PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 [108] 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Another all motor B16 dyno-Stock block, stock head other than ITR cams
  2. CP 11:1 Pistons in D16a6 75mm bore and 75.5mm bore can I use the stock rods and bolts?
  3. D16 all motor sohc
  4. Need input on Crower Chromoly Retainers
  5. b16 had used for ls/vtec... can be used for gsr block?
  6. Questions on new setup...
  7. ls or gsr? cuse i just got a great deal on a ls.
  8. is there truth to this statement?
  9. Rs Akimoto Iv filter does this filter truly flow better than the rest?
  10. What's the better in line fuel pump: MSD #2225 or WALBRO 255?
  11. itr bearring questions
  12. cruogenesis?? on valvetrain or more?
  13. over 200whp??? opinions appreciated....
  14. An-R header question
  15. SOHC Running Rich?
  16. PLEASE HELP ALL BUILT LS/VTEC GETTING BEAT BY STOCK STANGS
  17. skunk 2 pro 1 in my motor am i over cammed?
  18. H22 for my EK?
  19. toda spec c's??
  20. Piston ID
  21. LS/vtec build
  22. Cylinder Head Flow
  23. all u skunk2 pro1 cam users
  24. B18c1 stock whp and then....
  25. I have a question?
  26. Gsr long block build
  27. My build, JDM H22A 94 LS Integra
  28. RMF headers , where to buy??
  29. Help! I need to put a GSR head on my b18c5 ITR block
  30. Found the twm tps plug!
  31. omnipower dual springs....
  32. b16 internals? crankshaft, rods
  33. Over caming an engine...?
  34. chipping ecu
  35. b16 or lsvtec
  36. anybody have any experience with ferrea competition plus - hollow stem valves
  37. b16 all-motor fullout streetable build
  38. Spring Test - BVTEC
  39. New Cams Choice due to engine failure yesterday!
  40. SIR1 LMA?
  41. Allrighty I have a couple of questions on my LS/Vtec Build
  42. b16 with b17 internals
  43. 20LB TQ@9000RPM
  44. does anyone know this car in the Socal area???
  45. clutch and flywheel
  46. S&B airfilters...how well do they flow? any personal experiences?
  47. skunk 2 pro 1 cams......upgrade valvetrain YES or NO?
  48. GSR Fuel Injector Max????
  49. PHILLY AREA !!!!! need help/////
  50. dyno
  51. buddy club valves and and stock springs
  52. 84 mm bore w/o sleeving
  53. spoon oil pump?
  54. OEM mufflers: rsx type s or s2k muffler?
  55. Fuel Pressure Pinned
  56. d16y8 head on a d16z6 block compression ratio?
  57. victor x intake mani
  58. B18C5 Build Plan Advice
  59. B16 build
  60. Blox type A or B, or other cams poor mans R
  61. where do i start
  62. noob gear grinding question
  63. blue print mfg????
  64. h22 12.5:1 compression with 100 shot nitrous
  65. H22 M2B4 Final Drive
  66. All Motor v.s. Supercharger
  67. noop Questions
  68. Exedy HyperSingle Clutch Disc vs Cusco SuperSingle Clutch Disc
  69. supertech vs skunk2
  70. Blox or Skunk 2 Pro or stock ITR intake?
  71. ericks racing h22 throttle body
  72. SKUNK 2 PRO CAM GEARS GO TO SHIT LOOK LOOK PICS INSIDE
  73. Is it worth working my ITR head or not...
  74. Looking for a datalogging display unit
  75. Is my exhaust too big?
  76. AEM fuel rail?
  77. Stripped a Head bolt in my block! HELP!
  78. BONE STOCK B20 QUESTIONS
  79. CAM QUESTION??
  80. Motor shops in CT?
  81. D15 Powaa!
  82. How long a 86.5mm 14:1cr B motor last?
  83. Kamikaze 2.5" header ITR oil pan clearence
  84. Calculating redline?
  85. what to do i look for when buying a b16 head
  86. motor pics
  87. rebuild my d-series or swap for a b-series?
  88. gsr rebuild?????????
  89. CTR INTAKE CAM PART#?
  90. skunk2 intake manifold install advise
  91. which is Intake manifold is better for a gsr? oem/itr rep???
  92. Headstud question!
  93. DC2 header on a DA???
  94. LS Rebuild
  95. SKUNK 2 IM
  96. dyno prices?
  97. powder coating inside intake manifold
  98. K-Pro tuning questions - tuning fuel & spark for specific cam angle
  99. IACV removal/ block off?
  100. ok guys
  101. Building bottom end for use with N1 pulley???
  102. Headgames in NJ
  103. Mugen 4-2-1 header, can't find info
  104. Common aftermarket piston weights
  105. What would you choose?
  106. 86mm rs machines LS block
  107. should I chip my P72 ecu or leave it stock
  108. Need help with good old carb.
  109. quick question about b17 gsr
  110. CTR cams with b16a valvesprings?
  111. what exhaust?
  112. ****** Finally, the first public pics of the SMSP K series header ******
  113. dialing in toda b's
  114. constructive criticisms please!!
  115. PRELUDE PEAK AND HOLD INJECTORS IN OBD-1 GSR???
  116. Anyone have pictures of a Portflow head? Who puts dimples on intake ports?
  117. anybody using stock B16 or GSr LMA with skunk2 pro1 cams?
  118. ls/vtec help
  119. Synchromesh
  120. Breaking in motor--synthetic oil?!
  121. When VTEC lobes dont get ya what you need....
  122. let me get this right.......
