- Vtec sound like a two step
- ITR engine rebuild questions, HELP needed
- Building a B16B?
- how to see if motor is really built, cams valvetrain ect
- Piston condition
- Confused about skunk2 stage 1 camshaft specs. Desperate help
- Engine!
- B18c crank pulley broke for the second time
- Are cams on different D series heads interchangeable?
- cost of installing cams, valve springs and retainers???
- so I had a brain fart: timing belt install
- b20 build
- ebay headers vs. stock manifold
- Im back on the map
- Quick question.
- stock rods
- Need Some Help B20/VTEC
- got the h22a tuned something wrong?
- h23vtec timing questions
- B16 burns oil above 4 grand
- b20v wont start, one spark plug black
- Compression Resultss
- B18A1 Questions....
- crankcase venting......i think its cuzing my oil leaks.
- oil pan for jdm zc sohc non vtec
- Best HG for Raising Compression?
- adjusting cam gears? h22
- what bearings to use
- obd0 ls dizzy on obd2 head
- How to remove these block plugs and studs
- mill/machine head? block?
- what header is this
- Ls vtec compression ?
- Ls Rods
- b20vtec swap help
- are ctr and itr vavle springs and retainters the same?
- Do i tune or not?
- Rebuilt D17A1 Engine Pre-Lube procedure?
- ls/vtec write up
- leaning out
- Setting Skunk2 Tuner-1 Cam timing
- Engine Builders welcomed, How free is crank supposed to spin?
- Power from a stroker?
- CRANKSHAFT will NOT spin!?!?
- B17A1 rebuild
- MAP issues
- b16a2
- B18A1 Head Porting Advice Needed!
- 3-Angle valve job or buy aftermarket?
- Y8 Manifold IACV!!!HELP!!!
- buliding a good NA header? Help Please
- Help
- ls with type r pistons and 404's
- locking vtec
- Expected More.....
- Why does my JDM b18c feel so slow ? Not a noob question!
- how to test for bad headgasket
- head gasket
- decisions
- Friends B-Series N/A BUILD.
- Cam gears on Camshaft removal help
- Rod bearing clearance issue
- are dual valve springs on b16 the same as itr dual valve springs???
- ever heard of lucas injectors
- Building/rebuilding an engine how to..
- Kre8speed's dd N/A build plan
- non-vtec all motor dcr calculations
- ls cams question
- Driver side Engine mount nuts?
- Degreeing Blox Type B's?
- skunk2 pro-seires manifold
- i have a question?
- Pro 1 cams quick settings with tuner gears
- Rotating assembly balancing?
- b20 vtec or Type R
- PLEASE HELP!! how to tell if my 95 civic ex has vtech or not and milage?
- perfect throttle body size?
- Deglazing a Block
- headstud and timing belt question
- Blox TB problem
- piston and rods here!
- random misfire problem in a obd2 b18b1
- Skunk2 stage3 tuner cam degree specs
- CTR Piston and CTR cam setup question.
- Quality cam gears?
- Need HELP! Coolant going str8 thru block!!
- D16Z6 head on a D16Y8 block question.
- camgear install question
- KiDDracing H22 header FTW!
- supertrech valve springs, 01 itrs, stock retainers
- rebuilt ls/vtec
- putting new ls head on 246k block
- blackworks dual valve springs and TI retainers
- B20 P8R Non-vtec guys, what pistons do you guys use?
- CTR cams in b16a2
- S2P1 Cams Question
- zc motor swap please help.
- B18C1 Gsr block damaged.
- Found a crack on my block
- bad cylinder head? !!!!!!HELP!!!!!
- Best intake set up for NA
- s2 stage 1 cam with blox valvespring>comments?
- please help!!!
- DC Header, Donut Gasket Related
- Injector Sizing Help
- Bore and Stoke Q&A
- ANY EPM USERS?
- Toda C Cams with Skunk2 Valvesprings
- help with daily driver
- Guys at the EPA can't verify my CAT, can you help?
- Smokey Yunick and the secret of his "adiabatic engine
- Fuel management needed for this setup??
- Spoon 1 piece header
- b16a3 with itr cams will i need to tune it???
- 2000 spec gsr cams in obd0 b16a
- ls/vtec build
- Quick question before I purchase cams + springs/retainers
- Finally got to ride in a decent modified N/A car tonight.
- LS-VTEC?
- valves
- Head Block : Where does this Oring go?
