PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Help with Fuel pump in 1990 Integra
  2. Valve issue! Sunken valve seat?
  3. 2005 Honda Civic SE
  4. J30 broken rocker arm?
  5. v6 coupe transmission problems(need help fast)
  6. B20Vtec Oil Catchcan setup
  7. LS Vtec in a eg hatch bone stock with 1000cc injectors and 255pump need help!!!
  8. TD-62U Dizzy
  9. Ignition timing
  10. d16y8 not running at low throttle aperture
  11. B20 Vtec Tuning
  12. Burning Oil! - B16A
  13. 98 honda civic no spark no fuel
  14. H22A Block H22A4 Head
  15. 98 civic D28Y8 no spark
  16. B20v question
  17. Conversion to Crank-Fired ignition
  18. Need your help identifying D-series camshaft
  19. JDM Integra Type R pistons (P73-J00) in GSR... Compression Ratio?
  20. b16a2 head on GSR Block
  21. B20v crank ?
  22. Stage 2 Cams / built head with stock pistons?
  23. LS Vtec build: Use the LS or GSR crankshaft for 9000 rpm?
  24. D16W1 engine - any alternate replacement EGT sensor? Or info about it?
  25. B16 dual spring issue please help
  26. B16 head issue
  27. Suggestions for removing a crank pulley
  28. Misfire/low power after warm up below 2500 RPM on 1991 Honda CRX
  29. ITBs and IACV w/ S2 IACV Relocation
  30. 1998 civic D14A4 noise
  31. Dohc zc engine help
  32. H22 All motor build questions
  33. LSVtec b16a hose help
  34. Is it time for a TB or intake manifold upgrade
  35. Do more or stay
  36. Buddy Club Spec IV Cams: Thoughts on My Build Plan?
  37. Can anyone Id this h22 header
  38. IDENTIFY HEAD CODE
  39. D15y7 bolt ons
  40. LSvtec 600-700 rpm idle surging
  41. J35A7, Broke timing belt, New heads or engine?
  42. I need help building my b18b1
  43. Anybody have any experience with the crate engines from JEGS?
  44. F22B1 Rotating Assembly
  45. F22B1 Rotating Assembly
  46. No notch H beam build
  47. b Series best header
  48. Motor Machine shop help request
  49. What does it take for a B18B1 to make 250-300whp?
  50. Dyno result for rebuilt 1991 Prelude b20a6 + seeking advice
  51. 96 Gsr kick panel wiring connectors HELP
  52. JDM motor
  53. 2013 Acura TL NA build
  54. Peckurz's LS VTEC Build Questions to hit 10,000 RPMs. What else do I need?
  55. My 1st N/A Motor Build
  56. What is this on the surface of my block? And how do i remove it?
  57. Selection of engine equipment for d15b
  58. Drag Cartel 005.5 Killer Cams Timing Help
  59. Feedback Request: Nippon aftermarket PR3 Pistons.
  60. Oil Pressure Relief Valve Issue? *SOLVED* Loose oil filter
  61. Buddyclub Spec VI 6 camshafts
  62. B16A2 N/A Build
  63. 1995 del sol cranks but won't start - Possible bad compression?
  64. Having a weird power loss issue.
  65. H23A w/ BC Stage 2 Camshafts: Cam Degreeing
  66. Overheating issue with my B18 motor
  67. Finding alternative to compensate detonation/Knocking for increased compression ratio
  68. tps calibration question
  69. What coolant hoses do I choose for an F20B engine in an EM1 chassis?
  70. Assistance needed: b18c1 spark or timing issue. Where do I start?
  71. Strange issue with my b16. (losing power/jolting/poor idle).
  72. Assistance Needed: Swap B20z2(Auto) to JDM B20B. What is required?
  73. 11,000rpm B16 destroyed a piston. Any diagnostic theories to discuss?
  74. Engine Block Crack or Casting Marks
  75. Is a J Series question ok?
  76. zxpro is planning a B16A SIR2 All Motor for "Track". What are some options?
