- installing crankshaft
- how light can you get a B series flywheel?
- mill head or pistons? which route save me the most money?
- Best cams for stock valvetrain......
- I have a MSD-DIS system on my b16a would it be wise to upgrade my injectors??
- any way to identify blox B cams
- crower stage 3 cam question
- B18C Hatch vs H22 Hatch
- Installing Profab Header Help
- Should I get an engine management system?
- any1 has cam gear settings for skunk2 stage1 cams into a JDM GSR
- Valve clearence issues with Skunk2 Stage 2
- New Set Up AN-R/DIY ITB/12.5 C/R
- skunk2 stage 2 cams; i cant get the settings right. help?
- What exhaust systems fit JDM 2.5" cat/test pipe?
- Quick HELP!! BC3's
- P29 pistons
- Flow testing D16 heads
- msd blaster ss coil
- pvc valve
- Hesitation and sputtering.....
- Y7 head specs?
- what cams to use?
- how high is ur compression on your b20
- Jenvey ITB vs TODA ITB
- 11:0 compression any good? what cams to take most advantage of it?
- budget d head build...
- *Video* My 2.ol LSVTEC playing with some friends
- tuning
- The Honda DIY ITB Help Thread.
- ??? Anyone know which ALTERNATOR PULLEY to use with a JDM ITR alternator ???
- b16 vs b16b
- How much will Flat Valves (omni's) bump up compression.
- Which is a better head gasket
- What is the easiest way to make my B16A2 seemed to B16B?
- Js racing b20/vtec motor review- water line structure
- FS: Complete 01" B18C5 (motor and tranny swap) Link Inside!!
- k20a emissions in NY?
- been thinking about new pistons, but i have a "?"
- Where to set oem piston to wall clearances
- intake mani for dcoe or itbs
- Jdm header/exhaust question
- 93 civic
- Question regarding Valve Train Stress/Fatigue/Wear
- A6 block vs Z6
- valve guides
- Fiber-Tuned Carbon Fiber Manfold makes power NA
- D16 swap question
- blox cams with pro1 specs...ne1 run them yet?
- are cams emission friendly?
- D16z6 (Should i keep or swap)
- Help PCT Pistons on Eagle rods!!??!!
- Is it safe to bump compression by .3 and use stock ECU?
- Hytech header for B18C1???
- AEBS vs BLOX intake manifold, which one to go with?
- crome users - pls help
- Part 1 - ranta18's H22 All-Motor Build
- What are better valve springs and retainers
- whats wrong with my head.
- Some problems with my D16
- A couple of ITR rebuild questions
- What is the Best Compression Ratio for allmotor LS/Vtec??
- type r idle problem...
- Doing Cams install Plus! Pointers Please
- Skunk2 IM with Hondata Gasket for GSR head?
- Velocity Stack problem-scraps etc.
- H22 Integra not sounding too good. Help???
- eagle crank and eagle rods
- valve springs and retainers *need a quick reply pls*
- Vtec problem
- how do i make the d15b7 a vtech
- Intake manifold
- Toda Header for B18C1 with B16 Head and High Compression
- How much should this cost?
- all motor b18c5...platinum or iridium plugs?
- ML rods on OEM pistons? omniman?
- valve lash with adjustable camgears
- Airbox or intakes Itb's
- lsvtec help and opinions on setup
- arp head stud question
- B20 Injectors.
- Weird color on spark plugs
- lsvtev......vtec problem?
- 1st gear ratio..for drag??
- Naturally aspirated H23A 1996 Prelude
- ctr pistons or itr pistons on gsr motor
- ITR valvetrain on a b16a2?
- Q For Walbro Owners: Does your fuel Needle Fluctuate....?
- Quick question
- which setup???
- headlight help on a 1989 acura integra
- B16A2 Skunk2 Stage III problem?
- Locking Vtec with compressed air??
- ls vtec crank
- what is the best engine i can actually get for my car?
- vtec non vtec help me out
- Crank Shaft Pulley Bolt-Need Help ASAP
- chewed rocker pics built motor... "blown motor pics"
- What Header Is This? Came With My JDM ITR Motor.
- H22 HEAD BOLTS....TORQUE
- h22 block what to do?
- Too-tight valve lash causing burnt exhaust valves?
- B16B Video
- B16 ALL MOTOR......................?
- Buddy Club Vtec Controller, Any Good?
- Low compression block
- All motor teg
- DYNOMAX Muffler for H22 EG setup...what would you recommend???
- Rod numbers...
- GS-R gears with TypeR cams?
- F/S JDM ITR Long Block and transmission
- CTR Pistons into B16A
- H22A problem.
- B18C or B16B?
- Injector placement
- Ported and polished head, how does it feel?
- B18 Block/B20 block
- what final drive
- Uberdata chipped P75 ECU questions?
- K20 vs ? -> 1 mile race -> video
- Used JDM ITR head ; How much?
- B16 type r worth it
- Car starts to struggle...
- best bang for buck header
- Tuning Soon. Guess My Numbers And Win My Money!
- knock sensor help
- dseries... which cam??
