PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 [94] 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. tranny gurus, come here please!!
  2. bolt-on b16 dyno + track times in EJ1
  3. buddy club cams spec 3 to 6(for gsr owners)
  4. N/A Shops in Wisconsin & Minnesota?
  5. stock b20vtec or stock ls turbo?
  6. Just Curious: Possible Damage due to Lack of Oil Pressure
  7. ITBs on and running, few nick/nack questions
  8. start to build
  9. Difference between Cams?
  10. b20b or b18b
  11. Skunk 2 Stage 2 people, few quick questions...
  12. Basic B18c1 build
  13. JDM D15B with D16 internals
  14. ITR cams vs skunk2pro1's
  15. just finished my build/swap up, tell me what u think
  16. ctr pistons on eagle rods
  17. 12.6.1 CR question
  18. Opened and Ported Xcessive I/M For K series.
  19. who has knife edged/ lightend there crank?
  20. LSV/B18C?
  21. JDM ITR cat or Aftermarket High Flow cat????
  22. OBD2 manifold swap???
  23. B16a block/B18c (gsr) head
  24. P0505 CODE - IDLE CONTROL SYSTEM MALFUCTION
  25. Crower Stg. 2 cams on b16a
  26. Hyper 16 Valve / Jtech **Kyle Built GSR !!!**
  27. replacing valves on rebuilt head
  28. FLYWHEELS!!! need help
  29. Building a LSV with CTR pistons any Suggestions etc etc
  30. ARP head studs......? ASAP please...!
  31. power washing
  32. Project Cookie Cutter 1.8l
  33. Who actually has Knock issues with forged internals ?
  34. Basic Question on Octane
  35. price shopping for gsr head rebuild
  36. Tick Tick Tick......
  37. GSR build
  38. Clutch questions???
  39. skunk 2 pro 1+ on jdm ITR motor
  40. Cams Selection Help!!
  41. All Motor B18C Cutting Out/Breaking Up at 6K
  42. p73 pistons in b18a/b questions...skunk 2 pro 2's
  43. IACV Help!!
  44. Help with Injectors. What impedance?
  45. Are these real itr cams? Searched already.
  46. Low #'s after compression test
  47. What Head Stud Do You Use On a Poor Mans Type R?
  48. B20B With JDM ITR 98 Internals + JDM ITR 98 Head - Searched!!
  49. b16a nitrous question
  50. Anyonr Know....................
  51. Question about valvejob....
  52. Question about FPR's and Hondata
  53. Professional tune, Eratic Idle?
  54. good all motor setup for autox?
  55. help building all motor b18c-r
  56. Tuner help please
  57. K20 Long project up and running
  58. Thermal R&D exhaust!!??
  59. ITB's for my D-Series
  60. which pistons and rods for stock bore ls/vtec?
  61. engine builders
  62. b16 swap, no v tec.....help
  63. StreetImports JDM ITR 4-1 header?
  64. GSR vs. LS/Vtec
  65. B20B/Type R cylinder compression???
  66. Raise compression ratio on D16Z6
  67. Magnus Intake manifolds?
  68. 2 Questions
  69. Type R Piston Question??
  70. High RPM Vs. Low RPM
  71. ok.... can they chip out pr4-a01 ecu with a auto make it 5 speed?
  72. I HAVE 13 TO 1 COMPRETION WILL LIKE TO KNOW IF IT IS SAFE TO RUN NITROS
  73. who's running the skunk pro 3's
  74. Rocket L21 nonVTEC regrinds.
  75. All motor on a D15?
  76. Tech info - Offset boring? What is it? yay or nay.
  77. h22 in a eg
  78. vtec help
  79. building an NA b18a block with over 200,000km?good/bad idea?
  80. ARP Headstud problem!!
  81. new to honda-tech & building ls-vtec
  82. H22 and b series tranny combo
  83. which is the better clutch/flywheel setup?
  84. Weld Racing 15" Drag wheels
  85. drop in s2 stage 1s and go?
  86. Finally Camp1320.com Spec K24 h beam and I beam rods
  87. fuel injector max out? (fresh with efi calcs!)
  88. hp gains from i/h/e ?
  89. JG 301 cams for DOHC ZC... I need specs!!
  90. Suggested Plugs/Wires?
  91. i was bored so...
  92. I´m looking for an oil pump.
  93. WTB LSD for gsr tranny So Cal
  94. Who says you need a fancy header/IM to make power? 204whp h22.
  95. Help with ITB please
  96. Stock S2000 engine ?'s
  97. B20 is it B or Z?
  98. lean spot in a/f curve
  99. What else would help me out?
  100. F & K-series adjustable exhaust cam gear - what you didn't know & need to
  101. Skunk2 Stage 1 or Stage 2 QQ
  102. B series motor questions.
  103. has ne one heard of?????????
  104. Resonator ..do they reduce power ??
  105. What can it be?!?!?!?!
  106. k20 inside a dc2
  107. pr3 pistons vs. ctr pistons sugestions<<<
  108. TWM 52mm or 54mm for H25A
  109. ctr cams?
  110. Intake manifold for GSR
  111. suggestions for road race muffler
  112. OEM ITR flywheel or Exedy???
  113. question about timing
  114. ITR pistons in GSR block
  115. Question about a GSR stroker
  116. Team PhatBoyZ IN Minesota
  117. How to contact Randy Monroe...
  118. Good machine shops in miami fl...
  119. Questions for H22 Mahle Gold Series 11.5:1 Piston Owners
  120. Stage 1 cams vs. Stage 2 cams
  121. B18c1 to a 2.0L
  122. GSR Revving question
  123. built h22 head or built h22 head w/turbo?
