- I want to trap 106mph plus...
- HEAD DECISIONS!!!!!
- What are you off season plans?
- Landspeed Powercore headers - any good?
- is it the tranny or what
- whats a good ngk plugs for a all motor set up 12.5 cp
- manual hone vs. machine hone?
- What head gasket for a basic ls/vtec setup
- p72 ecu or p28
- rocket spark plug heat range???
- Where can I get 110 out of the pump in OC.
- What can I thank for this?
- Comments and Opinions Wanted
- portflow inner valvesprings with ITR outers...
- HEADERS
- Stroker kit?
- the right clutch
- How many liters
- grounding kit install...tried searching
- WTB: a set of stock valves
- Need a last minute confirmation on B16A! upgrade choices.
- throttle body size for an intake manifold with 65 mm inlet.
- Question? can a..............
- My dyno graph -- why did I lose torque over stock?
- Gsr cam in a b16a2 head?
- changing gears in a Y80 tranny
- Engine help, for the poor honda owner.
- 98plus ITR tranny vs GSR tranny
- all natural
- who want to get rid of CTR CAM
- Warped Block?
- Disappointing 1/4 time
- cam question!!
- HMT doing HM-ITB's lots of pics.. 56k go away..
- Crankcase ventilation trick
- Pistons, Boring, and sleeving???
- Fujitsubo 4-2-1 header....
- 70 mm TB
- tuning ctr intake cam with aem cam gears?
- opinions on rockets valve springs/retainers
- CTR cams
- Ideas on a Set up shooting for
- Frankenstein
- oil pan
- Which Cams?
- is this BS or what?
- lightweight clutch
- 200whp ????
- Last resort to ask here: Where to purchase a Bare B16B ?
- How high can Toda A's make power?
- will shotpeened rods be fine ?
- Any of you guys ever ran a stock bottem end lsvtec?
- Anyone know the #'s for an ITR
- Skunk2 Stage 1 VS. Toda Spec A Camshafts
- To Block Guard or Not to Block Guard?
- Wat is the difference?
- stock b16 bottom end, and toda B's?
- Possible NA set up but i !!NEED INPUT!!!
- why does everyone want a "poorman's type R"???
- Block Guard (Now or Never)
- Which Vtec head?
- Sparks Racing N/A Drag Block ... ????
- Top Line Pistons or OEM Type R Pistons?
- any all motor y5ers??
- Is 2.5" too big?
- lots of qeustions help on answers???
- New England machine shops.
- I need help on deciding which stroker kit to purchase
- hmmm what block girdle?
- which clutch is better
- What do you all use to block......
- A Good Deal(B18B Motor and Parts)?
- B20/VTEC vs. B18C5 for 215whp ALL-Motor!!!
- I KNOW I KNOW...
- skunk2 cam gears 1/2 off normal?
- turbo horsepower vs.all motor horsepower? difference. significance
- IB spec Wisecos in H22?
- best place to get new pistons and rods for my C32A V6
- Highest rev on stock b16 botom end
- itr slugs in a b16?
- Engine Building Professionals:...clearances
- PLEASE HELP!!!!!
- Best rods, pistons, cams for a b20 vtec
- IB I-beam Ultra Lite Rods vs Eagles vs Crower econo???
- head studs for b20 vtec
- South Florida (Fort Lauderdale) machine shop?
- twm, where to get a good deal?
- Head Milling & 4 layer head gaskets
- VTEC QUESTION: Can a Vtec work W/O a Vtec ECU?
- gonna buy jdm dc ss 4-1 header(96-96 acura integra type R header)good price, any hassles
- Balancing & Knife Edging H22 Crank?
- All Bets In!!!..Finally getting tuned!
- Compression for toda c's??
- n/a rules
- Need ECU/Tuning advice... bumping up my redline?
- 2 1/2" nonmandrel piping vs 2.36" mandrel
- need help on rod install
- B16A1 - What is better 63402 Crower or CTR (stock internals)
- CR FOR CROWER 63403 CAMS
- What flywheel would be..........
- ITR intake manifold on GSR head. (read)
- anyone use this FPR???
- LS VTEC HELP!
- CTR regrinds??
- throttle body question
- USDM ITR Valve Springs in LS?
- HELP!! With 87 CRX crankshaft and cam lining
- Best Intake Manifold and Throttle Body Combo?
- daily driven forged bottom end
- c1 bottom end with itr pistons..what will it hold?
- Real Quick Question...about type R cams?
- 96JDM ITR Tranny vs JDM GSR 94 tranny
- P29 pistons or Pm7's?
- pr3 or p72 ecu for c1?
- SRP 5.7 dome + cams question
- weird vibrating noise at high rpm..
- Does Toda make retainers?
- Best B-series head?
- h22a1 rev limits...
- Z6 and Y7 cranks are not the same
- do I need new injectors?