  77. 405 stock block
  78. eg6noise's reasonable budget B20VTEC build plan. Suggestions welcomed
  79. Resurfaced Block Has A Chip!!!! :-/
  80. F20b sohc vs dohc
  81. 86 EV E-series engine timing belt help
  82. Proper fuel injectors
  83. Ported f20b head and intake manifold
  84. help figure out this noise 8th gen 3.5L
  85. Apexi VAFC HP Gains Stock B18/20 Non-VTEC
  86. Fuel Pressure Regulator Comparisons. Are there any differences in "hp"?
  87. Ls/Vtec with rdx injectors. What is needed?
  88. D series itb shenanigans
  89. Crower cam spec questions
  90. Suggestions Needed: Running B20/VTEC. How should I run an Oil cooler?
  91. 4th gen TL J37 Oxygen sensor disabled
  92. Black oil in B16 head cam bore
  93. Feedback & Suggestions on Jag0's 230whp B20/VTEC Project Build
  94. Valve guide damage
  95. Valve guide damage
  96. JDM ITR Pistons + GSR Rods vs. Forged Internals
  97. Putting a vtec rocker assembly in a non vtec head
  98. Need Help-Dead Cylinder-Oil Fouled
  99. How hard is it to build a dy16, b16, b18 or k-series?
  100. How to go about b16head and b20 block?
  101. B18c skunk2 pro 2 Hp numbers
  102. another iacv question
  103. DC2 ITR oversize pistons
  104. Question: What is the possible cause of an oil leak?
  105. Usdm ek hatch swap
  106. ATI Super Damper on B16B Keyway Question
  107. Throttle Body iac question
  108. Hoping for a little guidance - B16B Rebuild
  109. B20v tb cable issue
  110. B16/b18c1 making knocking sound after timing and valve adjustment
  111. Can we make a list of dohc f/h cams from greatest to poorest
  112. F20B w/ Dyno
  113. N/A B16 how much can you squeeze from the stock cams?
  114. b20 build
  115. Is a B20V as reliable as a B16A on an N/A application?
  116. Toda Spec A2s on mostly stock GSR?
  117. Forgot to oil washers on head bolts, Advise please!
  118. Need help! Broken temp sensor
  119. Bad head gasket or cracked head, need opinions!
  120. B18 into 89 CRX
  121. Piston wear or damage?
  122. B16 idle surge
  123. CVT on B20B
  124. Looking for some guidance D16Y8
  125. Need help with b18c N/A build
  126. Throttle Body question
  127. Is this gsr head still usable
  128. B18c crankcase pressure leakage ?
  129. H23A using a p13 hf2 ECM with SK2 Pro1 cams + gears. Has this been done?
  130. Help Identifying Rocket Motorsports Camshafts
  131. Re: Landis Calle's b16A2 Block /B18C1 head questions -Newbie
  132. Tuner 2 presets or 0,0?
  133. OBD-II parameters
  134. B16a2 head on b18c1 block
  135. another Catch can post
  136. D15z6 Minime-swap
  137. 2000 ob2 oil pump
  138. 4Piston Skunk2 Ultra Street IM - Overkill for a stock JDM B18C?
