- Megaphone Style exit for race header What is this ideal for?
- vtec or non vtec?
- H-beam rods & bearings???
- ** B16a2 Dyno **
- Headwork......need some input
- blox2Spec b's or rocketM22's
- buddy club spec.III vs sk2 stage1's with some nitrous
- Will these parts work together. Checking compatibility
- RC injectors. Normal to tick like mad?
- probleme running high compression D16Y8 with Crower stage 3
- buddy club spec 3+, where in stock?
- cam questions
- Oil pressure/levels
- When an LSvtec goes boom........???
- Non noob having trouble with cam gear install
- overbore tb on k20a
- does rocket motorsports have a website (searched)
- P73 ecu for LSVTEC break-in
- 2.2L LS/VTEC or H22?
- Cams installed, now at Idle...
- Where To Send My Rods For Servicing?
- Stock oem valve..?
- High compression
- Cam Q.
- advice H22
- itb's or manifold tb setup?
- diff types of cams
- cams for my itr engine?
- hondata s200 4 wire lead question
- vtec problem
- hows my build sound?
- ITB's in VA? emessions?
- 8 or 12lb flywheel?
- Picking the right cams ( h22)
- Spoon Engine Swaps
- Question on headgaskets and claying
- Chip to ITB
- Another video of my ITR
- Getting the most out of a b16a?
- new to H-T and had a ?
- skunk 2 stage 3 too aggressive?????
- what do you use as a sealer on oil pump
- what injectors for mild ls vtec build
- need help
- Looking for good machine shop in the Bay Area
- DIY ITB's: Golden Eagle Vacuum Manifold too big/small?
- 00 ITR cams in a jdm B16A, what ECU program to run??? throttle body tapering???
- need uberdata tuner in SC
- Attn all ITBs owners, what kind of header are you using?
- portflow Ti retainers - unusual chipping on TOP edges of them? :o
- PLEASE HELP!!! Car is making Strange noise...
- ST Corsa Cam Gear questions...
- B16a chamber volume after opening up to 85mm?
- 2.0L GSR
- REQ:Differences between AN-R headers?!?!!?
- Crankshaft balancing: Benson's
- The limits of 91 octane?
- Number of Teeth...
- bearings which to use (acl)?
- 00 spec B18C jdm swap...is the ecu compatible with 00si?
- finally got the b20/vtec tuned; dyno graph inside:
- sudden power loss
- H22 all motor
- How much did your honeing, port and polish and mill cost?
- all motor stuff for sale
- b18c1 - help me pick plz
- Doing block
- LS VTEC Bottom End Build
- b18c1 power help
- QUICK need help ?????????
- Resonator placement, for the deepest sound?
- ** cams upgrade, opinions / suggestions needed!! **
- Spoon Transmissions
- 205 k on d16z
- 12 sec. daily driven integra possibilites...
- 11.5:1 compression 2.0ltr 267hp from dfe engineering.
- ebay headers
- STR, AEM, Hayame, Golden Eagle all have different center bore size fuel rail...
- Elevation and ALL MOTOR
- Think I may have a little rod knock...what to do??
- B20b thrust washers
- Highest Compression w/ 100oct
- Another Poor mans type R ???
- help!exhuast diameter
- Built GSR vs. b16a crx with itr cams any predictions?
- D16Y8 hp increases
- s2s2 cams alright with itr valvetrain?
- price on claying a motor?
- Lound Ticking AFTER oil change!>? help me out u guru's
- Anyone work at Mahdavi Motorsports?
- need some help with project that is done! b16 with ctr
- b18c1 11.5-1 compression to 11.9-1 compression
- Where to purchase jdm oem pistons?
- Ignitor Problem?
- Car throwing code 17, what do i do? need help fast
- I want to heard from my all motor peeps,, how does it feel when we spank, turbo cars.
- BIlly from Import Autoworks?
- ls trans making roaring sound?
- b16 trouble..help meeeee
- Is this going to be an okay set up?
- Anyone have timeslips for eg's with jdm b18c
- Best Header for LSVTEC setup?
- Accel 300+ ignition wiring problems
- Aem Ems basic tune guide ?
- OEM or Forged pistons?
- Rocket Motorsports CNC prog....
- what do i look for
- Skunk2 Pro-Series Intake Manifold???
- Setups under 4g's
- B16A (SIR-2) CR w/ Omni Valves & OEM 1 Layer HG
- valvetrain suggestion
- What do u think i will put down?
- f20b+itbs is runnign
- gsr build
- how to tell the difference in b series cranks?
- Does anyone know a site or have a list of Engines
- sugnificants of using itb's
- learn: MSD
- H22 Compression Question?
- b16 trouble...cel 14
- OBD1 Motor In A OBD2 based Civic. -extra wires-
- Best Cams for stock JDM GSR
- H22 or B16B?
- B18B all motor header question
- skunk 2 stage II stock jdm gsr bottom
- Much needed install instructions for Golden Eagle VTEC Conversion System!!!!
- Please help...need valve train advise
- Stroker kit
- pro topline heads? ever heard of them?
