PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 [185] 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. :any FREE mods to a B20Z????:
  2. ???????'s about itb's
  3. what type of motor is an LS ???
  4. Engine damage
  5. Crank Pulley question
  6. 7 intake and 9 exhaust......valves
  7. Problems with Probe Rods??
  8. //////// best ECU and compression rating for Buddy Club spec 3's? \\\\\\\\\
  9. Ecu for SK2 Stage 2 Cams?
  10. Are longer lash adjuster screws available?
  11. need some comp numbers
  12. 2,000 dollars to spend for motor upgrade, any ideas guys
  13. what would be the best cams?
  14. b20/vtec timing belt question
  15. Crower 404 Cams *HELP*
  16. Playing With My Beater D Series
  17. help deciding cams
  18. Buddy club or skunk 2
  19. Alternator Pulley
  20. ran my car last night.....
  21. Castrol Gtx Start Up Oil
  22. Lightweight pulleys
  23. Has anybody had any problems with HCP mount kits?
  24. ??? Anyone using as Victor X intake???
  25. $4000. to spend on a swap, what can i get
  26. B18c5 with Toda spec b's or c's
  27. is a b16 head bettter to build than a b18c1
  28. Tranny oil cause idling at low rpm! Emergency plz help
  29. Possible to make ZEX direct port?
  30. My soon to be Motor Setup
  31. Flames out of the exust. ???????????????????
  32. advice
  33. H22 Dyno pump gas
  34. another flat bottom valve Q
  35. Best cam for this setup
  36. Yet Another Homemade ITB Setup (at least its on a hypeR)
  37. there any stock rod, aftermarket 84mm pistons?
  38. What CR and power will 94octane support?
  39. good machine shop in washington
  40. Piston Choice...ls/vtec
  41. weird heat problem.
  42. can someone tell me the manufacturer of this lsd?
  43. ...Professional Product Harmonic Damper...
  44. Ominpower vs M24x Valves. Where is the difference
  45. Scrapper! Worth it or not?
  46. Skunk2 stage 2 compression craving?
  47. Forget the boost... all motor now!
  48. Throttle Bodies?
  49. Any engine rebuilders in or near MA?
  50. parts suggestions please?
  51. Crower Stage 3's streetable?
  52. Power output of all motor TODA ???
  53. Tools
  54. Piston Size
  55. Has anyone taken A.S.E's >AUTOMOTIVE EXCELLENCE SERVICE....
  56. Hytech New Header, #2 of 5 being made this year !
  57. Cat back exhaust
  58. Most Steetable All Motor HP....
  59. LS/VTEC put on dyno today...suprising baseline
  60. LS/VTEC Dyno, what should i do next?
  61. destroy a b-20 (part 2)
  62. Eagle stroker 2.2L ???
  63. Biggest non sleeved bore?
  64. Which TB to use on JDM 1G B16A w/AEBS 65mm IM
  65. Question on LS/B20 Heads!
  66. HEADER WRAP (DOES IT REALLY WORK???????)
  67. blox b spec cams
  68. LS Vtec ITB's
  69. Buddy Club Camshaft/ Cam Gear Adjustment/ Distributor adjustment
  70. AFR and fuel controllers
  71. oil pressure problem
  72. beginning my all motor build...
  73. question about valve to valve clearance...
  74. Header question
  75. H22a Jun cams with other valve train
  76. AEBS INTAKE MANIFOLD ANY GOOD?
  77. new GSR build let me kno what you think
  78. how does this sound for an all motor street strip build
  79. question on my upcoming build
  80. Help with digital 6
  81. how do i break in my car...
  82. previous post
  83. colder plugs= leaner a/f??
  84. Speed Problem
  85. lsvtec questions
  86. have itr cams on stock gsr valvetrain. upgrade springs w/ retainers? or just springs?
  87. Fuel rail with ITB's
  88. true or false...b16 head on jdm b-20 equals blown motor
  89. SOHC all motor no turbo or supers
  90. high comp ls/vtec piston issue
  91. question about p72?
  92. Latest progress: 954RR ITBs (Dial up....Um?)
  93. OVERHEATING PROBLEM : mystery to mankind
  94. B16 Bottom end..... Please help....
  95. skunk 2 mani on b18b(now my car runs like garbage )????
  96. PR3 Pistons on a GSR?
  97. Need new pistons to add a B16 head on a B20?
  98. B18 with B16 head compression anyone ?
  99. which motor to swap into 95 civ?
  100. Is this a good setup?
  101. B18C5 Buildup..need some input!!!!
  102. anyone with a streetimports aftermarket type-r headeR???
  103. Thermal plastic around header's manifold pipes + CAI
  104. heat-cycle
  105. b16a intake size/throttle body question.
  106. O2 sensor placement...aftermarket header, use one pipe or where all 4 merge???
  107. B16 bore and sleeve?
  108. Running the Skunk 2 Stage 2 cams
  109. Do b16 rod bearings work in ls rods?
  110. H-T.com proven power parts didn't add up
  111. ls/vtec bad for all motor?
  112. b20
  113. Where to weigh car
  114. Kenji ECU question
  115. Type R oil filter housing
  116. Injector sizing
  117. where can i find a plexiglass kit for my 88 crx ????
  118. good local shop in florida for valve job????????
  119. All-motor setup Toda, etc....
  120. SOHC power
  121. plugs are white?
  122. DISAPPONTED with 1/4 TIMES!!!
  123. Cleaning vtec head
  124. Darton-MID-sleeves with original HondaHeadgasket?
  125. Stock low-end B20Vtec users?
  126. Need more info about dropping valve...
  127. New exhaust. Do I need a donut gasket?
  128. b20 vtec ?'s
  129. Pics of current b-series project...
  130. greddy e-manage base maps?
