PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 [43] 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Fuel Upgrade Questions
  2. Header choice
  3. GSR engine probs and input needed..
  4. Project 98+ F23A1 Block W/H22 Head Can it Be Done?
  5. NEED HELP FAST
  6. NA Build for CRX Autocross Car
  7. Changing out the B20 Crankshaft for the LS Crankshaft. Does it matter?
  8. b20 vtec builds
  9. B18C: T/B and air intake question...
  10. AEBS IM VS STOCK ITR IM
  11. best torque number with b20
  12. D16 / B16 COMBO
  13. LS Rods/Crank in B18C5??
  14. N/A buildup, Looking for some guidance... :0
  15. best street legal header on a b20vtec
  16. B16 cams - BC, S2, or Blox?
  17. JDM GSR block crankshaft and block markings??
  18. fuel issue
  19. LS VTEC build question
  20. nitrous problem.
  21. F22 rod and main bearings??
  22. qUICK b20\vtec qUESTION
  23. Cam question
  24. What components needed for k-swap?
  25. 62mm throttle body for a b16?
  26. IACV block off plate?
  27. SM2 crx d16z6 motor help
  28. stock bottom end b20vtec builds
  29. stock b20z bottom end and gsr head question
  30. LOCK YOUR HONDA/ACURA......ITS NEW YEARS!!!
  31. d16z6 n/a pg6 or p29?
  32. harness modded with resistor box, can i use with reg rc 440's?
  33. Blox cams?Please help making sure I didnt get a bad deal.
  34. ITR crank and rods into B16B
  35. 95mm stroker wont go in gears at high rpm! OMG!!!
  36. ***B16a2 is Ticking HELP***
  37. High Comp. LS/V build
  38. Engine builder referral in Nor Cal
  39. H22 valve spring question
  40. Del Sol VTEC limited at 6500rpm??
  41. suggestions
  42. B16B block with a gsr head?????
  43. manley H-beam or I-beam rods..ALL MOTOR??
  44. Whats the difference from getting bigger valves to std size valves???
  45. Question about piston/rod combo
  46. help and suggestions on ls build
  47. 1st time i have EVER seen this
  48. h22 help/opinions
  49. Hytech replica header, should I wrap it or not?
  50. help me choose my cams
  51. Romo Pyro's Hybrid LS/Vtec Build
  52. Need help with Crankcase Vac system
  53. Cant believe GSR Passed NY Inspection with T1R Testpipe!
  54. Help with B16 Swap
  55. Skim limit on b16 with skunk 2 pro's
  56. Rich Porter Distributors, good or bad
  57. RSR Headers 4-2-1
  58. 95 eg coupe ...b18 swap question
  59. Any 200+whp B16s (not OMNIMAN)
  60. crank????
  61. What's the "Key" to making Good Power????
  62. Capability of Stock 240cc Injectors
  63. aftermarket camshaft identification?? ADDED PICS!
  64. Grounding question b16 msd blaster ss coil
  65. oil on spark plugs
  66. b18c1 unorthodox pulley
  67. Ls Vtec Build in need of piston ring clearances
  68. GSR stock block
  69. E85 or sunoco 110
  70. megan racing 4-1 header...need help!
  71. P.B Brand Dome Piston 0.50mm???
  72. crower 404 valve to pistons
  73. close topic (double post)
  74. gsr arp rod bolt issues?
  75. Royal Purple over Synthetic?
  76. All Motor H2B
  77. b20v = tq loose
  78. help with built ls/vtec to high comp
  79. B16 2.0?
  80. 13020-P73-J00
  81. Need engine upgrade advice/opinion!
  82. valve springs?
  83. gsr wont rev past 3000rpm while driving what can it be timing?
  84. ITR double valve spring green paint color
  85. 04 rsx seats
  86. b20 non vtec
  87. Is IPS out of business? See this gov link...
  88. ctr pistons in gsr
  89. Kinsler Induction B Series Applications
  90. Unsmooth Vtec transition after Dyno Tuning
  91. Cooling issues? B18 85x89
  92. 11.5:1 b18 pistons in my b16. what my comp?
  93. Mahle Pistons
  94. Help, fresh build and plugs are wet!
  95. My LSvtec dyno'd yesterday,something WEIRD happened to the powerband!
  96. Stupid question...help!
  97. Another Unidentified Cam Thread **Searched! Please HELP**
  98. b17 piston...
  99. Cam Overlap affecting vaccum?
  100. h22 sleeve liners question
  101. ISCARS HONDA
  102. precision injectors dont fit???
  103. Humble Performance Project Blue Balls K24/K20 300+ Pump Gas !!!!!
  104. need opinions on building head
  105. My used valves bought
  106. Having Horrible problems! Need help please! DOHC-ZC swap
  107. GOAL: ~250HP w/ B20V
  108. Crower Cams in GSR
  109. skunk2 B series camshafts
  110. newbie needing help asap 01 ls
  111. Cams for OS valve GSR????
  112. HELP.Motor sometimes cuts off after driving for a whiile
  113. monster b-series 2259cc vtec..????
  114. gsr dies out
  115. LS/V question
  116. 86 Honda Accord-Start up idle too high
  117. GSR head lower compression?
  118. wats better for gsr or lsvtec?
  119. should i build a b16A2
  120. Leak from small coolant spout SK2 Mani
  121. Figured I'd ask knowledgable folk...
  122. LS VTEC SET UP
  123. Problem with VTEC disengaging during WOT
  124. Head work (cams) on Integra GSR
  125. Intake...
  126. D16z6 ITBS ¿cams?
  127. Cant turn bottom end by hand.
  128. Poor mans R build... advise??
  129. New motor break in procedures????
  130. p30 or p73 pistons?
