PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 [217] 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. crank pulley timing
  2. To all those SOHC fans, another z6 and y8 questions?
  3. P&P B16A or B18C head for B20VTEC
  4. 2L motor with perfect r/s ratio? b20 bottom end possible?
  5. B20Vtec Probs
  6. lsvtec buildup questions?
  7. Just ordered some new toys!!
  8. ARP Rod Bolts: Anybody ever had them come back crooked?
  9. Compression Ratio Calculation - Please Double Check Me
  10. type r all motor run 10's?
  11. does any have a bare P&P race ready ls head (bare)
  12. my allmotor monstor what do u think
  13. How High can i make power Manual b16 cams 9k ?
  14. all motor 2.2 gsr???
  15. b16 all motor
  16. B20vtec..Balancing necessary?
  17. Alternatives to claying the motor?
  18. Is this worth the $$?
  19. Valve clearance & CR on IB-spec pistons
  20. Confidential Rocket Trade Secret Found Here
  21. Head ports? Crower Cams?
  22. differences
  23. Does a P08 ecu look for a Knock sensor??
  24. zc and itw???
  25. Motor rebuild questions???
  26. Deshroud chambers for B20VTEC ?
  27. prelude injectors on mild ls/vtec??
  28. ? about identifying USED Jun 3s... Can't tell if I got scammed.
  29. My 11.4:1 CR all motor LS.........150 miles in on the break in! Deisel like idle????
  30. Which engine
  31. Just starting on performance mods, need help
  32. does a p28 ecu have a knock sensor???
  33. how will a port & polish affect gas mileage
  34. Safc vs Emanage/Base Hondata
  35. Dave Hickman The All Motor Champ, Where is Jeremy Nutt?
  36. Timing
  37. has any had good results from exhaust insulating wrap
  38. stock b16a
  39. Building a D16Z6
  40. water pump b20
  41. What to do?
  42. b series 2.2L n/vtec
  43. gsr short block with a b16 head?
  44. thinkin of going b18a with vtec head
  45. cheaper injector alternatives???
  46. NEED HELP PUTTING IN A VAFC APEX controller in a d16z6 hatch wiring or anyhelp PLEASE????
  47. eagle stroker kit
  48. How to ID Jun stage 2 cams, got sick of searching and only finding stuf about 3s
  49. Check out this ported head.
  50. endyn breather kit question
  51. Stock GSR valve springs with CTR cam...any issues?
  52. Pomona , cali DYNO
  53. is b16a swap worth it?
  54. Function7 5-main girdle & stock P72 oil pan
  55. Question about CP 12.5:1 pistons
  56. high comp break in period?
  57. shit!!!!! broke off the engine ground wire post
  58. b16 help please
  59. What can i expect (WHP) (1/4 time)?
  60. stroking a b18-c1?
  61. LS/vtec, stock bottom end
  62. Need a little help with pistons
  63. dh-racing crank pulley has no key way, no timing marks.
  64. LS/VTEC- main cap bolts, reuse or not?
  65. Help me decide on a Toda cam for a LSVTEC roadrace/auto-X app!
  66. how much does tuning really help??
  67. Let's have a moment of silence.......
  68. I Need a MACHINE shop in SO CAL
  69. 92-96 Prelude injectors in CRX with a VAFC
  70. b20/vtec or full itr motor? which would you pick??
  71. SMOG ISSUES
  72. looking for a web site.. can you help me?
  73. JDM Civic Type R Cam Shafts CTR Cams
  74. usdm rings fit with jdm itr pistons??
  75. where to buy new p30 pistons
  76. Any websites having good christmas specials yet???
  77. what cams should go with ls/vtec setup on a 00' si ?
  78. valve noise under load
  79. compression ratios
  80. BBK Intake manifold...
  81. TIPS for Golden Eagle Block users and those planning to use 1.
  82. ls/vtec post
  83. For H22s if i were to mill the head mildly and get .25 over type S pistons what would my comp be at?
  84. how much power?
  85. jdm itr pistons
  86. GSR head raises compression...
  87. where is your vtec crossover set at on s2s2 cams
  88. net gains with skunk2 . . . .
  89. do you guys think this is going to be a reliable ls/vtec?
  90. Does this E/t not match the trap speed to you???
  91. all motor dseries research
  92. GSR opinions?
  93. VAFC Question
  94. IB Project 2.1 : Dr. Jekyll & Mr. Hyde.
  95. Milling rods for ctr pistons
  96. RC injectors for a GSR
  97. Question about bearings???
  98. ls/vtec info. needed
  99. ** horsepower differences from stock to 64 mm t/b on b20vtec??**
  100. whats a good cam for 00' Si ??
  101. stroker kits for b16
  102. milling b16 head?compression
  103. quick question
  104. What should my compression read for the following setup?
  105. How much compression will 30 thousandths give u?
  106. K24 - K20a? 2.3-4L potential...
  107. For those of you who dont know what to do with your b18c1(GSR) look!!!!lol
  108. skunk2 stage 2 cams what fuel set up?
  109. need help
  110. Going paycheck by paycheck.
  111. 98-2001 type r cams ?
  112. The specs on skunk stg2s for preludes and the specs on the 3's which *i think are out im not sure*
  113. Head studs...need to get them off.....
  114. wondering, if this swap will work okey ? b16a2 head with b18 ls/vtec
  115. how to post a pic of my car
  116. Open Header or not???
  117. only trapped at 99mph
  118. ARE THIS IB SPEC 7cc pistons ?
  119. PS ?
  120. Is it true K-series dont really need adjustable cam gears?
  121. anyone know when skunk2 is coming out with kseries stuff?
  122. stainless vs. others
  123. Valve adjustment specs?
  124. Are bigger valves better???????
  125. Aftermarket valve stem seals?
  126. RLZ intake manifold update
  127. what should I do next?
