PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. What are the best rods for reliable strength and lower weight
  2. What does it take for an NA B20VTEC to make 225whp?
  3. ** Any nitrous support mods?**
  4. First All Motor Build - Dyno chart inside
  5. Built 2.0l Type R No Spark
  6. All motor h22 whp goal
  7. Opinions needed: GS-R Engine Block Build -Warning - Novice level
  8. J30 intake butterfly valve. Pros and cons?
  9. K24 Combustion Chamber Volume (cc)
  10. Golden eagle for all motor
  11. Tcassaday's D16y7/z6 NA high compression progress build thread
  12. Br8crumb's B18C1/C5 Street Build Project Thread
  13. H22 Pistons into K24a block
  14. B16 head previously used for lsvtec
  15. B20 vtec 2500 miles rod knock?
  16. Exhaust Help on my 2007 TL Type S
  17. Low-revving D16A6
  18. All Motor B intake question
  19. B20 nonVtec Road Racing build guidance
  20. H22 OEM intake modification
  21. Dirt track motor
  22. Anyone have experience with the 1320 RMF 4-1 header (NA d16z6)?
  23. Need input on what cams fit my build
  24. 1320 twister header lol.
  25. Cam upgrade for high comp d16
  26. Need Assistance: JUN camshaft component complement list?
  27. Woodruff key
  28. Advice on BAD mpg in a Dutch D15z6 <28mpg>
  29. Skunk2 cams, past v present (H22)
  30. Recommendations: intake, header, exhaust for NA d16z6 making 156whp
  31. Building a GS-R need Advice
  32. Suggestions Welcomed: A Suitable All-Motor route for my Winnipeg Canada B16A2
  33. which IACV can i use
  34. Stripped main stud b18c help
  35. Cannot set Dizzy timing-Whats issue?
  36. Kswap Header Dyno Testing - PLM Rcrew Replica, Akmee, K-tuned Big Tube
  37. Lessons and learning about a new JDM GS-R Build
  38. Which spark plugs?
  39. Need Assistance: which engine to use in NA platform to make 250hp+ in factory form?
  40. B16a2 misfire and shooting
  41. Help with cam choice? Delta regrind specs vs others
  42. intake bypass valve for throttle tip in vacuum?
  43. best intake length for j35?
