle problem
- Is DC header w/ stock 00 integra LS exhaust worth it?
- ls vtec Why?
- B18C Type R Intake valves are larger than the other B-series, right?
- B20 Stock Sleeves?
- oil squirter stripped
- 12.5 comp ratio??????????????
- full 2.5" catback
- LSVTEC help
- f23 fuel rail
- all motor piston
- Kinsler ITBs
- Pic Request: Technical Illustrations of Engines
- Authentic 4-1 Spoon Sports VTEC header?? please help
- WhitfieldRacingInc. is the sh*t!!!
- My engine has no power on low RPM's HELP
- 90 Civic d1.5 Disassembly Quesion????
- Anyone using the innovate LC1 wideband? My's got issues
- rod differences
- question about Main Bearing thickness by color ????(help with math)
- ITB Water / Methanol Injection
- Official: K Series Dyno Chart Comparison & Calibration Registry
- itr manifold
- JDM itr Block
- do i need a tune?
- b20 vtec....please read this one.........
- H2B h22 dyno! bad results :(
- Next mod? b16a1 EE9 civic
- Camp1320 h2b header
- turbo cams work for an all motor application?
- Rod bolt stretch results
- Difference between USDM GSR cams and JDM GSR cams? *searched*
- need help
- REQ: Hytech Email
- Pros & Cons of a blockguard *SEARCHED*
- Anyone have pic of EF with B16 using performer x manifold?
- b20b whp question
- [freak]ing stupid [freak]ing gas attendants.....reassure me.
- Help Mini Me
- type r dyno
- wich blox cams for my application??
- is this a good setup ?
- Header tuning
- oil in exhaust port!!! help
- Spark Racing header???
- anybody used these ITB's?
- please look vtec prob almost sorted
- are these skunk2 stage 2 cams .. pics
- B20B/Z 160 foot pounds torque??
- what cams, b16a, skunk2 stage2 or BLOX B
- tuning???
- Help Me Pick Out A Good Clutch For My Allmotor H2B Set-up
- d-series motor project
- Purely 1600cc b16b power!
- Supertech Aluminum retainers + Skunk 2 valvesprings= drama?
- do i need an o2 sensor?
- My first engine build. b18c5
- All-motor H22 Dyno #'s from NRG Tech Racing!!!
- 200-300hp b20z build
- Noobs who "build" Engines- Come in here
- all motor sparkplug
- tuning ls-v
- ITR crank in a B16?
- Az race and machine LSD kit?
- spark plugs
- Any thoughts about this replacement head?
- Adjustable rev limits?
- 84.5mm LS/Vtec
- B16 missing cam caps!
- Differences in Octane Rating - Must read for NON US residents
- need help
- need help
- new build for 08
- better to break in with oem cams??
- DB1 Motor Swap
- Rebuilt Motor... What is the correct method of break-in and tuning??
- got my built b20vtec up and running, just have some questions
- H22a Skunk2 Stage2 camshafts
- plug wires
- Best Way to build a fast N/A k20
- Engine rebuild bearing question (for first timer)
- 1500 bucks
- prooffesional products throttle body?? what size
- Do EM2 headers fit on a EK??
- want to race the h22a in an off road race car, but have to run carbs, help please
- D16y8 head questions
- Break-in oil question
- can i gain hp with these?
- rob bolts
- I am looking for a TWM ITB airbox?
- which ECU
- Stock bottom end b18 build thread
- another break in question.
- 10w-30 or 20w-50 on a drag motor
- Rocker Arms + new cams
- Why B2D?
- rod question
- Help with Twm itb's
- build question
- side draft webers for an h22a?
- gearspeed, oem. where to buy syncros?
- vtec quits working
- Serious Problems....Please Help!!!
- My first N/A build?
- Input needed: is this a decent setup? B20vtec
- 96 automatic civic question
- Quick Clutch Question!!
- Who's running a harmonice balancer on their fully built motors?
- b20 vtec build, piston and head gasket questions
- Questions: GSR wants to do alittle build
- help me identify these cams
- blox stage 2??
- 86mm Block, TWM ITBs 52mm & Big Tube Header DYNO COMPARISON
- h22 rocker rods
- LS/Vtec w/GSR Head, will i encounter Clearance Issues?
- NPR rings???
- will gsr stock pistons clear valves in ls block?
- OIL PROBLEM!
- Cam Choice on stock JDM ITR, M22x, M22xx, Pro1's???
- P2W clearnce @ .005.....
- Square Port vs Normal Port (Any info in difference in power or better flowing?)