  128. b16 pistons in gsr....
  129. buying aftermarket pistons for ls/ vtec
  130. H22 JDM PARTS #s
  131. skunk2 stg2 question?
  132. Port & Polish LS Head. Which Year?
  133. B20B vtec times?
  134. Toda Killer cams and ITB's (Round 1 tuning complete) plots inside.
  135. CTR/ITR cams on stock valve train????
  136. CTR/ITR intake cam question
  137. what happens not rep main bearing?
  138. will skuk2 stage 2 fit in my set up
  139. H22 in EG Hatch-What 1/4's can i expect?
  140. 190whp crx lsvtec, what times can I hit
  141. Help, on piston dome displacement.
  142. trannys
  143. anyone have an idea about the whp of this setup??
  144. UNURTHODOX CRANK PULLEY QUESTION
  145. maximum gsr bore
  146. endyn breather kit?
  147. info toda piston
  148. MANIFOLD MODIFICATION WHAT'S YOUR OPINION???
  149. Need info on new valves for B16a.
  150. what bearings do you guys like to use?
  151. ctr or type r pistons?
  152. What's the best suspension setup for an all-motor drag car???
  153. h22 balance shafts
  154. What does crank weight affect
  155. Jun Dealers?
  156. H22 guy's Daily driver 13:1 C/r?
  157. are b18c5 bottom end components compatible in a ls block?
  158. dh-racing 10 sec eg hatch
  159. Thinkin of going the NA route. Got a few Questions.
  160. TOP FUEL intake manifold, anyone got info on it?
  161. ValveTrain - which one? where?
  162. Size of pump and Injectors? BRAND?
  163. Just decided to go all-motor, so I would like to ask some questions/rumors..etc.
  164. How to identify a Portflow Head?
  165. k20a2 head milling
  166. Crower, Skunk, CTR - expert advice needed?
  167. Honda/acura Enigne builder?
  168. feilds vtec sfc help
  169. All motor Dseries w/ 450 injectors...good or bad idea?
  170. h22 hytech header
  171. Don't do oversized valves
  172. ALL MOTOR H22 IN CIVIC
  173. Jdm ITR nitrate coating???
  174. Question about this weekend's IDRC Pro-Am FWD All-Motor
  175. will type R crank and rods work well in a b20b
  176. would you trust this valvetrain package?
  177. Engine builders: Steps and tips you use when building a bottom end?
  178. Where's Wil of Exospeed......
  179. VAFC vs Hondata (read before shooting at me.)
  180. What would you do first??? B16
  181. Aluminum vs Titanium Retainers
  182. what all is included in a complete shortblock, and how can you tell if a block is still good or not?
  183. best header for all motor
  184. DC Sports Header
  185. hey question....HELP PEOPLE
  186. TODA A or CTR in a B18c
  187. upgrading fuel system in lsvtec, need input
  188. TWM / JG / ENDYNE What would you use for 250hp + all motor.
  189. will a d16z6 make 150hp with these mods
  190. Crower Cams?
  191. I want to break the 200whp mark - What's the best way to do this?
  192. toda vtec killer,comments?
  193. If there is one part that is more important on a motor what would it be?
  194. B16A2 rebuild kits?
  195. Needing some help.......
  196. vafcII
  197. how much could i get for a b16 block?
  198. Stronger main caps? READ
  199. P28 SOHC ECU on a 98 B18C1-how low is the fuel pressure
  200. b16 displacement
  201. going all motor on a b18c
  202. How did omniman make 195whp b16?
  203. Satan's H22a dyno 11/18/03 - Balancer shaft belt test
  204. engine build....
  205. NA OR supercharger
  206. Do I need Golden Eagle Dowel Pins with ARP Head Studs?
  207. is this compression high enough for crower 404 b18a1 cams
  208. exaust maniflod
  209. Where to find High compression H22 pistons?
  210. Allmotor wheel HP Registry
  211. For all of the smart ones on the topic of LS/VTEC setups I desperately need your help
  212. Anyone have lift/duration specs for a B20 cam?
  213. best headers for a all motor type R?
  214. compression and clearance questions
  215. anyone ever use the dh-racing race crank pulley?
  216. B16 block, B17 crank and rods, 85mm pistons - Questions
  217. Just bought b18a block, want to go LSV, what to do now???
  218. Help how big a bore size for my B18C1 block?
  219. Understanding the specs ?
  220. K20a2 pistons into K20a3?
  221. need to kno... h22 swap
  222. cams on stock pistons?
  223. Crank weight
  224. 70mm throttle body too big for my all motor application? and another question
  225. I dont want to buy a DC JDM 4 -1 Header right now
  226. running lean b17
  227. is 35 more horses realistic? with the following
  228. is there any GOOD BUILDERS that can help me, lsvtec
  229. milling head on b16a with ctr pistons?
  230. ls vtec set ups
  231. Need pics of nice and visible place to put gauges.
  232. Group Buy on Greddy Timing Belts B16A and B18C!!!
  233. 96+ B18C5 specs vs. 98+ B18C5 specs
  234. Does anyone know how to change the seal on a tranny?
  235. Dynos of all my motors
  236. B16a(pr3) pistons in LS block w/ high lift cams???????
  237. D16Y7 + the D-series compression calculator = ????
  238. b20vtec suggestions
  239. B20 header
  240. Original b16 oil pump sufficient???
  241. Any experience with Crower Vtec cams?
  242. which intake.
  243. which cams??
  244. break in period
  245. IB spec intake manifold
  246. Need Advice on Cam Gear Settings
  247. Can you use???
  248. LS/VTEC HELP !!!!
  249. 12.0 c/r...now what cams to get
  250. Clearances????
