- RS-R ex mag fitment on a 99-00 civic
- B16A2 with ERL's Superdeck II pictures
- vafc question??
- Stumbling b16 swap
- most whp on CTR / ITR cams ?
- Hondata S200 Tuning
- AEBS Manifold INstall
- Aeromotive adjustable FPR question...
- i need help on identifying the colors on the bearings b18c1
- 1999 Civic Si Fault Light Location
- Rpm with GSR springs and certain death??? Read.
- Did b18c header will clear B20 block? Fit under the b20 oil pan?
- Really Slow b20vtec... searched.. need some advice...
- Anyone Interested in buyign my all motor block????? Look it's worth it.
- New Clutch Recommendations
- what do you think?
- Buddy club spec 3 on stock valvetrain?
- FS: 203 wheel HP CR-V-TEC 92' VX
- quick answer on oil pan
- B20 Vtec questions. swap options.
- Ditching ZC for B16
- my gsr compression bad?
- question, milled head w/lsvtec
- Nonexistent F22Z1 specs?
- weird stuff... please look!!!
- Ditched SOHC for B-series
- DYNO ITR RESULTS HELP BC3+ SPARKS HEADER
- Mechanical Oil temp gauge in oil pan? Anyone done this?
- Andy Knight from Knight Engineering/Iceman Motorsports
- VAFC2.....honest opinions. Please back up your statements.
- all motor sohc
- valve adjustment problem?
- B18B Rev Limit
- RPM Drops
- valves ajustments RM m22 in b18cR
- OBD2 oil pump and OBD1 Timing cover?
- new lisence plate OHMY12S I call it in indiana
- Headertech any good?
- thinking of ditching my 275hp setup for a turbo
- h22a4 rods.
- 97 Civic dx. changing fuel curve
- more mph help
- DC 4-2-1 2Piece Header Weight?
- is it worth to spend money on ITR trans for a GSR?
- tranny reassembly issues
- what are the best kind of main/rod bearings to buy that are reliable?
- What size collector with 2.36 exhaust, should i go big or small.
- need tork specs
- Aem gsr alternator pulley on Itr?
- chipped ecu
- Header Comparison Spoon vs Airmass vs Megan vs Stock 4-2-1
- SImple question.......
- s2s3 too much with no headwork?
- toda itb's - idle
- Love Fab Header
- Spoon 70mm throttle body, anyone?
- gsr oem lsd??
- b16 block bored and honed
- 1.6 VTI upgrade
- b16 build
- ls vtec
- ctr pistons on scat rods?
- block weight
- lost motion assemblies
- ITR Pistons in a LS..
- Sluggish B16 Del Sol ??
- Any tips to cooldown after run
- High Compression And Stock Starter?
- A little video of the build-up of my Mazda 3 all-motor drag car!
- 2003 Civic SI EP3.....N/A or FI??
- toda a's in b16
- Dynoed my Car a few weeks ago! LS/VTEC Tony1 Tuned!
- Which injectors?
- Help with b16a2 short blok build up!
- High compression LS motor.......how high can you go????
- church's dyno pac vs dyno jet MY DYNO AND TRACk TIMES
- how much $ for a b20vtec?
- VTEC oil pressure drop?
- Loose timing belt
- Which size CAT to go with my setup??
- Crower billet steel LS rods on pr3/p30 pistons???? What has to be done????
- sk2 gears on toda cams
- Do i have ITR or B16 cams???
- 12.2.1 compresion
- How to pull a 1990 Accord engine
- plugs
- How do I remove B-series VTEC rocker arm rod?
- DYNO DAY IN NY!!!!!!!
- Toda ITB users what throttle cable for ef?
- approx horspower for a stock b16/b20 crvtec ? im thinking just under 200 hp with 140tq
- K20 or K24
- head swap
- Help identify these B series cams
- buddy club iv cams??
- What colour honda bearins for me???
- RLZ built 92x86.5...more to come
- What would you do????
- Break In for B20Vtec
- MY ALL MOTOR SET UP!!!!!
- ctr pistons, obd2?
- ecu honda
- Should I keep the P8R????
- B18B LS/VTEC with ITR crank?
- Can an all motor type r engine make 400hp
- PR3 or P30 pistons, on Crower LS rods??????? what has to be done? please help
- besides hondata!! what else?
- Do-It-Dyno does it RIGHT! (Dyno results inside)
- Jun type 3 cams
- Cams - Buddy Club Spec 3+ or Spec IV
- s80 tranny problems....
- Quick b16a motor question.......
- how to assemble a b series
- 184whp track times
- B18a crank possibility?
- header wrap???
- Need opinions on ITB setup.
- King All Motor, All OEM B16
- JUN type-2R + other parts total price
- buddy club 4 cams
- JUN 4 cam specs
- car shuts off after after stage
- ctr cam???
- Safest GSR Redline point
- Anyone built or building an all-motor B18A/B...
- Congrats to Loi - "the tea father" on getting into honda tuning mag for july '05 issue...
- WTB: ITB's for a ITR DC2 Now!. Ready to purchase. High quality DIY's or TWM's and JDM ITB's
- HELP lower manifold pressure during vtec bc3+
- all motor or turbo??