  44. Ultimate B16A Dream Build...
  45. Intake setup questions
  46. which injector for h23a all motor
  47. Which Intake manifold should be used for the H23A?
  48. Car is too loud. Running stock cat with high compression
  49. Who's got the best value in cam gears these days?
  50. Looking for advice on an All-Motor build
  51. Suggestions Needed: Parts Methods to Rebuild the B16A2 to Glory
  52. Stock B16A2 EM1-Is the Rev limit 8000rpms?
  53. Is fuel quality is a major factor for high compression?
  54. Suggestions Needed: Finding the Right Direction w/ SRP Pistons
  55. Is it possible to fit K20 Pistons in an F20B Engine?
  56. Inquiry: 2005 Civic D17A2- What can be done to the engine to increase power output?
  57. H23A VTEC header Question: Is 4-2-1 the better option?
  58. Basic b18c catch can with 2 inlets setup, which line locations to install?
  59. CouchWarrior's Yet-Another-LS/VTEC-Project-Build
  60. What is the safest RPM limit for stock H23A Engine Block?
  61. Suggestions Needed: Oddly high fuel pressure in B20VTEC setup
  62. NA-B18C build from the land down under.
  63. Is it possible to use the valvetrain of a B18C1 in B18B1?
  64. Recommendations Requested: Aftermarket B-series valves best used for daily driving
  65. B18C1 w/ 95mm stroker: Progress build
  66. DOMS AMS H2B HATCH
  67. Any benefits with using D17A7 pistons in a D17A2 Engine?
  68. What rods and pistons for LS Vtec build.
  69. PSI GUY's Cool little D-series project.
  70. Assistance Needed: Identifying B-series Aftermarket Cams
  71. Suggestions: GS-R Original sleeves 84mm using a B16 head
  72. Agamemnon96's LSVTEC Build Thread Progress: Suggestions welcome
  73. Advantages & Disadvantages of the B18A/B vs. B18C1 Blocks
  74. Is it recommended to remove one layer of a FelPro Headgasket?
  75. For those that run race fuel, what is recommended for 12.0:1 NA B-series?
  76. HondaDseries's GSR Project Build: Suggestions welcome
  77. Another Code 9 CYP thread?NO.
  78. Skunk2 Pro Intake Manifold Coolant Leak
  79. Swap engine problem
  80. b20Vtec *need input if my parts list is complete?*
  81. Need some real world advice on manifold design.
  82. New motor
  83. How to safely disable a dead cylinder that has blown rings?
  84. JDM D15b swap problem
  85. Which is the Ideal intake manifold to make 250whp w/ a B20V?
  86. B series swap
  87. H22 euro r upgrades
  88. Looking for a rebuild kit
  89. First Lsvtec
  90. rebuilt ew1 or swap a new one? Civic 3g
  91. f22z2 build
  92. ChokeOnMySmoke's All motor J series Insight Project Build
  93. B18C Swap w/ Issues
  94. HONDA B20B4 PISTON RINGS SIZES
  95. Anyone helps~about J35 v6 VCM enggine.
  96. Camshafts for B16A2 with N1 ECU
  97. gsr block with type r head
  98. Best cam for my h22 build?
  99. CurlyBandit's Dyno-tuned NA d16z6 build: 156whp, 115wtrq (Mustang Dyno)
  100. NA intake manifold suggestions for a B18C5
  101. How to start with Mini me ???
  102. Strange behavior after car shell swap ... Help needed.
  103. My 95 Integra slowly but surely LSVTEC build
  104. Engine Won't turn over
  105. New injectors! Need anything else?
  106. M5 requirements
  107. (PLM) B-Series RF-V3 Header
  108. Built B16a to B18c??
  109. Proper belt sizes for Poor Man's Type R / LSVTEC
  110. Best vs. Cost ITB's
  111. B16 sputtering but only on warm up/low rpm?
  112. Crx ef8 custom exhaust piping size: 2.25 or 2.38"?
  113. H22 manifold
  114. K24Z3 Raising Compression
  115. Msd Digital 6 rev limiter causes check engine but turns off
  116. Dyno tested the SMSP style big tube header
  117. B20V advice
  118. Is the B series dead?
  119. Oil Filter Sandwich Question
  120. Car unable to start
  121. Ls vtec oil pressure
  122. info needed on mugen gymkhana header and spoon 421 header.
  123. KPDSM's B-series Swap progression - 2016 - Present
  124. F20B N/A Built Block or Built Head
  125. Vtec/ oil pressure problems b18c1
  126. which b16a?
  127. need some help please
  128. looking for some tips
  129. D15b Single vtec Vs Zc vtec in Civic 1995 Sedan
  130. B16A Intake Manifold on B18c6?
  131. engine swap ... help
  132. B16b code 21
  133. Throttle body swap B series on my d16y8
  134. Air locked oil pump?
  135. Street tuning timing
  136. B16A2 Block, B18C4 Head?
  137. 94 accord non vetech
  138. Honda Jazz L15A1 mods
  139. All motor integra 1/4 mile times?
  140. Scat crankshaft
  141. Stock stroke B series question: Possible to break 300whp mark?
  142. skunk2 throttle body sticking
  143. Web cam
  144. Honda Accord 2001 LX radiator top seal pin hole size leak
  145. Skunk2 ultra street.
  146. B20v issue...
  147. Camshaft ID?
  148. Duncann's Jdm GS-R high all motor progress build thread
  149. Brian Crower stage 2 b18c?
  150. Water in the oil
  151. Buddy club valve Springs and retainers with sk2 pro2 cams?
  152. any header comparsion outhere? for k20?
  153. Gsr oil pan gasket
  154. so my crankshaft snapped on the highway
  155. 2000 EM1 Gremlins-Please Help!!!