  131. WHO sells the ANR intake manifold cheap
  132. What is the maximum you can mill a b series head?
  133. VSS sensor
  134. Porting a p72 intake mani?
  135. Low KM ZC with Cams - Advice
  136. what else should i get?
  137. RM M22s VS SKUNK2 Stage 1 pics
  138. compression test sillyness---
  139. GE oil adapter for B20vtec
  140. will a b20vtec pass smog?
  141. re-torqe
  142. Toda high power clutch kit?
  143. Civic B16b pistons in ls block with ls head?
  144. balancer shaft removal
  145. LS head on Gsr block?
  146. PR3 pistons in LSVTEC
  147. WHICH CAM IS BEST FOR D16Z6?
  148. Headgasket question related to bore
  149. I want more compression
  150. dynoed my jdm b18c-r with skunk stage 2 cams and an-r compact header
  151. Boring to 82mm?
  152. problems after Edlebrock intake mani install...
  153. i need help with header with are goood header for my car
  154. Rob bolt stretch specs on stock GSR???
  155. B20 vtec writeup??
  156. Head Gasket Replacement Question
  157. CTR Crank Pulley on B18b?
  158. quik ?'s about pistons size
  159. all motor d16z6
  160. AEBS pictures on a B16
  161. advice on high comp built
  162. are gsr rods and itr rods the same?
  163. Questions for those who might know...
  164. Balanced and Blue Printing?
  165. sohc cam...
  166. tunning torque curve of tq&hp curves
  167. This is why not to run ITR cams on b16 valve train
  168. can i use motor syn oil 10-30 for tranny?
  169. 70 mm bbk throttle body making noise
  170. Part # for PR3 pistons????
  171. 11.5 compression tuning
  172. Toda Headgasket
  173. b20 block or 2.0L gsr
  174. What size is Thermal R&D NA Cat-back application ?
  175. i want 200whp b20vtec
  176. basemap request 2.0L 12.9 compression on 310cc
  177. need a 2.5in header for a b16a, help please
  178. b20 crank pulley an a b16
  179. ECU help
  180. WILL DO a+++ head porting (School of Automotive Machinest)
  181. Golden Eagle Mfg. needs your pics!!!!
  182. hairline crack in b20 block///
  183. swapping auto to standard any takers???
  184. 1 layer head gasket?
  185. Bore and Stroke pro's and cons
  186. CBR throttle body TPS question.......
  187. good setup
  188. Shop needs consumer thought on header design and install
  189. A question for those running ZC(P29) pistons in a D16A6
  190. How soon should motor be started after build?
  191. What is a "poor mans type r" or what they call "mini type r"?
  192. b18a crank in b17 block
  193. individual throttles for h22a
  194. M22 vs. M24 cams from Rocket Motorsports
  195. IAT intake air temperature sensor, the same on all motors?
  196. what mods for LS crank in b16?
  197. comptech or JDM type-r header??? NEED ADVICE...
  198. another b16 dyno
  199. new motor B18C1
  200. Headgasket question
  201. Vtec Pressure Switch, Code 22 Itr Swap Please Help
  202. JDM OS Type R Pistons and Skunk2 B16 Intake Manifold All Brand New
  203. crower cams
  204. Torque to expect out of an ls/gs-r (vtec)
  205. 85mm b16a...vs 81mm lsvtec
  206. best header in a integra
  207. whats my ls/vtec worth??
  208. does anyone know whats wrong
  209. J/E 81 MM HIGH COMP PISTON..I NEED PISTON RINGS AND BOSS CLIPS..
  210. B20vtec, .9 cr worth it?
  211. ~HONDATA/ ITB question~
  212. Compression
  213. ignition timing on decked block
  214. s200 datalogging
  215. 90crxobd0 b20vtec, pr3 okey for now? also injector "?'s"
  216. P30 PISTONS ON PR4 RODS??
  217. Anyone do this yet? AEBS IM on a B18B/A head.
  218. prices for GE and Darton sleeves
  219. Help me tune ITBS
  220. p30 piston rings?
  221. best pistons to use for b16 block
  222. will a obd2 plugs straight up to obd1 car, ANY allmotor know?
  223. b20/vtec is on the dyno
  224. kteller exhaust questions?????
  225. thicker vs thinner spark plug wires
  226. Aries pistons 84.5 bore on a gsr?????????????????????????
  227. Fitment of EnzoRacing header, and Final Thoughts
  228. how to tell a motor has been resleeved
  229. side exit exhaust
  230. side exit exhaust?
  231. where to find "side exit header" ???? and who makes a nice one
  232. Need some help on getting info on jg cams.
  233. b16 torque build up
  234. couple of ls/vtec questions
  235. My main bearing clearances. Please bear with me.
  236. Scuffed Retainers Re-usable?
  237. where can i get a spoon block
  238. What is the proper way to torque nuts & bolts down?
  239. How high can you rev on stock rods? (D-series)
  240. Appropriate Fuel Injector Sizing
  241. no vtec??
  242. RS Machine Dohc vtec Camshaft users what valve train are you guyz using?
  243. any quick horsepower tip for a 94 del sol under 60 bucks
  244. How well do your aggressive built motor start up.
  245. boring hayabusa throttle bodies
  246. no oil pressure at top of LS-vtec line???
  247. Code 15 cant rev past 6800???
  248. 1989 CRX sohc Cam Gear
  249. I want VTEC
  250. 2.0 all motor building questions