- b20 vtec bad idle
- B18C1 Rebuild - Fractured Exhaust Valve
- my new b20
- h22 cam seal issue
- b17 gsr build questions
- Need help with rod bearing clearences....?
- h22a stock valve size
- Oil Squirter Question
- euroR/S2kTB in cb7 help
- cam problems
- skunk2 cams and Pistons
- questions about performer x intake mani
- D16z6
- Valve adjustment help!
- Very impressed(stock jdm ITR dyno)
- blox header...
- I need help B18 gsr build!
- B17 with CTR pistons
- build questions
- Ca selection
- lsv in a gsr block
- Ring Gap for Road Racing
- motor build, ring gap for road racing?
- Broken Cam Cap Bolt
- Buddy Club Spec3+ vtec point
- lsvtec help
- Stock Rods ... what do they weight ???
- how to remove crank key, pully came loose?
- Cam gears with Skunk2 tuner stage 1's
- jdm dohc zc
- ctr cams?
- high compression bad for spray?
- f20A info
- Poor gas mileage. Help!
- dream B18C1?
- flywheel question on b16a
- Intake manifold
- aftermarket pistons 84.5mm are CAST for NA applications?
- Stroker? Vtec or non Vtec. D or B series.
- b16 ctr w/ gsr head?
- complete rebuild d15b2
- antifreeze in oil pan
- Y21 or S80 for an ALL MOTOR GSR
- ls vtec build
- b16 build questions
- wonky idle
- Heat Wrapping Headers?
- cam gears (true time)
- anybody all motor b17a?
- is this post on ls head usage on a b20z2 correct
- performance x manifold on b18c5
- gsr help??
- b18c1 building questions
- H22A4 Questions please help
- b17 with itr cams require tune?
- s2p1 what retainers
- Light Smoke at High Rpms?
- Need help w/ compression
- Crower stage 2 cam
- Limp mode + vtec controller
- b18c3
- need help on b18 and type r crankshaft
- ITB's....How much power?
- Intake manifold big bang theory. Gain or lose, you choose.
- ls-vtec vs b18c1
- Installing valves
- Reusing arp head studs
- Measuring for rod and main bolt stretch
- High Compression vs. Stroker (B Series)
- fresh rebuild, wont rev past 3k
- LS/VTEC idle problems
- spark plug gap for NA setup
- 2000 Civic Si Rebuild Problems!
- Ring Gap Question before assembly
- street legal allmotor class added to IFO @ Capitol raceway July 12th
- overfueling?
- what oil to use with forged pistons
- wat octane do i use
- toda b's
- B16 exhaust preference POST YOUR SETUP !!!
- Building a LS/Vtec
- STOCK RETAINERS.....WITH SK2 STG2 TUNERS...
- Type R rods/Wiseco pistons?
- b17 head for 175?
- Some help needed selection cams
- need advice on how to make my d16y8 faster
- f22b2 stroker (or something)
- do i need a fuel pressure gauge?
- slow power issue?
- another which cams to run sk2 pro stg2?
- gsr throttle body swap on b16a
- D16 Spring height adjustment
- DOHC ZC Questions
- need help identifying cams(searched)
- opinion??? megan racing header or DC sport header
- arp question
- del sol h22 zex nitrous
- AFR Going Nuts With Video
- Quick question about head gasket and over sized pistons
- LS/V & B20V Endurance
- D16Z6 Gasket Set??
- how many of you guys w/ quick daily drivers would race...
- NEED HELP: B16 Redline problems
- Who makes steel camshafts?
- dyno my h22 today and had good results
- Help....dizzy problem?
- My 2.4ltr H22 (revisited)
- Need your input on motor
- Another DIY ITB Thread...
- Ti Retainers in my DD a good idea?
- who makes a good 2.5 inch high flow cat
- 4 cylinder vs. V6-V8 or just more HP theory
- h22 its not a rod knock but sounds like it
- Skunk Stage 1?
- car smoking. what's wrong please help
- HELP!! B16A2 Oil Pressure Switch/Sensor Q's
- Washed out rings/cylinder walls
- need hondata s300 base map...
- battle of the noobs!!!
- tuners in pittsburgh
- how much hp with this b16a2 setup?
- Type R pistons In a b18c1= ? CR
- 100mm+ crankshaft?
- block damage
- k20a3 problem
- k20?
- touque and bore ????????
- How to measure the crankshaft stroke?
- ls/vtec to b16