  139. b20vtec high comp need suggestions
  140. D15z1
  141. Honda J-series Rocker Shaft Lubrication Question
  142. K20/24 supercharged
  143. Identify Skunk2 cams
  144. P1J-HU-2 head code
  145. New B20VTEC Build - What headgasket company & thickness are recommended?
  146. Help with Headers on B18C EG4
  147. Car bogging down
  148. D16y8 to d16z6 comparison stock vs ported and polished
  149. D15A2 power increase options
  150. B18c Seized - rebuildable?
  151. From boosted single jingle to all engine naturally aspirated help
  152. Crankshaft rotation
  153. B16 fuel pump question
  154. Currently have B18C JDM in a Classic mini. Things are about to change radically.
  155. Product Feedback Request: "ITM" pistons & their components
  156. Gsr girddle on a b18b ?
  157. B20v question please help
  158. can you run stg 1 cams with stock valve springs
  159. Assistance needed: what cams to use for a B20 VTEC? No purpose stated
  160. Burning oil at hi rpm what could be
  161. Intake/exhaust cam timing advance or retard for valve to valve clearance
  162. Any brand recommendations to get custom valves made?
  163. Can I run stg 2 cams
  164. B20 vtec pro2 camshafts using the stock block. Good idea? Discuss
  165. Piston Rings or Valve Seals (Compression Test B16a2)
  166. Intermittent code 17 VSS
  167. What ECU should I use for my B16A2 with cams, pistons, and I/H/E mods?
  168. Need advice choosing B20 VTEC cams for this build
  169. H22 Broken rocker arms 7 of 8 sets. Help.
  170. B20VTEC 12.7:1 CR on 91 Octane destroyed the block. What's next?
  171. LSVTEC p30 Nippon Cast pistons and gsr head 12.3:1. What fuel can I use?
  172. 70mm throttle body, or no? GSR 12.2:1 E85 build
  173. Suggestions needed: Stock B20b/P8R w/ IM - How should I proceed?
  174. Hondata vs. A'PEXi VAFC-II for mild build?
  175. H22 head work by JDMR
  176. B Series Timing - Crank turns on its own before cams
  177. H22 ported head please check it out!!!!
  178. Car hiccuping at low throttle.
  179. Skunk2 Pro2, 4Piston head - torque drop after VTEC
  180. B series engine build/head question
  181. JDMR PORTED H22 MANIFOLD
  182. B20z block with b16a2. Headgasket Suggestions?
  183. Advice on broken tranny alignment dowels?
  184. Dual H22A crank pulley on Euro R/JDM H22A4 possible?
  185. Supertech Springs/Retainers with stock GSR cams?
  186. help!!
  187. Camshaft differences between D16Y7 and D16Y8 engines
  188. B20v ecu issue
  189. Started engine broke with high comp/hard springs
  190. Dual Valve Springs with OEM Retainers on GSR?
  191. Flat vs dished valves or oem ?
  192. Team Loyalty has a B20VTEC build Question that needs your input.
  193. 99 civic si build
  194. Spark, Fuel, Compression, Timing. I have it all but still no start.
  195. B20VTEC w/ ITR Pistons: stay 84mm, or go with 84.5mm
  196. All motor b20v
  197. B20v on a Ek hatch overheat issue please help
  198. What oil drain fitting is needed?
  199. Can I install upgraded fuel pump on stock system?
  200. Question regarding Exhaust manifold civic EP2
  201. Is there an issue running 1000cc injectors with I/H/E B18c
  202. D16Z6 Stock Connecting rods maximum compression ratio.
  203. upgrade suggestions
  204. Troubleshooting: B16A Engine cannot rev past 3500rpms . Timing belt issue?
  205. Buddy Club Spec III+ Cams on GSR?
  206. H beam arp 2000 torque specs
  207. Aftermarket girdle question
  208. Is it beneficial to use E85 on stock injectors?
  209. H22A rear crankshaft seal clearance 0.02" - 0.03"
  210. opinions needed. Gsr build vs ls with gsr internals. Which to go with?
  211. Stock w/bolt-ons B18B Dyno
  212. B20z2
  213. Stock gsr rods capacity(n/a) I know this has been done
  214. Stock rods on B20v..?
  215. B20v issue please help
  216. CR Increase and Timing help!
  217. Suggestions needed: ideal injector size for E85 NA build
  218. Feedback request: Increasing B18C1 compression by resurfacing the head. yay or nay?
  219. 91redb20ef's B20/VTEC Build thread. Here we go..
  220. Oil squirted dowl pins
  221. B20 swap need some advice
  222. Valve lash - High compression
  223. Skunk2 cam identification HELP!
  224. The components of carbureted d15 work with a fuel-injected D15B?
  225. Regarding The J35A8 Engine
  226. How to Pull J35A8 From 2005 Acura TL?
  227. Rotation of J35A Engine....More
  228. What cams would you recommend? It's between Blox Type B, Blox HSL,or Blox P2?
  229. Code fuel Injector, what is the order. 2.2 i-ctdi
  230. b20v Dyno graph. Suggestions ???
  231. B20 crank and rods in a b18c1
  232. Compression ratio in a b18c1
  233. B18c1 oil squirters
  234. All Motor Mike's - H23A Blue top PDE “Type R” clone build,...
  235. B20 Swap Emissions Questions
  236. Product Inquiry: Blox p2 camshaft valve lash & cam gear settings for B-series engine?
  237. Product Inquiry : Obx stg 1 cams - Are they a value worth keeping?
  238. Poor mans type-r sad dyno numbers at 155/120 Ideas?
  239. H22/F22 SBXM th gear cuff
  240. B16 Cams and High Compression Discussion
  241. 94 eg euro r idle and start up issue
  242. B16 Head Valve Job and ITR Angles help!
  243. B16 Intake dual springs on exhaust
  244. Obd1 motor in an obd2 car
  245. Cat / Limp mode?
  246. LS VTEC Conversion in 2020 [My Experience No VTEC to VTEC]
  247. All Motor Mike's - H23A Blue top PDE “Type R” clone build
  248. OEM H series intake manifolds, which is the best for you?
  249. Is it worth it to swap 310cc injectors from the stock 240ccs I have now?
  250. Product Inquiry: 13.5:1 Compression B20v Camshaft options. What's out there?