  131. header question!
  132. what cam??
  133. LSVTEC Different, stange, head noise:(
  134. Honest feedback...
  135. need help starting up my ride
  136. JDM ITR b18c requild
  137. LS vs GSR engine carpartment hose connection.?
  138. Future build questions
  139. Expected gains w/ skunk2 intake manifold & 80mm tb?
  140. Time for a new thermostat? w/Pic
  141. Can 10.5-1 comp motor make power
  142. JDM ITR 96 spec vs JDM ITR 98 spec crank shaft
  143. first motor job!! help!
  144. what name brand is this intake manifold??
  145. A20A3 '88 LX-i motor help please
  146. Oil Temperature for Test Engine
  147. Performance cams for the ZC?????????????? Where??????????
  148. ALL MOTOR REBUILD 2.0 LSV
  149. Motorcycle Exhaust On A Car?
  150. S2S3 dyno results
  151. Happy with results DYNO b16a2 thanks all Honda-tech comunity gretting from Argentina
  152. cheap rebuild 4 winter
  153. Weird temp readings
  154. All Motor racing
  155. Stock B20vtec good DD??
  156. muffler for h22?
  157. Selling a h22a4
  158. a good cam, piston setup
  159. N/A non vtec b18b1?
  160. identify this motor
  161. Identifying BC Spec III's?
  162. AC Autotechnic Intake Manifolds on GSR
  163. ANOTHER MISS SHIFT
  164. check engine light no code,ecu bad or just need tune?
  165. 96 GSR with a b20 swap
  166. Help choosing a "drop-in" cam for my setup
  167. WTB: Dry Sump pan
  168. choosing rod and main bearings?
  169. Highest compression on E85??
  170. Is this a good B18c mild build for $700
  171. update: my 91 CRX HF/1..8 stock bottom/93 octane pumpgas
  172. 20 Valve Head (Stupid Question)
  173. Crower Offset Keepers
  174. b16a2 compression test results..
  175. Machine Shops
  176. anyone dial in crower stg. 2(402) cams??
  177. b20 eagle rods, 3 lengths & weight
  178. b20v or gsr built? hp goal 200+ daily driven
  179. JDM b16a, what cams to use?
  180. D series skunk2 stage1 camshaft question?
  181. quick arp head bolt question
  182. Anyone using Comp Cams?
  183. CLUTCH SELECTION
  184. ctr pistons, 2 layer HG, SK2P2s??????
  185. B18b1: 12.5 Compression - Pump Gas Dyno Tune
  186. H22 idle issues.
  187. 85.5x92mm b18c build!(Dyno results)
  188. jdm d15b po8 piston rings? Were can i get them?
  189. GSR Block/CTR Pistons. Cams?
  190. 85mm build questions
  191. NEW MOTOR... WHAT SHOULD I EXPECT POWER WISE
  192. VICTOR X vs PORTED PRO SERIES.....WOW
  193. b20b performance?
  194. ls vtec build
  195. Longer 5th into H22A tranny
  196. 2.1L motor runs lean and not making power anymore!!
  197. CTR Pistons and GSR Head Clearance Question
  198. NGK R BKR7ES question on these spark plugs for b16
  199. Help sourcing f22b2 flat top valves
  200. b20v going back to gsr block.whats needed?
  201. help on b18c1 main bearings clearance.
  202. Does anyone know the diameter of pipes used on Bisi headers?
  203. ITR build up
  204. A20A1 Vacuum Diagram?
  205. spoon ventuli and hondata gasket at the same time?
  206. BBP headers: anyone try them?
  207. Cams for a 2.3 stroked H22?
  208. H22A: JUN or Rocket Motorsport cams?? Help!!
  209. built head required?
  210. Buddy Club Spec II Catback (inputs or experience)
  211. Anyone use bosch platinum + 4 spark plugs
  212. best cams for my setup?
  213. input?
  214. TYPE R OR GSR SWAP
  215. WHERE to send my head out to?
  216. d15b, please help
  217. Is a larger tb and a bigger exhaust needed??
  218. Talk to me about Flame Travel
  219. Throttle Body
  220. broken Comp Cams
  221. all motor with fuel pressure problem
  222. Piston sitting 1.2mm out of deck. Problem?
  223. Size of transmission bolts?
  224. b20a question
  225. LS/VTEC for Justin Beaty
  226. PRO1 on Type-R head?
  227. help with B16 build
  228. Can't find this thread
  229. B20Z Block + LS Head
  230. B18C Compression Check
  231. Predicted ls/vtec Horsepower??
  232. Forget H23 VTEC... try H24Vtec from OEM Parts...
  233. lsvtec tuning
  234. Headers and Pistons Choice
  235. After a Day of beating at the track, Motor vibrates a tad bit more..
  236. GSR-LS/V advice/suggestions
  237. High Comp B20vtec Question
  238. Edelbrock D-Series Header Specs
  239. milled pct pistons????
  240. Ls vtec Build Help plz
  241. Jg sheetmetal intake or King ported skunk2?
  242. H22a All Motor Build?HELP?
  243. Bad Head STUD =/ Plz help
  244. b20 vs 84mm sleeved b18; which will yield better results?
  245. Heavy Duty Connecting Rod Separator Tool
  246. Walbaro fuel pump with stock injectors & blox fuel pressure regulator
  247. ek9 cams in b18c1
  248. What am I missing... any ideas?
  249. pr4 head build but with vtec size valves..please read!!!!!!!
  250. Gsr Head question