- H22 for auto cross
- testing water
- rocket cams and valvetrain
- what you think?
- what's the difference between ctr & itr blocks?
- 2.0 liter block question? where to start
- 197whp, stock internal h22 (DYNO VIDEO)
- ANR Header
- VAFCII Question?
- ITB's vs. IM?????
- crank pulley??
- Bottem end is good and combustion chamber filling with oil.
- RCrew K20 P.I.M.P Install & Dyno Results... (K20A2 - Stock RSX)
- need Help: ARP torque specs on deckplate motor
- D16Y5 Throttle body
- second gear from GSR
- S2S2 NEED HELP!!!
- b18c1 powered del sol dyno
- Honda DIY ITB's, what do you use for air horns?
- omni power valves- compression?
- need help please !! 100 bucks if helped
- OT: Any shops looking for help
- rocker arm piston wont come out
- Can you bore ITBs?
- timing off after milling my head
- CP pistons SC7121 84.5 adn Buddy Club IV's
- New Skunk2 B-series header?
- Oil coolers and Oil pressure?
- ls/vtec build this weekend
- for sale
- JDM ITR header NEED !!!!!!HELP!!!!!!!!!!!!
- 55mm Restrictor plate. Who makes them?
- jun
- DOHC vs. SOHC (non VTEC) why use 2 cams without VTEC? discussion
- yet another cheesy swamp rat dirtbag SOHC**VID**
- high compression dished piston??
- header choice - toda or hytech production header?
- ITR dyno (dyno sheet inside)
- WAYS TO LOWER COMPRESSION??
- gsr or type r
- Mild H22a NA Quest - Help please
- gauges
- does anyone know the list of honda motors
- Search button used....h22 allmotor yeah another one...
- quick gsr motor que.
- NEED HELP ASAP GSR block LS crank question (oil squirters)
- buddy club spec 3 stock valve train?
- Is this a B16B rod?
- $2000 to spend on a b16
- need to get my car tuned do i...
- Example Engine Build Sheet
- Installing Cams and Valvetrain
- Question about Edelbrock Cams Experienced Engine Builders Advice Sought
- Piston and Rod Questions?
- 8500 rpm.........but will not shift into gear until 8000 rpm why?
- New Gsr... What should i do!?
- List common misconceptions/myths of engine building and tuning.
- another 1.8 dyno
- Crower Cams
- What cluth to run
- h22 cams
- What yall think about this setup?!?!
- evap code
- Skunk2 stage3 cams with hytech header in bseries. GOOD OR NO GOOD?
- Need help have a question for all you smart car guys.
- obx h22 oil pan??? =X
- Hatch for sell
- DIY ITBS - What to do with IACV?
- ITR exhaust questions
- Did Baseline NA Before Boost Run At HOOKUPS - GSR *VIDEO*
- Need help regarding my Endyn Breather tank
- MILLED MY HEAD NOW WHAT DO I DO ABOUT CAM TIMING?????
- Looking for 200whp, with this setup get me there?
- Hookups - Rage Performance combine SHOPS!!!!!!!!!!!!!!!!!
- b16 im on gsr head?
- H22 all motor combos....
- Prelude and Integra
- check out this 208 hp b16 (dynapack)
- new to tuning just want a little info
- 50mm TWM ITB's (integrated vacuum block)????
- 1st gen teg
- Flow around a bend?
- WTB Or Trade for SKunk2 Stage 2 exhaust cam
- Wich cam for S2s1 top end and BC3+ bottom ?
- ITB Velocity Stack Air Filter Cleaner
- How to find piston dome volume?
- b16 with b17 crank and head?
- Cheap "AEBS" look alike intake manifolds on ebay
- b16 hp guestimate
- turbo freak turned NA...
- 84mm pistons
- Help with my D16A6 i need some help
- IM and TB combo, need help choosing
- b18a1 boost project
- How to get rid of that typical Honda Bumble Bee Droning sound?
- Does the Golden Eagle Vacuum Manifold come with the hose fittings?
- All motor d-series 91 octane gas mpg and horsepower
- B18C5, LS, *CTR pistons install HELP*
- skunk2 b16 vs b18c?
- built gsr head
- ??? fidanza 7.5lb flywheel ??? "The friction plate can be machined or replaced as needed." ???
- Is a stroker kit worth it for a B18c5?
- ►Official All Motor Dyno Thread!
- All Motor Results???
- Are the Skunk2 Stage 3 cams too much for my motor (not the pro series)
- 12.7:1 CR What kinda Muffler
- Anybody familiar with Chadil
- Reasonable price range for swap engine =
- am i undercamming?
- how can you tell what year an engine block is?
- What kind of cams should i look at?
- LS/Vtec stroker question
- CRVTEC need a bottle?
- is my set up worthy of 200whp?
- USDM ITR CAMSHAFTS
- Anyone making 200+hp using m22x?
- Integra type R diff / fianl drive question....[B]HELP[/B]
- type r pistons for ls
- IDLE PROBLEM!!
- tranny probs?
- Injector Problem!!!!!!!
- Where to find a PROFAB header?
- Rocket M22 cam differences
