PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 [222] 223 224 225 226 227 228 229 230 231 232
  1. LS internals in a GSR block
  2. what would u pay to tune your car....
  3. Which engine combo should i go with??
  4. H22 DTR header installed pics...20whp
  5. production cat backs......searched but no help, will they support 200hp??
  6. Cheapest tried and true way of getting 170whp out of a obd1 b16a2? (don't say nos)
  7. DC JDM 4-1 header on B16?
  8. who's put a b17 crank into a b16 block?
  9. ?about ls/vtec and 8000 rpm?
  10. edelbrock intake manifold dyno comparison vs Type R stock manifold
  11. comtech icebox kit fitment
  12. best cam
  13. broken oil pump picture, all motor ls/vtec
  14. How is this for a n/a gsr start...
  15. Things are getting heated on the ENDYN BBS
  16. b16a1 whp?
  17. help
  18. b16 exhaust cam specs
  19. CTR pistons in stock 00 type-r motor = what power?(Not a Clearence ?)
  20. ALL H22 Civic/Crx Owners!!! I Need Your Help!!!
  21. Valve adjustment...questions
  22. why go all motor?
  23. b18c1 question
  24. New AEM management system ???
  25. what kind of whp am i at?
  26. Congrats to DTR hittin 10s!!!!!
  27. 11:5:1 in a b18c1
  28. Who runs the REAL V-TECH KILLERS??
  29. cam caps cracked! HELP!!!
  30. oil in coolant
  31. b16 or??
  32. will b16a pr3 head bolt up to b18c1 block?
  33. Shant blew motor???
  34. clutch fly wheel...
  35. Omniman's Pending Project: 200whp B16
  36. best motor for my Si EG
  37. is it true about the b17?
  38. Compression ?
  39. All motor B16 - please help
  40. 305, or 350?
  41. still burning oil
  42. NEED HELP FAST!!!!! THIS JUST IN
  43. Price and availability of Titanium Piping..
  44. i got a cam adjusting quest.
  45. hp and tq from gsr head on ls block?
  46. pics of my ls/vtec project...
  47. P28 ECU
  48. Valve Clearance Measurement B-series
  49. LSVTEC - B16A1 head, what ecu?
  50. safe b18a revlimit
  51. Will I get big gains in my B16 from ITR cams?
  52. motor is finished pulls strong
  53. Can you install CTR cams in a B16A1 w/o changing springs???
  54. Help identfy my mystery cams
  55. this may be a noOb question
  56. B18c block and a B16, head how would you make it fast?
  57. an-r header??
  58. Toda 'D' installation note.
  59. head builders or head shops!!
  60. Adore my Header-tech Header!!!
  61. b16 in need of help
  62. DTR experiment
  63. Building LS/VTEC question is, is my valve-to-piston clearance safe??? HELP pls!
  64. fs: awesome gsr head for a great deal (sorry mods)
  65. CAn the car really be this lean :O
  66. car won't rev out
  67. b20vtec question?
  68. J's racing intake with Iceman ram air headlightscoop.
  69. jg cam gear tdc question
  70. K20 and K24 engine specs
  71. Little to no response in the integra forum...steering rack question.
  72. will ls intake arm fit in a GSR with a skunk2 im?
  73. 12.5 to 1 comp can i drive this setup???
  74. J's racing what model K&N filter??
  75. ? tuning my set up
  76. Any guesses
  77. roller followers, anyone found the limit yet?
  78. please clear this up!! GSR block w/ LS internals??
  79. whats you opinion on streetable
  80. no vtec...help
  81. Vtec
  82. heeltoeauto.com anyone vouch for this sight??
  83. Best bang for the buck header for gsr?
  84. B18 (LS) intake manifold?
  85. Help me decide on parts for my all motor non vtec B20
  86. Stroked B16 Question
  87. How do I beat a GSR
  88. JUN RACING Valve Train HELP!
  89. H22 type S WHP?
  90. JUN III's ,
  91. LS VTEC header...
  92. skunk2 stage 2 cams in gsr with ctr pistions, will it hit?
  93. ls vtec (rebuilt??)
  94. Leslie Durst..drop me an email...
  95. d15 cams
  96. Invidia exhaust insert DYNO difference...
  97. RS machine cams, thoughts?
  98. Any quick all motor Integra's here??
  99. lsvtec build up
  100. B20Z stock bottom end w/ PR3-4 head and CTR cams??? Did search, no answers
  101. What pistons to bump compression in D15B?
  102. Skunk2 H22 dyno
  103. Cam gears worth it without tuning?
  104. Recommendations for ls/vtec block
  105. When building a B20VTEC which block is better, B20B or B20Z???
  106. Need opinions on what set of cams to get for my setup
  107. SPOON VTEC CONTROLLER
  108. Who here blew up a LS/VTEC motor with stock B18A/B bottomend?
  109. Car smoking at redline....What is it??
  110. B16A2 IM vs B18C5 IM
  111. So basically when milling the head...
  112. Hondata Base Maps
  113. how to identify ITR valvesprigns...
  114. Good shop in AZ?
  115. What cams do you have???
  116. Will stock B17 valvetrain handle CTR cams?
  117. Which Cam to Purchase? b16
  118. What to buy???
  119. What timing belt to use with Jun3 cams?
  120. Fast n/a ludes
  121. Can this be fixed?
  122. Got some sick WHP numbers on the DYNO today...opinions please
  123. Piston to deck height w/ctr pistons
  124. built b16.......opinions
  125. what would it take for a d16z6 to hit 150-160whp?