  156. Gaskets, Seals, & O-Ring's Oh my!
  157. b20vtec first start went wrong need help !
  158. Nice guys finish last (maybe) 98-97 engine swap
  159. D15b2 with y8 head distributor timing maxed
  160. Skunk2 DIC
  161. How properly fit a gsr head on b20 block?
  162. Blue smoke
  163. Need help
  164. 1991 civic si hatch b16a1 problem.
  165. B18a1 All motor build suggestions?! Need help
  166. B20V question
  167. Headers on k24
  168. 1320 motorsports hood exit
  169. H23A1 stock sleeve/high comp pistons
  170. Wanna go k26
  171. High compression g23 question
  172. lc 1 Innovate wideband warm up time
  173. Dynod the B16a *sheet/specs inside* opinions?
  174. Stroked B16B-->B19 Road Racing Use
  175. ARP bolts on stock rods (B18C5/C6)
  176. Poor Mans Type R
  177. What tunning software use?
  178. Roller rocker clearance issue
  179. B18b1 ek hatch build ideas.
  180. JDM B18C N/A build.
  181. port only one side ?
  182. What should I do? B18c5
  183. Bogging going lean and breaking up under light throttle why?
  184. Original Skunk2 "stage 2" cam quick settings
  185. Installed my Type R cams in the B16
  186. Which block do I build
  187. B18c1 Build
  188. Building A Big Block B Or K For Drag Racing...The Theory and Planning Behind It All
  189. Questions on headers and ignition before retune, input needed
  190. 184hp/129tq Dyno jet, want to make more
  191. B20 p8r with bolt ons - dyno graph - comments wanted
  192. My new allmotor setup for 2k16
  193. B18b built bottom end. Burns oil but tests out great!
  194. Bseries Valves
  195. my b18c1 build
  196. JDM B20
  197. B18C(5) rod bolt torque?
  198. Header Tech Help
  199. K20 Eninge for $560 shipped worth it or not?
  200. B20z bolt ons only
  201. 95 X 89mm H series Cam question
  202. Toda Valvesprings ? What retainers
  203. Header ?
  204. B18c build (could use some pointers)
  205. B16a engine tunning
  206. ITB on B18c
  207. What to expect power wise? Sleeved LSvtec, forged internals
  208. Project Kaoru - A Michigander's H23AV
  209. Spontaneous Rod Knocking
  210. ITR head or B16a head for b20b block
  211. Scratch on cylinder wall
  212. Nippon Rings
  213. rod bearing knock /rod bearing install??
  214. Soo..Another 200whp B16 thread,Omni inspired-
  215. Can bad 02 affect my HP?
  216. My first build..
  217. B20z2 bottom end w/ b18c1 gsr top end
  218. Need help about Head on D series
  219. Displacement Question
  220. engine breathing route for all motor engines ?
  221. 94 gsr build
  222. How to calculate Compression if you swap head.
  223. b20z2 milled gsr head ptv questions
  224. Edelbrock 4730
  225. Methanol fuel
  226. Drag Cartel 4.5's vs Ultra 3's vs. Ultra 4's - Dyno Results
  227. b20vtec pcv question
  228. Torque specs B18C only (main + conrod caps)
  229. LsVtec Dyno.. Poor results
  230. Intakes
  231. B16 Header options
  232. D16Y8 NA build and programmable ECU
  233. B18c5 Head with no cam caps *Help*
  234. Idle Surge
  235. Best place to buy engine rebuild parts? Advice on my list?
  236. B16A build- pushing the envelope for my own interest
  237. High comp B16a to B18??
  238. Help with a D series!
  239. cams degree on a b16???
  240. Broken Skunk2 LMA
  241. Which intake manifold?
  242. BC 0021 turbo cams in n/a Motor?
  243. What cams to use on my 86x92
  244. low budget b20v cam choice
  245. b20 vtec head questons
  246. Custom cams by Schneider
  247. Accord Cl7 TypeS/Euro R/TSX all motor street racer
  248. Need help
  249. Is this a half decent build plan?
  250. need help with an exhaust