- jdm hydro b16 tranny vs usdm b16 tranny
- Stock rod width
- detonation
- Head Milled and now gap in the Head
- B18c1 Dyno
- Calling all Crvtec owners
- Poor Man's Type-R
- b16b cams in jdm itr swap?
- Are you happy with your AFC setup ?
- How much would this setup give me in B16A2???
- Give me some ideas
- JUN III's, Skunk2 stage 2, Toda B's?????
- what kind of power do u think
- plug?
- 200whp possible on these mods?
- Fuel rail and injectors
- Y1 tranny on a b18c5...
- how high....
- I need axel Length Measurements!
- bad cam timing prevent ring seal???
- B16A HP
- ctr cams tuning
- what throttle body gasket for a 89 b16
- compression question?
- best valvtrain
- 200whp-injector/pump?
- 99 Si Need help ctr cams
- Looking to build spare motor?
- Aebs/pro products IM for b16a
- Can anyone give me a good hondata basemap for my setup???
- 1.6---converted to v-tech??
- sohc hp vs. dohc hp
- street fuel system setup?
- P-W Clearance for All-Motor?
- what can i do???
- Throttle Body Spacers anyone?
- cam choices
- Importance of machine shop using a torque plate to bore???
- built head, need tuning info.
- blew jdm 97 gsr motor with nitrous, going all motor, thoughts...
- Where can I buy a JUN II intake cam, without the exhaust cam?
- block question (b16/b18c)
- Biggest cams in b18c w/ ctr pistons?
- need help bad
- Need help with valves
- DTR Fab, Weld, Strange, and QA1 goodies
- A few questions for Toda A users or anyone that would know...
- WHP with Hondata?
- Whats the Difference between engines
- Any input on copper head gaskets for allmotor?
- Side Exit Header yes or no?
- First CR/Vtec??
- WTF, got block back from machine shop. What would you do?
- Skunk2 cams and Fuel ????
- How many miles on your LS-VTEC motor?
- Block building ?'s
- TODA C CAM SPECS
- **Reccommended throttle body on AEBS 65m inlet..?**
- best NA motor
- Jun 3 users
- Any more opinions on Probe all motor rods?
- B18 Interchangeable Replacement parts?
- '91 Si: mini-me setup or two 2 barrel carb. what's your thoughts?
- 81.5mm Endyn pistons/ Eagle rods
- b18a/b na power
- best non synthetic oil for built b20 vtec...?
- sleeving/bore issues
- ???What would you do in my shoes???
- What 1/4 mile times do you think I can get?
- anbody know what TB this is
- Best motor for my road racing project.
- tuning my exhaust extension...
- San Diego people wanna help me out?
- Upgraded LMA and valves for this setup?
- Debating on crank pulley , to use or not tu use
- How many mm is in the quench pad of a b18c head?
- prelude headers an-r or imagineengineering
- 1.8L: worth getting a race header?
- Reasonable setup for b16 that see's road courses.
- ecu code reading and identification
- stage3's or not ???
- Obd2 switched to obd-0?
- Best All Motor Headers?
- ok who is pushing the most powes out of a ls ?
- skunk2 stage 3's VS. toda D's
- itr valvetrain
- specs for sk2 stage one cams?
- Poor man's ITR setup...
- '91 Si w/ two 2 barrel carb. what will I need?
- oil pump
- help lsvtec idle messed up
- Racing Oil pump...recommendation please.
- pic request , welded combustion chamer, cloverleafed !!
- which timing covers for ls/vtec???
- Taking a poll - what motor would you pick to build up? thanks
- CTR cams w/ port flow head....... What is the valve clearance set to?
- GSR
- HOW STRONG R B20B CYLENDERS FOR 12:1:1 COMP
- My idea for a NA z6
- Ported P30 manifold vs Skunk2 manifold
- What valve spring kit for CTR cams while roadracing
- Which header for a ls motor Greddy or DC sports
- What's better for high compression?
- Quetion about head gasket?
- what should i do next?
- need info on jun3 cams (pros and cons)
- Got bored and clicked around..
- b2 vtec vs poor man r
- break in time on comp cams
- stock oil cooler??
- P30 or P73 piston
- What type of pistons/rods for GSR
- money issues
- Troubleshoot #3: symptoms of a clogged cat..
- needs opinion on spoon venturi plate
- 99 accord f23 hp boost?
- Help with my ls/vtec problem
- Exhuast Question
- b20z w/b16 head
- some tips given for installing Euro R manifold on h22...
- Cammer jammer
- Exhaust
- I need part numbers for Valve Seals!!
- what is the most hp all motor on the board?
- All Motor thinking of a wet system???????
- GSR BLOCK, b16 head , what pistons??
- Another Round of: Name that Cam!!!
- no horse power
- did a search already(b16 bored out )