  123. DIY GSXR ITB's - LS/VTEC Pics.
  124. Skunk2 pro1 cam users and turners
  125. 97-01 type r difference?
  126. pnp with stock cams
  127. Replacement O2 sensor looks a bit different
  128. Buddyclub Spec II Exhaust: Any dyno graphs?
  129. post some pics of ur tube chassis set up.. thanks!
  130. Gsr with ITR cams.
  131. What kind of dizzy is this?
  132. Compression vs VE
  133. p13 vs p72
  134. Rebuild
  135. D15B7 Minime Questions
  136. verify these cams
  137. N/A v.s. Turbo
  138. All motor Crane Cams
  139. GOT A HEADACHE! which header. Searched. Just not sure. HELP PLEASE
  140. timing belt tension...
  141. hp potential of pro2's over pro1's
  142. K20 carnage pics
  143. b18c stroker
  144. WTB K-pro ecu at the sema show, any dealers?
  145. Broken new batch of crower 3s? NO WAY! OKay maybe pics inside =(
  146. Skunk2 Stage 3
  147. # SPR-H100DR KMS valve train with Skunk2 pro1s
  148. Best Cams For A OBD O B16
  149. Looking for advice on how to store a motor for over 1 year
  150. B16a2/Gsr Tranny Needed
  151. timing belt gear?
  152. 4.7 FD vs 4.92 FD Traction
  153. Help locating affordable velocity stacks
  154. IM manifold Design Theory
  155. I'm building me a ls/vtec right ? but i have some concern...
  156. **Question about B20z crankshaft**
  157. Swapping out OB2 to OBD1 question..
  158. what engine management setup is best?
  159. What Size Collector does a Greddy header have?
  160. need HELP w/ exhaust
  161. My All Motor LS/VTEC Build Up *SF_EF8*
  162. another bc3 cam question (i did search)
  163. NEED HELP!!!!!!!
  164. Valve lash for Skunk2 stage 1's please
  165. 86mm cometic gasket?
  166. B17 cams in B16?
  167. headwork
  168. Anyone have experience with the Mugen N1 ECU
  169. Running all but 1 arp head stud? Im missing one!
  170. where to buy valves?
  171. Ready to do more to the motor
  172. I NEED YOUR HELP. How do i make my JDM type R motor pass BAR??
  173. b18c build questions?
  174. what size b18c injectors?
  175. gained whp on dynojet but lost power on dynopack - discuss
  176. Whats the max lift/rpm on stock GSR valvetrain?
  177. twm thottle bodies for rsx???
  178. whats the best modifications to make for my motor??
  179. **Head gasket**: Mugen, Spoon Sports, Buddy Club need more info and help me choose!!
  180. F22A6 Advice
  181. can I use a6 gasket for this sohc setup ????
  182. How do I properly calculate compression??
  183. kazz lsd
  184. Looking for a shop to make a nice vac mani for my itb's...
  185. video footage of me thanks to Nyce1s.com
  186. Vtec solenoid Valve(help on a cel codes 21)
  187. My motor whistles??
  188. Philip Chase's build (ref: Import tuner)
  189. 84/84.5/85mm moderate CR cast piston selections
  190. racing header vs non racing headers
  191. k20a2 itb question
  192. 74 , 72 , 70 , 68 tb?
  193. K20R HATCH STOLEN IN MD.
  194. Windage tray
  195. I Just May Have My Own Air Flow Test Bench
  196. K-series swap question...
  197. New Header!!
  198. gsr cams in a b16
  199. limiter
  200. All motor guys . what clutch???
  201. guys i need some quick help - msd cap install
  202. a little chit chat about crome
  203. To sleeve or not to sleeve?
  204. all motor chassis...
  205. LS all motor vtec pistons?
  206. M24xx need help
  207. How to diy ITB's individual throttle bodies everthing inside cbr 954rr 954 Itb
  208. Does anyone know of good a tuner in the california bay area ????
  209. Official All Motor EF Thread!!
  210. low compression on my gsr!
  211. stupid????
  212. Throttlebody "how big is too big?"
  213. Twin loop mufflers, before & after dyno??
  214. type r ps bracket question
  215. os pistons on stock rods
  216. Ls-Ls Vtec
  217. searched... but didnt find exactly what i wanted
  218. jdm itr pistons
  219. and piston Eagle rods hit girdle in d16z6?
  220. Header
  221. OBD2 tuning options
  222. spoon chip vs. skunk2 chip ecu
  223. Rage or Hy-tech rip off????
  224. Were to buy Plastigage
  225. Does Pully Weight Affect HP....?
  226. cams
  227. Piston Velocity Discussion
  228. High Compression Z6
  229. whats crome's website??
  230. manley valve keeprs
  231. itr head/b16asir2
  232. stock P28 na build?
  233. AcuraOEMparts.com...what bearings what?
  234. Wildout finally dyno tuned
  235. my crx h22 times with explictspeed mounts
  236. need torque specs badly. ls/vtec head. cam holder bolts(the ends)
  237. How to tell which camshafts I have?
  238. is my header holding me back?
  239. LS vtec need help
  240. CALLING ALL CUSTOM HEADER BUILDER: DTR,SMSP,RMF ETC
  241. What's typically the thinnest head gasket you can run safely?
  242. Whats Hytech's official website??[searched]
  243. oem piston rings
  244. where do i buy these vtec orfice? i dont see it in the microfitch
  245. difference between gsr and type r head???
  246. Randy RMF contact details anyone?
  247. st vs os pistons
  248. potential of 92-95 b16?
  249. Bad night need advice!
  250. Dyno'ed My Basic OEM B20/Vtec Set Up