  126. what yeilds more performance?
  127. what would make my motor do this?
  128. Toda valvespring question
  129. b16 acceleration issue.
  130. cam gears?
  131. aebs or arp
  132. want to upgrade cams. but i dont have any knowledge, please help!
  133. ITR replica pistons
  134. Milling b16a2 head,how much do you recommend?
  135. I need dyno sheets of all motor sohc civics!!!!
  136. where to buy top fuel cams from?
  137. head gastket question
  138. if you were me and had 1k what would you buy?
  139. B18c1 Transformer
  140. do me a favor (experts only need reply)
  141. Specs for valve adjustment on Skunk2 Stage 1's???
  142. SOHC vtec head....safe redline
  143. Pistons What Kind Rock for B18 block and a B16head
  144. ecu and tranny questions for ls vtec setup???
  145. what should i do??
  146. AEBS Manifold tested dyno plots and more...
  147. MB web addy???
  148. First dyno run of my B18c5 with print out need suggestions plz
  149. skunk2 manifold for b18c1
  150. Idle unlike i've ever seen
  151. Stroking a b18c
  152. Import Builders/Import Review spec Heads.
  153. 90 crx hf should be the fastest all motor street car
  154. question about iac on itr intake manifold
  155. skunk3 stg3 overkill???
  156. just did a compression test
  157. head gasket for 86mm?
  158. ctr cams, jun valve springs and retainers any good??
  159. ***gap less piston rings***
  160. PR3 in LSVTEC good idea ... bad idea...
  161. Engine Swaps
  162. treating stock rods CRYRO and SHOT PEEN
  163. NEED HELP FOR SCHOOL PROJECT
  164. Idea for 70mm throttle body. what do you think?
  165. Head studs
  166. B18c buildup question
  167. got a question
  168. Guidance/Advice needed
  169. cat converter question
  170. Which pistons should i run????
  171. D-Series Question.
  172. cam gears
  173. dohc ZC upgrades
  174. B18C5 hatch running warm
  175. all motor nild up: forged or cast 12:1 pistons for all motor? rod info too
  176. Engine Rebuild Question aka Machine work
  177. DC Sports Header?
  178. F/S Jun3 cams - mint condition
  179. What do swiss emmenthaler cheese and JUN pistons have in common? [56k meltdown]
  180. H22 Balancer Shaft Removal?
  181. where can i get...
  182. please help me prove that stroking a b18b will be a bad idea!
  183. h22 potintial
  184. best cam gear settings for skunk2 st. 1s
  185. dude looked like he was gettin ready to cry or something.
  186. intakes.....
  187. Grounding question
  188. 200whp- what camshafts?
  189. H22A SWAP QUESTION
  190. please help my gsR type R project!
  191. how much horsep, h22a jdm 92-96
  192. tuners in san diego area
  193. Who makes the best H22 headers?
  194. what to ask when tuning?
  195. skunk2 stage 2, with minimal gain
  196. what exactly is TUNING
  197. ngk platinum spark plugs
  198. running stock fuel pump
  199. Daily driver setup
  200. whats the best compression?
  201. my ls/vtec set up opinions please
  202. need plug wire help
  203. HP FROM ALL MOTOR SETUP
  204. Mugen ECU???
  205. ITR valvtrain??????
  206. best/safest way to purge oil (PCV system ventilation)
  207. Good drag suspension?
  208. Mods for a 88 honda civic hatch?
  209. Badass all motor setup
  210. What kinda engine oil does your NA race motor use?
  211. poll: will my sleeves crack?
  212. b18c or b20z
  213. What kind of #'s with..
  214. IM going all motor with my y8
  215. B20 vtec , LS VTEC people Has this ever happoned to you??
  216. LS/VTEC and VTEC Crossover
  217. ITR cam
  218. what kinda whp with?
  219. who is making 200whp with toda cams?
  220. set up i want to do??
  221. Tranny question
  222. Need help! What do I need to do to get my motor to run good?
  223. going all motor
  224. what is the best
  225. Could use some help on possible power numbers I will put out with new setup in the works?
  226. for all you ls/vtec experts, i need help finding out where my oil leak is coming from
  227. itr block swap into b16???
  228. N/A Reputable Tuning Shops
  229. iceman intake...
  230. HELPPP!!!!
  231. Anyone seen this yet?
  232. Sensor Problem
  233. my b16 emits black smoke?
  234. ls/vtec or poor mans type r?
  235. dtr headers
  236. dtr header
  237. installing pistons? oversized or stock bore?
  238. HERE IT IS...my future setup...hoping for 200 whp
  239. fluidyne help
  240. ITB's and using the Honda ecu to control them
  241. non detergent motor oil for new engine break in??
  242. Pistons on d16z6??
  243. Info post about throttle body sizes...
  244. Does my Ls/VTEC need a knock sensor?
  245. JUN 3's over EF-1 m23, m24's
  246. H22 All Motor Header Production Pictures
  247. bore out tb?
  248. Behavior of Itb's
  249. sweet
  250. Sanding down head and block surfaces necessary?
