PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 [54] 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. CRX backfires through exhaust.
  2. evap system
  3. Stock Compression H22 and E85
  4. which cams with following spec
  5. B20v headgasket
  6. HELP! Identify these Camshafts!
  7. Can I use oem head gasket for 81.5mm bore/pistons?
  8. Roller Barrel ITB's for B-series?
  9. Need advice piecing together hybrid B-series
  10. B16 stroked to b17.. questions, help!
  11. 12:4:1 with 404 crower cams..safe?
  12. Made 211whp 142ft/lbs tq...ideas to make more!
  13. skunk2 tuner stg 1 with supertech valvesprings
  14. JDM LS or B20, non-vtec, need suggestions
  15. 2.1l Ls/Vtec?
  16. how much power can i make with this setup??
  17. Mild GDR build
  18. f23a1 build
  19. BPI flowstack price
  20. Hybrid B20 VTEC - N/A Gurus sugesstions
  21. Anyone have experience with the company "Si Valves"?
  22. K series guys.... this is pretty wild. have you seen anything about this?
  23. P2W clearance!
  24. na B18c1 build
  25. GSR intake with secondary butterfly removed...
  26. is it legal
  27. Checking valve clearences B20/b16
  28. what size injectors should i go with?
  29. b16/b18c/ctr wont idle properly
  30. problems with gsr injectors
  31. b20 vtec injectors?
  32. oil squirters
  33. Need Help ASAP! Cam Cap wont go on...
  34. knock sensor
  35. 300whp club
  36. G23
  37. Cammed B18c
  38. Blox or AEBS Intake Manifold
  39. B17 Rebuild, looking for some insight.
  40. first possible build
  41. Valve to pistons claerence
  42. Quick question about Jun 3 cams and Brian Crower valvetrain
  43. bogging...? fuel cutting or missing?
  44. apekd's All Motor D16Z6 build
  45. b16 project r help
  46. rebuilding gsr... couple questions
  47. what pistons to use (pros only pease)
  48. GSR cams. can someone post a pic of there JDM gsr cams the produc ring
  49. Fitting ITB's issues with vacuum
  50. Vancouver International Auto Show
  51. first all motor build
  52. K20a Skunk2 Stage2 HeadPackage Dyno Results
  53. lsvtec max cam lift
  54. b vtec rocker arm piston stuck
  55. Cam Suggestion?
  56. pr3 81.5mm on pistons on ls/vtec( PROS ONLY)
  57. Advice on Replica Hytech Headers
  58. Aftermarket Head gasket question
  59. My DB1 Project on a budget, got a few q's
  60. are there any cast pistons that are better than oem?
  61. ls vtec or gsr
  62. Now save even more on your aftermarket parts!
  63. Hey HT users
  64. 11k revs, is it necessary to upgrade valves?
  65. Ok Ok, a bad arse B production header you HAVENT seen
  66. Plastigauging: do you need bearings installed?
  67. oem vs forged pistons. that's the question..
  68. ls/vtec map sensor problem, rhd integra
  69. Pct Pistons Broken
  70. h22 swap ?????
  71. OBX ITBs
  72. lsvtec question
  73. Mild build. Help please!!!!!
  74. DOHC ZC rings....interchangable with other pistons?
  75. Valves
  76. how does swapping engine works
  77. what size gsr bearings???
  78. B17 ?? hp
  79. Some one tell me if my compression test is good or bad?
  80. Oil pan doesn't clear my windage tray
  81. someone help 87 sedan B16 swap...
  82. type r cams
  83. PLEASE HELP: identify these aftermarket cams
  84. Manifold and TB to Choose ? GSR
  85. tdc
  86. h22 intake help
  87. Timing belt....Gates blue or OEM
  88. Piston-wall clearance v. Ring wear
  89. P72-00 in ls block with b16 head what comp ??
  90. Headers for a B18C5 motor...
  91. Good Machine Shop in Sacramento??
  92. All motor LS
  93. N/A b18c1
  94. which motor?
  95. P29 pistons suit my Civic? help please
  96. My gsr rebuild
  97. 2.2 k20
  98. reaming/honing bronze valve guides
  99. How can i tell what the injector is
  100. d16 to around 160 hp?
  101. Also how about Blox B Cams..
  102. Type R (ITBs)
  103. Help! z6 head on y7 block, engine dies when gas hard...
  104. Which ARP studs to use w/skunk2 mani/hondata gask.
  105. Help me calculate my compression.
  106. IMW Presents: Sleeved 95x84, 13:1 Build / Dyno Project
  107. cam!!!
  108. Question for all you 2.0L guys
  109. 82mm lsvtec, cam suggestion
  110. Rev racing valvetrain (my first build)
  111. 94 integra, ls b18, fresh rebuild, won't start
  112. adding 40 hp with boltons???
  113. White smoke WTF! Plz help.
  114. BC Stage 2 Cams??
  115. 94 swaped civic torque damper help asap
  116. Valve job needed? with new clyinder head?
  117. my g23 vtec build.
  118. Victor X Manifold for Daily
  119. Help with cam selection - 89x84.5 ~11.x:1 - Skunk2, RM, BC, Toda ?
  120. gsr + less then $1500 = 192whp/129tq
  121. need a copy of dc sport header receipt! PLEASE HELP!!