- SMOKE OUT OF Exhaust pipe, looks like a mix of white and black smoke.
- Need Header/Intake/Exhaust combination for GSR Swap?
- h22 headers custom
- 4k rev limit after rc440s
- H22 vtec problems.
- goods & bads about dh-racing (dave)
- flat top piston dome cc's?
- h22a cams??
- TODA SPEC B'S in b20
- Eagle KnockOff's
- GSR NA setup suggestions help
- Civic Type R Cam Shafts 4 All Motor Build
- Need help asap this morning!!!!
- DTR street sweeper in a EF anyone?
- M3 Throttles on a B20
- Royal Purple Oil vs. Mobil 1
- b16 block with ls head set up
- Oil leak b series?
- Water-Meth injection kit for N/A
- Recommended fueling upgrades
- A question about valve/injector cleaners
- oil and oil filter
- Vacuum Or Breather Post up your Homemade PCV Setup
- Should i ditch turbo and go all motor????
- whats a good WHP for an JDM ITR motor??
- 85mm+ Dyno Results
- 86mm IB Spec Super Duper Pistons
- Are these Skunk2 Pro 1's?
- too much C/R?
- Rdx injector mod.....
- WILL THEY FIT???
- Input needed
- build y8 head?
- b18c5 rebuild
- HELP b16 running rough
- Crower 63402-2 -Valve adjustment specs????
- Seat pressure range spec's
- TWM ITBs on an H22 IN A PRELUDE... has anyone done it?
- Crower H22 63422A-2 Cams?
- lower compression ratio?
- CRVtec questions
- Crower Maxi-light rods
- B18CR/ B16AB Sleeve Rebore Issue?
- Ok I need some advice on which cams to get.
- oil cooler yay or nay
- got the b20 vtec dynoed.
- Castillo Knife Edge Crankshafts
- Recomend: Valve Spring Compressor?
- Help, mild gsr build!
- H-motors ONLY!
- B18C1 safe redline
- E cut out
- Need help with B16A please
- crower 402s ?
- looking for some opinions on motor upgrades lsvtec
- pulstar spark plugs
- Fidanza flywheel with exedy clutch and pressure Q time..
- ITR + RS*R Exmag.....is it hindering my performance?
- all motor B18A
- Type R valve springs and retainers!!!
- Storker kit question
- Type S Prelude Head Upgrade questions/weird cambelt wearing
- A valve train question
- B16a modification concerns
- could it be piston rattle...
- skunk2 pro1 on a stock gsr block?
- GSR rods on a B16 crank with a Gsr head
- best engine?
- help identifying valves
- Customers Integra ITR- Thanks SKunk2, *thumbsdown to TODA*
- headgasket/compression??
- BLEW IT BIGTIME! How do you re-time a SOHC 1.5 engine???
- Piston Issue?
- would i need a blockguard?
- Long Rod v. Short Rod - The Great Debate
- car wont run after cam install. UPDATE
- Pistons and Cams
- Omniman Valve Springs with Brain Crower Steel Retainers
- spun bearing/ block
- Valve Spring Pressure Tester?
- Any info on the Blox P1 (Pro1) or P2 (Pro2) replica cams?
- Good Place to Dyno tune?
- B16 Head work
- eagle rods or ls rods with arp rod bolts?
- ALL MOTORGSR
- Edelbrock manifold not just good for turbo ***Looky looky***
- question on what exhaust setup woulb be best for my car.....
- build help
- VTEC Bogging
- spun bearing(s) on ls motor
- Please Help!!! B16A Or GSR B18c1???
- cant decide on oil...
- Crower moly retainers + blox dual springs+.......
- LS VTEC ISSUES!!!
- Springs & Retainers combo
- Yet another cam question...
- Can't decide on cams for B18C6
- What crankshaft to use ???
- upgraded Throttle Body issue.
- heat soak?
- gettin si power
- crower 404 valve clearance ?
- z6 head on my y7 blck in my Si...
- building my B18C type R.
- SMSP
- ★84mm N/A B18c1 Build★
- Head Gasket ?
- What Spark plug on STOCK b16a
- Attn: Tunners and Gurus - Is My Tune Any Good?
- Need experienced opinions on what you think are the best cams for a stock block allmotor H22
- skunk2 stage 2 camshafts
- exhaust or silencer
- Need help, searched
- seeker parts
- Smog legal?
- More power from a JDM B18C ITR
- my b20 which header
- Need HONE or BORED H22 if new RINGS installed?
- nippon racing pistons what do u guys think
- Race fuel .. race gas.
- k24 long block for my lsd gsr tranny???!!!