- stock gsr c/r cams
- skunk2 stage 2 camshafts - dislike them?
- Manley internals...please help, need immediate assistance!!!
- Calculating static compression ratio
- BC3+ forced in....
- will 4 barrel weber beat ITR intake + Throttle Body.. ?????
- ALL MOTOR DRAG CAR FS
- 210 WHP 1.8-Lots of graphs inside (I feel like Tbone)
- LSVTEC dyno at LDL , blox B's vs. ITR intake cam
- HP estimates?
- what to do next? p&p head or b20vtec
- wicked stage 2 cams
- New exhaust question
- Help me decide whats next for my all motor b18c1..........?
- ls/vtec trouble
- cold intake vs. short ram
- running wierd after track day...
- HONDATA INTAKE GASKET QUESTION??
- Where can Lightweight valves?
- AN-R header?
- CNC Block Sleeving: Benson's
- which cam should I go with buddy club spec IV or buddyclub specV ?
- Vtec ECU, now Ls/Vtec is running rough!
- Anyone have to degree their motor just for stage 2 skunk 2 cams??
- stock ls/gsr head
- oxygen sensor on ef
- what cams to use for 200whp 81.5mm bore jdm itr
- RLZ ALLMOTOR garage sale .. 300 whp parts inside....
- 2.5 collector too much for b16a?
- WTK: What are my expected gains? i know i know
- Need Help with a 98 h22 swapp into my 99 civic coupe
- Budget Building an ls/vtec with p30 pistons... weak points of the bottom end????
- Cheap High Comp Piston for B20
- Went to the track. Now what?
- Spoon Ignition Wires Misfiring Intermittently???
- skunk2 intake manifold or the new bbk manifold
- almost/soon 14second LS integra, no cams *timeslip inside*
- First LS VTEC STORY by Steve Aka Omniman
- Motor Clay Specs Archive Thread
- Most power out of 1.8
- add vtech solenoid to get vtech?
- ls crx 1?4 mile times
- ITB Questions.
- Terrible pictures because I suck, but my d16y8 head I just got back from Portflow.
- underground racing cams? products?
- Low 13's to High 12's on a H22!
- Critique this set up.......
- what else can i do for my horsepower
- wicked stage 2 cams and rm valvetrain ?'s
- PLZ help me decide on a all motor set up
- 1st gen CRX head...ok to mill .020?
- Hondata Log - Knock Sensor
- crome pro users come here..
- cam plate holder HELP
- 13:1 on Stock B20 Cylinder Walls
- any h series compression calculators out there ?
- 98+ gsr & ls dizzy differences
- dohc zc internals
- **Deos this sound right? Machining**
- Car Chemistry Collector Insert Quiet Exhaust Quiter Muffler
- H22 HELP
- Is the f22b water pump same as h22a?
- 200whp achievable? 81.25mm b18c1 build finished this weekend
- 3 angle valve job?
- d-series header...???
- hondata or vafc
- gsr IM > b20 IM?
- what rods need to be shaved for use with CTR pistons?
- Calling All JDM H22a Experts!! Opinions
- what needed to break 190whp
- b16 ef hatch trouble..please help
- b16 head upgrades question???
- Complete Engine Gasket Kit....
- HELP!! WHICH SPRING IS INTAKE??!!?!
- b20 or gsr
- to much compression???
- Mild N/A Build
- LMA and high lift cams
- Ls crank and rods with pct in gsr????
- M24x's and your set up????
- need to know how to degree motor for skunk 2 specs!!!
- Race Fuel Octane Suggestions??
- fully built b16 vs. k20a2
- 0w30 Castrol Syntec okay for dyno day?
- ANYONE HAD PROBLEMS WITH SKUNK STAGE 2 CAMS??
- AEBS Intake Manifold? real?
- head studs stripping out of the block
- B20/vtec ALL MOTOR Hp & Tq questions.
- B20z swap actin up
- Blox manifold vs AEBS vs Skunk pro
- Best cams for stock JDM Hype-R Motor
- toda a cams for spoon cams?
- help me decide...stay N/A or boost.... options...
- F23A engine
- Any good tuners in the St Louis MO area
- Intake ports. polish/no polish ??? tech info please
- good sohc v cam
- Q's on stock B16B motor.
- Engine Info help
- F20b CAMS
- BC4's clear CTR pistons?
- debating ls/vtec
- Dizzy question along with some others
- b18c1 built shortblock
- all motor h23 or boosted h23
- Anything else I'm leaving out?
- spoon head gasket one gsr
- ctr cams or s2s2
- del sol b16
- B16b at high altitude
- Would like feedback on All Motor Honda Dyno Day in June (Tristate)
- Copper Head Gasket
- Old School 85 CRX
- NE tuning best places to tune all motor//.
- Head rebuild question
- what is the difference between these 2 motors
- All Motor HELP!!
- Is this setup safe for a driver?
- First 2 gauges you would get
- Problem: VTEC makes hissing/grinding sound at 3500 rpm
- Questions on f23: VTEC, VAFC, Tuning