  122. What B series cams are these. SOme pics inside
  123. p73ao in a gsr
  124. B18C to B18C6 Block Differences?
  125. suggestions on new rings???
  126. Omni Power TB ???
  127. Time for another rebuild.. need some input on pisons..
  128. d16 help
  129. What all do I need to put in my ls vtec motor
  130. pistons
  131. ITR intake manifold
  132. Header Selection???
  133. Blox Valvesprings
  134. how many use stock cam gears?
  135. Building a B18c1 and wanna know what to expect....... pls help
  136. Piston rings?
  137. b16a2 head rebuilt safe rpm with duel valve springs
  138. Type R/B16 valves, Cotters, retainer?
  139. Power steering
  140. Poor Mans B stroker?
  141. your opinion..
  142. Too much cam???
  143. ATTN: Header Gurus, your assistance is needed :)
  144. h23 weight
  145. OBD2 to OBD1 conversion throwing code???
  146. civic type r pistons in gsr b16 head
  147. surging idle
  148. power steering
  149. type r or aebs intake manifold!!!need opinions
  150. Ecu help...
  151. Who makes the most effective CAI or SRI for a '00 Civic Si?
  152. Crower cam broke
  153. my motor in makin ticken noise?
  154. Can I use a USDM p72 with B18c
  155. MiniME - ticking time bomb? Or just ticks?
  156. k20 hatch u tube vid
  157. need help with my poor man type r build
  158. should i use torco sr-5 oil in my b16?
  159. how important is tuning.
  160. crome tuners in sacramento area, need a tune
  161. b16b ctr piston ?
  162. CTR pistons compression in B18c w/ pr3 head
  163. $300 budget. What to buy?
  164. DIY ITB's : Manifold Connection Questions
  165. my first n/a build. poor mans type r. help and advice needed
  166. sk2 pro2 and itr spec pistons
  167. buddy club spec 3 cams with stock b16 bottom need help.
  168. $1000 to spend
  169. Crower camshaft question?
  170. Need help... What model is this exhaust for?
  171. Jdm 4.785 Fd Problem?
  172. B18c bottom end build question
  173. 304 WHP H SERIES BUILD (dyno gragh inside)
  174. Whats the word on Bead Screws??
  175. Is this plausible?
  176. LS vtec mild all motor
  177. skunk2 pro 2 cams
  178. Need Help, B18C High-comp spark plug GAP
  179. npr pistons
  180. h23/vtec timing belt?
  181. high compression head gasket
  182. lsv or ls...
  183. Valves???
  184. lsvtec head gasket? what else works?
  185. bent valves?
  186. anyone have a experience with a cat 98 or 97mm crank
  187. JDM D15B Vtec vs D16Z6 camshafts
  188. Ti-retainers Vs. Stock Type-R
  189. gsr rebuild 220whp
  190. Time for my H23 VTEC Build DD
  191. fj distributors?
  192. Ls/Vtec Help!!! Please help me out
  193. Some troubles with SRP pistons
  194. LS VTEC Strange Sound - Video Inside
  195. my b20v is running without a map sensor i need help
  196. b16 head on GSR block
  197. Sparkplug/Head issue, need help ASAP!
  198. Skunk2 Pro2 I.D. marks
  199. KMS valvetrain
  200. ?'s on Building my Gsr.
  201. Can this head be saved?
  202. Car wont Start?
  203. Is this a ITR head?
  204. question about cam gear
  205. 190+ stock b18c5 ???
  206. weber carbs
  207. CTR pistons with stock GSR head
  208. 98 integra gsr dyno tune by Courtney Green
  209. Valvetrain - Skunk2? Crower? Fererra?
  210. What happened to Import Builders?
  211. obd2b to obd1 limp mode problems HELP please
  212. cylinder head "Core Shift" pics?
  213. poor mans type r build kicking my ass!!!
  214. fully build
  215. building the head.. skunk2?
  216. apexi ws vs itr oem muffler? dyno sheet inside
  217. b20 into integra ls
  218. Semi built poormans type r?
  219. Advancing intake cam?
  220. 92mm crank causing pressure plate to touch starting motor?
  221. Ycp civic type r b16b piston specs
  222. ARP main studs
  223. 200 + whp???
  224. N/A running meth? question
  225. Piston to head clearance
  226. Question about breaking in built motor on a stock ecu.
  227. j series?
  228. b18c-r built head....
  229. Installing valve springs, have a new idea to pressurize cylinder, good idea or not?
  230. B20 all motor tips and help please
  231. oil pressure problem
  232. What cams should used on b18c ?
  233. OEM b16 valves Rev limits
  234. What kind of oil should I use?
  235. Whats it cost to have short block assembled
  236. Fidanza 7.5lb flywheel? HELP!!!!
  237. What was the one thing that opened up pandoras box?
  238. vtec bearings vs non vtec
  239. rod ratio question.. 1.68??
  240. Wat all can i do to my b17 with 3,500
  241. turbo motor to NA + spray?
  242. has anyone used greddy cams?
  243. 4-1 or tri y header for b18c1
  244. B18b1 Build
  245. B20 all motor
  246. ctr pistons installed into ls compression ratio
  247. b18c1 blown up???
  248. What B Series 4-2-1 Header is this?
  249. b18c ITB's
  250. gsr internals in ls block???