- 92x86mm Freshened and back on the rollers.
- Help with diganosis of problem, think is its a bad head gasket but i don't know.
- just in
- What do you consider stock? And what do you consider built?
- b16 build up
- Spark problem for gsr hatch
- Missfire CEL code 73 and 74. how to fix!!!!!!!!!!
- IPS K2 Dynojet Results: 234whp & 161ft/lbs
- P8R B20Z got tuned today, not all that impressed
- Help on Clutch for All motor car.
- how to determine if internals are stock or not?
- Best setup
- need help ?
- b16 unsteady idle
- arp headstuds
- Where to buy: STR TB Gasket
- Comtech Icebox I;m not so satisfied with it
- GSRLS-Vtec Build
- ***WHAT IS A TYPICAL 1/4 MILE TIME***
- planning b16 build
- burn clutch???
- Stolen Parts...longshot but any help is appreciated!!!
- ls vtec with a pr4 ecu with a msd rpm activated switch for vtec
- LS tranny with LSD or B16 Tranny help?
- Should i go from Crower 401's to 402's
- m22 LSA and lift @TDC
- Need good link for ls/vtec build
- equal length headers
- b20 13 sec flat?
- rev 9k??
- b20... camshaft?? *need help*
- general mother specs
- LSVTEC Toda Header CTR cams DYNO dynojet vs.dynapack **update!!**
- B.O.T.I. Fontana V2 MOTORSPORTS takes 1st. INTEGRA ALL MOTOR 12 sec. S/S class
- anyone had/ having problems with their itb's clearing the brake master cylinder or hard lines?
- B17A1 head on B18C1 block. Pros and cons?
- *BAY AREA* DNR HEADWORK
- Springs and Retainer? Omnipower, RM, SKUNK2, CROWER??
- headwork on k20a2 (need help!!!))))
- ITB???
- Help me choose a header for LS build
- Need help!! Pistons & rings
- question about vac and itb
- Oil pan gasket stuck to oil pan.. HELP!
- Can't find the right exhaust! Help!
- CTR head on B20 block, CR?
- What dizzy for obd-1 ls/vtec
- new SERDI machine added
- hmotors shipping
- cylinder block sensor checklist
- JUN III owners, valve lash ??
- maximizing power from stock engine
- LS/V-tech , NEED HELP
- San Jose Grand Prix..
- noob itb/ direct port ?
- Dc2 Exhaust Help Please. ASAP
- From Ek To dc2 exhaust help
- Engine Weight
- LS/VTEC noob questions
- question
- Laminar/Raceheads all motor CRX 12.15@116 mph
- B16B Build option/questions
- nitous wit my setup y/n
- oem all motor b16
- spark plugs
- RMF Narrow VS Comptech 4-2-1
- after valve adjustment
- Flat faced valves.
- LS/VTEC running super lean at idle
- ep3 head change
- Lsvtec picking my cam
- Integra Type-R Cylinder Head Casting Numbers I NEED HELP
- *another Block Guard question?*
- How to tell if you have a blown Headgasket or cracked Cylinder head?
- good macine shops in dfw? need block bored/honed
- How to set up ignition&fuel for D16Z2('91 SOHC non-vtec) racing engine?
- rebuilding b18c1, need piston recomendation
- oil cooler on a stock JDM type R motor..
- Anyone in NY/NJ running hondata please help
- Dyno: SMSP vs Mugen
- motor at TDC, how to install distributor
- VAFC fuel settings for fuel right before VTEC engages.
- Official rods, pistons and cranks...
- ls/vtec w/ a type r
- H22 intake manifold....whats good...
- DC 4-1 2.5" collector OR Comptech 4-2-1?
- Intake opinion
- Dyno'd my fully build SOHC and.....
- what type vtec is in a prelude? LS?
- is JG manifold overkill for my setup?
- LS Vtec vs Type R
- need advices about where to buy parts for engine rebuild, B16A2. and a q.
- PCV and LS/VTEC OBDII?
- Catalytic Converter Testing - Round 2
- What valvetrain would be recommended?
- New Setup: All Motor - 97 Civic - G23 VTEC
- First steps
- JDM EG9 B16a Dyno Chart - Opinions
- 2.5 inch exhaust
- car wont start.searched and no help...HELP!!!!!!!!!!!!
- Which motor would be better??
- Is a block swap worth it? want more power
- Stupid ass shop???
- how much was the labor to have your motor built?
- **SOCAL** Need Simple Info Help on ITB setup on a B18c5 DC2 for a Noob that Searched
- 9 second CRX???
- What happens to the pistons after they have hit the valves?
- stroker kit for d16z6
- cam suggestion for all motor gsr
- LS/Vtec or GSR in a DA?
- does the header really matter that much?
- Cam Specs.......
- RLZ and Wiseco Develop the Perfect Piston
- XTD flywheels, has anyone used one?
- ls vtec vs. gsr
- d15b power
- Ls/Vtec......92 GSR cams or 94 B16 cams? Specs?
- my new setup LS/VTEC
- B16 CRX dyno Part2 (prev. made 114whp :( +GSR cams
- RMF vs ANR vs Rage B-series