  124. Buddy Club Stage 4 cams?
  125. k20a2 power potential?
  126. KMS Supertech Valve Seals
  127. B16a2 BUILD UP NEED INSITE
  128. all motor build smoking!!
  129. motor help!!!!
  130. gsr build with stock injectors
  131. motor won't start???
  132. compression
  133. ls/vtec problems
  134. what's a good header that will clear A/C condensor???
  135. ebay 4-1 or edlebrock 4-1 proflo on LS
  136. ls/vtec bottom end build
  137. Engine Rebuild & Upgrade!
  138. *** B20 Setups
  139. best setup for all mota CRX!
  140. what to use for tuning? In VA.
  141. ls and b16 numbers and info
  142. All Motor LS ring gap help
  143. B20/type R setup????
  144. Throttle Body/Intake Manifold Modification H22
  145. b18b ls compression , port polish head
  146. JDM B18C in EG swap not starting
  147. What's the best lsvtec setup(reliabilty and performance)
  148. B20Z BUILD JUST NEED INSIGHT
  149. ITBs for the street?
  150. built poor mans type r
  151. i wan't to make a HEADER for my setup NEED SOME help!!!!!
  152. check engine light coming on, need help
  153. Is it safe?
  154. question about installing pistons
  155. ****************METHONAL ON A ALL MOTOR SETUP****************
  156. Done more mods to the motor but lower trapspeed?
  157. Correct shim size for H22 LMA in B series engine???
  158. ITR header, is it equal length?
  159. My 1.8 Build-up (56k beware)
  160. b17 question
  161. switch from ls/v to h22??
  162. Lost to a bolt on h22 prelude. need some help.
  163. Skunk2 vs. Blox LS Intake manifold
  164. Opinions on what cams to go with
  165. timing belt
  166. All Motor.....?
  167. Red on the engine code?
  168. question about fuel pressure
  169. individual throttle bodies...??
  170. Alaniz head porting, can anyone vouch for him lately??
  171. a b16a w. std. ctr pistons/ ign. timing question....
  172. H22A: Is it worth it?
  173. hondata ?
  174. Ls-vtec dyno chart,(street car im bored! )
  175. oil temp- what do you guys normally run at??
  176. BC IV VTEC Change Over
  177. ek9 VS ek
  178. Amazing customer service from skunk2!!
  179. just got an 07 civic si 4 door, what next???
  180. New All Motor Build Head Gasket Problems??
  181. neecd a solid answer on pcv/ catch can
  182. quick question!!!!!!!!!
  183. CTR crank pulley on LS/VTEC?
  184. B18A Compression Numbers...
  185. BLACK SMOKE(I KNOW ITS RUNNING RICH)
  186. 98 civic ex... what motor shiould i drop into it????
  187. What do you guys think of this header...is it a piece?
  188. TIme for a new clutch
  189. exhaust piping
  190. SMSP header on 92 integra b18a?
  191. oil lines???
  192. BDL fuel rail question
  193. M2 Race cnc head porting for H22 Anyone tried them??
  194. f22 rods
  195. WHAT TO DO WITH THIS D16Y5 in my jdm inspired ek :( hx
  196. HELP!!!!!
  197. NSX Injectors
  198. Just got some M22x's
  199. Wrist Pins question/problem?????
  200. Wiseco B18C1 piston in B18C5...
  201. thinking about buying this rmf header, it is an rmf header right
  202. poormans r need to kno
  203. help me wit my build b18c1
  204. vtec problems
  205. SMSP header installed.. dyno graph will be posted tom when I can get a hold of a scanner
  206. Anyone Playing with a Dual Cam ZC???
  207. knocking sound... need some help
  208. srt-4 exhaust side before and aftre pics
  209. 99 Civic EX Engine
  210. throttlebody taper...
  211. Vtec Smell
  212. QUICK LS BLOCK QUESTION HELP!!!!!!!!!!!!!!!!!!!!!!!!!
  213. need ls vtec info
  214. Edelbrock 65 mm TB vs Skunk2 68mm TB?
  215. Best Header For Under $700au
  216. what to do next??
  217. What exhaust do you recommend?
  218. help finding part
  219. 13:1 compression?
  220. HELP:B20 Install
  221. Ring gap for 89mm built h23vtec
  222. honda tuning build...
  223. Jerry Built vs. Prostreetimports.com
  224. which cams
  225. Starting my build this weekend, advice???
  226. gsr head on crv
  227. all motor H22 good build ?
  228. what should i do
  229. d16y8?
  230. Okay to run with low compression on 1 cylinder??
  231. crank work
  232. stock pistons on eagle rods?
  233. problem ls/vtec
  234. Edelbrock Header
  235. Can anyone tell me what these cams are??
  236. GSR rods vs. B16 rods?
  237. need opinion on build
  238. arp head studs.. washers ???
  239. I need your inputs on crank pulleys?
  240. Compression check shows 210 across the board. Is my motor healthy?
  241. BDL Throttle Body Getting Stuck
  242. Removing girdle
  243. Dyno: Skunk2 Pro3 vs Pro2 vs BC5
  244. AN-R compact, street vs merge ?
  245. need help with my setup
  246. Sk8er5150's Vouch Thread
  247. gsr crank in a b16
  248. Is my head still good?
  249. Best Throttle Body?
  250. H22a N/A options....?
